[General] Latest F5CAB3 Exam Test - Most F5CAB3 Reliable Questions
93
【General】 Latest F5CAB3 Exam Test - Most F5CAB3 Reliable Questions
Posted at 1/23/2026 06:51:31      View:123 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4SureReview F5CAB3 dumps for free: https://drive.google.com/open?id=1XKIwJJk32aoCh6LujV_pzDJ_Lo8zFHzX
Many candidates said that they failed once, now try the second time but they still have no confidence, they want to know if our F5CAB3 braindumps PDF materials can help them clear exam 100%. We say "Yes, 100% passing rate for most exams". They would like to purchase F5CAB3 Braindumps Pdf materials since they understand the test cost is quite expensive and passing exam is not really easy. Why not choose F5CAB3 braindumps PDF materials at the beginning?
Our Prep4SureReview's F5CAB3 exam dumps and answers are researched by experienced IT team experts. These F5CAB3 test training materials are the most accurate in current market. You can download F5CAB3 free demo on Prep4SureReview.COM, it will be a good helper to help you pass F5CAB3 certification exam.
Most F5CAB3 Reliable Questions - Reliable F5CAB3 Test BootcampA calm judgment is worth more than a thousand hasty discussions. I know that when you choose which ourF5CAB3 exam materials to buy, it will be very tangled up. This is a responsible performance for you. But you can't casually make a choice because of tangle. And our F5CAB3 Study Materials won't let you regret. You can just free download the demos of the F5CAB3 practice guide to have a check our quality.
F5 BIG-IP Administration Data Plane Configuration Sample Questions (Q23-Q28):NEW QUESTION # 23
Users are unable to reach an application. The Virtual Server shows a red diamond status.
What is the cause?
  • A. Pool members disabled
  • B. All pool members are down
  • C. HTTPS traffic sent to HTTP VS
  • D. Virtual Server disabled
A red diamond indicates that the Virtual Server is enabled but unavailable, typically due to all pool members being down.
NEW QUESTION # 24
The BIG-IP Administrator has to provide encrypted communication between users and the virtual server they access. Multiple hostnames are configured in DNS with the same IP address.
Which profile type and setting in the profile should be used? (Choose one answer)
  • A. Server SSL, Client Name
  • B. Client SSL, Client Name
  • C. Server SSL, Server Name
  • D. Client SSL, Server Name
When multiple hostnames resolve to the same IP address and encrypted communication is required, the BIG-IP must be able to present the correct SSL certificate based on the hostname requested by the client. This is accomplished using Server Name Indication (SNI).
According to BIG-IP Administration: Data Plane Configuration documentation:
SNI is a client-side TLS extension, where the client includes the requested hostname during the SSL handshake.
BIG-IP evaluates this hostname using the Client SSL profile, not the Server SSL profile.
The "Server Name" setting in the Client SSL profile enables BIG-IP to select the appropriate SSL certificate for the requested hostname.
Why option C is correct:
Client SSL profile handles inbound (client-side) encryption.
Server Name enables SNI-based certificate selection when multiple DNS names share the same virtual server IP.
A . Client SSL, Client Name
There is no Client SSL setting called Client Name for SNI certificate selection.
B . Server SSL, Server Name
Server SSL is used for encryption between BIG-IP and backend servers, not for client-side hostname identification.
D . Server SSL, Client Name
Server SSL does not process client-requested hostnames during TLS negotiation.
Correct Resolution:
Configure a Client SSL profile and enable the Server Name (SNI) setting to support multiple encrypted hostnames on the same virtual server IP.
NEW QUESTION # 25
What is the status of a pool member when manual resume is enabled and a health check first fails and then passes?
  • A. Available (Disabled)
  • B. Offline (Enabled)
  • C. Available (Enabled)
  • D. Offline (Disabled)
With manual resume enabled, BIG-IP does not automatically return a pool member to service after recovery. The member remains offline until manually re-enabled.
NEW QUESTION # 26
A BIG-IP Administrator configures an SSH pool with five members.
Which health monitor should be applied?
  • A. TCP
  • B. HTTP
  • C. HTTPS
  • D. UDP
SSH is a TCP-based service. A TCP monitor validates service availability without requiring application-layer inspection.
NEW QUESTION # 27
In a pool there are 2 pool members out of the 5 members that are older servers. The number of connections these can handle is less than the other 3 pool members. Which load balancing method would allow more traffic to be directed to the newer servers? (Choose one answer)
  • A. Least Connections (member)
  • B. Round Robin
  • C. Weighted Least Connections (member)
  • D. Global Availability
When a pool contains servers with heterogeneous hardware capabilities (differing CPU, RAM, or connection limits), a static load balancing method like Round Robin is ineffective because it distributes requests equally, regardless of the server's capacity. To optimize traffic distribution for newer, more powerful servers, a dynamic or weighted method is required.
* Weighted Least Connections (member): This is the ideal method for this scenario. It combines two factors:
* Least Connections: It first checks the current active connection count to ensure traffic goes to the least busy server.
* Weight (Ratio): It allows the administrator to assign a "Ratio" value to each pool member. Newer servers can be assigned a higher ratio (e.g., 3) while older servers are assigned a lower ratio (e.g.,
1). The BIG-IP system uses these weights to disproportionately favor the newer servers even when connection counts are similar.
* Why other options are incorrect:
* Global Availability: This is primarily a GSLB (Global Server Load Balancing) or specific LTM priority group concept where traffic is sent to the first available member in a list until it fails, then moves to the next. It does not load balance based on capacity.
* Round Robin: This passes each new connection request to the next server in line, treating the old and new servers exactly the same.
* Least Connections (member): While this sends traffic to the server with the fewest active connections, it assumes all servers are equal. If an old server and a new server both have 10 connections, they are treated as equally capable of taking the 11th, which is not true in this scenario.
NEW QUESTION # 28
Our accurate, reliable, and top-ranked BIG-IP Administration Data Plane Configuration (F5CAB3) exam questions will help you qualify for your F5 F5CAB3 certification on the first try. Do not hesitate and check out Prep4SureReview excellent BIG-IP Administration Data Plane Configuration (F5CAB3) practice exam to stand out from the rest of the others.
Most F5CAB3 Reliable Questions: https://www.prep4surereview.com/F5CAB3-latest-braindumps.html
Using F5CAB3 practice engine may be the most important step for you to improve your strength, Our F5CAB3 exam questions are applicable for everyone in all walks of life which is not depends on your educated level, F5 Latest F5CAB3 Exam Test That is why we can survive in the market, And the price higher than F5CAB3 test torrent: BIG-IP Administration Data Plane Configuration may do not have same high quality as well as the economic price, F5 Latest F5CAB3 Exam Test The better life is easy to create along with the improvement of your personal ability.
How to solve this problem is your new trouble, On the properties page of a distributed switch, check the Enable Network Resource Pools box, Using F5CAB3 Practice Engine may be the most important step for you to improve your strength.
100% Pass Quiz F5 Marvelous F5CAB3 - Latest BIG-IP Administration Data Plane Configuration Exam TestOur F5CAB3 exam questions are applicable for everyone in all walks of life which is not depends on your educated level, That is why we can survive in the market.
And the price higher than F5CAB3 test torrent: BIG-IP Administration Data Plane Configuration may do not have same high quality as well as the economic price, The better life is easy to create along with the improvement of your personal ability.
DOWNLOAD the newest Prep4SureReview F5CAB3 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1XKIwJJk32aoCh6LujV_pzDJ_Lo8zFHzX
