[General] CBIC CIC Valid Braindumps Sheet - Valid Dumps CIC Sheet
94
【General】 CBIC CIC Valid Braindumps Sheet - Valid Dumps CIC Sheet
Posted at 1/23/2026 12:26:41      View:143 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that DumpStillValid CIC dumps now are free: https://drive.google.com/open?id=1Cf1SSLZMneUZNZxEj8-uCjtuXrzu8DcM
Many candidates who take the qualifying exams are not aware of our CIC exam questions and are not guided by our systematic guidance, and our users are much superior to them. In similar educational products, the CIC quiz guide is absolutely the most practical. Also, from an economic point of view, our CIC Exam Guide Materials is priced reasonable, so the CIC test material is very responsive to users, user satisfaction is also leading the same products. You can deeply depend on our CIC exam guide materials when you want to get the qualification.
The DumpStillValid are one of the high-in-demand and top-rated platforms that has been offering real, valid, and updated CBIC Certified Infection Control Exam (CIC) practice test questions for many years. Over this long time period countless candidates have got success in their dream CBIC Certified Infection Control Exam (CIC) certification exam. They all got help from CBIC Certified Infection Control Exam (CIC) exam questions and easily crack the final CBIC CIC exam.
100% Pass Pass-Sure CIC - CBIC Certified Infection Control Exam Valid Braindumps SheetOur CIC PDF format is also an effective format to do test preparation. In your spare time, you can easily use the CIC dumps PDF file for study or revision. The PDF file of CBIC CIC real questions is convenient and manageable. These CBIC CIC Questions are also printable, giving you the option of paper study since some CBIC CIC applicants prefer off-screen preparation rather than on a screen.
CBIC Certified Infection Control Exam Sample Questions (Q48-Q53):NEW QUESTION # 48
An infection preventionist is asked to recommend a product for disinfection of bronchoscopes. Which of the following agents would be appropriate?
  • A. Peracetic acid
  • B. Phenolic
  • C. Alcohol
  • D. Iodophor
The correct answer is D, "eracetic acid," as this agent is appropriate for the disinfection of bronchoscopes.
According to the Certification Board of Infection Control and Epidemiology (CBIC) guidelines, bronchoscopes are semi-critical devices that require high-level disinfection (HLD) to eliminate all microorganisms except high levels of bacterial spores, as they come into contact with mucous membranes but not sterile tissues. Peracetic acid is recognized by the Centers for Disease Control and Prevention (CDC) and the Association for the Advancement of Medical Instrumentation (AAMI) as an effective high-level disinfectant for endoscopes, including bronchoscopes, due to its broad-spectrum antimicrobial activity, rapid action, and compatibility with the delicate materials (e.g., optics and channels) of these devices (CBIC Practice Analysis, 2022, Domain III: Infection Prevention and Control, Competency 3.3 - Ensure safe reprocessing of medical equipment). It is commonly used in automated endoscope reprocessors, ensuring thorough disinfection when combined with proper cleaning and rinsing protocols.
Option A (iodophor) is typically used for intermediate-level disinfection and skin antisepsis, but it is not sufficient for high-level disinfection of bronchoscopes unless specifically formulated and validated for this purpose, which is uncommon. Option B (alcohol) is effective against some pathogens but evaporates quickly, fails to penetrate organic material, and is not recommended for HLD of endoscopes due to potential damage to internal components and inadequate sporicidal activity. Option C (phenolic) is suitable for surface disinfection but lacks the efficacy required for high-level disinfection of semi-critical devices like bronchoscopes, as it does not reliably eliminate all microbial threats, including mycobacteria.
The selection of peracetic acid aligns with CBIC's emphasis on evidence-based reprocessing practices to prevent healthcare-associated infections (HAIs) associated with endoscope use (CBIC Practice Analysis,
2022, Domain III: Infection Prevention and Control, Competency 3.4 - Implement environmental cleaning and disinfection protocols). This choice ensures patient safety by adhering to manufacturer and regulatory guidelines, such as those in AAMI ST91 (AAMI ST91:2015, Flexible and semi-rigid endoscope processing in health care facilities).
References: CBIC Practice Analysis, 2022, Domain III: Infection Prevention and Control, Competencies 3.3 - Ensure safe reprocessing of medical equipment, 3.4 - Implement environmental cleaning and disinfection protocols. AAMI ST91:2015, Flexible and semi-rigid endoscope processing in health care facilities. CDC Guidelines for Disinfection and Sterilization in Healthcare Facilities, 2019.
NEW QUESTION # 49
The infection preventionist (IP) collaborates with the Intravenous Therapy team to select the best antiseptic for use during the insertion of an intravascular device for adults. For a patient with no contraindications, what antiseptic should the IP suggest?
  • A. Antibiotic ointment
  • B. Alcohol
  • C. Povidone-iodine
  • D. Chlorhexidine
The selection of an appropriate antiseptic for the insertion of an intravascular device (e.g., peripheral or central venous catheters) is a critical infection prevention measure to reduce the risk of catheter-related bloodstream infections (CRBSIs). The Certification Board of Infection Control and Epidemiology (CBIC) emphasizes evidence-based practices in the "revention and Control of Infectious Diseases" domain, which includes adhering to guidelines for aseptic technique during invasive procedures. The Centers for Disease Control and Prevention (CDC) provides specific recommendations for skin antisepsis, as outlined in the
"Guidelines for the Prevention of Intravascular Catheter-Related Infections" (2017).
Option A, chlorhexidine, is the preferred antiseptic for skin preparation prior to intravascular device insertion in adults with no contraindications. Chlorhexidine, particularly in a 2% chlorhexidine gluconate (CHG) with
70% isopropyl alcohol solution, is recommended by the CDC due to its broad-spectrum antimicrobial activity, residual effect (which continues to kill bacteria after application), and superior efficacy compared to other agents in reducing CRBSI rates. Studies cited in the CDC guidelines demonstrate that chlorhexidine-based preparations significantly lower infection rates compared to povidone-iodine or alcohol alone, making it the gold standard for this procedure when tolerated by the patient.
Option B, povidone-iodine, is an alternative antiseptic that can be used for skin preparation. It is effective against a wide range of microorganisms and is often used when chlorhexidine is contraindicated (e.g., in patients with chlorhexidine allergy). However, its efficacy is less persistent than chlorhexidine, and it requires longer drying time, which can be a limitation in busy clinical settings. The CDC considers povidone-iodine a second-line option unless chlorhexidine is unavailable or unsuitable. Option C, alcohol (e.g., 70% isopropyl or ethyl alcohol), has rapid bactericidal activity but lacks a residual effect, making it less effective for prolonged protection during catheter dwell time. It is often used as a component of chlorhexidine-alcohol combinations but is not recommended as a standalone antiseptic for intravascular device insertion. Option D, antibiotic ointment, is not appropriate for skin preparation during insertion. Antibiotic ointments (e.g., bacitracin or mupirocin) are sometimes applied to catheter sites post-insertion to prevent infection, but their use is discouraged by the CDC due to the risk of promoting antibiotic resistance and fungal infections, and they are not classified as antiseptics for initial skin antisepsis.
The CBIC Practice Analysis (2022) supports the adoption of CDC-recommended practices, and the 2017 CDC guidelines explicitly state that chlorhexidine-based preparations with alcohol should be used for skin antisepsis unless contraindicated. For a patient with no contraindications, the infection preventionist should suggest chlorhexidine to optimize patient safety and align with best practices.
* CBIC Practice Analysis, 2022.
* CDC Guidelines for the Prevention of Intravascular Catheter-Related Infections, 2017.
NEW QUESTION # 50
Which of the following individuals should be excluded from receiving live attenuated influenza virus?
  • A. Pregnant persons
  • B. Healthy persons aged 2 to 49
  • C. Persons with allergies to chicken feathers
  • D. Persons simultaneously receiving an inactivated vaccine
The correct answer is A, "regnant persons," as they should be excluded from receiving the live attenuated influenza virus (LAIV) vaccine. According to the Certification Board of Infection Control and Epidemiology (CBIC) guidelines, which align with recommendations from the Centers for Disease Control and Prevention (CDC) and the Advisory Committee on Immunization Practices (ACIP), the LAIV, commonly known as the nasal spray flu vaccine, contains a live attenuated form of the influenza virus. This vaccine is contraindicated in pregnant individuals due to the theoretical risk of the attenuated virus replicating and potentially harming the fetus, despite limited evidence of adverse outcomes (CBIC Practice Analysis, 2022, Domain III: Infection Prevention and Control, Competency 3.2 - Implement measures to prevent transmission of infectious agents).
Pregnant persons are instead recommended to receive the inactivated influenza vaccine (IIV), which is considered safe during pregnancy.
Option B (healthy persons aged 2 to 49) is incorrect because this group is generally eligible to receive LAIV, provided they have no other contraindications, as the vaccine is approved for healthy, non-pregnant individuals in this age range (CDC Immunization Schedules, 2024). Option C (persons with allergies to chicken feathers) is not a contraindication for LAIV; the vaccine is produced in eggs, and while egg allergy was historically a concern, current guidelines indicate that LAIV can be administered to persons with egg allergies if they can tolerate egg in their diet, with precautions managed by healthcare providers. Option D (persons simultaneously receiving an inactivated vaccine) is also incorrect, as LAIV can be co-administered with inactivated vaccines without issue, according to ACIP recommendations, as there is no significant interference between the two vaccine types.
The exclusion of pregnant persons reflects CBIC's emphasis on tailoring infection prevention strategies, including vaccination programs, to protect vulnerable populations while minimizing risks (CBIC Practice Analysis, 2022, Domain III: Infection Prevention and Control, Competency 3.1 - Collaborate with organizational leaders). This decision is based on precautionary principles outlined in CDC and ACIP guidelines to ensure maternal and fetal safety (CDC Prevention and Control of Seasonal Influenza with Vaccines, 2023).
References: CBIC Practice Analysis, 2022, Domain III: Infection Prevention and Control, Competencies 3.1 - Collaborate with organizational leaders, 3.2 - Implement measures to prevent transmission of infectious agents. CDC Prevention and Control of Seasonal Influenza with Vaccines, 2023. CDC Immunization Schedules, 2024.
NEW QUESTION # 51
Following an outbreak of Hepatitis A, the water supply is sampled. A high count of which of the following isolates would indicate that the water was a potential source?
  • A. Legionella
  • B. Coliforms
  • C. Pseudomonads
  • D. Acinetobacter
Coliform bacteria are indicators of fecal contamination in water, making them a critical measure of water safety. Hepatitis A is a virus primarily transmitted via the fecal-oral route, often through contaminated food or water.
Step-by-Step Justification:
* Fecal Contamination and Hepatitis A:
* Hepatitis A virus (HAV) spreads through ingestion of water contaminated with fecal matter. High coliform counts indicate fecal contamination and increase the risk of HAV outbreaks.
* Use of Coliforms as Indicators:
* Public health agencies use total coliforms and Escherichia coli (E. coli) as primary indicators of water safety because they signal fecal pollution.
* Waterborne Transmission of Hepatitis A:
* Hepatitis A outbreaks have been traced to contaminated drinking water, ice, and improperly treated wastewater. Coliform detection signals a need for immediate action.
Why Other Options Are Incorrect:
* B. Pseudomonads:
* Pseudomonads (e.g., Pseudomonas aeruginosa) are environmental bacteria but are not indicators of fecal contamination.
* C. Legionella:
* Legionella species cause Legionnaires' disease through inhalation of contaminated aerosols, not through fecal-oral transmission.
* D. Acinetobacter:
* Acinetobacter species are opportunistic pathogens in healthcare settings but are not indicators of waterborne fecal contamination.
CBIC Infection Control References:
* APIC Text, "Water Systems and Infection Control Measures".
* APIC Text, "Hepatitis A Transmission and Waterborne Outbreaks".
NEW QUESTION # 52
A patient has an oral temperature of 101° F (38.33 C). Erythema and tenderness arc noted at the central line site. Blood samples are submitted for culture and intravenous vancomycin is ordered. This is an example of which of the following forms of antibiotic treatment?
  • A. Prophylactic
  • B. Empiric
  • C. Experimental
  • D. Broad spectrum
Empiric antibiotic therapy is the immediate initiation of antibiotics based on clinical judgment before laboratory confirmation of an infection. In this case, the presence of fever, erythema, and tenderness at the central line site suggests a possible bloodstream infection, prompting empiric treatment with vancomycin.
* Initiation Before Lab Confirmation:
* Empiric therapy starts treatment based on symptoms while awaiting culture results.
* Prevents Complications:
* Delayed treatment in central line-associated bloodstream infections (CLABSI) can lead to sepsis.
* Common in High-Risk Situations:
* Empiric treatment is used in cases where waiting for lab results could worsen the patient's condition.
* B. Prophylactic:
* Prophylactic antibiotics are given to prevent infection, not to treat an existing one.
* C. Experimental:
* Experimental treatment refers to clinical trials or unproven therapies, which does not apply here.
* D. Broad spectrum:
* Broad-spectrum antibiotics cover multiple bacteria, but empiric therapy may be narrow- spectrum based on suspected pathogens.
* APIC Text, Chapter on Antimicrobial Stewardship and Empiric Therapy.
NEW QUESTION # 53
Our CIC guide torrent is compiled by experts and approved by the experienced professionals. The language is easy to be understood to make any learners have no learning obstacles and our CIC study questions are suitable for any learners. The software boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our CIC Exam Torrent boosts timing function and the function to stimulate the exam. It is very easy to pass the CIC exam with our CIC learning guide.
Valid Dumps CIC Sheet: https://www.dumpstillvalid.com/CIC-prep4sure-review.html
CIC reliable exam bootcamp materials contain three formats: PDF version, Soft test engine and APP test engine so that our products are enough to satisfy different candidates' habits and cover nearly full questions & answers of the real test, CBIC CIC Valid Braindumps Sheet The knowledge you have learned is priceless, CBIC CIC Valid Braindumps Sheet While others are surprised at your achievement, you might have found a better job.
Sharpen the skills measured by these objectives: Manage Document Options and Settings, Intention Revealing Message, CIC reliable exam bootcamp materials contain three formatsDF version, Soft test engine and APP test engine so that our CIC Pdf Torrent products are enough to satisfy different candidates' habits and cover nearly full questions & answers of the real test.
Latest CIC Reliable Torrent - CIC Actual Pdf & CIC Exam QuestionsThe knowledge you have learned is priceless, While others are surprised at your achievement, you might have found a better job, CIC authentic dumps come in three formats: CBIC CIC pdf questions formats, Web-based and desktop CIC practice test software are the three best formats of DumpStillValid CIC valid dumps.
Your investment in Exam Dumps CIC will be safe with us and we offer the money back guarantee.
2026 Latest DumpStillValid CIC PDF Dumps and CIC Exam Engine Free Share: https://drive.google.com/open?id=1Cf1SSLZMneUZNZxEj8-uCjtuXrzu8DcM
Posted at 2/16/2026 08:48:14        Only Author  2#
I was completely taken by that article. Free Reliable AP-209 exam simulations materials are the stepping stones to your career advancement and salary growth!
