[General] Ace Your Medical Tests AAPC-CPC Exam With Web-based Practice Tests
103
General Ace Your Medical Tests AAPC-CPC Exam With Web-based Practice Tests
Posted at 1/23/2026 01:23:38      View162 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New AAPC-CPC dumps are available on Google Drive shared by UpdateDumps: https://drive.google.com/open?id=1i_XpgLO0heKS1CH1UD6x_BwAB1PLzfnb
Our AAPC-CPC study materials have a professional attitude at the very beginning of its creation. The series of AAPC-CPC measures we have taken is also to allow you to have the most professional products and the most professional services. I believe that in addition to our AAPC-CPC Exam Questions, you have also used a variety of products. We believe if you compare our AAPC-CPC training guide with the others, you will choose ours at once.
We all know the effective diligence is in direct proportion to outcome, so by years of diligent work, our experts have collected the frequent-tested knowledge into our Medical Tests AAPC-CPC practice materials for your reference. So our American Academy of Professional Coders: Certified Professional Coder training materials are triumph of their endeavor.
Pass4sure Medical Tests AAPC-CPC Study Materials & AAPC-CPC Reliable Dumps FreeWith our motto "Sincerity and Quality", we will try our best to provide the big-league AAPC-CPC exam questions for our valued customers like you. Our company emphasizes the interaction with customers. We not only attach great importance to the quality of AAPC-CPC exam, but also take the construction of a better after-sale service into account. Its our responsibility to offer instant help to every user. If you have any question about AAPC-CPC Exam, please do not hesitate to leave us a message or send us an email. Our customer service staff will be delighted to answer questions on the AAPC-CPC exam guide.
Medical Tests American Academy of Professional Coders: Certified Professional Coder Sample Questions (Q44-Q49):NEW QUESTION # 44
A primary care physician is requesting a second opinion to determine which strain of Ebolavirus the patient has. The specimen is sent to a pathologist, who carefully examines it.
A written report is sent promptly back to the primary care physician, confirming Zaire Ebolavirus and recommending immediate isolation and emergency care. What code should be reported by the pathologist?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
A clinical pathology consultation was rendered at the request of the primary care physician.
The consultation is considered high based on the level of medical decision making. The CDC describes Ebola disease as a "rare and often deadly illness." Therefore, the number and complexity of problems addressed is high, as is the management ofthe disease due to the decision to escalate this case to hospital level care. E/M codes can be billed only when a patient themself is evaluated by the provider. In this case, the pathologist only evaluated a specimen.
NEW QUESTION # 45
A 34-year-old established male patient presents for treatment to his lower back. He reports exacerbated symptoms due to lifting heavy materials at work. The osteopath performs a problem-focused history and exam followed by manipulative treatment to the lumbar and sacral region of the spine. What procedure(s) should the osteopath report?
  • A. 99212-25, 97140x2
  • B. 99212-25, 98925
  • C. 0
  • D. 1
Osteopathic manipulation services do not include evaluation and management services.
Although the patient's treatment has already been established, the osteopathic physician has enough supporting documentation to report a separate evaluation and management code.
Manipulation services rendered by an osteopathic physician are reported with CPT codes 98925-
98929. A chiropractor would report manipulative treatment to t'.vo body regions with CPT 98940, and a physical therapist would report CPT 97140.
NEW QUESTION # 46
Code the following surgical note:
54-year-old male is experiencing left-sided weakness and visual disturbance. An MRI revealed a lesion in the brain. He presents today for a biopsy. General anesthesia is given, and the area is shaved and cleaned. The brain lab system is synced with prior MRI images to confirm the accurate placement of burr hole drilling. A cutting needle is inserted into the frontal lobe, and lesion location is confirmed with the brain lab system. A portion of the lesion is obtained without complication. All instruments removed, and the incision is sutured.
  • A. 0
  • B. 1
  • C. 2
  • D. 3
The coding crosswalk for a brain biopsy leads to three CPT codes. CPT code 61140 is a burr hole through which a lesion in the brain can be located and biopsied. CPT code 61750 is a biopsy using a CT or MRI scanning technique to locate the lesion in the brain. CPT code 61751 is the same as 61750, with the addition of the use of CT or MRI scanning during the procedure to confirm the location of lesion and/or accurate placement of surgical instruments. In this case, that occurred with the brain lab system. CPT code 61575 is a biopsy done on a different anatomic location and does not describe this procedure.
NEW QUESTION # 47
A patient has a colonoscopy in which the provider removes three polyps from the transverse colon. The first polyp is removed by means of a hot snare technique, and the following two polyps are removed using hot biopsy forceps. What CPT code(s) should be reported for this encounter?
  • A. 45385, 45384-59, 45384-59
  • B. 45385, 45384-59
  • C. 0
  • D. 1
When coding colonoscopies, remember that the number of removal techniques is what has a bearing on code selection and not the number of lesions and/or polyps that are being removed. In this case, two techniques are being used: I) the snare technique (CPT 45385) and 2) the hot biopsy forceps technique (CPT 45384). Modifier 59 is appended onto the secondary code to indicate that separate polyps '.vere removed by two different techniques. CPT 45388 is reported when a provider uses any methods other than snare and hot biopsy forceps to remove a lesion and/or polyp.
NEW QUESTION # 48
A laboratory receives a pap smear as a screening for a patient's annual gmecological exam. A thin-layer preparation screened by an automated system with manual rescreening is performed. A pathologist interprets the results and confirms a diagnosis of high-grade squamous intraepithelial lesion. What should the laboratory report?
  • A. G0148, R87.610
  • B. 88175, 88141, ZOI.419,R87.613
  • C. 88175, Z12.4
  • D. G0148, G0141, Z12.4 R8.613
The CPT codes for cytopathologv smears are dependent on the payer and the method used to test the specimen. HCPC II G0148 does accurately describe the test method; however, this code is used for Medicare payers only. As the documentation does not specify that this is the case, it should be assumed that the carrier is non-Medicare. The appropriate non-Medicare CPT for this test method is 88175. CPT 88141 is always reported as a secondary code for the associated physician interpretation. Regarding the diagnosis, the primary ICD-IO-CM code should be synonymous with the reason for the encounter, which in this scenario would be the Omecological exam (ZOI.419).
Although Z12.4 does describe a screening of the cervix, it specifically is excluded from the diagnosis list "when the screening is part of general gynecological examination (ZOI.4-ZOI.42)." Any abnormal findings are reported as secondary and/or tertiary.
NEW QUESTION # 49
Getting the American Academy of Professional Coders: Certified Professional Coder certification exam is necessary in order to get a job in your desired tech company. Success in the American Academy of Professional Coders: Certified Professional Coder (AAPC-CPC) certification exam gives you an edge over the others because you will have certified skills. The American Academy of Professional Coders: Certified Professional Coder certification exam badge will make a good impression on the interviewer. Most of the people planning to attempt the AAPC-CPC Exam are confused that how will they prepare and pass AAPC-CPC exam with good grades.
Pass4sure AAPC-CPC Study Materials: https://www.updatedumps.com/Medical-Tests/AAPC-CPC-updated-exam-dumps.html
Medical Tests Latest AAPC-CPC Exam Guide While, if you are not enough confident or need to prepare in a short time, thus you may need some extra helps, Passing an Medical Certification Certification AAPC-CPC exam rewards you in the form of best career opportunities, Medical Tests Latest AAPC-CPC Exam Guide As an emerging industry, internet technology still has a great development space in the future, If you decide to buy a AAPC-CPC exam braindumps, you definitely want to use it right away!
Temporarily indulging in another impulse, giving it ample opportunity Latest AAPC-CPC Exam Guide to satisfy it, consuming the energy that would have been used for the impulse carried by the surge, with the same result.
Fast Download Latest AAPC-CPC Exam Guide C The Best Pass4sure Study Materials for AAPC-CPC - Reliable AAPC-CPC Reliable Dumps FreeThis chapter provides an overview of the options for adding graphics to AAPC-CPC your Office application files, While, if you are not enough confident or need to prepare in a short time, thus you may need some extra helps.
Passing an Medical Certification Certification AAPC-CPC exam rewards you in the form of best career opportunities, As an emerging industry, internet technology still has a great development space in the future.
If you decide to buy a AAPC-CPC exam braindumps, you definitely want to use it right away, UpdateDumps never hits its customers with any kind of scam instead they are offered with 100% authentic products for Medical Tests AAPC-CPC exam preparation.
BTW, DOWNLOAD part of UpdateDumps AAPC-CPC dumps from Cloud Storage: https://drive.google.com/open?id=1i_XpgLO0heKS1CH1UD6x_BwAB1PLzfnb
Posted at 1/25/2026 14:59:52        Only Author  2#
Liking this instantly, its that good! Lets do this! Wishing for success in the L5M8 latest test objectives exam!
Posted at 1/31/2026 20:07:40        Only Author  3#
I feel like Ive gained so much from it. Get access to the Exam dumps D-UN-OE-23 provider exam that helped me achieve a promotion and pay raise, now free for everyone today. Best wishes in your professional development!
Posted at 2/14/2026 09:52:11        Only Author  4#
Cisco인증300-435시험의자격증은 여러분에 많은 도움이 되리라 믿습니다. 하시는 일에서 한층 더 업그레이드될 것이고 생활에서도 분명히 많은 도움이 될 것입니다. 자격증취득 즉 재산을 얻었죠.Cisco인증300-435시험은 여러분이 it지식테스트시험입니다. Pass4Test에서는 여러분의 편리를 위하여 Pass4Test만의 최고의 최신의Cisco 300-435덤프를 추천합니다. Pass4Test를 선택은 여러분이 최고의 선택입니다. Pass4Test는 제일 전면적인Cisco 300-435인증시험자료의 문제와 답을 가지고 잇습니다.
