[General] Workday-Prism-Analytics Related Content, Workday-Prism-Analytics Exam Sample Onl
85
General Workday-Prism-Analytics Related Content, Workday-Prism-Analytics Exam Sample Onl
Posted at 1/23/2026 05:14:55      View104 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Workday Workday-Prism-Analytics dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=1b88z4JGgKiuVYf7AxgScYcaoDG5cSvFe
The easy to learn format of these amazing Workday-Prism-Analytics exam questions will prove one of the most exciting exam preparation experiences of your life! When you are visiting on our website, you can find that every button is easy to use and has a swift response. And there are three varied versions of our Workday-Prism-Analytics learning guide: the PDF, Software and APP online. Every version of our Workday-Prism-Analytics simulating exam is auto installed if you buy and study with them. They are perfect in every detail.
As a worldwide leader in offering the best Workday-Prism-Analytics test torrent in the market, NewPassLeader are committed to providing update information on Workday-Prism-Analytics exam questions that have been checked many times by our professional expert, and we provide comprehensive service to the majority of consumers and strive for constructing an integrated service. What's more, we have achieved breakthroughs in certification training application as well as interactive sharing and after-sales service. It is worth for you to purchase our Workday-Prism-Analytics training braindump.
Workday-Prism-Analytics Exam Sample Online & Certification Workday-Prism-Analytics QuestionsThere is plenty of skilled and motivated staff to help you obtain the Workday Pro Prism Analytics Exam exam certificate that you are looking forward. We have faith in our professional team and our Workday-Prism-Analytics Study Tool, and we also wish you trust us wholeheartedly. Because of this function, you can easily grasp how the practice system operates and be able to get hold of the core knowledge about the Workday Pro Prism Analytics Exam exam. In addition, when you are in the real exam environment, you can learn to control your speed and quality in answering questions and form a good habit of doing exercise, so that youre going to be fine in the Workday Pro Prism Analytics Exam exam.
Workday Pro Prism Analytics Exam Sample Questions (Q37-Q42):NEW QUESTION # 37
You want to configure access to a published Prism data source to use it in reporting and discovery boards.
What action must you take?
  • A. Edit the data source security and select a domain.
  • B. Share the dataset with appropriate users.
  • C. Share the imported Workday report to provide users with access to the published Prism data source.
  • D. Schedule the recurring publish process.
In Workday Prism Analytics, configuring access to a published Prism data source for use in reporting and discovery boards requires managing its security settings. According to the official Workday Prism Analytics study path documents, the necessary action is to edit the data source security and select a domain (option A).
After a dataset is published as a Prism data source, access is controlled through security domains. By editing the data source security and assigning it to an appropriate security domain (e.g., a domain that grants access to specific user groups like report writers or analysts), you ensure that authorized users can access the data source for reporting and discovery boards. This aligns with Workday's configurable security framework, ensuring that only users with the appropriate permissions can view or use the data source.
The other options are incorrect:
* B. Share the dataset with appropriate users: Sharing the dataset itself does not grant access to the published Prism data source; access to the data source is controlled through its security settings, not the dataset's sharing settings.
* C. Share the imported Workday report to provide users with access to the published Prism data source:
Sharing an imported Workday report does not affect access to the Prism data source; the data source's security must be configured directly.
* D. Schedule the recurring publish process: Scheduling a recurring publish process ensures the data source is updated regularly, but it does not configure access for reporting or discovery boards.
Editing the data source security and selecting a domain is the critical step to enable access for reporting and discovery boards.
Workday Prism Analytics Study Path Documents, Section: Security and Governance in Prism, Topic:
Configuring Access to Prism Data Sources
Workday Prism Analytics Training Guide, Module: Security and Governance in Prism, Subtopic: Managing Data Source Security for Reporting
NEW QUESTION # 38
You have a number of Workday reports that use a Prism data source. When are the values of the Prism calculated fields in the Workday reports calculated?
  • A. At dataset creation time.
  • B. At time of publishing.
  • C. At the calculated field creation time.
  • D. At report run time.
In Workday Prism Analytics, calculated fields in a dataset are evaluated as part of the dataset's processing logic, and their values are materialized when the dataset is published as a Prism data source. According to the official Workday Prism Analytics study path documents, the values of Prism calculated fields are calculated at the time of publishing (option D). When a dataset is published, Prism processes all transformation stages, including calculated fields, and the resulting values are stored in the publisheddata source. Workday reports that use this Prism data source then retrieve these pre-calculated values, ensuring consistent and efficient reporting without recalculating the fields at report run time.
* A. At report run time: Calculated field values are not computed when the Workday report is run; they are pre-calculated and stored in the Prism data source during publishing.
* B. At dataset creation time: Dataset creation involves defining the transformation logic, but the actual computation of calculated fields occurs during publishing, not at creation.
* C. At the calculated field creation time: Creating a calculated field defines its expression, but the values are not computed until the dataset is processed during publishing.
The calculation of Prism calculated fields at the time of publishing ensures that Workday reports can efficiently access the results without additional computation overhead.
Workday Prism Analytics Study Path Documents, Section: Integrating Prism with Workday Reports, Topic:
Calculated Fields in Prism Data Sources
Workday Prism Analytics Training Guide, Module: Publishing and Visualizing Data, Subtopic: Processing Calculated Fields During Publishing
NEW QUESTION # 39
You just imported your table on worker compensation into a derived dataset but before adding any transformation you want to make sure you have no NULL values for the Worker ID field. How can you get this insight?
  • A. Join on the Worker ID field.
  • B. Click on the field name and check the stage statistics.
  • C. Create a Prism calculated field.
  • D. Add a Manage Fields stage.
In Workday Prism Analytics, after importing a table into a derived dataset (DDS), you can inspect the data for quality issues, such as NULL values, before proceeding with transformations. According to the official Workday Prism Analytics study path documents, to check for NULL values in a specific field like Worker ID, the most direct method is to click on the field name and check the stage statistics. When viewing a dataset in the Prism Analytics interface, clicking on a field name (e.g., Worker ID) in the dataset preview displays stage statistics, which include metrics such as the count of NULL values, distinct values, and other data quality indicators. This feature allows users to quickly assess the presence of NULLs without modifying the dataset or adding unnecessary stages.
The other options are not the best approach for this task:
* A. Add a Manage Fields stage: The Manage Fields stage is used to modify field properties (e.g., type, visibility), not to inspect data for NULL values.
* C. Create a Prism calculated field: While a calculated field could be used to flag NULLs (e.g., using ISNULL), this is an indirect and unnecessary step compared to checking stage statistics.
* D. Join on the Worker ID field: Joining with another dataset does not help identify NULL values in the Worker ID field and is irrelevant to this task.
Using stage statistics by clicking on the field name provides a straightforward and efficient way to gain insight into NULL values in the Worker ID field.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Data Quality Checks in Derived Datasets Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Inspecting Data Using Stage Statistics
NEW QUESTION # 40
What window function returns the number of rows within a window?
  • A. AVG
  • B. SUM
  • C. COUNT
  • D. MAX
In Workday Prism Analytics, window functions are used to perform calculations over a defined set of rows (a
"window"). According to the official Workday Prism Analytics study path documents, the COUNT window function is used to return the number of rows within a specified window. When applied in a dataset transformation, the COUNT function counts the rows that fall within the window, which can be defined by partitioning (e.g., by a specific column) and ordering criteria. For example, COUNT(*) OVER (PARTITION BY department) would return the number of rows for each department in the dataset.
The other options serve different purposes:
A: MAX: Returns the maximum value within the window, not the number of rows.
B: SUM: Calculates the sum of a numeric field across the window, not the row count.
D: AVG: Computes the average of a numeric field within the window, not the row count.
The COUNT function is specifically designed to provide the row count, making it the correct choice for this purpose in Prism Analytics transformations.
Workday Prism Analytics Study Path Documents, Section: Data Prep and Transformation, Topic: Window Functions and Their Applications Workday Prism Analytics Training Guide, Module: Data Prep and Transformation, Subtopic: Using COUNT in Window Functions
NEW QUESTION # 41
You had to change the imported pipeline in a Join stage and your View Dataset Lineage report shows a Stage Alert regarding the disconnected pipeline. How can you fix this and make the alert disappear?
  • A. Delete the disconnected pipeline.
  • B. Change the imported pipeline to a different one.
  • C. Publish the derived dataset.
  • D. Add a Manage Fields stage and re-attach the pipeline.
In Workday Prism Analytics, a Stage Alert in the View Dataset Lineage report indicates an issue with the dataset's transformation pipeline, such as a disconnected pipeline resulting from changing the imported pipeline in a Join stage. According to the official Workday Prism Analytics study path documents, a disconnected pipeline occurs when a pipeline (e.g., a table or dataset) is no longer referenced by any transformation stage, often after modifying the Join stage to use a different imported pipeline. To resolve this alert, the recommended action is to delete the disconnected pipeline (option D). By removing the disconnected pipeline from the dataset, the lineage is updated to reflect only the active pipelines, and the Stage Alert will disappear, indicating that the dataset's configuration is now valid.
The other options are not appropriate:
* A. Add a Manage Fields stage and re-attach the pipeline: A Manage Fields stage modifies field properties and cannot re-attach a disconnected pipeline to the Join stage.
* B. Publish the derived dataset: Publishing the dataset does not resolve the issue of a disconnected pipeline; the alert will persist until the pipeline is addressed.
* C. Change the imported pipeline to a different one: This does not address the disconnected pipeline; it only changes the Join stage's configuration again, potentially causing further issues.
Deleting the disconnected pipeline ensures the dataset's lineage is clean and free of errors, resolving the Stage Alert in the View Dataset Lineage report.
Workday Prism Analytics Study Path Documents, Section: Datasets and Data Sources, Topic:
Troubleshooting Stage Alerts in Dataset Lineage
Workday Prism Analytics Training Guide, Module: Datasets and Data Sources, Subtopic: Managing Pipeline Connections in Derived Datasets
NEW QUESTION # 42
The Workday Pro Prism Analytics Exam (Workday-Prism-Analytics) PDF dumps format can be accessed from any smart device such as laptops, tablets, and smartphones. NewPassLeader regularly updates the Workday-Prism-Analytics PDF Questions to reflect the latest Workday Workday-Prism-Analytics exam content. All test questions in the Workday-Prism-Analytics exam PDF format are real and latest.
Workday-Prism-Analytics Exam Sample Online: https://www.newpassleader.com/Workday/Workday-Prism-Analytics-exam-preparation-materials.html
Our Workday-Prism-Analytics prep material target all users and any learners, regardless of their age, gender and education background, All these Workday-Prism-Analytics certification exam benefits will not only prove your skills but also assist you to put your career on the right track and achieve your career objectives in a short time period, There are also free demos of our Workday-Prism-Analytics study materials on the website that you can download before placing the orders.
The most common scenarios are looping through code a set number Certification Workday-Prism-Analytics Questions of times, looping until a condition becomes true or false, or looping through code once per element in a collection of objects.
Workday Workday-Prism-Analytics Exam Dumps - Reliable Way to Pass Exam InstantlyThe Raspberry Pi can open opportunities for you to create your own home automation Exam Workday-Prism-Analytics Duration projects, which is popular among people in the open source community because it puts you in control, rather than using a proprietary closed system.
Our Workday-Prism-Analytics prep material target all users and any learners, regardless of their age, gender and education background, All these Workday-Prism-Analytics certification exam benefits will not only prove your skills but also assist Workday-Prism-Analytics you to put your career on the right track and achieve your career objectives in a short time period.
There are also free demos of our Workday-Prism-Analytics study materials on the website that you can download before placing the orders, If you want the Workday-Prism-Analytics certification to change your life and make it better, what are you waiting for?
Our passing rate of Workday-Prism-Analytics exam guide is 98%-100% and our Workday-Prism-Analytics test prep can guarantee that you can pass the exam easily and successfully.
P.S. Free & New Workday-Prism-Analytics dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=1b88z4JGgKiuVYf7AxgScYcaoDG5cSvFe
