[General] Salesforce - Mule-Dev-301 - Updated Reliable Salesforce Certified MuleSoft Devel
86
General Salesforce - Mule-Dev-301 - Updated Reliable Salesforce Certified MuleSoft Devel
Posted at 1/23/2026 06:33:42      View177 | Replies2        Print      Only Author   [Copy Link] 1#
Professionals who hold Mule-Dev-301 certification demonstrate to their employers and clients that they have the knowledge and skills necessary to succeed in the industry. To meet the growing demand for Salesforce Mule-Dev-301 certification exam, preparation platforms have emerged in recent years. ExamDiscuss offers candidates actual Mule-Dev-301 Questions Pdf, practice exams, and 24/7 support to ensure they have the best possible preparation for the exam.
We are confident in the ability of Mule-Dev-301 exam torrent and we also want to our candidates feel confident in our certification exam materials. For this reason, all questions and answers in our Mule-Dev-301 valid dumps are certified and tested by our senior IT professionals. And we guarantee that if you failed the certification exam with our Mule-Dev-301 Pdf Torrent, we will get your money back to reduce your loss.
Salesforce - The Best Mule-Dev-301 - Reliable Salesforce Certified MuleSoft Developer II Braindumps BookIn today's rapidly changing Salesforce industry, the importance of obtaining Salesforce Mule-Dev-301 certification has become increasingly evident. With the constant evolution of technology, staying competitive in the job market requires professionals to continuously upgrade their skills and knowledge. The ExamDiscuss is committed to completely assisting you in exam preparation with Mule-Dev-301 Questions. Success in the Salesforce Certified MuleSoft Developer II (Mule-Dev-301) certification exam is crucial in the tech sector, where the stakes are high, and a single mistake can have significant consequences.
Salesforce Certified MuleSoft Developer II Sample Questions (Q52-Q57):NEW QUESTION # 52
A mule application exposes and API for creating payments. An Operations team wants to ensure that the Payment API is up and running at all times in production.
Which approach should be used to test that the payment API is working in production?
  • A. Create a health check endpoint that reuses the same port number and HTTP Listener configuration as the API itself
  • B. Configure the application to send health data to an external system
  • C. Monitor the Payment API directly sending real customer payment data
  • D. Create a health check endpoint that listens on a separate port and uses a separate HTTP Listener configuration from the API
NEW QUESTION # 53
A Mule application deployed to a standardalone Mule runtime uses VM queues to publish messages to be consumed asynchronously by another flow.
In the case of a system failure, what will happen to in-flight messages in the VM queues that have been consumed?
  • A. For persistent queues, the message will be processed after the system comes online
  • B. For any type of queue, the message will be lost
  • C. For transient queues, the message will be processed after the system comes online
  • D. For nay type of queue, the message will be processed after the system comes online
In case of a system failure, in-flight messages in persistent VM queues that have been consumed will be processed after the system comes online. This is because persistent VM queues store messages on disk and guarantee delivery even if there is a system crash or restart. Therefore, any in-flight messages that have been consumed but not processed will be recovered from disk and processed when the system is back online. Reference: https://docs.mulesoft.com/mule-r ... r#persistent-queues
NEW QUESTION # 54
Two APIs are deployed to a two-node on-prem cluster. Due to a requirements change, the two APIs must communicate to exchange data asynchronously.
  • A. The VM Connector is used to inter-application communication, so it is not possible to use the VM Connector
  • B. If the two APIs use the same domain, the VM Connector can be leveraged
  • C. It is not possible to use the VM Connector since the APIs are running in a cluster mode and each mode has it own set of VM Queues
  • D. Instead of using the VM Connector use <flow-ref>directly
To communicate asynchronously between two APIs deployed to a two-node on-prem cluster, the developer can use the VM Connector if the two APIs use the same domain. The VM Connector allows passing messages between different Mule applications within a single Mule runtime instance or across different instances using shared memory or persistent storage. If two APIs are deployed under the same domain, they can share resources such as VM queues and communicate asynchronously using VM Connector operations. Reference: https://docs.mulesoft.com/mule-runtime/4.3/vm-connector https://docs.mulesoft.com/mule-runtime/4.3/shared-resources
NEW QUESTION # 55
The flow is invoicing a target API. The API's protocol is HTTPS. The TLS configuration in the HTTP Request Configuration global element is set to None. A web client submits a request to http:localhost:8081/vehicles.
If the certificate of the target API is signed by a certificate authority (CA), what is true about the HTTP Request operation when the flow executes?
  • A. The HTTP Request operation will succeed if the CA'S certificate is present in the JRE's default keystore
  • B. The HTTP Request operation will always fail regardless of the CA
  • C. The HTTP Request operation will always succeed regardless of the CA
  • D. The HTTP Request operation will succeed if the CA's certificate is present in the JRE's default truststore.
The HTTP Request operation will use the default truststore of the JRE to validate the certificate of the target API. If the CA's certificate is present in the truststore, the operation will succeed. Otherwise, it will fail with a handshake exception. Reference: https://docs.mulesoft.com/mule-r ... uration#tls-default
NEW QUESTION # 56
A system API that communicates to an underlying MySQL database is deploying to CloudHub. The DevOps team requires a readiness endpoint to monitor all system APIs.
Which strategy should be used to implement this endpoint?
  • A. Create a dedicated endpoint that responds with the API status only
  • B. Create a dedicated endpoint that responds with the API status and health of the server
  • C. Create a dedicated endpoint that responds with the API status and reachability of the underlying systems
  • D. Use an existing resource endpoint of the API
To implement a readiness endpoint to monitor all system APIs, the developer should create a dedicated endpoint that responds with the API status and reachability of the underlying systems. This way, the DevOps team can check if the system API is ready to receive requests and if it can communicate with its backend systems without errors. Reference: https://docs.mulesoft.com/mule-r ... es#readiness-probes
NEW QUESTION # 57
Keeping in view, the time constraints of professionals, our experts have devised Mule-Dev-301 dumps PDF that suits your timetable and meets your exam requirements adequately. It is immensely helpful in enhancing your professional skills and expanding your exposure within a few-day times. This Salesforce MuleSoft brain dumps exam testing tool introduces you not only with the actual exam paper formation but also allows you to master various significant segments of the Mule-Dev-301 syllabus.
Valid Study Mule-Dev-301 Questions: https://www.examdiscuss.com/Salesforce/exam/Mule-Dev-301/
And Mule-Dev-301 simulating questions are carefully arranged with high efficiency and high quality, We suggest all candidates purchase Mule-Dev-301 exam braindumps via Credit Card with credit card, While the PC test engine and Online test engine of Mule-Dev-301 exam preparation all can simulate the actual test which bring you to experience the real test environment in advance, Salesforce Reliable Mule-Dev-301 Braindumps Book Self-contained model testing system.
The original version of Keynote for iPad wasn't especially great at importing tables, Does this scenario excite or scare you, And Mule-Dev-301 simulating questions are carefully arranged with high efficiency and high quality.
Free PDF Quiz 2026 Mule-Dev-301: Perfect Reliable Salesforce Certified MuleSoft Developer II Braindumps BookWe suggest all candidates purchase Mule-Dev-301 exam braindumps via Credit Card with credit card, While the PC test engine and Online test engine of Mule-Dev-301 exam preparation all can simulate the actual test which bring you to experience the real test environment in advance.
Self-contained model testing system, Please trust our Mule-Dev-301: Salesforce Certified MuleSoft Developer II test questions.
Posted at 2/6/2026 18:23:16        Only Author  2#
ITI¤ƤԤITJԇYYҪԤ褯֪äƤƤǤ礦ITJԇYˤ϶यηNޤF˚ݤԇY⤤ޤ300-425JԇYʤɤǤФԇYɤYޤ⤷һĤJ^Y֤äƤʤʤ顢ITJԇYꤷzԇYYȡäҪޤԇYܤ趨СTech4ExamƱҪҊĤޤ礦Tech4ExamϤʤ300-425JԇY˺ϸ񤹤뱣ϤǤ顣
Posted at 2/16/2026 17:52:28        Only Author  3#
ɹǤ ĿǤ uƷxkƤ g줿Revenue-Cloud-Consultant-Accredited-ProfessionalģMԇY̲Ĥṩ褦Ƥ򾡤Ƥޤ uƷxkϤϡԇYYЄJYȡäSalesforce Revenue-Cloud-Consultant-Accredited-ProfessionalģMԇY̲ĤǴ󤭤ʥåȤä뤳ȤǤޤ mФʥݥˏļϡSalesforce Revenue Cloud Consultant Accredited Professionalޤ СRevenue-Cloud-Consultant-Accredited-ProfessionalģMƥȥեʹäơ¤һi̤߳δgFƤ
