[General] Reliable 156-836 Exam Cram Review & Pass-Sure 156-836 Official Practice Test
90
【General】 Reliable 156-836 Exam Cram Review & Pass-Sure 156-836 Official Practice Test
Posted at 1/23/2026 01:06:40      View:130 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsKing 156-836 PDF Dumps and 156-836 Exam Engine Free Share: https://drive.google.com/open?id=1V8Qx3DkhoLp6Y12rO3XNgZLouExZXJgX
DumpsKing is a website to meet the needs of many customers. Some people who used our simulation test software to pass the IT certification exam to become a DumpsKing repeat customers. DumpsKing can provide the leading CheckPoint training techniques to help you pass CheckPoint Certification 156-836 Exam.
The Check Point Maestro platform is a network security solution that provides organizations with the ability to manage large-scale security infrastructures. It allows organizations to scale their security infrastructures as their needs grow, without having to add additional hardware or software. The platform provides centralized management, seamless deployment, and granular control over security policies, making it an ideal solution for large enterprises and service providers.
156-836 Exam Cram Review | High-quality Check Point Certified Maestro Expert - R81 (CCME) 100% Free Official Practice TestAre you still worried about the exam? Don’t worry! Our 156-836 exam torrent can help you overcome this stumbling block during your working or learning process. Under the instruction of our 156-836 test prep, you are able to finish your task in a very short time and pass the exam without mistakes to obtain the CheckPoint certificate. We will tailor services to different individuals and help them take part in their aimed exams after only 20-30 hours practice and training. Moreover for all your personal information, we will offer protection acts to avoid leakage and virus intrusion so as to guarantee the security of your privacy. What is most important is that when you make a payment for our 156-836 Quiz torrent, you will possess this product in 5-10 minutes and enjoy the pleasure and satisfaction of your study time.
CheckPoint Check Point Certified Maestro Expert - R81 (CCME) Sample Questions (Q29-Q34):NEW QUESTION # 29
What cannot be learned from the output of asg monitor command?
  • A. Security Policy status
  • B. Port status
  • C. Appliances cluster status
  • D. Uptime
NEW QUESTION # 30
What is one benefit of a Dual MHO environment?
  • A. Dual MHOs can be used to achieve increased scalability and redundancy.
  • B. Dual MHOs allow additional SGMs to be added to the SG.
  • C. Dual MHOs provide redundancy to the Maestro environment by increasing throughput by at least 50 percent.
  • D. Dual MHOs allow better synchronization to occur between SGMs.
One of the benefits of a Dual MHO environment is that it can provide both scalability and redundancy to the Maestro system. Scalability means that the system can handle more traffic and SGMs as the demand grows, and redundancy means that the system can survive the failure of one or more components without losing functionality or performance. Dual MHOs can achieve these benefits by distributing the load and the management tasks among two orchestrators, and by providing backup and failover mechanisms for each other.
References
*Maestro Expert (CCME) Course - Check Point Software, page 251
*CheckPoint Certified Maestro Expert (CCME) - Skillzcafe, page 22
*Check Point Certified Maestro Expert (CCME) R81.X, page 23
NEW QUESTION # 31
What is the command 'asg diag' used for?
  • A. Asg diag is used for system diagnostics
  • B. Asg diag is used for system backup
  • C. Asg diag used for system diagnostics on Chassis only. It does not exist on Maestro
  • D. Asg diag is used for creating traffic flow diagrams
The asg diag command is used for system diagnostics on both Maestro and Chassis systems. The asg diag command can perform various tests and checks on the system components, such as hardware, software, network, clock, ARP, and more. The asg diag command can help identify and troubleshoot any issues or errors that may affect the system functionality or performance.
References =
*Check Point Maestro R81.X Administration Guide, page 66, section "asg diag" 1
*Check Point Maestro R81.X Getting Started Guide, page 28, section "asg diag" 2
*Check Point Maestro Under the Hood presentation by Lari Luoma, slide 25
1: https://www.manualslib.com/manua ... estro-R80-20sp.html 2: https://sc1.
checkpoint.com/documents/R81/WebAdminGuides/EN/CP_R81_Maestro_GettingStarted/html_frameset.htm
2: https://community.checkpoint.com ... 91/1/Check%20Mates%
20Maestro%20under%20the%20hood%202022.pptx
NEW QUESTION # 32
In what mode do MHOs process traffic?
  • A. MHOs process traffic in Active-Active mode
  • B. MHOs process traffic in Active-Standby mode
  • C. MHOs process traffic in VSLS mode
  • D. MHOs process traffic in load sharing mode
MHOs process traffic in Active-Active mode, which means that both MHOs are active and share theload of the traffic that is sent to and from the SGMs. Active-Active mode provides better performance and scalability than Active-Standby mode, which only uses one MHO at a time and keeps the other as a backup. Active- Active mode also allows for faster failover and recovery in case of an MHO failure, as the surviving MHO can take over the traffic without interruption.
References
*Check Point Certified Maestro Expert (CCME) R81.X - Global Knowledge, page 2
NEW QUESTION # 33
How many orchestrators may Dual-Site include?
  • A. 2 or 4
  • B. 0
  • C. Only 4
  • D. 1
A Dual Site environment can include either two or four orchestrators, depending on the scenario. There are three primary scenarios for Dual Site configuration:
*Direct connectivity between remote site orchestrators: This scenario requires two orchestrators, one for each site, and a direct connection between them using the site-sync port.
*Two orchestrators on the same site are connected to the remote site orchestrators through two different switches: This scenario requires four orchestrators, two for each site, and a connection between them using the site-sync port and two external switches that support QinQ and MTU increment.
*Two orchestrators on the same site are connected to the remote site orchestrators through one switch: This scenario also requires four orchestrators, two for each site, and a connection between them using the site-sync port and one external switch that supports QinQ and MTU increment.
References =
*Maestro Dual Site configuration with a direct connection through L2 switches
*Dual Site Single Maestro Hyperscale Orchestrator Cluster (Dual Site Single MHO Redundancy)
*Maestro Frequently Asked Questions (FAQ)
NEW QUESTION # 34
Our DumpsKing 156-836 exam certification training materials are real with a reasonable price. After you choose our 156-836 exam dumps, we will also provide one year free renewal service. Before you buy DumpsKing 156-836 certification training materials, you can download 156-836 free demo and answers on probation. If you fail the 156-836 exam certification or there are any quality problem of 156-836 exam certification training materials, we guarantee that we will give a full refund immediately.
156-836 Official Practice Test: https://www.dumpsking.com/156-836-testking-dumps.html
P.S. Free & New 156-836 dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1V8Qx3DkhoLp6Y12rO3XNgZLouExZXJgX
