Latest 800-150 Braindumps Pdf & 800-150 Valid Test Tips
104
Posted at 1/23/2026 12:11:21      View:107 | Replies:1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Pass4sureCert 800-150 dumps from Cloud Storage: https://drive.google.com/open?id=1nggxLBoKZJen2nPWkdVCSanTY91Cvns3
800-150 practice exam will provide you with wholehearted service throughout your entire learning process. This means that unlike other products, the end of your payment means the end of the entire transaction our 800-150 learning materials will provide you with perfect services until you have successfully passed the 800-150 Exam. And if you have any questions, just feel free to us and we will give you advice on 800-150 study guide as soon as possible.
Cisco 800-150 Exam Syllabus Topics:
  • Networking Foundations: This section of the exam measures the skills of a Network Engineer and covers the basic building blocks of computer networking. It explains different types of networks like local area networks and wireless networks, and introduces lightweight wireless LANs. It describes the layers of communication models like the OSI model and TCP
  • IP stack, and explains how data moves across networks. It also discusses the physical cabling used in networks, such as Ethernet and fiber optics. Students will learn about network switching, IP addressing, subnetting, and routing at Layer 3. The section also introduces Cisco’s campus network devices, data center switches, UCS servers, and collaboration devices, describing their roles and functions in the network.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Cisco’s cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
  • Common Service Tasks and Tools: This section of the exam measures the skills of a Technical Support Engineer and focuses on tasks commonly needed to manage Cisco devices. It explains how devices boot up, introduces common Cisco IOS commands, and identifies tools for file management. It shows how to confirm physical connections, remotely access devices, and connect to the console port. It also covers how to capture the status of a device, recover passwords, and replace devices by using proper tools. Students are also taught how to find serial numbers on Cisco equipment to assist with support and maintenance activities.
  • Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Cisco’s UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
Topic 5
  • Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
New Latest 800-150 Braindumps Pdf | Reliable 800-150: Supporting Cisco Devices for Field Technicians 100% PassThere has been fierce and intensified competition going on in the practice materials market. As the leading commodity of the exam, our 800-150 training materials have get pressing requirements and steady demand from exam candidates all the time. So our 800-150 Exam Questions have active demands than others with high passing rate of 98 to 100 percent. Don't doubt the pass rate, as long as you try our 800-150 study questions, then you will find that pass the exam is as easy as pie.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q100-Q105):NEW QUESTION # 100
Refer to the exhibit. What are two ways remote sites or branchesconnect to the enterprise campus network?
(Choose two.)
  • A. Access layer switches
  • B. WAN links
  • C. LAN core switches
  • D. Ad hoc Wi-Fi network
  • E. IPsec VPN tunnels
Answer: B,E
In enterprise networking, remote sites or branch offices connect to the central campus network using:
* WAN Links:These are dedicated communication paths that connect geographically dispersed networks. WAN links can be leased lines, MPLS circuits, or other forms of long-distance connectivity that facilitate reliable data transmission between remote sites and the main campus.
* IPsec VPN Tunnels:Internet Protocol Security (IPsec) VPNs provide secure, encrypted tunnels over the public internet, allowing remote sites to connect to the enterprise network securely. This method is cost-effective and widely used for connecting branch offices to the central network infrastructure.
Access layer switches (Option A) and LAN core switches (Option E) are components within a local network and do not facilitate remote connectivity. Ad hoc Wi-Fi networks (Option D) are temporary and lack the security and reliability required for enterprise-level remote connections.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 101
What is the purpose of the pre-service checklist in the endpoint replacement process?
  • A. To test the functionality of the existing endpoint
  • B. To ensure all necessary tools and personnel are available
  • C. To gather information about the replacement unit
  • D. To verify the current configuration settings of the endpoint
A pre-service checklist is a procedural step followed before replacing an endpoint. Its primary purpose is to confirm that all resources, tools, documentation, and personnel are in place to execute the replacement efficiently and without delays.
It helps avoid service interruptions and ensures a smooth replacement by ensuring that every necessary component and action is accounted for ahead of time.
NEW QUESTION # 102
Which type of license is locally managed and does not require external tools for management?
  • A. RTU licenses
  • B. PAK licenses
  • C. Hybrid licenses
  • D. Smart licenses
Right-To-Use (RTU) licenses are locally managed licenses that allow users to activate specific features on Cisco devices without the need for external tools or connectivity to Cisco's licensing infrastructure. These licenses operate on an honor-based system, where the user agrees to comply with the licensing terms without mandatory enforcement mechanisms.
In contrast:
Hybrid licenses combine aspects of traditional and smart licensing models.
PAK (Product Authorization Key) licenses require registration and activation through Cisco's licensing portal.
Smart licenses necessitate communication with Cisco's Smart Licensing servers for activation and management.
NEW QUESTION # 103
When should a crossover UTP cable be used instead of a straight-through cable when connecting network devices?
  • A. To connect electrically like devices
  • B. To connect electrically unlike devices
  • C. To connect a switch to a router
  • D. To connect a PC to a wireless access point
Acrossover UTP (Unshielded Twisted Pair) cableis used to connect two similar devices directly. This includes:
* Switch to switch
* Router to router
* PC to PC
The crossover cable reverses the transmit and receive pairs, allowing for proper communication between like devices without the need for an intermediary device.
Conversely, astraight-through cableis used to connect dissimilar devices, such as:
* PC to switch
* Router to switch
* PC to router
This cable maintains the same wiring on both ends, suitable for connecting different types of devices.
Therefore, when connecting electrically like devices, a crossover cable is appropriate.
Reference:Supporting Cisco Devices for FieldTechnicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 104
What is the primary function of a wireless LAN controller in a Cisco Unified Wireless Network solution?
  • A. To manage and configure associated access points centrally
  • B. To translate data into a frame format for transmission
  • C. To operate at Layer 3 of the OSI model
  • D. To provide wireless connectivity to LAN devices
The Wireless LAN Controller (WLC) plays a central role in Cisco's Unified Wireless Network solution by providing centralized management, configuration, and monitoring for multiple access points (APs). It allows for streamlined policy enforcement, seamless mobility, load balancing, and security management across wireless networks.
While WLCs facilitate wireless connectivity indirectly, their main role is to centrally manage and control access points - not to function as Layer 3 routers or format data frames.
The primary function of a wireless LAN controller (WLC) in a Cisco Unified Wireless Network is to centrally manage, configure, and monitor multiple access points, simplifying administration and enhancing scalability.
NEW QUESTION # 105
Elaborately designed and developed 800-150 test guide as well as good learning support services are the key to assisting our customers to realize their dreams. Our 800-150 study braindumps have a variety of self-learning and self-assessment functions to detect learners’ study outcomes, and the statistical reporting function of our 800-150 test guide is designed for students to figure out their weaknesses and tackle the causes, thus seeking out specific methods dealing with them. Most of them give us feedback that they have learned a lot from our 800-150 Exam Guide and think it has a lifelong benefit. They have more competitiveness among fellow workers and are easier to be appreciated by their boss. In fact, the users of our 800-150 exam have won more than that, but a perpetual wealth of life.
800-150 Valid Test Tips: https://www.pass4surecert.com/Cisco/800-150-practice-exam-dumps.html
P.S. Free 2026 Cisco 800-150 dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1nggxLBoKZJen2nPWkdVCSanTY91Cvns3
Posted at 1/26/2026 17:11:54        Only Author  2#
I don’t even need to think—this content deserves a like. Free Valid CDFOM exam simulator exam questions for everyone. Best of luck to all candidates!
