[General] H35-211_V2.5 Interactive EBook - H35-211_V2.5 Valid Exam Topics
72
【General】 H35-211_V2.5 Interactive EBook - H35-211_V2.5 Valid Exam Topics
Posted at 1/23/2026 18:55:48      View:146 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that Pass4sures H35-211_V2.5 dumps now are free: https://drive.google.com/open?id=19mn3yge7qI0qnT9jLMuleml2DjWhg2A9
The software creates an HCIP-Access V2.5 (H35-211_V2.5) exam-like scenario for you which helps to kill anxiety about the Huawei H35-211_V2.5 Certification Exams Questions. Customizable H35-211_V2.5 practice test software enables you to change settings of practice exam time and questions. Since the Pass4sures software tracks your progress, you can know mistakes and overcome them before the Huawei H35-211_V2.5 final test.
Huawei H35-211_V2.5 (HCIP-Access V2.5) Certification Exam is a comprehensive exam that covers a wide range of topics related to network access. H35-211_V2.5 exam covers topics such as network architecture, access protocols and technologies, network security, and network management. H35-211_V2.5 Exam also evaluates the candidate's ability to design, configure, troubleshoot, and maintain Huawei's network access solutions.
H35-211_V2.5 Valid Exam Topics | H35-211_V2.5 Latest Test FeeThere are many large and small platforms for selling examination materials in the market, which are dazzling, but most of them cannot guarantee sufficient safety and reliability. Are you worried about the security of your payment while browsing? H35-211_V2.5 Test Torrent can ensure the security of the purchase process, product download and installation safe and virus-free. If you have any doubt about this, we will provide you professional personnel to remotely guide the installation and use.
Huawei HCIP-Access V2.5 Sample Questions (Q19-Q24):NEW QUESTION # 19
The QoS should be planned according to service requirements. Generally, a service with a higher priority adopts the ( ) scheduling mode.
  • A. PQ
  • B. WRR
  • C. DRR
  • D. RR
Huawei QoS describes PQ (Priority Queuing) as the strict-priority scheduler ensuring that high-priority queues are served first before lower-priority queues. WRR/DRR/RR are weighted or round-robin modes intended for fair sharing and do not guarantee strict preemption for latency-sensitive traffic. Therefore, PQ is selected for higher-priority services (e.g., voice, control).
References: HCIP-Access V2.5 Study Guide - QoS Fundamentals and Queue Scheduling on OLT/ONU (PQ, WRR/DRR/RR behaviors).
NEW QUESTION # 20
Detection principle for GPON Type B single-homing protection switching: The standby port receives and transmits optical signals. If the standby port fails to detect upstream optical signals for four consecutive dynamic bandwidth assignment (DBA) allocation periods, an upstream optical signal interruption occurs, triggering automatic protection switching.
  • A. TRUE
  • B. FALSE
NEW QUESTION # 21
When the H.248 protocol is used to deploy the VoIP service, the registration information sent by the MG to the MGC contains the following information:
Services {Method=Restart Reason=[901]}
Which command can trigger the information?
  • A. Board restart
  • B. ONT re-register
  • C. Reset coldstart
  • D. Reboot system
The MG reports availability and restarts to the MGC using H.248 ServiceChange with Method=Restart. The Reason code distinguishes the type of restart. In Huawei implementations aligned with H.248 semantics, Reason=[901] corresponds to a warm/warmboard restart scenario rather than a full cold start.
Board restart triggers a warm restart of the voice board/MG, producing ServiceChange { Method=Restart, Reason=901 }.
Reset coldstart performs a cold start, which would use a different reason code (cold start), not 901.
Reboot system generally implies a broader device reboot similar to cold start semantics, not 901.
ONT re-register affects ONU registration and does not cause the MG to announce a ServiceChange restart to the MGC.
References: HCIP-Access V2.5 Study Guide (H.248 ServiceChange usage and restart reporting); Huawei VoIP/MG Board Maintenance Guide (warm vs cold restart indications in ServiceChange).
NEW QUESTION # 22
(Radio) Follow the multicast IP address 227.120.1.32. The correct multicast MAC address corresponding to it is:
  • A. 01-00-5e-78-01-20
  • B. 01-00-5e-14-01-20
  • C. 01-00-5e-78-01-32
  • D. 01-00-5e-14-01-32
For IPv4 multicast, the destination MAC is derived by mapping the lower 23 bits of the multicast IP address into the OUI 01-00-5E. The 4th MAC byte is the lower 7 bits of the IP's second octet (so it ranges 00-7F), and the 5th and 6th MAC bytes are the third and fourth IP octets directly:
Multicast OUI: 01-00-5E
IP: 227.120.1.32
2nd octet = 120 (0x78). Its lower 7 bits are still 0x78 (since the MSB is 0).
3rd octet = 1 (0x01)
4th octet = 32 (0x20)
Therefore the MAC is 01-00-5E-78-01-20 # option C.
(This mapping aligns with standard IPv4 multicast-to-Ethernet rules described in Huawei's multicast overview sections in HCIP-Access materials and Huawei OLT product guides.)
NEW QUESTION # 23
If the ONT zero-touch provisioning function is enabled on eSight, you can configure multiple service profiles.
Which parameters can be set on the Multi-Service Profile Management tab page?
  • A. Voice VLAN
  • B. Default VLAN
  • C. VLAN
  • D. Number of Ethernet ports
  • E. ONU type
In eSight's ONT Zero-Touch workflow, multi-service profiles define service parameters delivered to ONTs- primarily service VLANs such as Internet/Data VLAN, Voice VLAN, and IPTV/Multicast VLAN with related QoS. Hardware attributes like ONU type or Ethernet port count are part of the device/ONT profile, not the multi-service profile. A generic "Default VLAN" parameter is not used here; instead, explicit service VLANs are specified (for example, data VLAN and voice VLAN).
References: HCIP-Access V2.5 Study Guide - Network Management & Maintenance: eSight ONT Zero- Touch (multi-service profile content: data/voice/multicast VLAN parameters, QoS templates).
NEW QUESTION # 24
The H35-211_V2.5 torrent prep contains the real questions and simulation questions of various qualifying examinations. It is very worthy of study efficiently. Time is constant development, and proposition experts will set questions of real H35-211_V2.5 exam continuously according to the progress of the society change tendency of proposition, and consciously highlight the hot issues and policy changes. In order to be able to better grasp the proposition thesis direction, the H35-211_V2.5 study question focus on the latest content to help you pass the H35-211_V2.5 exam.
H35-211_V2.5 Valid Exam Topics: https://www.pass4sures.top/HCIP-Access/H35-211_V2.5-testking-braindumps.html
P.S. Free & New H35-211_V2.5 dumps are available on Google Drive shared by Pass4sures: https://drive.google.com/open?id=19mn3yge7qI0qnT9jLMuleml2DjWhg2A9
Posted at 2/4/2026 00:27:00        Only Author  2#
Your article really shocked me; thank you for sharing! The Valid exam SOA-C02 questions answers test was my key to career success. Get it for free today and start advancing your career!
