真實的C_HRHFC_2411題庫和資格考試中的領導者和C_HRHFC_2411考試心得
Posted at 1/23/2026 02:03:55
此外,這些KaoGuTi C_HRHFC_2411考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1DjSgfUQ8WJh7g-OtDyDjWmUo2Yn1bBk2
KaoGuTi為你提供了一個明確而優秀的選擇,為你減少煩惱。想早點成功嗎?早點拿到SAP C_HRHFC_2411認證考試的證書嗎?快點將KaoGuTi加入購物車吧。KaoGuTi會給你很好的指導,能確保你通過考試。使用KaoGuTi你可以很快獲得你想要的證書。
SAP C_HRHFC_2411 考試大綱:| 主題 | 簡介 | | 主題 1 | - SAP SuccessFactors Compound Employee API: This section of the exam measures the skills of SAP Consultants and covers the Compound Employee API, which facilitates employee data replication between systems. It focuses on structuring employee data for efficient transfer. A skill to be measured is utilizing the Compound Employee API for data synchronization.
| | 主題 2 | - Organizational Data Replication from SAP SuccessFactors Employee Central to SAP ERP: This section of the exam measures the skills of SAP HRM Consultants and covers the replication of organizational data from SAP SuccessFactors Employee Central to SAP ERP.
| | 主題 3 | - SAP ERP User Interface Integration with SAP SuccessFactors Employee Central: This section of the exam measures skills of SAP Developers and covers integrating user interfaces between SAP ERP and SAP SuccessFactors Employee Central.
| | 主題 4 | - SAP SuccessFactors Employee Central Integration with SAP ERP Scenarios Overview: This section of the exam measures the skills of professionals in understanding various scenarios for integrating SAP SuccessFactors Employee Central with SAP ERP.
| | 主題 5 | - SAP SuccessFactors Employee Central Integration Overview and Basic Settings: This section of the exam measures the skills of SAP Consultants and covers the basic settings and overview of integrating SAP SuccessFactors Employee Central with other systems. It focuses on the initial configuration steps necessary for successful integration. One skill to be measured is configuring basic integration settings accurately.
C_HRHFC_2411考試心得 & C_HRHFC_2411認證資料考古題網站在近幾年激增,這可能是導致你準備 SAP 的 C_HRHFC_2411 考試認證毫無頭緒。SAP C_HRHFC_2411 考試培訓資料是一些專業人士和通過了的考生用實踐證明瞭的有效的培訓資料,它可以幫助你通過考試認證。告訴各考生一個好消息:KaoGuTi C_HRHFC_2411 考古題已經更新,解除了考生的擔憂!現在購買考題將得到一定的優惠!每個考生在準備 SAP 認證考試時,都非常苦惱!希望各位考生順利通過考試!
最新的 SAP Certified Associate C_HRHFC_2411 免費考試真題 (Q36-Q41):問題 #36
Your customer requires you to set up the initial load from SAP ERP HCM to SAP SuccessFactors.
Which configuration elements do you use in SAP ERP?
Note: There are 2 correct answers.
- A. EC template group
- B. EC model
- C. EC company ID
- D. EC permission roles
答案:B,C
解題說明:
To configure theinitial load, you need to:
* Define theEC company ID, which maps the company codes between systems.
Reference: Infoporter Configuration and Initial Load Guide.
問題 #37
Your customer wants to replicate cost centers from SAP ERP to SAP SuccessFactors Employee Central.
Which integration add-on package should be installed?
- A. PA_SE_IN
- B. ODTFINCC
- C. ODTFINCO
- D. ODTHCMER
答案:B
解題說明:
The ODTFINCC (Cost Center Integration Content) add-on is specifically designed to handle cost center data replication from SAP ERP to Employee Central. It includes the necessary middleware configurations.
Reference: Add-On Installation Guide - Cost Center Replication Section.
問題 #38
Your customer needs to send historical employment data to the benefits system using the OData API. Which filter parameters must you use in the OData API query?
- A. fromDate and toDate
- B. beginDate and end Date
- C. startDate and end Date
- D. effectiveStartDate and effectiveEndDate
答案:A
問題 #39
Which of the following guidelines should you follow when using basic extensibility to replicate from SAP Success Factors Employee Central to SAP ERP HCM?
- A. You can only map Employee Central Personal Information to SAP ERP Info type 0002.
- B. You CANNOT map fields from Job Info and Compensation Info to the Basic Pay Wage Type (LGART) field.
- C. You can map Employee Central standard and custom fields to SAP ERP HCM standard or customer fields.
- D. You can go to IMG-> SAP Customizing Implementation Guide > Personnel Management -> Integration with Success Factors Employee Central -> Business Integration Builder -> Business Add-ins (BAdis) to configure basic extensibility.
答案:C,D
問題 #40
What setting needs to be enabled before you can use Business Integration Builder (BIB)-based configuration?
- A. Maintain the flag in SAP SuccessFactors Employee Central configuration.
- B. Maintain "X" with SAP Integration Suite extensions.
- C. Activate BIB with Provisioning.
- D. Activate the BIB setting in customizing activity in SAP ERP HCM.
答案:C
解題說明:
BIB must be activated inProvisioning(backend SAP SuccessFactors admin tool). This activation enables the metadata and templates required for BIB to function during replication from EC to SAP ERP.
Reference: Provisioning Settings for BIB Enablement Guide
問題 #41
在短短幾年內,SAP C_HRHFC_2411 認證考試已經成為比較有影響力電腦能力認證考試。然而如何簡單順利地通過SAP C_HRHFC_2411認證考試?我們的KaoGuTi在任何時間下都可以幫您快速解決這個問題。我們在KaoGuTi中為您提供了可以成功通過C_HRHFC_2411認證考試的培訓工具。C_HRHFC_2411認證考試培訓工具的內容是由IT行業專家帶來的最新的考試研究材料組成
C_HRHFC_2411考試心得: https://www.kaoguti.com/C_HRHFC_2411_exam-pdf.html
- C_HRHFC_2411考試備考經驗 📑 C_HRHFC_2411套裝 🌷 C_HRHFC_2411新版題庫上線 🔱 開啟【 [url]www.newdumpspdf.com 】輸入➡ C_HRHFC_2411 ️⬅️並獲取免費下載C_HRHFC_2411指南[/url]
- C_HRHFC_2411在線考題 🔴 C_HRHFC_2411考試備考經驗 🏆 C_HRHFC_2411指南 🔊 打開網站[ [url]www.newdumpspdf.com ]搜索“ C_HRHFC_2411 ”免費下載C_HRHFC_2411指南[/url]
- 最新C_HRHFC_2411試題 🦗 C_HRHFC_2411在線考題 🎭 C_HRHFC_2411熱門認證 ↩ ▷ [url]www.vcesoft.com ◁是獲取【 C_HRHFC_2411 】免費下載的最佳網站C_HRHFC_2411證照資訊[/url]
- 完全覆蓋的C_HRHFC_2411題庫和資格考試和熱門的C_HRHFC_2411考試心得的領導者 👯 「 [url]www.newdumpspdf.com 」提供免費➠ C_HRHFC_2411 🠰問題收集C_HRHFC_2411考試證照綜述[/url]
- 精準覆蓋的C_HRHFC_2411題庫 |高通過率的考試材料|快速下載C_HRHFC_2411:SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Full Cloud/Core Hybrid 🧘 在➡ [url]www.newdumpspdf.com ️⬅️網站上查找➥ C_HRHFC_2411 🡄的最新題庫C_HRHFC_2411題庫分享[/url]
- 快速下載的SAP C_HRHFC_2411:SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Full Cloud/Core Hybrid題庫 - 高質量的Newdumpspdf C_HRHFC_2411考試心得 👤 到( [url]www.newdumpspdf.com )搜索➡ C_HRHFC_2411 ️⬅️輕鬆取得免費下載C_HRHFC_2411題庫分享[/url]
- 無與倫比的C_HRHFC_2411題庫擁有模擬真實考試環境與場境的軟件VCE版本&最好的C_HRHFC_2411考試心得 🕌 【 [url]www.newdumpspdf.com 】最新➽ C_HRHFC_2411 🢪問題集合最新C_HRHFC_2411試題[/url]
- 精準覆蓋的C_HRHFC_2411題庫 |高通過率的考試材料|快速下載C_HRHFC_2411:SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Full Cloud/Core Hybrid 👦 「 [url]www.newdumpspdf.com 」是獲取➠ C_HRHFC_2411 🠰免費下載的最佳網站C_HRHFC_2411考試備考經驗[/url]
- C_HRHFC_2411指南 📻 C_HRHFC_2411題庫 😕 C_HRHFC_2411考試證照綜述 🏞 到➽ [url]www.newdumpspdf.com 🢪搜尋【 C_HRHFC_2411 】以獲取免費下載考試資料C_HRHFC_2411套裝[/url]
- 新版C_HRHFC_2411考古題 ⏹ C_HRHFC_2411學習指南 🆖 C_HRHFC_2411考試證照綜述 👯 ▛ [url]www.newdumpspdf.com ▟是獲取➠ C_HRHFC_2411 🠰免費下載的最佳網站C_HRHFC_2411指南[/url]
- 快速下載的SAP C_HRHFC_2411:SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Full Cloud/Core Hybrid題庫 - 高質量的[url]www.pdfexamdumps.com C_HRHFC_2411考試心得 💟 立即打開{ www.pdfexamdumps.com }並搜索[ C_HRHFC_2411 ]以獲取免費下載C_HRHFC_2411熱門認證[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, iatdacademy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, justpaste.me, Disposable vapes
順便提一下,可以從雲存儲中下載KaoGuTi C_HRHFC_2411考試題庫的完整版:https://drive.google.com/open?id=1DjSgfUQ8WJh7g-OtDyDjWmUo2Yn1bBk2
