[General] Certificate PT-AM-CPE Exam | PT-AM-CPE Vce Free
93
General Certificate PT-AM-CPE Exam | PT-AM-CPE Vce Free
Posted at 1/23/2026 12:58:01      View137 | Replies0        Print      Only Author   [Copy Link] 1#
Real4exams's braindumps provide you the gist of the entire syllabus in a specific set of questions and answers. These study questions are most likely to appear in the actual exam. The Certification exams are actually set randomly from the database of PT-AM-CPE. Thus most of the questions are repeated in PT-AM-CPE Exam and our experts after studying the previous exam have sorted out the most important questions and prepared dumps out of them. Hence Real4exams's dumps are a special feast for all the exam takers and sure to bring them not only exam success but also maximum score.
The Real4exams is committed from the day first to ace the Certified Professional - PingAM Exam (PT-AM-CPE) exam questions preparation at any cost. To achieve this objective Real4exams has hired a team of experienced and qualified PT-AM-CPE certification exam experts. They utilize all their expertise to offer top-notch Certified Professional - PingAM Exam (PT-AM-CPE) exam dumps. These Ping Identity PT-AM-CPE exam questions are being offered in three different but easy-to-use formats.
100% Pass Quiz Ping Identity - PT-AM-CPE CHigh Pass-Rate Certificate ExamWith these mock exams, it is easy to track your progress by monitoring your marks each time you go through the PT-AM-CPE practice test. Our PT-AM-CPE practice exams will give you an experience of attempting the PT-AM-CPE original examination. You will be able to deal with the actual exam pressure better when you have already experienced it in our Ping Identity PT-AM-CPE practice exams.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q22-Q27):NEW QUESTION # 22
In an authentication tree process, considering best practice, where can the collected context data for mobile devices be persisted for subsequent risk analysis?
  • A. In shared node state
  • B. With the user profile
  • C. In the session state
  • D. In a browser cookie
In PingAM 8.0.2, the Intelligent Access engine (Authentication Trees) uses a specific data-passing mechanism to move information between individual nodes within a single journey. When a journey involves collecting context-such as device metadata (OS, version, screen resolution), location data (IP, geofencing), or risk signals-this information must be stored temporarily while the tree evaluates the next steps.
According to the "Authentication Node Development" and "Nodes and Trees" documentation, PingAM uses two primary transient storage objects during the authentication flow:
Shared State: This is the primary map used to share data between nodes in the same tree. Contextual data collected by nodes like the Device Profile Collector or Browser Capabilities nodes is stored here. It exists only for the duration of the authentication journey.
Transient State: Similar to shared state, but often used for sensitive data that should not be visible to certain types of nodes or scripts.
The documentation identifies Shared Node State (Option B) as the best practice for persisting collected context during the tree process.
Session State (Option A) is only available after the authentication is successful and a session has been created. It is not suitable for data needed by nodes within the tree to make a decision (like a risk engine node).
User Profile (Option C) is for long-term persistence (LDAP/PingDS). Storing transient device context there would cause unnecessary database write overhead and privacy concerns.
Browser Cookies (Option D) are limited in size and pose security risks if used to store raw device data that could be tampered with by the client.
Therefore, for real-time risk analysis within a journey, nodes write data to the shared state, where subsequent nodes (like a Scripted Decision Node or Adaptive Risk Node) can retrieve and analyze it.
NEW QUESTION # 23
What should be configured in PingAM if you are using an LDAP directory service that does not support persistent search?
  • A. Enable user data caching, which will have a negative impact on performance
  • B. Disable user data caching, which will have a negative impact on performance
  • C. Enable user data caching, which will have a positive impact on performance
  • D. Disable user data caching, which will have a positive impact on performance
Persistent Search is an LDAP control that allows a client (like PingAM) to receive real-time notifications from the Directory Server (like PingDS) whenever a user record is modified. PingAM 8.0.2 uses this to maintain its User Data Cache.
According to the "Identity Store Configuration" and "Tuning AM" documentation:
When persistent search is supported, PingAM caches user profile data in memory to speed up authentication and authorization decisions. When a change happens in the LDAP store, the directory server "pushes" the update to AM via the persistent search connection, and AM updates its cache immediately.
If the LDAP directory does not support persistent search (common in some legacy or highly restricted environments):
Cache Inconsistency: If caching were enabled, PingAM would not know when a user's attribute (like a group membership) had changed in the back-end. The cache would become "stale," leading to incorrect authorization decisions.
Required Configuration: The administrator must Disable user data caching to ensure that every request results in a direct query to the LDAP server, ensuring "Read-through" accuracy.
Performance Impact: Disabling the cache has a negative impact on performance (Option D) because every policy evaluation or session check now requires a synchronous network round-trip to the LDAP server, increasing latency and putting higher CPU/IO load on the directory.
Therefore, for directories lacking persistent search, disabling the cache is necessary for data integrity but comes at a significant performance cost.
NEW QUESTION # 24
The Core Token Service (CTS) can be used for storing which of the following?
  • A. OAuth2 tokens
  • B. Kerberos tokens
  • C. Configuration
  • D. Users
The Core Token Service (CTS) is a high-performance persistence layer in PingAM 8.0.2 designed to store short-lived, stateful data. Unlike the Configuration Store (which holds static system settings) or the Identity Store (which holds user profiles), the CTS is optimized for "token-like" data that is frequently created, updated, and deleted.
According to the "Core Token Service (CTS) Overview" in the PingAM 8.0.2 documentation, the primary purpose of the CTS is to provide a centralized repository for:
Session Tokens: For server-side sessions, the session state is stored in the CTS.
OAuth 2.0 Tokens: This includes Access Tokens, Refresh Tokens, and Authorization Codes. When an OAuth2 client requests a token, AM generates it and, if configured for server-side storage, persists it in the CTS so that any node in an AM cluster can validate it.
SAML 2.0 Tokens: Used for tracking assertions and managing Single Logout (SLO) states.
UMA (User-Managed Access) Labels and Resources: Various state information for the UMA protocol.
The documentation explicitly clarifies that the CTS is not a general-purpose database. Configuration (Option A) is strictly stored in the Configuration Data Store (usually a dedicated PingDS instance). Users (Option B) are stored in an Identity Store such as Active Directory or PingDS. Kerberos tokens (Option C) are part of a challenge-response handshake that is typically handled at the protocol layer and not stored as persistent records in the CTS. Therefore, OAuth2 tokens are the definitive type of data managed by the CTS among the choices provided. Utilizing the CTS for OAuth2 tokens is a prerequisite for supporting features like token revocation and refresh token persistence across multiple AM instances in a high-availability deployment.
NEW QUESTION # 25
Which of the following actions can be specified in a policy by default?
  • A. HEAD
  • B. INSERT
  • C. CREATE
  • D. UPDATE
In PingAM 8.0.2, Authorization Policies define who can perform what actions on a specific resource. These "Actions" are defined within a Resource Type. When you create a new policy, you must select which actions are allowed or denied.
According to the "Resource Types" documentation, PingAM includes several "Default" resource types (such as URL, RPC, and others).9 For the most common resource type, the URL Resource Type, PingAM defines a set of standard HTTP-related actions by default:
GET
POST
PUT
DELETE
HEAD
OPTIONS
PATCH
HEAD (Option A) is a standard HTTP method and is included in the default list for URL-based policies.
INSERT, CREATE, and UPDATE (Options B, C, and D) are not provided by default in the standard URL resource type. While an administrator can certainly create a Custom Resource Type and define "INSERT" or "UPDATE" as valid actions (common for database or API-specific policies), they are not present in the "default" out-of-the-box configuration for web-based resources. Understanding the default action set is important for administrators when quickly securing web applications without the need for custom schema development.
NEW QUESTION # 26
Which of the following needs to be configured in order to use social authentication in PingAM?
  • A. An OAuth2 client
  • B. A realm service
  • C. A data store
  • D. A realm policy
Social Authentication in PingAM 8.0.2 allows users to log in using identities from external providers like Google, Apple, or LinkedIn. This process relies on PingAM acting as an OAuth2 Client or OpenID Connect Relying Party (RP) toward the social provider.
According to the PingAM "Social Authentication" and "Social Identity Provider Client Configuration" documentation, for PingAM to successfully hand off authentication to a social provider, you must configure an OAuth2 Client (specifically a Social Identity Provider client) within the PingAM realm. This configuration includes:
Client ID and Client Secret: Obtained from the social provider's developer console (e.g., Google Cloud Console).
Endpoints: The authorization, token, and UserInfo endpoints of the social provider.
Scopes: The permissions PingAM is requesting (e.g., openid, profile, email).
Once this "Social Client" is configured, it is used by a Social Provider Handler node (or the legacy Social Authentication module) within an authentication tree. When the user clicks "Login with Google," PingAM uses these client credentials to initiate the OIDC flow with Google.
Why other options are not the primary requirement:
While a Data Store (A) is eventually used to save the linked user profile, the mechanism of social auth itself is driven by the OAuth2 client configuration.
A realm service (B) is too broad; while social auth is a service within a realm, the specific configuration object required is the client.
A realm policy (D) governs authorization after login, but does not enable the social login process itself. Therefore, the OAuth2 client configuration is the technical prerequisite for establishing the trust relationship with the external provider.
NEW QUESTION # 27
With the rapid development of computer, network, and semiconductor techniques, the market for people is becoming more and more hotly contested. Passing a PT-AM-CPE exam to get a certificate will help you to look for a better job and get a higher salary. If you are worried about your job, your wage, and a PT-AM-CPE Certification, if you are going to change this, we are going to help you solve your problem by our PT-AM-CPE exam torrent with high quality, now allow us to introduce you our PT-AM-CPE guide torrent.
PT-AM-CPE Vce Free: https://www.real4exams.com/PT-AM-CPE_braindumps.html
Ping Identity Certificate PT-AM-CPE Exam To let the clients be familiar with the atmosphere and pace of the real exam we provide the function of stimulating the exam, So let us take an unequivocal look of the PT-AM-CPE study materials as follows, Our PT-AM-CPE study braindumps cover almost all possible braindumps which may appear in the certification tests, Ping Identity Certificate PT-AM-CPE Exam To keep up with the development of world, a person must study during his whole life.
We are deeply saddened to learn of the death of noted author PT-AM-CPE W, If you choose a file or application, a preview or description of the selected item appears in the column to the right.
To let the clients be familiar with the atmosphere and pace of the real exam we provide the function of stimulating the exam, So let us take an unequivocal look of the PT-AM-CPE Study Materials as follows.
Unique Features of Real4exams's PT-AM-CPE Exam Dumps (Desktop and Web-Based)Our PT-AM-CPE study braindumps cover almost all possible braindumps which may appear in the certification tests, To keep up with the development of world, a person must study during his whole life.
Pragmatic PT-AM-CPE pass-king torrent.
