[General] Downloadable XSOAR-Engineer PDF - XSOAR-Engineer Reliable Exam Testking
72
General Downloadable XSOAR-Engineer PDF - XSOAR-Engineer Reliable Exam Testking
Posted at 1/23/2026 18:48:35      View136 | Replies0        Print      Only Author   [Copy Link] 1#
TestSimulate offers verified, authentic Palo Alto Networks XSOAR-Engineer Real Questions and answers, which are essential for passing the Palo Alto Networks XSOAR Engineer (XSOAR-Engineer). These questions and answers have been designed by Sitecore experts and can be easily downloaded on a PC, MacBook, or smartphone for comfortable and convenient learning.
Palo Alto Networks XSOAR-Engineer Exam Syllabus Topics:
  • Incident Interactions and Reporting: This domain covers incident operations including states and actions, War Room activities, incident relationships, and dashboard and report configuration for metrics and visualization.
  • Threat Intelligence Management: This domain focuses on threat intelligence operations including indicator creation and configuration, indicator relationships, enrichment with source reliability, external intelligence sharing, and exclusion list management.
  • Planning, Installation, and Maintenance: This domain covers system setup and administration including authentication configuration, engine deployment, dev
  • prod environment planning, Marketplace pack management, integration instance configuration, and system maintenance.
  • Use Case Planning and Development: This domain focuses on designing security use cases through incident and indicator lifecycle management, field and layout customization, classifier and mapper configuration, incident creation methods, pre
  • post-processing, and incident type configuration with playbooks, layouts, SLAs, and lists.
Topic 5
  • Playbook Development: This domain addresses automation through playbook creation including task configuration, context data manipulation, various task types, sub-playbooks with looping, filters and transformers, debugger usage, built-ins and scripts, automation script creation, and job management.
Pass Guaranteed Quiz XSOAR-Engineer - Useful Downloadable Palo Alto Networks XSOAR Engineer PDFThe passing rate of our XSOAR-Engineer training quiz is 99% and the hit rate is also high. Our professional expert team seizes the focus of the exam and chooses the most important questions and answers which has simplified the important XSOAR-Engineer information and follow the latest trend to make the client learn easily and efficiently. We update the XSOAR-Engineer Study Materials frequently to let the client practice more. We provide the function to stimulate the XSOAR-Engineer exam and the timing function of our XSOAR-Engineer study materials to adjust your speed to answer the questions. You will pass the XSOAR-Engineer exam easily.
Palo Alto Networks XSOAR Engineer Sample Questions (Q66-Q71):NEW QUESTION # 66
What is needed to send a survey with multiple questions to a customer?.
  • A. Section Header task.
  • B. Data Collection.
  • C. Survey task.
  • D. Conditional Ask.
XSOAR provides two types of user-interaction mechanisms in playbooks:Ask tasksandData Collection tasks
. Ask tasks present asingle questionwhose answer determines the playbook's conditional path. Conversely, Data Collection tasks are specifically designed to gathermultiple questions, forming a structured form or survey.
The Admin Guide explains that Data Collection tasks allow multiple question fields such as text input, dropdowns, yes/no responses, and date fields. These tasks may be delivered via email links, the XSOAR UI, or external response pages. Once completed, responses are automatically populated into incident fields or context keys.
A Section Header (option B) only organizes information within playbooks and layouts; it does not collect user input. Conditional Ask (option C) is strictly limited to single-question logic branching. A "Survey task" (option D) does not exist as a named task type in XSOAR; surveys are implemented through Data Collection tasks.
Thus, the correct answer isA: Data Collection, as it is the documented method for sending multi-question forms to users or customers.
NEW QUESTION # 67
Where are incident layouts customized?
  • A. Settings > Advanced > Incident Layouts
  • B. Settings > Object Setup > Indicators > Layouts
  • C. Settings > Object Setup > Incidents > Layouts
  • D. Settings > Integrations > Instance configuration
Reference: https://docs-cortex.paloaltonetw ... SOAR-Administrator- Guide/Customize-Incident-Layouts
NEW QUESTION # 68
What happens when an integration is deprecated?
  • A. The integration commands in a playbook can no longer be used
  • B. The integration commands in a playbook can be used, but it will fail at runtime
  • C. The configuration settings will be lost and the integration will no longer function
  • D. The integration commands can be used, but it is recommended to update to the latest content pack
NEW QUESTION # 69
What is a primary use case of data collection tasks?
  • A. To allow multi question surveys without authentication restrictions
  • B. To generate new widgets for a dashboard
  • C. To determine different paths in a playbook
  • D. To automate tasks such as parsing a file or enriching indicators
Reference: https://docs.paloaltonetworks.co ... oar-admin/playbooks
/playbook- tasks/communication-tasks/create-a-data-collection-task.html
NEW QUESTION # 70
What are inputs and outputs in reference to a Playbook Development Lifecycle? (Choose three.)
  • A. Outputs can be derived from the result of a task or command
  • B. Inputs are data pieces that are present in the task
  • C. Inputs are the data fields parsed by the Classifier
  • D. Inputs are data pieces that are present in the playbook
  • E. Outputs are used as incident trigger for playbook
Answer: A,C,D
NEW QUESTION # 71
The PDF file of XSOAR-Engineer real exam questions is easy to use on laptops, tablets, and smartphones. We have added all the Palo Alto Networks XSOAR-Engineer questions, which have a chance to appear in the Palo Alto Networks XSOAR-Engineer real test. Our Palo Alto Networks XSOAR Engineer (XSOAR-Engineer) dumps PDF exam questions are beneficial to prepare for the test in less time.
XSOAR-Engineer Reliable Exam Testking: https://www.testsimulate.com/XSOAR-Engineer-study-materials.html
