Quiz PL-200 - Marvelous Training Microsoft Power Platform Functional Consultant
103
Posted at 1/23/2026 14:08:01      View144 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft PL-200 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=1Xw6iTwTxPjWXlfQ7Qe-ZKxVusLWhIYT8
PrepAwayPDF gives a guarantee to our customers that they can pass the Microsoft PL-200 Certification Exam on the first try by preparing from the PrepAwayPDF and if they fail to pass it despite their efforts they can claim their payment back as per terms and conditions. PrepAwayPDF facilitates customers with a 24/7 support system which means whenever they get stuck somewhere they don't struggle and contact the support system which will assist them in the right way. A lot of students have prepared from practice material and rated it positively.
Configuring the Common Data Service (25-30%)The first section entails the expertise of the candidates in:
  • Configuring Common Data Service settings (configuring Relevance Search; configuring auditing; performing data management tasks; configuring duplicate detection settings);
  • Creating and managing processes (defining the requirements for business rules; defining and implementing business rule logic; defining the scope for business rules, etc.);
  • Managing an existing data model (assigning a type for an entity, such as virtual, standard, or activity; configuring entity ownership; creating new entities or modifying existing ones, etc.);
  • Configuring security settings (creating and managing business units; creating and managing security roles; creating and manage users as well as teams, etc.).
Latest Microsoft PL-200 Test Online - PL-200 Reliable Test BraindumpsWill you feel that the product you have brought is not suitable for you? One trait of our PL-200 exam prepare is that you can freely download a demo to have a try. Because there are excellent free trial services provided by our PL-200 exam guides, our products will provide three demos that specially designed to help you pick the one you are satisfied. On the one hand, by the free trial services you can get close contact with our products, learn about the detailed information of our PL-200 Study Materials, and know how to choose the different versions before you buy our products. On the other hand, using free trial downloading before purchasing, I can promise that you will have a good command of the function of our PL-200 exam prepare. According to free trial downloading, you will know which version is more suitable for you in advance and have a better user experience.
Microsoft Power Platform Functional Consultant Sample Questions (Q75-Q80):NEW QUESTION # 75
You need to assign 10 percent of the Qualification records to the QV queue through table configuration by using a Power Automate flow.
What should you do?
  • A. Create an autonumber column on the Qualification table and assign its qualification records if the number cleanly divides by 10.
  • B. Create a roll-up column on the Service Request table that is the count of qualification records, generates a random number between zero and the number from the new field, and assigns each qualification record if the number generated is 10 percent or less of the value of the new field.
  • C. Create an autonumber column on the Service Request table and assign its qualification records if the number cleanly divides by 10.
  • D. Create a calculated column on the Service Request table that sums the number of qualification records, generates a random number between zero and the number from the new field, and assigns each qualification record if the number generated is 10 percent or less of the value of the new field.
NEW QUESTION # 76
You are designing an app for a bank.
You must create entities for the app and configure relationships between entities:
Which relationship types should you use? To answer, drag the appropriate relationship types to the correct requirements. Each relationship type may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Text Description automatically generated
Box 1: N:1
You add a lookup column with a many-to-one relationship.
Box 2: N:N
Box 3: N:1
https://docs.microsoft.com/en-us ... tform-entity-lookup
NEW QUESTION # 77
A company is creating a business process flow in Power Automate to analyze the probability that a customer will buy a specific product.
The company uses ratings from zero to one hundred. The company assigns likelihoods based on the following table:
You need to define the business process steps. All logic must be included in a single evaluation statement.
Which step should you use? To answer, drag the appropriate steps to the correct ratings. Each step may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content NOTE: Each correct selection is worth one point.
NEW QUESTION # 78
You are designing a desktop user interface (Ul) flow.
The Ul flow automates legacy software.
You need to prepare data for transfer to a Microsoft SharePoint list.
https://docs.microsoft.com/en-us ... s-to-extract-inform
NEW QUESTION # 79
You ate a Dynamics 365 Customer Engagement administrator. You create workflows to automate business processes. You need to configure a workflow to meet the following requirements:
* Be triggered when a condition is met.
* Run immediately.
* Perform an action when a condition is met.
How should you configure the workflow? To answer, select the appropriate configuration in the answer area.
1) Be triggered when a condition is met - Subject contains data
2) Run Immediately - Configure the workflow to run now
3) Perform an action when a condition is met - send an email
NEW QUESTION # 80
To help candidates study and practice the PL-200 exam questions more interesting and enjoyable, we have designed three different versions of the PL-200 test engine that provides you a number of practice ways on the exam questions and answers: the PDF, Software and APP online. The PDF verson can be printable. And the Software version can simulate the exam and apply in Windows system. The APP online version of the PL-200 training guide can apply to all kinds of the eletronic devices, such as IPAD, phone, laptop and so on.
Latest PL-200 Test Online: https://www.prepawaypdf.com/Microsoft/PL-200-practice-exam-dumps.html
2026 Latest PrepAwayPDF PL-200 PDF Dumps and PL-200 Exam Engine Free Share: https://drive.google.com/open?id=1Xw6iTwTxPjWXlfQ7Qe-ZKxVusLWhIYT8
Posted at 2/19/2026 21:53:13        Only Author  2#
The content of this article is thought-provoking, thank you for sharing! The Sample CLT questions pdf platform offers detailed material at no cost, aimed at assisting you.
