Pass Guaranteed 2026 DVA-C02: Pass-Sure 100% AWS Certified Developer - Associate
Posted at 1/23/2026 18:35:33
View142
Replies1
DOWNLOAD the newest PDF4Test DVA-C02 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-DRRiQNtxX5eXwUhBCW4pMZ9nAKrbSLw
Desktop AWS Certified Developer - Associate (DVA-C02) practice exam software also keeps track of the earlier attempted DVA-C02 practice test so you can know mistakes and overcome them at each and every step. The Desktop DVA-C02 Practice Exam software is created and updated in a timely by a team of experts in this field. If any problem arises, a support team is there to fix the issue.
Amazon DVA-C02 (AWS Certified Developer - Associate) Exam is a certification exam that is designed to test the knowledge and skills of individuals who are interested in becoming AWS Certified Developers. DVA-C02 exam is ideal for developers who have experience in developing and maintaining applications on the AWS platform. DVA-C02 exam assesses the candidate's ability to design, develop, and deploy cloud-based solutions using AWS services and tools.
Amazon DVA-C02 exam covers a range of topics related to AWS services, including AWS Compute, AWS Storage, AWS Databases, AWS Security, AWS Management Tools, and AWS Application Integration. DVA-C02 Exam is designed to test an individual's knowledge and understanding of these services, as well as their ability to design and implement solutions that are secure, scalable, and highly available. DVA-C02 exam is also designed to test an individual's ability to troubleshoot and optimize applications on AWS, as well as their ability to use AWS services and tools to automate and streamline deployment and management processes. For individuals who are interested in pursuing a career in cloud computing or who want to enhance their skills and knowledge in AWS, the Amazon DVA-C02 exam is an excellent option to consider.
DVA-C02 Online Training | DVA-C02 Pass GuaranteedIf you want to demonstrate your expertise in solving complex Amazon real-life problems, then you need to pass the Amazon DVA-C02 certification exam. However, passing this exam is not an easy task. It requires you to master complicated subjects related to AWS Certified Developer - Associate. To help you prepare for this exam, PDF4Test offers verified Amazon DVA-C02 Exam Questions that are ruling the preparation world.
Amazon AWS Certified Developer - Associate Sample Questions (Q383-Q388):NEW QUESTION # 383
A developer wants to insert a record into an Amazon DynamoDB table as soon as a new file is added to an Amazon S3 bucket.
Which set of steps would be necessary to achieve this?
- A. Create an AWS Lambda function that will poll the S3 bucket and then insert the records into DynamoDB.
- B. Configure an S3 event to invoke an AWS Lambda function that inserts records into DynamoDB.
- C. Create a cron job that will run at a scheduled time and insert the records into DynamoDB.
- D. Create an event with Amazon EventBridge that will monitor the S3 bucket and then insert the records into DynamoDB.
Amazon S3 is a service that provides highly scalable, durable, and secure object storage. Amazon DynamoDB is a fully managed NoSQL database service that provides fast and consistent performance with seamless scalability. AWS Lambda is a service that lets developers run code without provisioning or managing servers.
The developer can configure an S3 event to invoke a Lambda function that inserts records into DynamoDB whenever a new file is added to the S3 bucket. This solution will meet the requirement of inserting a record into DynamoDB as soon as a new file is added to S3.
* [Amazon Simple Storage Service (S3)]
* [Amazon DynamoDB]
* [What Is AWS Lambda? - AWS Lambda]
* [Using AWS Lambda with Amazon S3 - AWS Lambda]
NEW QUESTION # 384
A developer is using AWS CodeDeploy to automate a company's application deployments to Amazon EC2.
Which application specification file properties are required to ensure the software deployments do not fail? (Choose two.)
- A. The file must be a JSON-formatted file named appspec.json.
- B. The file must be a YAML-formatted file named appspec.yml.
- C. The file must be placed in the root of the directory structure of the application's source code.
- D. The file must be stored in AWS CodeBuild and referenced from the application's source code.
- E. The file must be stored in Amazon S3 and referenced from the application's source code.
To ensure successful software deployments using AWS CodeDeploy, the application specification file (appspec.yml or appspec.json) must adhere to specific requirements:
File Format Requirement (Option B):
The appspec.yml file is a YAML-formatted file required for defining deployment actions and file locations. This is the modern and recommended format for application specification files. It can also be a JSON-formatted file named appspec.json, but YAML is most commonly used and accepted.
File Placement Requirement (Option D):
The application specification file must reside in the root directory of the application's source code.
This is necessary so that AWS CodeDeploy can detect and use the file during deployment.
NEW QUESTION # 385
A developer is creating an application that will give users the ability to store photos from their cellphones in the cloud. The application needs to support tens of thousands of users. The application uses an Amazon API Gateway REST API that is integrated with AWS Lambda functions to process the photos. The application stores details about the photos in Amazon DynamoDB.
Users need to create an account to access the application. In the application, users must be able to upload photos and retrieve previously uploaded photos. The photos will range in size from 300 KB to 5 MB.
Which solution will meet these requirements with the LEAST operational overhead?
- A. Create a users table in DynamoDB. Use the table to manage user accounts. Create a Lambda authorizer that validates user credentials against the users table. Integrate the Lambda authorizer with API Gateway to control access to the API. Use the Lambda function to store the photos in Amazon S3. Store the object's S3 key as par of the photo details in the DynamoDB table. Retrieve previously uploaded photos by querying DynamoDB for the S3 key.
- B. Create an IAM user for each user of the application during the sign-up process. Use IAM authentication to access the API Gateway API. Use the Lambda function to store the photos in Amazon S3. Store the object's S3 key as part of the photo details in the DynamoDB table. Retrieve previously uploaded photos by querying DynamoDB for the S3 key.
- C. Use Amazon Cognito user pools to manage user accounts. Create an Amazon Cognito user pool authorizer in API Gateway to control access to the API. Use the Lambda function to store the photos in Amazon S3. Store the object's S3 key as part of the photo details in the DynamoDB table. Retrieve previously uploaded photos by querying DynamoDB for the S3 key.
- D. Use Amazon Cognito user pools to manage user accounts. Create an Amazon Cognito user pool authorizer in API Gateway to control access to the API. Use the Lambda function to store the photos and details in the DynamoDB table. Retrieve previously uploaded photos directly from the DynamoDB table.
NEW QUESTION # 386
A developer has a continuous integration and continuous delivery (CI/CD) pipeline that uses AWS CodeArtifact and AWS CodeBuild. The build artifacts are between 0.5 GB and 1.5 GB in size.
The builds happen frequently and retrieve many dependencies from CodeArtifact each time.
The builds have been slow because of the time it takes to transfer dependencies. The developer needs to improve build performance by reducing the number of dependencies that are retrieved for each build.
Which solution will meet this requirement?
- A. Specify an Amazon S3 cache in CodeBuild. Add the S3 cache folder path to the buildspec.yaml file for the build project.
- B. Specify a local cache in CodeBuild. Add the CodeArtifact repository name to the buildspec.yaml file for the build project.
- C. Retrieve the buildspec.yaml file directly from CodeArtifact. Add the CodeArtifact repository name to the buildspec.yaml file for the build project.
- D. Specify a local cache in CodeBuild. Add the cache folder path to the buildspec.yaml file for the build project.
Using a local cache in CodeBuild allows you to cache dependencies locally on the build host, which can significantly reduce the time it takes to retrieve dependencies during subsequent builds.
NEW QUESTION # 387
A company is building a new application that runs on AWS and uses Amazon API Gateway to expose APIs Teams of developers are working on separate components of the application in parallel The company wants to publish an API without an integrated backend so that teams that depend on the application backend can continue the development work before the API backend development is complete.
Which solution will meet these requirements?
- A. Create an AWS Lambda function that returns mocked responses and various HTTP status codes. Create API Gateway resources and set the integration type value to AWS_PROXY Deploy the API.
- B. Create API Gateway resources and set the integration type value set to HTTP_PROXY. Add mapping templates and deploy the API. Create an AWS Lambda layer that returns various HTTP status codes Associate the Lambda layer with the API deployment
- C. Create API Gateway resources and set the integration type value to MOCK Configure the method integration request and integration response to associate a response with an HTTP status code Create an API Gateway stage and deploy the API.
- D. Create an EC2 application that returns mocked HTTP responses Create API Gateway resources and set the integration type value to AWS Create an API Gateway stage and deploy the API.
* API Gateway Mocking: This feature is built for decoupling development dependencies. Here's the process:
* Create resources and methods in your API Gateway.
* Set the integration type to 'MOCK'.
* Define Integration Responses, mapping HTTP status codes to desired mocked responses (JSON, etc.).
* Deployment and Use:
* Create a deployment stage for the API.
* Frontend teams can call this API and get the mocked responses without a real backend.
* Mocking API Gateway APIs: https://docs.aws.amazon.com/apig ... eloperguide/how-to- mock-integration.html
NEW QUESTION # 388
As far as the DVA-C02 practice test are concerned, these DVA-C02 practice questions are designed and verified by the experience and qualified Amazon DVA-C02 exam trainers. They work together and strive hard to maintain the top standard of DVA-C02 exam practice questions all the time. So you rest assured that with the Amazon DVA-C02 Exam Dumps you will ace your Amazon DVA-C02 exam preparation and feel confident to solve all questions in the final Amazon DVA-C02 exam.
DVA-C02 Online Training: https://www.pdf4test.com/DVA-C02-dump-torrent.html
- Reliable DVA-C02 Exam Guide 🦃 New DVA-C02 Real Exam 🤔 Review DVA-C02 Guide 🕦 Open [url]www.easy4engine.com enter ▷ DVA-C02 ◁ and obtain a free download 🖼Accurate DVA-C02 Study Material[/url]
- Best Amazon DVA-C02 test training guide 🎧 Open website ➤ [url]www.pdfvce.com ⮘ and search for ☀ DVA-C02 ️☀️ for free download 🏣DVA-C02 Reliable Test Pattern[/url]
- Best Amazon DVA-C02 test training guide 🚥 Search for ➥ DVA-C02 🡄 on ⮆ [url]www.troytecdumps.com ⮄ immediately to obtain a free download 🥧Exam DVA-C02 Simulator Online[/url]
- DVA-C02 Reliable Test Pattern ⚗ DVA-C02 Valid Practice Materials 💛 New DVA-C02 Real Exam 🕖 Go to website [url]www.pdfvce.com open and search for ➡ DVA-C02 ️⬅️ to download for free ✔DVA-C02 Dumps Torrent[/url]
- DVA-C02 Valid Practice Materials 🚮 Exam DVA-C02 Simulator Online 🕣 New DVA-C02 Real Exam 🍞 Search for DVA-C02 and easily obtain a free download on [url]www.dumpsquestion.com 🥓Dumps DVA-C02 Reviews[/url]
- Quiz 2026 Amazon Unparalleled DVA-C02: 100% AWS Certified Developer - Associate Exam Coverage 🦀 Search on [url]www.pdfvce.com for ➠ DVA-C02 🠰 to obtain exam materials for free download 😍New DVA-C02 Study Notes[/url]
- Exam DVA-C02 Simulator Online 🍰 Accurate DVA-C02 Study Material 💝 DVA-C02 Test Prep 📊 Download DVA-C02 for free by simply searching on ▷ [url]www.verifieddumps.com ◁ ✒New DVA-C02 Test Papers[/url]
- Pdfvce DVA-C02 Exam Dumps Offers Exam Passing Money Back Guarantee 🥼 Search for DVA-C02 on ✔ [url]www.pdfvce.com ️✔️ immediately to obtain a free download 💠New DVA-C02 Learning Materials[/url]
- Top 100% DVA-C02 Exam Coverage 100% Pass | High Pass-Rate DVA-C02 Online Training: AWS Certified Developer - Associate 🌴 Search for ☀ DVA-C02 ️☀️ and download exam materials for free through ➽ [url]www.practicevce.com 🢪 🏢Accurate DVA-C02 Study Material[/url]
- Pdfvce DVA-C02 Exam Dumps Offers Exam Passing Money Back Guarantee 🕤 Open ➠ [url]www.pdfvce.com 🠰 and search for ➥ DVA-C02 🡄 to download exam materials for free 🐣DVA-C02 Reliable Test Pattern[/url]
- Amazon DVA-C02 BY USING DVA-C02 EXAM QUESTIONS 🕊 Search on ✔ [url]www.prep4sures.top ️✔️ for ▛ DVA-C02 ▟ to obtain exam materials for free download 🗾New DVA-C02 Real Exam[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
