[General] Microsoft MB-820 Exam Sample Questions - MB-820 Latest Test Discount
53
General Microsoft MB-820 Exam Sample Questions - MB-820 Latest Test Discount
Posted at 1/23/2026 17:33:51      View152 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4pass MB-820 dumps for free: https://drive.google.com/open?id=1OFR6Bf4ANWQkSRO5HaBP7hmNJaNDI4Ke
To address the problems of Microsoft Dynamics 365 Business Central Developer (MB-820) exam candidates who are busy, Prep4pass has made the Microsoft Dynamics 365 Business Central Developer (MB-820) dumps PDF format of real Microsoft Dynamics 365 Business Central Developer (MB-820) exam questions. This format's feature to run on all smart devices saves your time. Because of this, the portability of Microsoft Dynamics 365 Business Central Developer (MB-820) dumps PDF aids in your preparation regardless of place and time restrictions.
Microsoft MB-820 Exam Syllabus Topics:
  • Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
  • Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
  • Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
Topic 5
  • Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
MB-820 Latest Test Discount | MB-820 Sample QuestionsIf we want to survive in this competitive world, we need a comprehensive development plan to adapt to the requirement of modern enterprises. We sincerely recommend our MB-820 preparation exam for our years dedication and quality assurance will give you a helping hand on the MB-820 Exam. There are so many advantages of our MB-820 study materials you should spare some time to get to know. Just have a try and you will love our MB-820 exam questions.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q37-Q42):NEW QUESTION # 37
You are developing a test application to test the posting process of a sales order. You must provide the following implementation:
* Specify the value of post options (dialog: Ship, Invoice, Ship & Invoice) as Invoice.
* Perform calculations and values checking.
You need to complete the development of the test codeunit.
Which methods should you use? To answer, move the appropriate methods to the correct implementation. You may use each method once, more than once, or not at all. You may need to move the split bar between panes or scroll to view content.
NEW QUESTION # 38
A company plans to change a field on the Resource Card page in a Base Application.
You need to hide the field "Unit Price" from the Resource Card page.
Which code snippet should you use?
  • A.
  • B.
  • C.
  • D.
To hide the field "Unit Price" from the Resource Card page in Microsoft Dynamics 365 Business Central, you need to modify the visibility property of the field using the modify keyword, which allows you to change the properties of an existing field on a page.
* modify("Unit Price") is the correct way to target an existing field on a page (like the Resource Card page).
* The line Visible = false; makes the field invisible on the page.
Here's a breakdown of why each option is right or wrong:
* Option A:
* Uses addlast("Unit Price"), which is incorrect because you are not adding a new field; you're modifying an existing one. Also, Visible = false is correct for hiding a field, but the wrong method (addlast) is used.
* Option B:
* Uses modify("Unit Price") with Enabled = false;. This would disable the field (make it non- editable), not hide it. The field would still be visible, so this does not meet the requirement.
* Option C:
* Uses addlast("Unit Price"), which is incorrect, and Enabled = false;, which would disable the field, not hide it.
* Option D:
* modify("Unit Price") { Visible = false; } is the correct syntax for hiding the field on the page.
Correct Code Snippet:
Visible = false;
This hides the "Unit Price" field from the Resource Card page.
NEW QUESTION # 39
You create a table with fields.
You observe errors in the code
You need to resolve the errors.
* In line 12, declare "Job Task" as a variable. = NO
* Add the property FieldClass = FlowField; for field 3. = YES
* Add the property FieldClass = FlowFilter; for field 3. = NO
* In line 23, assign the "User Setup" table to a field. = YES
For "In line 12, declare 'Job Task' as a variable": In the AL code provided, the "Job Task" appears to be part of a CalcFormula of a FlowField, which means it references a table and not a variable. The "Job Task" does not need to be declared as a variable because it is used to reference a table in a CalcFormula expression.
For "Add the property FieldClass = FlowField; for field 3": The line of code CalcFormula = sum("Job Task
"."Recognized Sales Amount" where("Job No." = field("No."))); indicates that this field is calculated from other table data, which is the definition of a FlowField. Therefore, adding the property FieldClass = FlowField; is necessary for the field to function correctly.
For "Add the property FieldClass = FlowFilter; for field 3": FlowFilters are used to filter data based on the value in a flow field. Since field 3 is using a CalcFormula to sum values, it is a FlowField and not a FlowFilter. Therefore, this statement is not correct.
For "In line 23, assign the 'User Setup' table to a field": The line TableRelation = "User Setup"; suggests that the "Project Manager" field has a relation to the "User Setup" table, which is a method of assigning a table to a field to ensure that the values in "Project Manager" correspond to values in the "User Setup" table.
Hence, this statement is true.
NEW QUESTION # 40
You have the following XML file sample for the Items list:
You plan to create the next XML file by using an XMLport object.
You need to complete the code segment to export the file in the required format How should you complete the code segment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 41
You are writing a procedure to block all inventory items with numbers that do not start with the letter S.
You need to complete the procedure.
How should you complete the code expressions? To answer, select the appropriate options in the answer area.
procedure BlockNonSItems()
var
Item: Record Item;
begin
// Reset the Item record to clear any previous filters.
Item.Reset();
// Set the filter to exclude items that start with 'S'.
Item.SetFilter("No.", '<>%1*', 'S');
// Find each item that matches the filter.
if Item.FindSet() then
repeat
// Set the Blocked field to true to block the item.
Item.Blocked := true;
// Save the changes to the Item record.
Item.Modify();
until Item.Next() = 0; // Continue until no more items are found.
end;
NEW QUESTION # 42
The Prep4pass MB-820 Practice Questions are designed and verified by experienced and renowned MB-820 exam trainers. They work collectively and strive hard to ensure the top quality of MB-820 exam practice questions all the time. The MB-820 Exam Questions are real, updated, and error-free that helps you in Microsoft MB-820 exam preparation and boost your confidence to crack the upcoming MB-820 exam easily.
MB-820 Latest Test Discount: https://www.prep4pass.com/MB-820_exam-braindumps.html
P.S. Free 2026 Microsoft MB-820 dumps are available on Google Drive shared by Prep4pass: https://drive.google.com/open?id=1OFR6Bf4ANWQkSRO5HaBP7hmNJaNDI4Ke
Posted at 2/1/2026 18:14:40        Only Author  2#
What a stunning article, thank you for sharing this amazing piece! Good luck with your exam! Here are the free CRISC test questions vce materials.
