[Hardware] 100% Pass Quiz Microsoft - Professional MS-102 Sample Questions Answers
94
【Hardware】 100% Pass Quiz Microsoft - Professional MS-102 Sample Questions Answers
Posted at 1/23/2026 05:05:11      View:136 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest CramPDF MS-102 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1hI3X4SHMJwflClNoU79fR2hcSbVnKKrZ
When you first contacted us with MS-102 quiz torrent, you may be confused about our MS-102 exam question and would like to learn more about our products to confirm our claims. We have a trial version for you to experience. If you encounter any questions about our MS-102 Learning Materials during use, you can contact our staff and we will be happy to serve for you. As for any of your suggestions, we will take it into consideration, and effectively improve our MS-102 exam question to better meet the needs of clients.
You will have the chance to renew your knowledge while getting trustworthy proof of your expertise with the Microsoft MS-102 exam. After passing the Microsoft MS-102 certification exam, you can take advantage of a number of extra benefits. The Microsoft MS-102 Certification test, however, is a valuable and difficult credential. But with the correct concentration, commitment, and MS-102 exam preparation, you could ace this test with ease.
MS-102 Reliable Exam Vce, MS-102 Valid Test DurationMicrosoft is here to assist you to advance in the quick-paced, technology world if that is your goal. Your dream of passing the Microsoft MS-102 certification exam on your first try will come true thanks to Microsoft's first-rate MS-102 Practice Exam. The majority of people struggle to locate outstanding Microsoft MS-102 exam dumps that can enable them to get ready for the real Microsoft MS-102 exam.
Microsoft MS-102 Exam Syllabus Topics:
  • Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
  • Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
  • Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
  • Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
Microsoft 365 Administrator Sample Questions (Q336-Q341):NEW QUESTION # 336
HOTSPOT
You have a Microsoft 365 E5 subscription that contains the users shown in the following table.
You configure the Microsoft Authenticator authentication method policy to enable passwordless authentication as shown in the following exhibit.
Both User1 and User2 report that they are NOT prompted for passwordless sign-in in the Microsoft Authenticator app.
Box 1: Yes
User1 is member of Group1.
User1 has MFA registered method of Microsoft Authenticater app (push notification) The Microsoft Authenticator authentication method policy is configured for Group1, registration is optional, authentication method is any.
Note: Microsoft Authenticator can be used to sign in to any Azure AD account without using a password.
Microsoft Authenticator uses key-based authentication to enable a user credential that is tied to a device, where the device uses a PIN or biometric. Windows Hello for Business uses a similar technology.
This authentication technology can be used on any device platform, including mobile. This technology can also be used with any app or website that integrates with Microsoft Authentication Libraries.
Box 2: No
User2 is member of Group2.
The Microsoft Authenticator authentication method policy is configured for Group1, not for Group2.
Box 3: No
User3 is member of Group1.
User3 has no MFA method registered.
User3 must choose an authentication method.
Note: Enable passwordless phone sign-in authentication methods
Azure AD lets you choose which authentication methods can be used during the sign-in process. Users then register for the methods they'd like to use.
https://learn.microsoft.com/en-u ... -passwordless-phone
NEW QUESTION # 337
You have a Microsoft 365 E5 tenant.
You need to implement compliance solutions that meet the following requirements:
* Use a file plan to manage retention labels.
* Identify, monitor, and automatically protect sensitive information.
* Capture employee communications for examination by designated reviewers.
Which solution should you use for each requirement? To answer, drag the appropriate solutions to the correct requirements. Each solution may be used once, more than once, or not at all. You may need to drag the split bat between panes or scroll to view content.
NEW QUESTION # 338
You have a Microsoft 365 subscription that uses Microsoft Defender for Office 365.
You need to identify the settings that are below the Standard protection profile settings in the preset security policies.
What should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 339
HOTSPOT
You have a Microsoft 365 subscription that contains the users shown in the following table.
You need to configure a dynamic user group that will include the guest users in any department that contains the word Support.
How should you complete the membership rule? To answer, select the appropriate options in the answer area.
Box 1: -eq "Guest"
Dynamic membership rules for groups in Azure Active Directory
Supported expression operators
The following table lists all the supported operators and their syntax for a single expression. Operators can be used with or without the hyphen (-) prefix. The Contains operator does partial string matches but not item in a collection matches.
* Equals
-eq
* Contains
-contains
* Etc.
Box 2: -contains "Support"
Incorrect:
* -in
If you want to compare the value of a user attribute against multiple values, you can use the -in or -notIn operators.
https://learn.microsoft.com/en-u ... -dynamic-membership
NEW QUESTION # 340
You have a Microsoft 365 E5 subscription.
You plan to create the data loss prevention (DLP) policies shown in the following table.
You need to create DLP rules for each policy.
Which policies support the sender is condition and the file extension is condition? To answer select the appropriate options in the answer area.
NEW QUESTION # 341
We have installed the most advanced operation system in our company which can assure you the fastest delivery speed, to be specific, you can get immediately our MS-102 training materials only within five to ten minutes after purchase after payment. As soon as you pressed the payment button on our MS-102 Exam Questions, you can study right away if you choose to buy the MS-102 exam practice from us. We aim to leave no misgivings to our customers so that they are able to devote themselves fully to their studies on MS-102 guide materials and they will find no distraction from us.
MS-102 Reliable Exam Vce: https://www.crampdf.com/MS-102-exam-prep-dumps.html
2026 Latest CramPDF MS-102 PDF Dumps and MS-102 Exam Engine Free Share: https://drive.google.com/open?id=1hI3X4SHMJwflClNoU79fR2hcSbVnKKrZ
Posted at 1/26/2026 04:48:41        Only Author  2#
Your article is spellbinding, thank you for sharing such brilliance! HPE2-E84 latest practice questions free test questions available for free—get ready for promotions and salary growth!
Posted at 2/3/2026 16:50:16        Only Author  3#
안심하시고Itexamdump 를 선택하게 하기 위하여, Itexamdump에서는 이미CIPS L6M3인증시험의 일부 문제와 답을 사이트에 올려놨으니 체험해보실 수 있습니다. 그러면 저희한테 신뢰가 갈 것이며 또 망설임 없이 선택하게 될 것입니다. 저희 덤프로 여러분은 한번에 시험을 패스할 수 있으며 또 개인시간도 절약하고 무엇보다도 금전상으로 절약이 제일 크다고 봅니다. Itexamdump는 여러분들한테 최고의CIPS L6M3문제와 답을 제공함으로 100%로의 보장 도를 자랑합니다, 여러분은CIPS L6M3인증시험의 패스로 IT업계여서도 또 직장에서도 한층 업그레이드되실 수 있습니다. 여러분의 미래는 더욱더 아름다울 것입니다.
Posted at 2/16/2026 08:30:14        Only Author  4#
Your article was incredibly insightful, and I’m truly thankful for it. Sharing Valid AZ-104 exam papers materials for free—boost your career with these essential resources!
