Plat-Dev-301 Vce Format, Latest Plat-Dev-301 Exam Camp
Posted at 1/23/2026 21:45:53
View148
Replies1
We make sure that the Salesforce Plat-Dev-301 exam questions prices are affordable for everyone. All three Braindumpsqa Plat-Dev-301 exam practice test questions formats are being offered at the lowest price. Just get benefits from this cheap Salesforce Certified Platform Developer II - Multiple Choice Plat-Dev-301 Exam Questions price and download it right now.
Our company has a professional team of experts to write Plat-Dev-301 preparation materials and will constantly update it to ensure that it is synchronized with the exam content. In addition to the high quality, reasonable price and so on, we have many other reasons to make you choose our Plat-Dev-301 Actual Exam. There are three versions of our Plat-Dev-301 exam questions: PDF, Software and APP online which can provide you the varied study experiences.
Salesforce Plat-Dev-301 Exam Questions - Guaranteed SuccessYou may find that on our website, we have free renewal policy for customers who have bought our Plat-Dev-301 practice quiz. You can enjoy one year free updated service. This policy greatly increase the pass percentage of the candidates if they can't pass in one time or in the limited date. And they can enjoy 50% off if they buy them again one year later. All in all, our service is completely considerate. Come to experience our Plat-Dev-301 Training Materials.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q34-Q39):NEW QUESTION # 34
Refer to the code snippet below:
A custom object called Credit_Memo__c exists in a Salesforce environment. As part of a new feature development that retrieves and manipulates this type of record, the developer needs to ensure race conditions are prevented when a set of records are modified within an Apex transaction. In the preceding Apex code, how can the developer alter the query statement to use SOQL features to prevent race conditions within a transaction? A)
B)
C)
D)
- A. Option A
- B. Option C
- C. Option D
- D. Option B
To prevent race conditions during an Apex transaction, the SOQL query can be modified to include the "FOR UPDATE" keyword. This keyword locks the records that are returned by the query, preventing other transactions from modifying them until the current transaction is complete. This ensures that the retrieved records cannot be changed by another process before the current transaction is completed, thus preventing race conditions. The correct option to use in the code snippet provided is:
[SELECT Id, Name, Amount__c FROM Credit_Memo__c WHERE Customer_Id__c = :customerId LIMIT 50 FOR UPDATE] This will lock up to 50 records of Credit_Memo__c with the specified Customer_Id__c for the duration of the transaction.
FOR UPDATE
Preventing Record Update Conflicts
NEW QUESTION # 35
A company accepts orders for customers in their enterprise resource planning (ERP) system that must be integrated into Salesforce as order_ c records with a lookup field to Account. The Account object has an external ID field, ENF_Customer_ID_c.
What should the Integration use to create new Oder_c records that will automatically be related to the correct Account?
A)
B)
C)
D)
- A. Option A
- B. Option C
- C. Option D
- D. Option B
When integrating external systems with Salesforce and creating records that need to be associated with existing Salesforce records based on an external ID, Salesforce provides the ability to reference an external ID field in a related object directly within a create or update call.
Option A is correct because the upsert operation can be used to either insert new records or update existing ones. By specifying the external ID field (ENF_Customer_ID__c) for the Account relationship, the system will automatically link the Order__c record to the correct Account based on the external ID provided by the ERP system.
Options B, C, and D are incorrect because they do not specifically utilize the capability of referencing an external ID to associate records during an integration process.
Salesforce Developer Documentation on Inserting or Updating Records Using an External ID: Inserting or Updating Records Using an External ID
NEW QUESTION # 36
A company has an Apex process that makes multiple extensive database operations and web service callouts. The database processes and web services can take a long time to run and must be run sequentially.
How should the developer write this Apex code without running into governor limits and system limitations?
- A. Use Queueable Apex to chain the jobs to run sequentially.
- B. Use multiple 3zutuze methods for each process and callout.
- C. Use Apex Scheduler to schedule each process.
- D. Use Limits class to stop entire process once governor limits are reached.
Queueable Apex is suitable for complex processes that require chaining jobs to run sequentially. It can handle long-running processes without hitting governor limits, as each chained job runs in a new transaction with its own set of governor limits.
NEW QUESTION # 37
A developer wants to write a generic Apex method that will compare the Salesforce Name field between any two object records. For example, to compare the Name field of an Account and an Opportunity; or the Name of an Account and a Contact.
Assuming the Name field exists, how should the developer do this?
- A. describe) function to compare the values of each Name field.
- B. Cast each object into an sObject and use sObject.get to compare the Name fields.
- C. Use a string. Replace () method to parse the contents of each Name field and then compare the results.
- D. Use the Salesforce Metadata API to extract the value of each object and compare the Name fields.
Casting each object to an sObject and using the get method to compare the Name fields is the correct approach. This is because sObjects are generic object representations that can be used to access the fields of any Salesforce object dynamically. Reference:
sObject Class
NEW QUESTION # 38
A developer needs to store variables to control the style and behavior of a Lightning Web Component.
Which feature can be used to ensure that the variables are testable in both Production and all Sandboxes?
- A. Custom setting
- B. Custom variable
- C. Custom metadata
- D. Custom object
Custom metadata types are the best feature for storing variables that control style and behavior of a Lightning Web Component. Unlike custom settings, custom metadata is deployable and testable in both Production and all Sandboxes.
NEW QUESTION # 39
Our experts composed the contents according to the syllabus and the trend being relentless and continuously updating in recent years. We are sufficiently definite of the accuracy and authority of our Plat-Dev-301 practice materials. They also simplify the difficulties in the contents with necessary explanations for you to notice. To make the best Plat-Dev-301 study engine, they must be fully aware of exactly what information they need to gather into our Plat-Dev-301 guide exam.
Latest Plat-Dev-301 Exam Camp: https://www.braindumpsqa.com/Plat-Dev-301_braindumps.html
We must pay more attention to the certification and try our best to gain the Plat-Dev-301 certification, If you have been using our study guide for Plat-Dev-301 exam, and you have failed the exam, then we will refund your money immediately, Allowing for your different taste and preference of Plat-Dev-301 sure-pass torrent: Salesforce Certified Platform Developer II - Multiple Choice and increasing the diversity of our products, we have prepared three versions for you, Salesforce Plat-Dev-301 Vce Format Targeting exam candidates of the exam, we have helped over tens of thousands of exam candidates achieved success now.
In light of the truth that different people have various learning habits, we launch three Plat-Dev-301 training questions demos for your guidance: the PDF, Software and the APP online.
We asked a company about a week ago if they could explain to us how Plat-Dev-301 their vendor had setup the scoring mechanisms;they had no idea, and it took us quite a while to actually extract that from the vendor.
Free PDF Salesforce - Plat-Dev-301 Accurate Vce FormatWe must pay more attention to the certification and try our best to gain the Plat-Dev-301 Certification, If you have been using our study guide for Plat-Dev-301 exam, and you have failed the exam, then we will refund your money immediately.
Allowing for your different taste and preference of Plat-Dev-301 sure-pass torrent: Salesforce Certified Platform Developer II - Multiple Choice and increasing the diversity of our products, we have prepared three versions for you.
Targeting exam candidates of the exam, we have helped over tens of thousands of exam candidates achieved success now, When you decide to pass Plat-Dev-301 exam, you must want to find a good study materials to help you prepare for your exam.
- Quiz Plat-Dev-301 - Salesforce Certified Platform Developer II - Multiple Choice CHigh-quality Vce Format 🧉 ✔ [url]www.prep4away.com ️✔️ is best website to obtain ▷ Plat-Dev-301 ◁ for free download 💭High Plat-Dev-301 Quality[/url]
- Relevant Plat-Dev-301 Answers 🕢 Plat-Dev-301 Official Practice Test 👭 Exam Vce Plat-Dev-301 Free 😟 Easily obtain free download of { Plat-Dev-301 } by searching on ▶ [url]www.pdfvce.com ◀ ⛴
lat-Dev-301 Reliable Test Pdf[/url] - Plat-Dev-301 Trustworthy Practice 🔄 Plat-Dev-301 Study Guides 💋 Reliable Plat-Dev-301 Exam Sims 🍗 Easily obtain ▷ Plat-Dev-301 ◁ for free download through ⮆ [url]www.prepawayexam.com ⮄ 🚏Reliable Plat-Dev-301 Exam Sims[/url]
- Plat-Dev-301 Online Lab Simulation 🔢 Relevant Plat-Dev-301 Answers 😃 Plat-Dev-301 Study Guides 🆖 Download ▶ Plat-Dev-301 ◀ for free by simply searching on ➥ [url]www.pdfvce.com 🡄 🔸
lat-Dev-301 Latest Exam Materials[/url] - Plat-Dev-301 Exam Preview 📀 Plat-Dev-301 Trustworthy Practice 🍲 New Plat-Dev-301 Dumps Book 🙃 Open ➡ [url]www.prep4away.com ️⬅️ enter ☀ Plat-Dev-301 ️☀️ and obtain a free download 🛥
lat-Dev-301 Latest Exam Materials[/url] - Plat-Dev-301 Study Guides 🧹 Plat-Dev-301 Trustworthy Practice ⛑ Exam Vce Plat-Dev-301 Free 🚀 Copy URL ▷ [url]www.pdfvce.com ◁ open and search for ➠ Plat-Dev-301 🠰 to download for free ✈Reliable Plat-Dev-301 Test Sims[/url]
- Reliable Plat-Dev-301 Exam Sims 🙊 Plat-Dev-301 Valid Exam Practice 🚀 Reliable Plat-Dev-301 Test Sims 😭 Copy URL [ [url]www.examcollectionpass.com ] open and search for Plat-Dev-301 to download for free 🔅
lat-Dev-301 Online Lab Simulation[/url] - High Plat-Dev-301 Quality 🦢 Plat-Dev-301 Valid Exam Practice 💠 Reliable Plat-Dev-301 Test Sims 🔦 Easily obtain ▷ Plat-Dev-301 ◁ for free download through ➽ [url]www.pdfvce.com 🢪 💼Latest Plat-Dev-301 Demo[/url]
- Plat-Dev-301 Latest Exam Materials 🚣 Certification Plat-Dev-301 Test Answers 🎋 Plat-Dev-301 Trustworthy Practice 🐒 Go to website ▛ [url]www.torrentvce.com ▟ open and search for Plat-Dev-301 to download for free 🐫New APP Plat-Dev-301 Simulations[/url]
- Salesforce Plat-Dev-301 PDF Questions - Increase Your Exam Passing Chances 🚦 Enter [url]www.pdfvce.com and search for Plat-Dev-301 to download for free 🥿
lat-Dev-301 Online Lab Simulation[/url] - Valid Plat-Dev-301 Practice Materials 🏡 High Plat-Dev-301 Quality 🚵 New APP Plat-Dev-301 Simulations 🦕 Download ✔ Plat-Dev-301 ️✔️ for free by simply searching on ▶ [url]www.prepawayete.com ◀ 🥪
lat-Dev-301 Trustworthy Practice[/url] - www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, bbs.t-firefly.com, Disposable vapes
