[Hardware] Cisco 300-820 Valid Exam Book & 300-820 Latest Demo
85
Hardware Cisco 300-820 Valid Exam Book & 300-820 Latest Demo
Posted at 1/23/2026 05:24:11      View203 | Replies2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ValidTorrent 300-820 dumps from Cloud Storage: https://drive.google.com/open?id=1_ivYydQMEX5QWt4lbSxMCIGA-9wCjQeD
Cisco 300-820 valid test cram will help you to get your 300-820 certification. It will be a breeze to get your 300-820 certification with the help of the ValidTorrent 300-820 pdf vce. We will help whenever you need: 24*7 dedicated email and chat support are available. Besides, we ensure you a flawless shopping experience by Paypal. You can get passed by our latest & updated 300-820 Preparation material.
Cisco 300-820 Exam is designed for IT professionals who want to validate their expertise in implementing Cisco collaboration cloud and edge solutions. Implementing Cisco Collaboration Cloud and Edge Solutions certification exam is intended for individuals who have a good understanding of Cisco collaboration solutions and the ability to implement and troubleshoot Cisco cloud and edge solutions. Successful candidates will be able to implement and troubleshoot Cisco cloud collaboration solutions and edge architectures, including Cisco Webex, Cisco Expressway, and Cisco Unified Communications Manager.
100% Pass 2026 Latest Cisco 300-820 Valid Exam BookOur 300-820 study materials present the most important information to the clients in the simplest way so our clients need little time and energy to learn our 300-820 study materials. The clients only need 20-30 hours to learn and prepare for the test. For those people who are busy in their jobs, learning or other things this is a good news because they neednt worry too much that they dont have enough time to prepare for the test and can leisurely do their main things and spare little time to learn our 300-820 Study Materials. So it is a great advantage of our 300-820 study materials and a great convenience for the clients.
Cisco Implementing Cisco Collaboration Cloud and Edge Solutions Sample Questions (Q83-Q88):NEW QUESTION # 83
An organization wants to enable a Cisco Webex connector to synchronize all employees automatically with Cisco Webex instead of using a manual list.
Where is the Webex Hybrid Directory Service configured?
  • A. Install Cisco Directory Connector on a Microsoft Windows Domain server and configure the software and Webex Control Hub.
  • B. Install the Cisco Express Connector and configure the device in Cisco Unified Communications Manager under Cisco Unified Serviceability and add the service in Webex Control Hub.
  • C. Enable the directory service in Cisco Unified Communications Manager under Cisco Unified Serviceability and add the service in Webex Control Hub.
  • D. Enable the directory service on Cisco Expressway Edge for Office 365 or Cisco Expressway Core for internal Active Directory and add the service in Webex Control Hub.
NEW QUESTION # 84
Which service is available in a cloud-based deployment using Cisco Webex Messenger?
  • A. Presence
  • B. Phone services
  • C. Voicemail
  • D. Call forward services
NEW QUESTION # 85
In a larger Cisco Collaboration deployment, a user requires the advanced file transfer function in Cisco Jabber while the client is using Mobile and Remote Access. The deployment has multiple Expressway clusters and internal Cisco UCM clusters. Which configuration must be applied on Cisco Expressway-C for this function to be available?
  • A. The HTTP Allow List must use Automatic update rules to include all Cisco UCM servers.
  • B. The HTTP Allow List must be manual or use Automatic inbound rules updated to include all Cisco IM and Presence servers.
  • C. The HTTP Allow List must use Automatic update rules to include all Cisco IM and Presence servers.
  • D. The HTTPS Allow List must be manual or use Automatic inbound rules updated to include all Cisco IM and Presence servers.
For the AFT feature to work across Expressway, make sure that all Unified CM IM and Presence Service nodes are on the allow list, whether manually or automatically added.
Automatic Inbound Rules
Edit the HTTP Allow List
Upload Rules to the HTTP Allow List
https://www.cisco.com/c/en/us/td ... y/config_guide/X12-
5/exwy_b_mra-expressway-deployment-guide/exwy_b_mra-expressway-deployment- guide_chapter_01000.html#task_FED878914C77C914B5FD7C7108F5CDCE
NEW QUESTION # 86
An engineer configures a Cisco Collaboration environment to use Mobile and Remote Access for external access for company users. The engineer uses OAuth with refresh on the Cisco UCM SIP lines for extra security and improved user experience. During the setup, Mobile and Remote Access does not work, it is enabled on the Cisco UCM and Cisco Expressways. SIP trunks on ports 5090 and 5091 are configured to avoid conflicts with other SIP trunks between internal Cisco UCM clusters. The traversal zone also uses port 6500. The traversal zone between Expressways shows no errors, and the requests hit Expressway-E from the Internet. What is the reason that the solution does not work?
  • A. The default port for Mobile and Remote Access is 6500, which creates a conflict with the existing traversal zone port.
  • B. Mobile and Remote Access does not support OAuth with refresh with this configuration.
  • C. The default port for Mobile and Remote Access is 6001. Therefore, the traversal port must be port 6001 for Mobile and Remote Access to work.
  • D. The default port for Mobile and Remote Access is 5091, which creates a conflict with the existing SIP trunks.
NEW QUESTION # 87
An Expressway-E is configured using a single NIC with NAT.
How must the Expressway-C traversal client zone be configured to connect to the Expressway-E?
  • A. The zone profile must be set to default.
  • B. TLS verify must be enabled.
  • C. The peer address must be the Expressway-E LAN 1 IP address.
  • D. The peer address must be the Expressway-E NAT address.
NEW QUESTION # 88
With rapid development of IT industry, more and more requirements have been taken on those who are working in IT industry. So if you don't want to be eliminated in the competition, to pass 300-820 exam is a necessary for you. If you worry that you will not get the satisfied results after you have taken too much time and energy to prepare the 300-820 Exam. Now let our ValidTorrent help you! Countless 300-820 exam software users of our ValidTorrent let us have the confidence to tell you that using our test software, you will have the most reliable guarantee to pass 300-820 exam.
300-820 Latest Demo: https://www.validtorrent.com/300-820-valid-exam-torrent.html
P.S. Free 2026 Cisco 300-820 dumps are available on Google Drive shared by ValidTorrent: https://drive.google.com/open?id=1_ivYydQMEX5QWt4lbSxMCIGA-9wCjQeD
Posted at 1/23/2026 06:07:07        Only Author  2#
Your article is simply remarkable, thank you for sharing! Hope I can conquer the MO-210 valid exam discount exam. Wish me luck!
Posted at 2/23/2026 10:38:15        Only Author  3#
This article is brilliant beyond words, thank you for sharing. Wish me all the success I can get for the New Associate-Google-Workspace-Administrator exam dumps demo exam!
