[Hardware] USB C port
19
Hardware USB C port
Posted at 12/6/2024 15:45:24      View2060 | Replies2        Print      Only Author   [Copy Link] 1#
Please tell me if I can use the Firefly ROC-RK3328-PC USB type C female port for connecting anything other than charger? I connect a hub with a USB C male connector to it, and the board starts up normally, but does not see the mouse and keyboard connected to the hub. It turns out that the USB C port on it is only for charging? Thanks in advance.
Posted at 5/19/2025 10:05:17        Only Author  2#
The primary objective in repo is to locate, transport, and extract valuable items from haunted environments. Players must handle objects carefully, as even minor mishaps can lead to mission failure.
Posted at 1/9/2026 13:58:30        Only Author  3#
ھWMdVCESoftṩPSAP C_TS4FI_2023 JCԇIJֿԇ}ʹ𰸣Lԇz҂Ʒ|ֻҪxُIVCESoftĮaƷVCESoft͕Mȫһͨ^SAP C_TS4FI_2023 JCԇ
