[General] Test C_THR92_2505 Pdf & C_THR92_2505 Valid Test Forum
87
【General】 Test C_THR92_2505 Pdf & C_THR92_2505 Valid Test Forum
Posted at 1/22/2026 22:04:22      View:102 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New C_THR92_2505 dumps are available on Google Drive shared by VCEDumps: https://drive.google.com/open?id=1YjnHbCLbHTYq8MI9cCEgW3xm-fFQAz6m
So many candidates have encountered difficulties in preparing to pass the C_THR92_2505 exam. But our study materials will help candidates to pass the exam easily. Our C_THR92_2505 guide questions can provide statistics report function to help the learners to find weak links and deal with them. The C_THR92_2505 Test Torrent boost the function of timing and simulating the exam. They set the timer to simulate the exam and help the learners adjust the speed and keep alert. So the C_THR92_2505 guide questions are very convenient for the learners to master and pass the exam.
SAP C_THR92_2505 Exam Syllabus Topics:
  • Advanced Reporting Tool with Replicated Data: This section targets a Reporting Specialist and covers leveraging advanced reporting tools that operate on replicated data. It includes knowledge of data replication concepts and using these tools to perform comprehensive reporting that supports detailed analysis.
  • Story Reports: This section of the exam measures skills of a Report Creator and covers the creation and management of Story Reports within SAP SuccessFactors. It emphasizes designing queries, configuring pages with widgets, and managing report permissions to generate insightful visualizations.
  • Tile-Based Dashboard Framework: This domain targets a Dashboard Designer and covers building and managing tile-based dashboards. It encompasses creating tiles, assigning access, applying filters on dashboard data, and sharing dashboards to provide users with interactive and visually engaging insights.
  • Table Reports: This part measures the skills of a Data Analyst and involves creating, managing, and running Table Reports. It focuses on designing tabular data presentations that facilitate straightforward access to detailed workforce analytics information.
Topic 5
  • Report Consumers: This domain evaluates the understanding of a Business User and focuses on how report consumers interact with and utilize generated reports. It highlights user roles, permissions, and effective report sharing practices to ensure reports serve decision-making needs.
Trustable C_THR92_2505 – 100% Free Test Pdf | C_THR92_2505 Valid Test ForumTime and tides wait for no man. Take away your satisfied C_THR92_2505 preparation quiz and begin your new learning journey. You will benefit a lot after you finish learning our C_THR92_2505 study materials just as our other loyal customers. Live in the moment and bravely attempt to totally new things. You will harvest meaningful knowledge as well as the shining C_THR92_2505 Certification that so many candidates are dreaming to get.
SAP Certified Associate - SAP SuccessFactors People Analytics: Reporting Sample Questions (Q66-Q71):NEW QUESTION # 66
You have a field in Job Information that stores the assignment of an employee to a Generic Object record for a Company Car Company Car records include an Assignment Date of the Car. You want to create a query that includes the Employee Information, and also include the Assignment Date of the Car. You add the Job Information Table to Query Designer. What steps do you take to accomplish the query? Note; There are 2 correct answers to this question.
  • A. In the Company Car table, select the Assignment Date Field.
  • B. In Job information table, select the Assignment Date field.
  • C. In Job Information table, expand the Company Car Field.
  • D. In Related tables, add the Company Car table to the Query.
To include the Assignment Date of a Company Car in your query:
* In Job Information Table, Expand the Company Car Field (A):
* Open the Job Information table in Query Designer.
* Locate the Company Car field and expand it to access related fields and data.
* In the Company Car Table, Select the Assignment Date Field (D):
* Add the Company Car table from the related tables section to the query.
* Select the Assignment Date field from the Company Car table to include it in the query output.
NEW QUESTION # 67
You are constructing a Story. You want to return the quarter to date event records to count terminations.
Which options would you set in the time filter? Note: There are 3 correct answers to this question.
  • A. Range Type: fixed
  • B. Records Returned: Include only records that begin in your defined date range
  • C. Range Parameters: Period to Date
  • D. Range period: Actual start/end date of the current quarter
  • E. Range Type: dynamic
Answer: B,C,E
* Setting Time Filters for Quarter-to-Date Data
* To return records within a quarter-to-date timeframe, the filters must be configured dynamically to adapt to the current period.
* Explanation of Correct Answers
* A (Period to Date): Ensures the filter dynamically calculates dates for the current quarter.
* C (Dynamic Range Type): Dynamically adjusts the date range based on the current period.
* E (Records Returned): Ensures only records within the defined range are included.
* Why Other Options are Incorrect
* B (Fixed Start/End Dates): Fixed dates do not accommodate dynamic quarter-to-date filtering.
* D (Fixed Range Type): Fixed ranges do not adapt to the current quarter.
References
* SAP SuccessFactors Story Reporting Guide
NEW QUESTION # 68
In a Story, which of the following would make it possible for a filter to update multiple charts using linked analysis? Note: There are 2 correct answers to this question.
  • A. The chart should use the same aggregation.
  • B. The charts should have the same data source.
  • C. The charts should use the same measures.
  • D. The data sources for the charts should contain linked dimensions.
To enable a filter to update multiple charts using linked analysis in a Story report:
* Same Data Source (C):
* All the charts must share the same data source to allow consistent filtering and updates across the visuals.
* Linked Dimensions in Data Sources (D):
* If the charts use different data sources, those sources must contain linked dimensions to allow the filter to propagate changes.
NEW QUESTION # 69
User A schedules a report in Report Center Scheduler What can user A achieve by enabling the Job Completion notification option for a scheduled job in the Report Center Scheduler?
  • A. An e-mail is sent to the recipient of the report that the report distribution process is complete.
  • B. An e-mail is sent to user A after the report distribution process is complete.
  • C. A notification appears for the recipient of the report on the home page after the report distribution process is complete.
  • D. A notification appears for user A on the home page after the report distribution process is complete.
* Job Completion Notification:
* When the Job Completion Notification is enabled for a scheduled job, the scheduling user (User A) receives an email notification once the report distribution process is complete.
NEW QUESTION # 70
When you share a tile, how can the user view that tile? Note: There are 3 correct answers to this question.
  • A. Canvas Report
  • B. Homepage
  • C. Dashboard
  • D. Custom table report
  • E. iOS SF app
Answer: B,C,E
When you share a tile in SAP SuccessFactors, the recipient can view the tile in the following ways:
* Homepage (C):
* Shared tiles can appear on the recipient's homepage if configured appropriately.
* iOS SF App (D):
* Tiles are accessible through the SAP SuccessFactors mobile application, enabling on-the-go access to reports and visualizations.
* Dashboard (E):
* Tiles can be added to dashboards, where users can view multiple tiles and reports in one interface.
NEW QUESTION # 71
The SAP - SAP Certified Associate - SAP SuccessFactors People Analytics: Reporting C_THR92_2505 PDF file we have introduced is ideal for quick exam preparation. If you are working in a company, studying, or busy with your daily activities, our SAP C_THR92_2505 dumps PDF format is the best option for you. Since this format works on laptops, tablets, and smartphones, you can open it and read SAP C_THR92_2505 Questions without place and time restrictions.
C_THR92_2505 Valid Test Forum: https://www.vcedumps.com/C_THR92_2505-examcollection.html
