| Im new to working with the AIO-3399J and recently received a v1.3 model after working with the v12 for a while. Ive managed to get everything set up, but Im running into an issue with the LVDS display. On the v12, I was able to get dual-LVDS working perfectly after configuring the kernel, but with the v1.3 model, the screen stays black, and only the HDMI output works. Ive tried using the same kernel configuration from the v12 board, but Im not sure if theres a new setting or patch required for the v1.3. Has anyone here encountered a similar issue? Are there any changes to the device tree or kernel options for dual-LVDS support on the v1.3 version? Any help would be greatly appreciated! geometry dash |
1.45 MB, Down times: 1
