[Hardware] Exam Plat-Dev-301 Duration, Reliable Plat-Dev-301 Test Simulator
102
【Hardware】 Exam Plat-Dev-301 Duration, Reliable Plat-Dev-301 Test Simulator
Posted at 1/23/2026 18:01:10      View:152 | Replies:3        Print      Only Author   [Copy Link] 1#
Only by practising our Plat-Dev-301 exam braindumps on a regular base, you will see clear progress happened on you. Besides, rather than waiting for the gain of our Plat-Dev-301 practice guide, you can download them immediately after paying for it, so just begin your journey toward success now. With our Plat-Dev-301 learning questions, you will find that passing the exam is as easy as pie for our Plat-Dev-301 study materials own 100% pass guarantee.
The Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) PDF dumps provide you with everything that you must need in Plat-Dev-301 exam preparation and enable you to crack the final Plat-Dev-301 exam quickly. The Salesforce Plat-Dev-301 Exam Questions are being updated on a regular basis. As you know the Plat-Dev-301 exam syllabus is being updated on a regular basis.
Reliable Plat-Dev-301 Test Simulator, Plat-Dev-301 Valid Exam Experiencewe will provide you with the best Salesforce Plat-Dev-301 exam dumps. You can pass the Salesforce Plat-Dev-301 exam with high marks with the help of the Salesforce Plat-Dev-301 exam questions. These Salesforce Plat-Dev-301 exam practice questions are designed and verified by experienced and qualified Plat-Dev-301 Exam Preparation trainers. They work together and put all their expertise and knowledge while verifying Plat-Dev-301 exam questions all the time.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q111-Q116):NEW QUESTION # 111
Refer to the following code snippet:
A developer created a JavaScript function as part of a Lightning web component (LWC) that surfaces information about Leads by wire calling geyFetchLeadList whencertain criteria are met. Which three changes should the developer implement in the Apex class above to ensure the LWC can display data efficiently while preserving security? Choose 3 answers
  • A. Use the WZ E D clause within the SOQL query.
  • B. Annotate the Apex method with @AuraEnabled(Cacheable=True).
  • C. Implement the with sharing keyword in the class declaration.
  • D. Implement the with keyword in the class declaration.
  • E. Annotate the Apex method with @AuraEnabled.
Answer: B,C,E
The Apex class needs to have the method annotated with @AuraEnabled to expose it to the LWC. The 'with sharing' keyword ensures that the data access is enforced according to the user's permissions. @AuraEnabled(cacheable=true) allows client-side caching for improved performance.
@AuraEnabled Annotation: Apex Developer Guide
Enforcing Sharing Rules: Apex Developer Guide
NEW QUESTION # 112
How should a developer verify that a specific Account record is being tested in a test class for a Visualforce controller?
  • A. Insert the Account in the test class, instantiate the page reference in the test class, then use System.currentFageReference() .getFarameters() .put{) to set the Account ID.
  • B. Insert the Account into Salesforce, instantiate the page reference in the test class, then use system. setFarentRecordId() .get() to set the Account ID.{of Instantiate the page reference in the test class, insert the Account inthe test class, then use =seeAllData=trus to view the Account.
  • C. Instantiate the page reference in the test class, insert the Account inthe test class, then use system.setFarentRecordrd() .get() to set the Account ID,
To test a Visualforce controller that works with specific records, you should insert the necessary test data in the test class. Then instantiate a PageReference for the Visualforce page, set the record id in the page parameters, and use System.currentPageReference().getParameters().put('id', recordId) to simulate navigating to the page with that record.
NEW QUESTION # 113
Universal Containers (UC) has an ERP system that stores customer Information, When an Account is created in Salesforce, the ERP system's REST endpoint for creating new customers must automatically be called with the Account information. If the call to the ERP system falls, the Account should still be created. Accounts in the UC org are only created, one at a time, by users in the UC customer on-boarding department.
What should a developer implement to make the call to the ERP
system's REST endpoint?
  • A. Call a Queueable from a Trigger
  • B. REST call from JavaScript
  • C. Apex Continuation
  • D. Headless Quick Action
Since the requirement is to make a callout to an external ERP system when an Account is created and still allow for the Account creation even if the call fails, a Queueable class called from a trigger is the best solution. Queueable Apex allows you to submit jobs for asynchronous processing similar to future methods but with additional benefits such as chaining jobs and monitoring the job status.
By using a Queueable, the callout can be made after the Account is created, which respects the Salesforce order of execution and avoids the limitation of callouts not being allowed after DML operations in the same transaction. This approach also does not block the user interface or the creation of the Account record if the callout to the ERP system takes a long time or fails.
Salesforce Documentation on Queueable Apex: Using Queueable Apex to Perform Jobs Salesforce Developer Guide on Asynchronous Apex: Queueable Apex
NEW QUESTION # 114
A company needs to automatically delete sensitive information after seven years.
This could delete almost a million records every day.
How can this be achieved?
  • A. Use aggregate functions to query for records older than seven years, and then delete the aggrigateResults objects.{civ [+] Schedule a batch Apex process to run every day that queries and deletes records older than seven years.
  • B. Schedule an @fuzure process to query records older than seven years, and then recursively invoke itself in 1,000 record batches to delete them,
  • C. Perform a SOSL statement to find records older than 7 years, and then delete the entire result set.
Batch Apex is designed to handle large data operations by breaking the transaction into smaller batches. Scheduling a batch process to run daily enables the system to manage the deletion of large numbers of records efficiently, without hitting governor limits. It's the best practice for performing mass deletions on a regular schedule.
Using Batch Apex
NEW QUESTION # 115
Which method should be used to convert a Date to a String in the current user's locale?
  • A. Date.paras
  • B. String.valueof
  • C. Date. format
  • D. String.format
The format method of the Date class is used to convert a Date to a String formatted in the current user's locale. This respects the locale settings of the user context under which the code is running, ensuring the date is represented in a way that is familiar to the user.
NEW QUESTION # 116
DumpsQuestion offers you a full refund if you are not able to pass the Plat-Dev-301 certification exams after preparing with our products. The high quality of Plat-Dev-301 certification exam preparation products increases your success probability and reduces the chances of failure. The Plat-Dev-301 exam preparation products contain all the features to make you ready for embracing success in a first attempt. These Plat-Dev-301 Exam Preparation products are updated regularly for guaranteed success. Free demo is also offered to the users for checking the Plat-Dev-301 exam preparation products quality.
Reliable Plat-Dev-301 Test Simulator: https://www.dumpsquestion.com/Plat-Dev-301-exam-dumps-collection.html
Salesforce Exam Plat-Dev-301 Duration It is hard to find a high salary job than before, It is a common sense that only high quality and accuracy Plat-Dev-301 practice materials can relive you from those worries, Salesforce Plat-Dev-301 exam demo is ready for download and full version is available for instant purchase through MacAfee Secure payment method, When you place your order, we will send Salesforce Developer Plat-Dev-301 vce practice to your mailbox immediately.
This section covers five basic high-level structural patterns Plat-Dev-301 for a common information model, The score that the candidate gets in this part is not added to the overall score report.
It is hard to find a high salary job than before, It is a common sense that only high quality and accuracy Plat-Dev-301 practice materials can relive you from those worries.
Free PDF Quiz Valid Salesforce - Exam Plat-Dev-301 DurationSalesforce Plat-Dev-301 exam demo is ready for download and full version is available for instant purchase through MacAfee Secure payment method, When you place your order, we will send Salesforce Developer Plat-Dev-301 vce practice to your mailbox immediately.
Our passing rate of candidates who purchase our Plat-Dev-301 actual test questions and answers is high up to 99.16%.
Posted at 1/26/2026 19:33:06        Only Author  2#
I sincerely thank you for sharing such a shocking article! Wishing you all the best of luck! Here’s the free Rev-Con-201 test notes material.
Posted at 2/17/2026 21:41:25        Only Author  3#
Can’t resist liking this great content. OGBA-101 reliable test cram materials questions shared for free—unlock promotions and salary increases!
Posted at 4/19/2026 18:43:01        Only Author  4#
This article is absolutely inspiring, thank you for sharing! Pdf Databricks-Generative-AI-Engineer-Associate torrent is a free resource, full of valuable content to help you succeed.
