[General] Salesforce AP-219 New Braindumps Questions | AP-219 Real Questions
110
【General】 Salesforce AP-219 New Braindumps Questions | AP-219 Real Questions
Posted at 1/23/2026 15:50:47      View:179 | Replies:3        Print      Only Author   [Copy Link] 1#
According to the different demands from customers, the experts and professors designed three different versions of our AP-219 exam questions for all customers. According to your need, you can choose the most suitable version of our AP-219 guide torrent for yourself. The three different versions have different functions. If you decide to buy our AP-219 Test Guide, the online workers of our company will introduce the different function to you. You will have a deep understanding of the three versions of our AP-219 exam questions. We believe that you will like our AP-219 study guide.
If you do not know how to pass the exam more effectively, I'll give you a suggestion is to choose a good training site. This can play a multiplier effect. FreePdfDump site has always been committed to provide candidates with a real Salesforce AP-219 Certification Exam training materials. The FreePdfDump Salesforce AP-219 Certification Exam software are authorized products by vendors, it is wide coverage, and can save you a lot of time and effort.
AP-219 Real Questions | AP-219 New Dumps FilesOur AP-219 study materials boost the function to stimulate the real exam. The clients can use our software to stimulate the real exam to be familiar with the speed, environment and pressure of the real AP-219 exam and get a well preparation for the real exam. Under the virtual exam environment the clients can adjust their speeds to answer the AP-219 Questions, train their actual combat abilities and be adjusted to the pressure of the real test. They can also have an understanding of their mastery degree of our AP-219 study materials. The clients can use our software to stimulate the real exam at any time and there are no limits for the times of stimulation.
Salesforce AP-219 Exam Syllabus Topics:
  • User Experience and Customization: Customizing Lightning UI for different user roles using declarative tools like Lightning Page Editor and Report Builder.
  • Deployment and Debugging: Deployment options, lifecycle management, building processes with pre-configured data, and understanding supporting objects and system runtime.
  • Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q98-Q103):NEW QUESTION # 98
A customer wants to change the layout of the out of the box Order Summary Lightning Record Page to three columns instead of two. How can an administrator satisfy this requirement?
  • A. Change the page layout template to Three Regions in the layout editor
  • B. Create a new Lightning Record Page and select the ThreeRegions template
  • C. Edit the Lightning Record Page and change the Template lo Three Regions
  • D. Add another column component lo the existing Lightning Record Page
The bestway for the administrator to satisfy this requirement is to edit the Lightning Record Page and change the Template to Three Regions. A Lightning Record Page is a type of page that displays details and related information about a specific record in Lightning Experience or Salesforce mobile app. A Lightning Record Page can be customized using the Lightning App Builder, which is a tool that allows administrators to drag and drop components onto a page layout. A Template is a predefined layout that determines how components are arranged on a page. A Three Regions template is a type of template that divides the page into three columns or regions. The administrator can edit the Lightning Record Page for the Order Summary object, and change the Template to Three Regions in the Lightning App Builder. Verified Reference: https://help.salesforce.com/s/ar ... ages.htm&type=5[/url]
NEW QUESTION # 99
What are two reasons for using Flows instead of Apex code?
  • A. Flows have better performance options for large batches of records
  • B. Flows can be triggered by undelete events
  • C. Flows can be modified and created without a developer
  • D. Flows provide a visual debug process
Two reasons for using Flows instead of Apex code are:
Flows can be modified and created without a developer. Flows are declarative tools that allow administrators to build complex business logic using clicks instead of code. Flows do not require any programming skills or knowledge, and they can be easily modified and maintained by administrators.
Flows provide a visual debug process. Flows have a built-in debugger that allows administrators to test and troubleshoot their flows in a graphical interface. The debugger shows the flow execution path, the values of variables and sObject fields, and any errors or warnings that occur in the flow.
Verified Reference: https://help.salesforce.com/s/ar ... lder.htm&type=5 https://help.salesforce.com/s/ar ... ebug.htm&type=5
NEW QUESTION # 100
Which two practices ate needed for a custom attribute to map into Order Management assumingthe attribute has been created on the necessary objects?
  • A. The types must match within reason
  • B. The names must only contain letters and underscores
  • C. The names must be an exact match
  • D. The types must be an exact match (i.e. String to String)
Two practices that are needed for a custom attribute to map into Order Management assuming the attribute has been created on the necessary objects are:
The types must match within reason. The data type of the custom attribute in Order Managementmust match or be compatible with the data type of the corresponding attribute in the external system, such as B2C Commerce or B2B Commerce. For example, if the attribute is a string in B2C Commerce, it must also be a string in Order Management.
The namesmust be an exact match. The name of the custom attribute in Order Management must be exactly the same as the name of the corresponding attribute in the external system, including capitalization and punctuation. For example, if the attribute is named "kitItem" in B2C Commerce, it must also be named "kitItem" in Order Management.
Verified Reference: https://documentation.b2c.commer ... stomAttributes.html
NEW QUESTION # 101
What two tools can an administrator use to debug an issue with an Apex trigger?
  • A. Apex Logs in Setup
  • B. Error Logs in the Developer Console
  • C. Log Inspector in the Developer Console
  • D. Debug Logs in Setup
The administrator can use two tools to debug an issue with an Apex trigger: Log Inspector in the Developer Console and Debug Logs in Setup. The Log Inspector is a tool that displays agraphical representation of a debug log, which is a record of database operations, system processes, and errors that occur when executing a transaction or running unit tests. The Log Inspector helps you analyze and troubleshoot your code by highlighting errors, checkpoints, and execution times. The Debug Logs page in Setup lets you monitor and retain debug logs for users, Apex classes, Apex triggers, and Lightning components. You can view, download, or delete debug logs from this page.
NEW QUESTION # 102
What object must an admin populate to create digital wallet type payment methods, such as ApplePay or Electronic Gift Certificate?
  • A. GtwyProvPaymentMethodType
  • B. CardPaymentMethod
  • C. PaymentGatewayProvider
  • D. AlternativePaymentMethod
NEW QUESTION # 103
Are you ready to accept this challenge? Looking for the simple, quick, and easiest way to pass the career advancement Salesforce Order Management Administrator Accredited Professional (AP-219) certification exam? If your answer is yes then you do not need to worry about it. Just visit the FreePdfDump and explore the top features of Salesforce Order Management Administrator Accredited Professional (AP-219) exam practice test questions offered by the trusted platform FreePdfDump. With FreePdfDump AP-219 Dumps questions you can easily prepare well and feel confident to pass the final Salesforce Order Management Administrator Accredited Professional exam easily.
AP-219 Real Questions: https://www.freepdfdump.top/AP-219-valid-torrent.html
Posted at 1/23/2026 17:01:57        Only Author  2#
I’m really thankful for your article, it’s truly unforgettable. I advanced with the Professional-Cloud-Network-Engineer new exam guide files, earning a promotion and salary increase. Now, it’s free for everyone. Best of luck with your own promotions!
Posted at 1/24/2026 23:07:26        Only Author  3#
Your article is a work of art, thank you for sharing it with us! Good luck! Here are the New FCP_FGT_AD-7.6 test guide materials shared for free.
Posted at 1/28/2026 16:09:04        Only Author  4#
Amazon인증 SAA-C03시험을 패스하는 지름길은KoreaDumps에서 연구제작한 Amazon 인증SAA-C03시험대비 덤프를 마련하여 충분한 시험준비를 하는것입니다. 덤프는 Amazon 인증SAA-C03시험의 모든 범위가 포함되어 있어 시험적중율이 높습니다. Amazon 인증SAA-C03시험패는 바로 눈앞에 있습니다. 링크를 클릭하시고KoreaDumps의Amazon 인증SAA-C03시험대비 덤프를 장바구니에 담고 결제마친후 덤프를 받아 공부하는것입니다.
