New MB-335 Test Bootcamp & MB-335 Reliable Test Book
Posted at 1/23/2026 08:31:05
P.S. Free & New MB-335 dumps are available on Google Drive shared by ExamDiscuss: https://drive.google.com/open?id=1XAhVM95ln6YcVd1n4R_97VCDwTiBxV4-
You have to know that a choice may affect your very long life. Our MB-335 guide quiz is willing to provide you with a basis for making judgments. You can download the trial version of our MB-335 practice prep first. After using it, you may have a better understanding of some of the advantages of MB-335 Exam Materials. We have three versions of our MB-335 learning quiz: the PDF, Software and APP online for you to choose.
Microsoft MB-335 certification exam is designed for professionals who want to become certified in Dynamics 365 Supply Chain Management Functional Consultant Expert. Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert certification exam covers a wide range of topics related to supply chain management, including inventory management, procurement, quality control, and production control. MB-335 exam is designed to test the candidate's knowledge and skills in these areas and to ensure that they are able to effectively implement and manage supply chain operations using Dynamics 365.
Microsoft MB-335 Exam is an important milestone for professionals seeking to validate their skills in Microsoft Dynamics 365 Supply Chain Management. Passing MB-335 exam will boost the professional credibility and increase earnings. As a result, it is imperative to take the necessary steps to prepare for the test, including studying hard and utilizing resources such as Microsoft's website. The Microsoft MB-335 Exam is an excellent investment for professionals who are looking to take their career to the next level.
MB-335 Reliable Test Book, Exam MB-335 Vce FormatOur Microsoft MB-335 desktop and web-based practice software are embedded with mock exams, just like the actual Microsoft Data Center certification exam. The ExamDiscuss designs its mock papers so smartly that you can easily prepare for the Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert exam. All the essential questions are included, which have a huge chance of appearing in the real Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert exam. Our mock exams may be customized so that you can change the topics and timings for each exam according to your preparation.
Microsoft MB-335 certification exam is designed for professionals who specialize in supply chain management and are looking to enhance their skills and knowledge in the field. MB-335 exam is part of the Microsoft Dynamics 365 certification program and is specifically tailored for functional consultants with expertise in supply chain management. Passing MB-335 Exam validates the skills and knowledge required to perform the job of a functional consultant expert in supply chain management.
Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert Sample Questions (Q97-Q102):NEW QUESTION # 97
A company uses distributed hybrid topology within their Dynamics 365 Supply Chain Management system.
The company plans to build a manufacturing plant on a mountain to be closer to a required mineral source. Internet connectivity is unreliable, and availability of bandwidth speed is limited. The company plans to deploy an operational edge scale unit for the plant to address the connectivity issue.
You need to determine where production operations can be performed.
Which method should you recommend?
To answer, drag the appropriate methods to the correct requirements. Each method may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 98
An electronics manufacturing company is transitioning from infinite capacity planning to finite capacity planning to improve scheduling efficiency and manage resource constraints effectively.
The company observes that its manufacturing process typically requires a minimum lead time of five days.
The company requires finite capacity scheduling to create realistic production schedules that account for resource limitations over a defined minimum lead time of five days.
You need to implement finite capacity planning with a time fence that aligns with the five-day manufacturing lead time.
Solution: Enable finite capacity planning and set the finite capacity time fence for each master plan and resource. Does the solution meet the goal?
NEW QUESTION # 99
A company produces various products using Process manufacturing.
The manufacturer makes two co-products from a formula and rarely produces the primary formula item. The costs of making the co-products are inflated. The manufacturer must update the costs of producing the co-products and change the formula to not produce the primary formula item.
You need to change the primary formula item type.
What should you do?
- A. Change the cost of the primary formula item to zero and then recalculate the item cost.
- B. Change the primary formula item to use the planning item type.
- C. Change the production type to Bill of materials and recalculate the item cost.
- D. Associate the costs to produce by-products with the items.
NEW QUESTION # 100
You need to create the constraint for the ML seat selection.
Which expression constraint should you use?
- A. Implies[Seat==ML,Trim==Legend]
- B. Seat!=ML
- C. Implies[Trim==Legend,Seat==ML]
- D. [Trim==Legend|Seat==ML]
https://docs.microsoft.com/en-us ... -table-constraints- product-configuration-models
Topic 1, CASE STUDY 1 Manufacturing Company
General information
A manufacturing company produces custom configured-to-order motorcycles. The company plans to implement Dynamics 365 Supply Chain Management. The company contains one legal entity located in Missouri where all production and warehousing operations occur.
Customization options
The custom motorcycles have a variety of selections that can be selected in the listed order by the end customer, including the following:
Customization restrictions
The following restrictions on customizations are in place:
* Green color can only be sold with the Legend Trim.
* Orange color can be sold with the Sport or Legend Trim.
* The ML seat must be included in the Legend package.
* The MS seat must be included in the Sport package.
Manufacturing facilities
The company includes the following manufacturing groups: Assembly and Plastic Molding. The Assembly group is responsible for assembling the motorcycles with purchased and manufactured goods. The Plastic Molding group is responsible for manufacture of all plastic parts used in the assembly area.
Motorcycle manufacturing
The parts for the product assembly are picked from the warehouse and staged at the correct workstation by a warehouse operator for each production order.
Plastic manufacturing
Plastic parts are molded using dyes that create multiple parts at once. The parts are machined in the same production process to remove excess plastic and add additional holes for assembly. Excess plastic is recycled back into the feedstock of the same color plastic chips for use in the molding process.
Metal Parts
Raw metal parts are purchased fully machined but without primer or paint. The parts are subcontracted to a vendor for primer and paint based upon the color requirements.
Facility
The company has a single warehouse that supports both the assembly and plastic manufacturing areas. The warehouse consists of three aisles with 15 bins and three shelves. The facility has no Wi-Fi capacity but has hardwired terminal stations throughout the assembly production line.
Transactions are currently completed by office staff. Raw materials transfer must support capacity constraints for paint and primer.
Requirements
Sales Order
The company has the following requirements for sales orders:
* During the configuration of a sales order, invalid combinations must be prevented.
* Each configuration must create a unique bill of material (BOM) and Route based on options selected.
* Sales pricing for the sales order must be based upon options selected.
* Due to emissions regulations, the motorcycles cannot be sold to the state of California.
The company has the following requirements for motorcycle manufacturing:
* Schedule labor only at the labor pool level without machines by day
* Produce motorcycles within a scheduled day in any order.
* Record actual production labor with start/stop times.
* Record manager approval of labor entered prior to posting.
* Post actual material consumption after production is finished.
Plastic manufacture
* Schedule both labor and machines.
* Adjust schedules by using a Gantt chart.
* Backflush standard labor by operation.
* Post actual material consumption at the start of production.
* Track and allocate costs to the excess plastic.
* Report multiple molded part numbers during the same production run.
* Determine the correct mold to use on a production order.
* Generate a batch number for each production order.
Metal Parts
The company has the following requirements for metal parts manufacturing:
* Schedule shipments to the vendor for painting.
* Receive painted parts into inventory from the vendor.
* Track vendor inventory levels.
Default
You must configure defaults for manufacturing execution production orders to meet the following requirements:
* Ensure accuracy for production order pick list posting.
* Ensure correct pick list creation.
Issues
A). In the current system, the company cannot calculate overhead rates and determine the breakdown of material, labor, machine, and overhead costs for production.
B). The company is manually calculating an 8% overhead on materials and posting a journal manually.
NEW QUESTION # 101
A manufacturing company is implementing production in Dynamics 365 Supply Chain Management.
The production scheduler requires that machines not be scheduled to run concurrently when planning production. The scheduler also must be able to see the scheduling in a graphical view.
You need to configure the system to meet the requirements.
Which three options should you configure? Each answer presents a partial solution.
- A. Capable to Promise
- B. operations scheduling
- C. job scheduling
- D. bottleneck resource
- E. finite capacity
Answer: B,C,E
NEW QUESTION # 102
MB-335 Reliable Test Book: https://www.examdiscuss.com/Microsoft/exam/MB-335/
- Detailed MB-335 Study Plan 🥊 Valid Real MB-335 Exam 🩸 MB-335 Reliable Exam Tips 🧲 Go to website ☀ [url]www.verifieddumps.com ️☀️ open and search for ➡ MB-335 ️⬅️ to download for free 🦞Reliable MB-335 Learning Materials[/url]
- New MB-335 Study Notes 💦 MB-335 Reliable Exam Tips 🥺 Latest MB-335 Dumps 🎫 Easily obtain free download of { MB-335 } by searching on 《 [url]www.pdfvce.com 》 ❗Instant MB-335 Access[/url]
- The Microsoft MB-335 Exam with Desktop Practice Exam Software 🛩 Open website ⏩ [url]www.troytecdumps.com ⏪ and search for ☀ MB-335 ️☀️ for free download 🎅MB-335 PDF[/url]
- MB-335 Pdf Version 🥵 Latest Braindumps MB-335 Book 🛴 MB-335 Vce Test Simulator ❤️ Easily obtain ▷ MB-335 ◁ for free download through ( [url]www.pdfvce.com ) 🏂Valid Real MB-335 Exam[/url]
- Pass Guaranteed Quiz 2026 Microsoft MB-335: Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert Useful New Test Bootcamp 🚲 Search for 【 MB-335 】 and obtain a free download on ⮆ [url]www.pdfdumps.com ⮄ 🪔Latest Braindumps MB-335 Book[/url]
- MB-335 PDF 💌 Exam MB-335 Bootcamp 🍈 New MB-335 Study Notes 🕘 Simply search for ▛ MB-335 ▟ for free download on [ [url]www.pdfvce.com ] 🖐MB-335 Test Simulator Free[/url]
- New MB-335 Test Bootcamp - Valid Microsoft Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert - MB-335 Reliable Test Book 🦢 Search for ⏩ MB-335 ⏪ and obtain a free download on 《 [url]www.testkingpass.com 》 ➖MB-335 Latest Exam Camp[/url]
- Latest Braindumps MB-335 Book 🕔 Detailed MB-335 Study Plan 😙 Valid Real MB-335 Exam ✒ Search for ▷ MB-335 ◁ and obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 🦙MB-335 PDF[/url]
- 100% Pass Quiz MB-335 - Updated New Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert Test Bootcamp 🎩 Search for “ MB-335 ” and obtain a free download on 「 [url]www.practicevce.com 」 🐊Exam MB-335 Bootcamp[/url]
- Real Microsoft MB-335 Questions - Verified By Experts 🍎 Enter ⮆ [url]www.pdfvce.com ⮄ and search for “ MB-335 ” to download for free 🤙New MB-335 Test Guide[/url]
- Top New MB-335 Test Bootcamp | Professional MB-335: Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert 100% Pass 💟 Search for ➤ MB-335 ⮘ and download it for free on { [url]www.dumpsquestion.com } website 📦Latest MB-335 Dumps[/url]
- bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, escuela.expandeconsciencia.com, bicyclebuysell.com, www.competize.com, www.stes.tyc.edu.tw, gyancool.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of ExamDiscuss MB-335 dumps for free: https://drive.google.com/open?id=1XAhVM95ln6YcVd1n4R_97VCDwTiBxV4-
