[General] 2V0-17.25 Exam Questions: VMware Cloud Foundation 9.0 Administrator & 2V0-17
82
【General】 2V0-17.25 Exam Questions: VMware Cloud Foundation 9.0 Administrator & 2V0-17
Posted at 1/23/2026 13:33:51      View:141 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Itcertking 2V0-17.25 dumps for free: https://drive.google.com/open?id=1Q7DHdm5CEqNVvm2oS6dRU9mb6rvQn7nc
Itcertking aims to assist its clients in making them capable of passing the VMware 2V0-17.25 certification exam with flying colors. It fulfills its mission by giving them an entirely free VMware Cloud Foundation 9.0 Administrator (2V0-17.25) demo of the dumps. Thus, this demonstration will enable them to scrutinize the quality of the VMware 2V0-17.25 study material.
As long as you get to know our 2V0-17.25 exam questions, you will figure out that we have set an easier operation system for our candidates. Once you have a try, you can feel that the natural and seamless user interfaces of our 2V0-17.25 study materials have grown to be more fluent and we have revised and updated 2V0-17.25 learning braindumps according to the latest development situation. Without doubt, we are the best vendor in this field and we also provide the first-class service for you.
VMware 2V0-17.25 Dumps PDF- Easiest Preparation Method [2026]Our 2V0-17.25 quiz torrent boost 3 versions and they include PDF version, PC version, App online version. Different version boosts different functions and using method. For example, the PDF version is convenient for the download and printing our 2V0-17.25 exam torrent and is easy and suitable for browsing learning. It can be printed on the papers which are convenient for you to take notes and learn at any time and place. You can practice 2V0-17.25 Quiz prep repeatedly and there are no limits for the amount of the persons and times. And the PC version of 2V0-17.25 quiz torrent can stimulate the real exam’s scenarios, is stalled on the Windows operating system and runs on the Java environment. You can use it any time to test your own Exam stimulation tests scores and whether you have mastered our 2V0-17.25 exam torrent.
VMware Cloud Foundation 9.0 Administrator Sample Questions (Q56-Q61):NEW QUESTION # 56
Which tool does an administrator use to collect and validate the initial inputs for the deployment of a VMware Cloud Foundation (VCF) fleet?
  • A. VCF Installer
  • B. SDDC Manager
  • C. Cloud Builder
  • D. VCF Operations
VCF 9.0 replaces legacy bring-up tooling with the VCF Installer, which provides a deployment wizard that validates configuration before bring-up. The guide describes: "The deployment wizard validates your inputs... and displays errors and warnings if any." and that administrators "Download and complete the planning and preparation workbook and have the information ready for validating inputs in the deployment wizard." While the workbook is used to collect information, the validation of those inputs is performed by the VCF Installer wizard prior to deployment. SDDC Manager is used after bring-up for lifecycle operations, and Cloud Builder is not used in VCF 9.0 deployments. Therefore, VCF Installer is the correct tool for collecting (via wizard prompts) and validating initial deployment inputs.
NEW QUESTION # 57
An administrator is tasked with upgrading a vSphere 8-only environment to VCF 9.0. Which three components must be deployed as part of the upgrade? (Choose three.)
  • A. VCF Operations for Logs
  • B. VCF Operations for Networks
  • C. VCF Identity Broker
  • D. VCF Operations Collector
  • E. VCF Operations
  • F. VCF Operations fleet management
Answer: D,E,F
The VCF 9.0 Upgrade Guide specifies required components when converting from a vSphere-only deployment to full VCF. The must-deploy services include:
VCF Operations fleet management - central monitoring of multiple instances.
VCF Operations - core operational monitoring platform.
VCF Operations Collector - required for data ingestion from vSphere, NSX, and vSAN.
The Identity Broker is already embedded with VCF 9.0 SSO, while VCF Operations for Logs and Networks are optional add-ons for extended visibility. Thus, the required three are: A, D, F.
NEW QUESTION # 58
When planning disaster recovery for a VMware data center, which of the following best practices or tools can help create a robust DR strategy?
  • A. Manual VM backups stored on local host datastores only
  • B. Cross-site vMotion with Stretch Cluster configurations
  • C. Regularly testing the failover plan in a sandbox environment
  • D. Site Recovery Manager (SRM) for orchestrated failover
Answer: B,C,D
SRM (A) automates and orchestrates failover; stretch clusters enable cross-site vMotion for resilience (C); and testing DR in a controlled environment (D) ensures readiness. Storing backups only on local host datastores (B) creates a single point of failure and is not recommended.
NEW QUESTION # 59
An administrator has been tasked to create a new cluster in an existing VMware Cloud Foundation (VCF) instance. The hosts within the cluster have different generation Intel processors. What feature must be configured on the cluster to ensure VMware Distributed Resource Scheduler (DRS) is able to automatically move Virtual Machines within the cluster?
  • A. vSphere Fault Tolerance
  • B. Enhanced vMotion Compatibility
  • C. vSphere Availability
  • D. Host Affinity Rules
EVC ensures vMotion compatibility across hosts with different CPU generations by exposing a uniform set of CPU features to all virtual machines in the cluster.
NEW QUESTION # 60
Which security feature in ESXi ensures that only signed and trusted code can run during the host boot process?
  • A. TPM 2.0 Integration
  • B. Secure Boot
  • C. vSphere Encryption
  • D. Lockdown Mode
Secure Boot uses digital signatures to verify the integrity of the ESXi boot loader and kernel modules.
Lockdown Mode restricts remote access, TPM integration stores cryptographic keys, and vSphere Encryption secures VM data at rest, not the boot process itself.
NEW QUESTION # 61
Life is beset with all different obstacles that are not easily overcome. For instance, 2V0-17.25 exams may be insurmountable barriers for the majority of population. However, with the help of our 2V0-17.25exam questions, exams are no longer problems for you. The reason why our 2V0-17.25 Training Materials outweigh other 2V0-17.25 study prep can be attributed to three aspects, namely free renewal in one year, immediate download after payment and simulation for the software version.
2V0-17.25 Reliable Exam Questions: https://www.itcertking.com/2V0-17.25_exam.html
However, preparing for the 2V0-17.25 exam is not an easy job until they have real VMware Cloud Foundation 9.0 Administrator (2V0-17.25) exam questions that are going to help them achieve this target, Our Itcertking promise you that you can pass your first time to participate in the VMware certification 2V0-17.25 exam and get VMware 2V0-17.25 certification to enhance and change yourself, VMware Test 2V0-17.25 Free As you know, our v practice exam has a vast market and is well praised by customers.
The person might own a PC running Windows and pick up the Macintosh version of the program by mistake, This is why we say instant access to 2V0-17.25 exam study guide is available.
However, preparing for the 2V0-17.25 exam is not an easy job until they have real VMware Cloud Foundation 9.0 Administrator (2V0-17.25) exam questions that are going to help them achieve this target.
Top Test 2V0-17.25 Free | High-quality 2V0-17.25 Reliable Exam Questions: VMware Cloud Foundation 9.0 AdministratorOur Itcertking promise you that you can pass your first time to participate in the VMware certification 2V0-17.25 exam and get VMware 2V0-17.25 certification to enhance and change yourself.
As you know, our v practice exam has a vast market 2V0-17.25 and is well praised by customers, You will make progress and obtain your desired certification with our topping 2V0-17.25 exam dumps for we own the first-class quality as well as the first-class customer service online.
Besides, you can download the 2V0-17.25 : VMware Cloud Foundation 9.0 Administrator free demo and install it on your electronic device, thus you can review at anytime and anywhere available.
BTW, DOWNLOAD part of Itcertking 2V0-17.25 dumps from Cloud Storage: https://drive.google.com/open?id=1Q7DHdm5CEqNVvm2oS6dRU9mb6rvQn7nc
Posted at 2/12/2026 09:28:59        Only Author  2#
Oracle 1z1-809인증시험이 이토록 인기가 많으니 우리ExamPassdump에서는 모든 힘을 다하여 여러분이 응시에 도움을 드리겠으며 또 일년무료 업뎃서비스를 제공하며, ExamPassdump 선택으로 여러분은 자신의 꿈과 더 가까워질 수 있습니다. 희망찬 내일을 위하여 ExamPassdump선택은 정답입니다. ExamPassdump선택함으로 당신이 바로 진정한IT인사입니다.
