Cisco Penetration testers simulate 350-701 Exam Questions And Answers
Posted at 1/23/2026 07:27:11
View216
Replies2
P.S. Free & New 350-701 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1AG601kMqRDqiB0H7xP93C07TnVZijuAn
In fact, a number of qualifying exams and qualifications will improve your confidence and sense of accomplishment to some extent, so our 350-701 learning materials can be your new target. When we get into the job, our 350-701 learning materials may bring you a bright career prospect. Companies need employees who can create more value for the company, but your ability to work directly proves your value. Our 350-701 Learning Materials can help you improve your ability to work in the shortest amount of time, thereby surpassing other colleagues in your company, for more promotion opportunities and space for development.
Cisco 350-701 exam is an essential certification for security professionals who work with Cisco technologies. 350-701 exam validates the knowledge and skills required to implement and operate core security technologies and helps professionals enhance their skills and knowledge to effectively manage complex security solutions. 350-701 Exam is also a great way to demonstrate your expertise in security technologies to potential employers and clients, making it a valuable asset for anyone looking to advance their career in the field of cybersecurity.
Valid Braindumps 350-701 Files - Exam 350-701 OutlineIn order to survive better in society, we must understand the requirements of society for us. In addition to theoretical knowledge, we need more practical skills. After we use 350-701 practice guide, we can get the certification faster, which will greatly improve our competitiveness. Of course, your gain is definitely not just the 350-701 certificate. Our 350-701 study materials will change your working style and lifestyle. You will work more efficiently than others. Our 350-701 training materials can play such a big role.
Cisco Implementing and Operating Cisco Security Core Technologies Sample Questions (Q377-Q382):NEW QUESTION # 377
In which situation should an Endpoint Detection and Response solution be chosen versus an Endpoint Protection Platform?
- A. when there is no need to have the solution centrally managed
- B. when there is a need to have more advanced detection capabilities
- C. when there is a need for traditional anti-malware detection
- D. when there is no firewall on the network
NEW QUESTION # 378
A network engineer is tasked with configuring a Cisco ISE server to implement external authentication against Active Directory. What must be considered about the authentication requirements? (Choose two.)
- A. Active Directory supports user and machine authentication by using MSCHAPv2.
- B. The ISE account must be a domain administrator in Active Directory to perform JOIN operations.
- C. Active Directory only supports user authentication by using MSCHAPv2.
- D. LDAP communication must be permitted between the ISE server and the domain controller.
- E. RADIUS communication must be permitted between the ISE server and the domain controller.
Answer: D,E
To implement external authentication against Active Directory, the Cisco ISE server needs to communicate with the domain controller using either RADIUS or LDAP protocols. RADIUS is used for network access control, while LDAP is used for identity management and directory services. Both protocols require the appropriate ports to be opened and firewall rules to be configured to allow the traffic between the ISE server and the domain controller.
The ISE account does not need to be a domain administrator in Active Directory to perform JOIN operations.
It only needs to have the permissions to create computer objects and reset passwords in the domain. This can be achieved by delegating the rights to a specific OU or using a service account with limited privileges.
Active Directory supports user and machine authentication by using various methods, not only MSCHAPv2.
MSCHAPv2 is a challenge-response authentication protocol that is commonly used with RADIUS and VPN connections. However, Active Directory also supports other protocols such as Kerberos, NTLM, EAP, and PEAP, depending on the scenario and the client capabilities.
Implementing and Operating Cisco Security Core Technologies (SCOR) v1.0 Cisco ISE Integration with Microsoft Active Directory RADIUS vs. LDAP: What's the Difference?
MS-CHAP v2 Authentication
NEW QUESTION # 379
An organization received a large amount of SPAM messages over a short time period. In order to take action on the messages, it must be determined how harmful the messages are and this needs to happen dynamically.
What must be configured to accomplish this?
- A. Configure the Cisco WSA to receive real-time updates from Talos
- B. Configure the Cisco ESA to modify policies based on the traffic seen
- C. Configure the Cisco WSA to modify policies based on the traffic seen
- D. Configure the Cisco ESA to receive real-time updates from Talos
The Mail Policies menu is where almost all of the controls related to email filtering happens. All the security and content filtering policies are set here, so it's likely that, as an ESA administrator, the pages on this menu are where you are likely to spend most of your time.
NEW QUESTION # 380
Which solution detects threats across a private network, public clouds, and encrypted traffic?
- A. Cisco Encrypted Traffic Analytics
- B. Cisco Stealthwatch
- C. Cisco Umbrella
- D. Cisco CTA
NEW QUESTION # 381
An organization wants to reduce their attach surface for cloud applications. They want to understand application communications, detect abnormal application Behavior, and detect vulnerabilities within the applications. Which action accomplishes this task?
- A. Implement Cisco Umbrella lo control the access each application is granted.
- B. Configure Cisco Secure Workload to detect anomalies and vulnerabilities.
- C. Modify the Cisco Duo configuration to restrict access between applications.
- D. Use Cisco ISE to provide application visibility and restrict access to them.
Cisco Secure Workload (formerly Tetration) is a solution that provides visibility, segmentation, and security for cloud applications. It can monitor application communications, detect abnormal application behavior, and identify vulnerabilities within the applications. Cisco Secure Workload can also enforce granular policies to control the traffic between applications and prevent unauthorized access. References: Implementing and Operating Cisco Security Core Technologies (SCOR) v1.0, Module 6: Cloud and Content Security, Lesson
6.2: Cisco Cloud Security Solutions, Topic 6.2.2: Cisco Secure Workload
NEW QUESTION # 382
After you purchase 350-701 exam questions, you should always pay attention to your email address. Once there is a new version, we will send updated information to your email address. As we all know, the authority of a product matches its hit rate. How high the authority of 350-701 Real Exam is, I don't need to say any more. You just know what you will know. You can't really find a product that has a higher hit rate than our 350-701 study materials!
Valid Braindumps 350-701 Files: https://www.prepawaytest.com/Cisco/350-701-practice-exam-dumps.html
- 350-701 Dump 🥙 350-701 Exam Demo 🦹 350-701 Reliable Exam Cram 🥍 Open website [url]www.vce4dumps.com and search for ⮆ 350-701 ⮄ for free download 🛸350-701 Pass Rate[/url]
- Pass Guaranteed Updated Cisco - 350-701 - Implementing and Operating Cisco Security Core Technologies Exam Questions And Answers 🍝 Enter ▛ [url]www.pdfvce.com ▟ and search for 350-701 to download for free ⬇Certification 350-701 Questions[/url]
- Pass Guaranteed Updated Cisco - 350-701 - Implementing and Operating Cisco Security Core Technologies Exam Questions And Answers 👊 Download 350-701 for free by simply entering ➤ [url]www.troytecdumps.com ⮘ website 🍧Valid 350-701 Test Pass4sure[/url]
- Practice 350-701 Questions 🕚 350-701 Related Content 😊 Premium 350-701 Files 📜 Immediately open ⏩ [url]www.pdfvce.com ⏪ and search for { 350-701 } to obtain a free download ➿350-701 Pdf Pass Leader[/url]
- 350-701 Related Content 🔄 350-701 Dump 🏢 350-701 Latest Exam Labs 🛥 Go to website [url]www.troytecdumps.com open and search for 350-701 to download for free 🔲350-701 Related Content[/url]
- Practice 350-701 Questions 🐽 350-701 Pass Rate 💏 350-701 Reliable Test Test 📢 Open [ [url]www.pdfvce.com ] and search for 350-701 to download exam materials for free 🔅350-701 Dump[/url]
- Pass Guaranteed Newest Cisco - 350-701 - Implementing and Operating Cisco Security Core Technologies Exam Questions And Answers 📻 Open ✔ [url]www.vce4dumps.com ️✔️ enter ✔ 350-701 ️✔️ and obtain a free download 🎴350-701 Certification Exam Infor[/url]
- Premium 350-701 Files 🤷 350-701 Exam Objectives Pdf 👙 350-701 Related Content ❗ Search for 350-701 on ▶ [url]www.pdfvce.com ◀ immediately to obtain a free download 🎹350-701 Reliable Exam Cram[/url]
- Pass Guaranteed Newest Cisco - 350-701 - Implementing and Operating Cisco Security Core Technologies Exam Questions And Answers 🪒 Simply search for 350-701 for free download on ➽ [url]www.validtorrent.com 🢪 🙌350-701 Pass Rate[/url]
- Valid 350-701 Test Pass4sure 🟡 350-701 Valid Test Blueprint 👺 350-701 Pass Rate 🔀 Go to website [url]www.pdfvce.com open and search for ➤ 350-701 ⮘ to download for free 😳350-701 Pass Rate[/url]
- 350-701 Latest Exam Labs 😥 350-701 Exam Objectives Pdf 🥼 New 350-701 Braindumps Questions ☮ The page for free download of ➥ 350-701 🡄 on ⏩ [url]www.practicevce.com ⏪ will open immediately 🚥350-701 Reliable Test Test[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, associates.gmdf.or.tz, lokeshyogi.com, Disposable vapes
What's more, part of that PrepAwayTest 350-701 dumps now are free: https://drive.google.com/open?id=1AG601kMqRDqiB0H7xP93C07TnVZijuAn
