312-97 Reliable Dumps Free - Reliable 312-97 Exam Test
Posted at 1/23/2026 06:40:31
Although a lot of products are cheap, but the quality is poor, perhaps users have the same concern for our 312-97 learning materials. Here, we solemnly promise to users that our product error rate is zero. Everything that appears in our products has been inspected by experts. In our 312-97 learning material, users will not even find a small error, such as spelling errors or grammatical errors. It is believed that no one is willing to buy defective products, so, the 312-97 study materials have established a strict quality control system.
Many don't find real 312-97 exam questions and face loss of money and time. Real4exams made an absolute gem of study material which carries actual ECCouncil 312-97 Exam Questions for the students so that they don't get confused in order to prepare for ECCouncil 312-97 Exam and pass it with a good score. The ECCouncil 312-97 practice test questions are made by examination after consulting with a lot of professionals and receiving positive feedback from them.
Reliable 312-97 Exam Test, Reliable 312-97 Exam QuestionsIf you are preparing for an exam, it may spend lots of time, but don't worry, if you are preparing for the 312-97 exam, the product of our company will help you save your time. The product of our company will list the major key points of the 312-97 exam, and you can grasp the knowledge points as quickly as possible, therefore the time is saving. Besides, the product for 312-97 Exam also provide specific training materials for the exam. And the PDF version is convenient to read, and sopport printing, while the software version stimulate the real environment of the 312-97 exam. The APP online version is slao available of the product, you can learn at any time and at any place. Choosing our product, it wil help you.
ECCouncil EC-Council Certified DevSecOps Engineer (ECDE) Sample Questions (Q100-Q105):NEW QUESTION # 100
(Curtis Morgan has been working as a software developer in an MNC company. His team has developed a NodeJS application. While doing peer review of the NodeJS application, he observed that there are insecure libraries in the application. Therefore, he approached, Teresa Lisbon, who is working as a DevSecOps engineer, to detect the insecure libraries in the NodeJS application. Teresa used a SCA tool to find known vulnerabilities in JavaScript libraries for Node.JS applications and detected all the insecure libraries in the application. Which of the following tools did Teresa use for detecting insecure libraries in the NodeJS application?)
- A. Bundler-Audit.
- B. Tenable.io.
- C. Retire.js.
- D. Bandit.
Retire.js is a Software Composition Analysis (SCA) tool designed specifically to identify known vulnerabilities in JavaScript libraries used in web and NodeJS applications. It scans dependencies and compares detected versions against a vulnerability database to identify insecure libraries. Bandit is a static analysis tool for Python, Bundler-Audit is used for Ruby dependencies, and Tenable.io focuses on infrastructure and vulnerability management rather than JavaScript libraries. Using Retire.js during the Code stage allows DevSecOps teams to identify insecure third-party dependencies early, reducing the likelihood of vulnerable libraries being deployed into production. This supports shift-left security and strengthens the application's overall security posture.
NEW QUESTION # 101
(William O'Neil has been working as a senior DevSecOps engineer in an IT company that develops software products related to ecommerce. At this point in time, his team is working on securing a python-based application. Using GitGraber, William would like to detect sensitive information in real-time in his organizational GitHub repository. Therefore, he downloaded GitGraber and installed the dependencies. Which of the following commands should William use to find secrets using a keyword (assume the keyword is yahoo)?.)
- A. python3 gitGraber.py -g wordlist/keywordsfile.txt -q "yahoo" -s.
- B. python3 gitGraber.py -p wordlist/keywordsfile.txt -q "yahoo" -s.
- C. python3 gitGraber.py -k wordlist/keywordsfile.txt -q "yahoo" -s.
- D. python3 gitGraber.py -w wordlist/keywordsfile.txt -q "yahoo" -s.
GitGraber uses specific command-line flags to define how secret detection is performed. The -k flag is used to specify akeyword filethat contains search terms for identifying sensitive data in repositories. In this case, William wants to search for secrets using the keyword "yahoo," which is passed using the -q flag. Options -w,
-g, and -p are not valid flags for keyword-based scanning in GitGraber. By using -k, GitGraber scans repositories for matches against the defined keywords and reports potential secret exposures in real time. This capability is especially valuable during the Code stage, helping teams prevent credential leakage and maintain secure repositories.
NEW QUESTION # 102
(Jeremy Renner has been working as a senior DevSecOps engineer at an IT company that develops customized software to various customers stretched across the globe. His organization is using Microsoft Azure DevOps Services. Using an IaC tool, Jeremey deployed the infrastructure in Azure. He would like to integrate Chef InSpec with Azure to ensure that the deployed infrastructure is in accordance with the architecture and industrial standards and the security policies are appropriately implemented. Therefore, he downloaded and installed Chef InSpec. He used Azure CLI command for creating an Azure Service Principal with reader permission to the Azure resources, then he exported the generated credentials. After installation and configuration of Chef InSpec, he would like to create the structure and profile. Which of the following commands should Jeremy use to create a new folder jyren-azureTests with all the required artifacts for InSpec tests?)
- A. inspec init prof jyren-azureTests.
- B. chef inspec init profile jyren-azureTests.
- C. chef inspec init profile jyren-azureTests.
- D. inspec init profile jyren-azureTests.
Chef InSpec provides a command-line interface for creating and executing compliance profiles. To initialize a new profile with the required directory structure, metadata file, and example controls, the correct command is inspec init profile <profile-name>. In Jeremy's case, running inspec init profile jyren-azureTests creates a new folder with all required artifacts needed to write and run Azure compliance tests. Options using prof are invalid abbreviations, and prefixing the command with chef is incorrect when using the InSpec CLI directly.
Creating a structured InSpec profile during the Build and Test stage enables automated validation of infrastructure against architectural standards and security policies, supporting Infrastructure as Code security and continuous compliance practices.
NEW QUESTION # 103
(Steven Gerrard has been working as a DevSecOps engineer at an IT company that develops software products and applications related to the healthcare industry. His organization has been using Azure DevOps services to securely and quickly develop software products. To ensure that the deployed infrastructure is in accordance with the architecture and industrial standards and the security policies are appropriately implemented, she would like to integrate InSpec with Azure. Therefore, after installation and configuration of InSpec, she created InSpec profile file and upgraded it with personal metadata and Azure resource pack information; then she wrote the InSpec tests. Which of the following commands should Steven use to run InSpec tests to check the compliance of Azure infrastructure?)
- A. inspec exe inspec-tests/integration/ -it azure://.
- B. inspec exec inspec-tests/integration/ -t azure://.
- C. inspec exec inspec-tests/integration/ -it azure://.
- D. inspec exe inspec-tests/integration/ -t azure://.
Chef InSpec executes compliance tests using the inspec exec command. When testing Azure infrastructure, InSpec requires a target specification using the -t flag with the Azure transport identifier azure://. The correct command is inspec exec inspec-tests/integration/ -t azure://. Options using exe instead of exec are invalid due to incorrect command spelling. Options that use the -it flag misuse command-line parameters that are not intended for target selection. Running InSpec tests in this way allows DevSecOps teams to validate that Azure resources comply with architectural, security, and regulatory requirements. Integrating these checks into the Build and Test stage ensures continuous compliance and reduces the risk of insecure infrastructure reaching production environments.
NEW QUESTION # 104
(Rahul Mehta is working as a DevSecOps engineer in an IT company that develops cloud-native web applications. His organization follows a strict DevSecOps practice and wants to ensure that third-party open- source dependencies used in the application do not introduce known security vulnerabilities. Rahul decided to integrate a Software Composition Analysis (SCA) tool into the CI pipeline so that every build is automatically scanned. During one of the builds, the SCA tool detects a critical vulnerability in a transitive dependency.
What should ideally happen in a mature DevSecOps pipeline when such a critical vulnerability is detected at build time?.)
- A. The pipeline should fail the build and prevent the artifact from progressing further.
- B. The pipeline should notify the security team and continue with deploy-time checks.
- C. The pipeline should ignore transitive dependencies and only scan direct dependencies.
- D. The pipeline should log the vulnerability details and continue the build to avoid delivery delays.
In a mature DevSecOps pipeline, security controls are enforced asgates, not merely as informational checks.
When an SCA tool detects acritical vulnerabilityin a dependency-whether direct or transitive-the correct response at the Build and Test stage is tofail the build. This prevents vulnerable artifacts from moving forward into later stages such as deployment or production, where remediation would be more expensive and risky. Allowing the build to continue, even with notifications, contradicts the shift-left security principle.
Ignoring transitive dependencies is also dangerous, as many real-world vulnerabilities originate from indirect libraries. Failing the build forces developers to remediate the issue immediately by upgrading, replacing, or mitigating the vulnerable dependency. This approach reduces attack surface, enforces accountability, and ensures that only secure artifacts are released. Therefore, stopping the pipeline upon detection of critical vulnerabilities reflects a strong DevSecOps maturity model and effective security governance.
NEW QUESTION # 105
We know students run on low budgets so we made every possible effort to reduce the pre-purchase doubts. You can easily avail of our product at an affordable price. We are aware that the syllabus of 312-97 exam is extremely dynamic and changes with incoming updates, so we also offer you updates for free after purchase for 1 year. We assure you in every possible way that our ECCouncil 312-97 Exam Preparation material is the most reliable there is.
Reliable 312-97 Exam Test: https://www.real4exams.com/312-97_braindumps.html
Therefore, you can have 100% confidence in our 312-97 exam guide, Now as you have the best test study material from Real4exams Reliable 312-97 Exam Test, you must start with the process of learning, ECCouncil 312-97 Reliable Dumps Free some are paid while others are free, We have online and offline chat service stuff, they possess professional knowledge for 312-97 training materials, if you have any questions, just contact us, ECCouncil 312-97 Reliable Dumps Free In the information era, IT industry is catching more and more attention.
For Adobe Flex Beginners, Creating New Workflows, Therefore, you can have 100% confidence in our 312-97 Exam Guide, Now as you have the best test study material from Real4exams, you must start with the process of learning.
Real ECCouncil 312-97 Dumps Attempt the Exam in the Optimal Waysome are paid while others are free, We have online and offline chat service stuff, they possess professional knowledge for 312-97 training materials, if you have any questions, just contact us.
- Test 312-97 Simulator Free 🐎 312-97 Latest Test Preparation 💸 312-97 Latest Test Simulator 🎼 Search for 「 312-97 」 and download it for free on 【 [url]www.troytecdumps.com 】 website 💚High 312-97 Passing Score[/url]
- Quiz ECCouncil - 312-97 - EC-Council Certified DevSecOps Engineer (ECDE) Latest Reliable Dumps Free 🚺 Easily obtain free download of ⏩ 312-97 ⏪ by searching on ➠ [url]www.pdfvce.com 🠰 🤠Latest 312-97 Exam Duration[/url]
- 100% Pass Quiz ECCouncil - 312-97 –Efficient Reliable Dumps Free ➡️ Easily obtain free download of ✔ 312-97 ️✔️ by searching on ⮆ [url]www.vce4dumps.com ⮄ 🧅Valid 312-97 Exam Pass4sure[/url]
- 312-97 Valid Guide Files 🚧 Latest 312-97 Study Guide 🎹 312-97 Reliable Test Sims 😧 Enter “ [url]www.pdfvce.com ” and search for ⮆ 312-97 ⮄ to download for free 👗Test 312-97 Simulator Free[/url]
- 100% Pass Quiz ECCouncil - 312-97 –Efficient Reliable Dumps Free 🕙 The page for free download of [ 312-97 ] on ➥ [url]www.pdfdumps.com 🡄 will open immediately 🥳Latest 312-97 Study Guide[/url]
- Top 312-97 Reliable Dumps Free | Amazing Pass Rate For 312-97: EC-Council Certified DevSecOps Engineer (ECDE) | Free Download Reliable 312-97 Exam Test ⏺ Search for ▛ 312-97 ▟ and download it for free immediately on [ [url]www.pdfvce.com ] 👝312-97 Valid Test Notes[/url]
- Realistic ECCouncil 312-97 Reliable Dumps Free Free PDF 🌌 Immediately open ▛ [url]www.troytecdumps.com ▟ and search for ▛ 312-97 ▟ to obtain a free download 📑Test 312-97 Simulator Free[/url]
- [url=http://tinhatranch.com/?s=Quiz%20ECCouncil%20-%20312-97%20-%20EC-Council%20Certified%20DevSecOps%20Engineer%20(ECDE)%20Latest%20Reliable%20Dumps%20Free%20%e2%8f%aa%20Easily%20obtain%20%e2%9e%a4%20312-97%20%e2%ae%98%20for%20free%20download%20through%20[%20www.pdfvce.com%20]%20%f0%9f%93%b8312-97%20Valid%20Test%20Notes]Quiz ECCouncil - 312-97 - EC-Council Certified DevSecOps Engineer (ECDE) Latest Reliable Dumps Free ⏪ Easily obtain ➤ 312-97 ⮘ for free download through [ www.pdfvce.com ] 📸312-97 Valid Test Notes[/url]
- Top 312-97 Reliable Dumps Free | Amazing Pass Rate For 312-97: EC-Council Certified DevSecOps Engineer (ECDE) | Free Download Reliable 312-97 Exam Test 🍍 Search for ⮆ 312-97 ⮄ and download it for free on ▷ [url]www.exam4labs.com ◁ website 😭Test 312-97 Simulator Free[/url]
- Exam 312-97 Papers 🔎 Reliable 312-97 Learning Materials 🎎 Latest 312-97 Exam Duration 😦 The page for free download of ☀ 312-97 ️☀️ on ➽ [url]www.pdfvce.com 🢪 will open immediately 🔆312-97 Reliable Test Sims[/url]
- 312-97 Latest Test Simulator 🔂 Test 312-97 Simulator Free 🚃 Exam 312-97 Papers 📪 Search on { [url]www.vceengine.com } for ➥ 312-97 🡄 to obtain exam materials for free download 😳312-97 Certification Book Torrent[/url]
- lms.anatoliaec.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, training.michalialtd.com, Disposable vapes
