Oracle 1z1-076 Pass-Sure Valid Test Pass4sure
Posted at 1/23/2026 08:28:21
View226
Replies2
BONUS!!! Download part of BraindumpsPrep 1z1-076 dumps for free: https://drive.google.com/open?id=1fLAYgc0PXtFki_BAOnHNdSCjDiksyWLg
you can stand out in your work and impressed others with professional background certified by 1z1-076exam and feel self-fulfillment, get sense of satisfaction in personal perspective, and have stand a better chance of getting better working condition with the 1z1-076 Certification. Therefore, our affordable 1z1-076 study guide will definitely be gainful opportunity. Come and buy our 1z1-076 exam materials, and you will be grateful for your wise decision.
Most IT workers prefer to choose our online test engine for their 1z1-076 exam prep because online version is more flexible and convenient. With the help of our online version, you can not only practice our 1z1-076 Exam PDF in any electronic equipment, but also make you feel the atmosphere of 1z1-076 actual test. The exam simulation will mark your mistakes and help you play well in 1z1-076 practice test.
Oracle 1z1-076 Updated Testkings | Training 1z1-076 ToolsIt is common in modern society that many people who are more knowledgeable and capable than others finally lost some good opportunities for development because they didnt obtain the 1z1-076 Certification. The prerequisite for obtaining the 1z1-076 certification is to pass the exam, but not everyone has the ability to pass it at one time. Because of not having appropriate review methods and review materials, or not grasping the rule of the questions, so many candidates eventually failed to pass even if they have devoted much effort.
Oracle Database 19c: Data Guard Administration Sample Questions (Q91-Q96):NEW QUESTION # 91
In Oracle Database 19c, you can set the value of database initialization parameters in a database using the EDIT DATABASE... SET PARAMETER Command:
DGMGRL> EDIT DATABASE 'boston' SET PARAMETER log_archive_trace - 1;
Which THREE statements are TRUE about the command?
- A. The value set using this command is directly stored in the broker configuration file.
- B. The database must be available when the above command is run.
- C. The EDIT DATABASE PARAMETER command can be used to set the value of a static parameter in a database.
- D. The value set using this command is directly applied to the boston database.
- E. The edit database parameter command can only be used to modify the value of a dynamic parameter in a database.
Answer: B,D,E
The EDIT DATABASE...SET PARAMETER command in Data Guard Management (DGMGRL) is used to modify the value of initialization parameters for a database within a Data Guard configuration. This command can be used to modify both static and dynamic parameters, but if a static parameter is changed, the new value will take effect only after the database is restarted. The database must be up and running for the command to execute, and the values set using the command are directly applied to the specified database (in this case,
'boston') .
NEW QUESTION # 92
You must configure flashback database for your Oracle 19c databases that will be part of a Data Guard Broker configuration.
The databases are all in ARCHIVELOG mode.
You will execute the SQL statement:
ALTER DATABASE FLASHBACK ON;
Which three are true concerning this command?
- A. It will execute successfully while an Oracle 19c primary database is mounted.
- B. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all physical standby databases that are part of the configuration.
- C. It will execute successfully on an Oracle 19c physical standby database while Real Time Query is active.
- D. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all logical standby databases that are part of the configuration.
- E. It will execute successfully while an Oracle 19c primary database is open.
- F. It will execute successfully on an Oracle 19c logical standby database while SQL apply is active.
Answer: A,E,F
The command ALTER DATABASE FLASHBACK ON; enables the Flashback Database feature, which provides a way to quickly revert an entire Oracle database back to a previous point in time. This command can be executed while an Oracle 19c primary database is either open (option A) or mounted (option B). It is also applicable to an Oracle 19c logical standby database while SQL Apply is active (option E). However, it's important to note that enabling Flashback Database on the primary does not automatically enable it on all associated standby databases, whether they are physical or logical. Each database in a Data Guard configuration must have Flashback Database explicitly enabled if desired. Real Time Query being active on a physical standby does not directly relate to the ability to execute this command on the standby. Reference: The explanation is based on Oracle's concepts for Flashback Technology and Data Guard configurations as detailed in the Oracle Database Backup and Recovery User's Guide and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 93
Which TWO statements are true about database parameters for databases in a Data Guard environment?
- A. LOG_FILE_NAME_CONVERT applies to online redo logs and archived logs.
- B. If DB_RECOVERY_FILE_DEST is specified, then LOG_ARCHIVE_DEST_n is not required for local archive logs.
- C. COMPATIBLE must have identical values for primary and standby databases.
- D. DB_FILE_NAME_CONVERT is only required if the standby database is on the same host as the primary database.
- E. The databases that are part of a Data Guard configuration must have different DB_UNIQUE_NAME initialization parameters.
Answer: C,E
NEW QUESTION # 94
You are using Data Guard in conjunction with Global Database Services.
You have a Data Guard Broker configuration called Sales and a GDS pool called Prod.
Which three are true concerning the management of the broker configuration when using GDS?
- A. Adding a database to the Sales configuration with DGMGRL automatically adds the database to the Prod Pool.
- B. Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services.
- C. Adding a database to the Sales configuration with DGMGRL requires that the Sales configuration be disabled first. It must then be enabled after the new database is added to the configuration.
- D. DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool.
- E. DGMGRL may be used to add the Sales configuration to the Prod pool in gds.
Answer: B,D,E
In the context of Oracle Data Guard and Global Database Services (GDS):
DGMGRL may be used to add the Sales configuration to the Prod pool in gds (A): Data Guard Broker's command-line interface DGMGRL can be utilized to manage configurations with GDS, allowing the addition of Data Guard Broker configurations to GDS pools.
Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services (B): When a role change is executed using DGMGRL, GDS is automatically notified, and it then activates the services that are appropriate for the new database roles.
DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool (C): DGMGRL provides the capability to manage individual databases within a broker configuration, including adding databases to a configuration that is already part of a GDS pool.
Oracle Data Guard Broker documentation
Oracle Global Data Services documentation
NEW QUESTION # 95
Which two statements are true when using non-rolling release upgrades in a Data Guard environment?
- A. During the upgrade of a logical standby database, standby redo log files must reside on O/S file systems.
- B. Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a physical standby database.
- C. User equivalence must be established for the owner of the Oracle software on the affected hosts prior to the upgrade.
- D. Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a logical standby database.
- E. The compatible parameter on a standby database that is applying redo, must be equal to or greater than the compatible parameter on the primary that is shipping redo to that standby.
Answer: B,E
The compatible parameter on a standby database that is applying redo, must be equal to or greater than the compatible parameter on the primary that is shipping redo to that standby (A): This ensures that the standby database can apply redo from the primary, even after the primary has been upgraded. The COMPATIBLE parameter setting on the standby database should not preclude it from understanding the redo it receives.
Modifications to the data dictionary on the primary database caused by the upgrade, are applied on a physical standby database (C): When the primary database undergoes a non-rolling upgrade, any resulting data dictionary changes are transmitted through redo data and applied to the physical standby database.
Oracle Database Upgrade Guide
Oracle Data Guard Concepts and Administration Guide
NEW QUESTION # 96
We all know that the importance of the Oracle Database 19c: Data Guard Administration (1z1-076) certification exam has increased. Many people remain unsuccessful in its 1z1-076 exam because of using invalid 1z1-076 Practice Test material. If you want to avoid failure and loss of money and time, download actual 1z1-076 Questions of BraindumpsPrep.
1z1-076 Updated Testkings: https://www.briandumpsprep.com/1z1-076-prep-exam-braindumps.html
Our professional experts are working hard to gradually perfect the 1z1-076 dumps torrent in order to give customers the best learning experience, Be alert and use the helping tools for your preparation for the latest 1z1-076 cbt, Oracle Oracle Database 19c: Data Guard Administration exam questions are secured with the 100 Oracle Database 19c: Data Guard Administration 1z1-076 exam passing a money-back guarantee, With the pass rate high as 98% to 100%, you can totally rely on our 1z1-076 exam questions.
To create this new product, Peachpit and Adobe Press have joined forces with 1z1-076 team of outstanding instructors who have a great track record getting students certified: Rob Schwartz and his colleagues at BrainBuffet.com.
Features of BraindumpsPrep Oracle 1z1-076 Web-Based Practice QuestionsWhen a server provides identification as well as requiring Training 1z1-076 Tools client authentication, the authentication is called mutual authentication or two-way authentication, Our professional experts are working hard to gradually perfect the 1z1-076 Dumps Torrent in order to give customers the best learning experience.
Be alert and use the helping tools for your preparation for the latest 1z1-076 cbt, Oracle Oracle Database 19c: Data Guard Administration exam questions are secured with the 100 Oracle Database 19c: Data Guard Administration 1z1-076 exam passing a money-back guarantee.
With the pass rate high as 98% to 100%, you can totally rely on our 1z1-076 exam questions, In a matter of days, if not hours, our clients' purchases are updated 1z1-076 New Question with newly introduced questions within the offer of 90 days of free updates.
- 1z1-076 Free Study Material ℹ 1z1-076 Reliable Test Vce 🔷 1z1-076 Exam Vce Format 🐢 ▷ [url]www.examdiscuss.com ◁ is best website to obtain ➡ 1z1-076 ️⬅️ for free download ⬅️Exam 1z1-076 Introduction[/url]
- 1z1-076 Advanced Testing Engine 🦕 1z1-076 Latest Test Cram ✨ 1z1-076 Advanced Testing Engine 🔅 Open ⮆ [url]www.pdfvce.com ⮄ and search for ➤ 1z1-076 ⮘ to download exam materials for free 🧪
ass Leader 1z1-076 Dumps[/url] - Hot 1z1-076 Valid Test Pass4sure | High Pass-Rate 1z1-076 Updated Testkings: Oracle Database 19c: Data Guard Administration 😢 Immediately open ☀ [url]www.dumpsmaterials.com ️☀️ and search for 1z1-076 to obtain a free download 🏢Valid Dumps 1z1-076 Ppt[/url]
- Features that Make Pdfvce's Oracle 1z1-076 Questions Top Choice for Exam Preparation 🔕 Search for ➠ 1z1-076 🠰 and download it for free on ▶ [url]www.pdfvce.com ◀ website 🌍1z1-076 Exam Quick Prep[/url]
- Latest 1z1-076 Test Simulator 👲 Latest 1z1-076 Exam Vce 🛴 1z1-076 Reliable Test Vce 🕞 The page for free download of ➽ 1z1-076 🢪 on ▛ [url]www.exam4labs.com ▟ will open immediately 🎬1z1-076 New Braindumps[/url]
- 1z1-076 New Real Exam ☘ 1z1-076 Dumps Collection ❗ 1z1-076 Reliable Test Vce 🔦 Search for ⮆ 1z1-076 ⮄ and download exam materials for free through [url]www.pdfvce.com 💇1z1-076 New Real Exam[/url]
- 1z1-076 New Real Exam 📨 Latest 1z1-076 Exam Registration 🥴 1z1-076 Valid Test Sample 🥳 Search for ➽ 1z1-076 🢪 and obtain a free download on ➡ [url]www.practicevce.com ️⬅️ 😚1z1-076 Dumps Collection[/url]
- Latest 1z1-076 Test Simulator 🚕 1z1-076 Exam Vce Format 🥴 1z1-076 New Braindumps 🏯 The page for free download of ➽ 1z1-076 🢪 on ➥ [url]www.pdfvce.com 🡄 will open immediately 🍚Exam 1z1-076 Introduction[/url]
- 1z1-076 Latest Demo 🧰 Valid Dumps 1z1-076 Ppt 🙁 1z1-076 Reliable Test Vce 🎄 Easily obtain free download of ➡ 1z1-076 ️⬅️ by searching on { [url]www.torrentvce.com } 🕙1z1-076 Reliable Test Vce[/url]
- Oracle 1z1-076 Exam Questions-Shortcut To Success 🧃 Go to website ⮆ [url]www.pdfvce.com ⮄ open and search for ⮆ 1z1-076 ⮄ to download for free 🌐Latest 1z1-076 Test Simulator[/url]
- HOT 1z1-076 Valid Test Pass4sure - Oracle Oracle Database 19c: Data Guard Administration - High Pass-Rate 1z1-076 Updated Testkings 🚙 Search for ☀ 1z1-076 ️☀️ and easily obtain a free download on [url]www.pdfdumps.com 🧔1z1-076 Exam Vce Format[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.posteezy.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
P.S. Free & New 1z1-076 dumps are available on Google Drive shared by BraindumpsPrep: https://drive.google.com/open?id=1fLAYgc0PXtFki_BAOnHNdSCjDiksyWLg
