[General] ExamTorrent Pure Storage FAAA_005 Exam Questions Formats
88
General ExamTorrent Pure Storage FAAA_005 Exam Questions Formats
Posted at 1/23/2026 22:19:24      View146 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamTorrent FAAA_005 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1R32efvJHFEFJ86mCC3ZrN0MSjdLi1rNa
The Pure Storage PDF Questions format designed by the ExamTorrent will facilitate its consumers. Its portability helps you carry on with the study anywhere because it functions on all smart devices. You can also make notes or print out the Pure Storage FlashArray Architect Associate (FAAA_005) pdf questions. The simple, systematic, and user-friendly Interface of the Pure Storage FlashArray Architect Associate (FAAA_005) PDF dumps format will make your preparation convenient.
If you want to find a good jobyou must own good competences and skillful major knowledge. So owning the FAAA_005 certification is necessary for you because we will provide the best FAAA_005 study materials to you. Our FAAA_005 exam torrent is of high quality and efficient, and it can help you pass the test successfully. For the FAAA_005 training guide we provide with you is compiled by professionals elaborately and boosts varied versions which aimed to help you learn the FAAA_005 study materials by the method which is convenient for you. And you can pass the exam with success guaranteed.
FAAA_005 Exam Labs - Your Trusted Partner to Pass Pure Storage FlashArray Architect AssociateExamTorrent FAAA_005 latest exam dumps are the reliable and valid study material with latest & guaranteed questions & answers for your preparation. We promise you the easiest way to success and offer you the most prestigious and updated FAAA_005 Exam Training practice which carry 100% money return policy. Come on, and use Pure Storage FAAA_005 pdf download torrent, you can pass your FAAA_005 actual test at first attempt.
Pure Storage FlashArray Architect Associate Sample Questions (Q52-Q57):NEW QUESTION # 52
Which FlashArray feature best protects local snapshots from ransomware attacks?
  • A. CloudSnap
  • B. ActiveCluster
  • C. SafeMode
The FlashArray feature that best protects local snapshots from ransomware attacks is SafeMode.
Why This Matters:
SafeMode Snapshots:
SafeMode is a security feature that creates immutable snapshots, meaning they cannot be deleted, modified, or encrypted by malicious actors, including ransomware.
These snapshots are locked for a user-defined retention period, ensuring data integrity and recoverability even in the event of a ransomware attack.
Why Not the Other Options?
A). CloudSnap:
CloudSnap offloads snapshots to cloud storage (e.g., AWS S3 or Azure Blob). While it provides an offsite backup solution, it does not inherently protect against ransomware attacks targeting local snapshots.
C). ActiveCluster:
ActiveCluster provides synchronous replication between two sites for high availability. While it ensures data redundancy, it does not protect against ransomware attacks targeting snapshots.
Key Points:
SafeMode: Creates immutable snapshots to protect against ransomware attacks. Data Integrity: Ensures snapshots remain unaltered during the retention period. Ransomware Protection: A critical feature for safeguarding data in modern IT environments.
Reference: Pure Storage FlashArray Documentation: "SafeMode Snapshots for Ransomware Protection" Pure Storage Whitepaper: "rotecting Data Against Ransomware with FlashArray" Pure Storage Knowledge Base: "Best Practices for Using SafeMode Snapshots"
NEW QUESTION # 53
A potential customer has a use case where they need to use a stretched cluster for high availability and also require a third copy of their data in a remote geographic location.
Which replication method should be recommended?
  • A. Fan-out asynchronous snapshot replication
  • B. ActiveCluster with asychronous snapshot replication
  • C. ActiveDR with periodic snapshot replication
  • D. CloudSnap to an offload target
The customer requires a storage solution that supports a stretched cluster for high availability and also maintains a third copy of their data in a remote geographic location. The best replication method to recommend is ActiveCluster with asynchronous snapshot replication.
Why This Matters:
ActiveCluster:
ActiveCluster provides synchronous replication between two sites within a stretched cluster, ensuring zero RPO and near-zero RTO for high availability.
It is ideal for scenarios where applications require continuous access to data across two locations.
Asynchronous Snapshot Replication:
Asynchronous replication extends the disaster recovery strategy by replicating snapshots to a third site. This ensures an additional layer of protection against regional failures.
A). CloudSnap to an offload target:
CloudSnap is used to offload snapshots to cloud storage (e.g., AWS S3 or Azure Blob). While it satisfies the requirement for a third copy, it does not integrate with ActiveCluster for high availability in a stretched cluster.
B). Fan-out asynchronous snapshot replication:
Fan-out replication involves sending snapshots to multiple targets asynchronously. However, it does not provide the synchronous replication required for a stretched cluster.
C). ActiveDR with periodic snapshot replication:
ActiveDR is designed for asynchronous replication and failover/failback scenarios but does not support synchronous replication for a stretched cluster.
Key Points:
ActiveCluster: Ensures high availability with synchronous replication in a stretched cluster.
Async Replication: Adds a third-site replication target for comprehensive disaster recovery.
Integrated Solution: Combines high availability and disaster recovery into a single architecture.
Reference: Pure Storage FlashArray Documentation: "ActiveCluster with Async Replication" Pure Storage Whitepaper: "Disaster Recovery Strategies with FlashArray" Pure Storage Knowledge Base: "Using Protection Groups in Stretched Pods"
NEW QUESTION # 54
A manufacturing customer is running Oracle volumes on their existing //X90R3 array and would like to use FlashArray for their Windows file shares. They are asking if it is feasible to do this.
How should the SE respond?
  • A. The customer should be able to use their current FlashArray.
  • B. The customer should migrate their Windows file servers to Pure.
  • C. The customer needs to upgrade to XL to be able to use FA File.
The SE should respond that the customer can use their current FlashArray for Windows file shares alongside their existing Oracle workloads. Pure Storage FlashArray is a versatile platform capable of supporting multiple workloads, including block storage for databases (e.g., Oracle) and file services for Windows file shares.
Why This Matters:
FlashArray Versatility:
Pure Storage FlashArray supports both block and file workloads through its integrated architecture. While FlashArray is primarily known for block storage, it can also support file workloads using FA File Services, which provides NFS and SMB protocols for file sharing.
The customer does not need to migrate their Windows file servers or upgrade their hardware unless there are specific capacity or performance constraints.
Current Array Feasibility:
Assuming the existing //X90R3 array has sufficient capacity and performance headroom, it can handle the additional workload without requiring upgrades.
A). The customer should migrate their Windows file servers to Pure:
While migrating file servers to Pure Storage can provide benefits like simplified management and improved performance, it is not a requirement. The customer can continue using their existing file servers while leveraging FlashArray for block storage.
B). The customer needs to upgrade to XL to be able to use FA File:
Upgrading to a higher-end model like FlashArray//XL is unnecessary unless the current array lacks the required capacity or performance for the additional workload. The //X90R3 is fully capable of supporting FA File Services.
Key Points:
Versatility: FlashArray can support both block and file workloads simultaneously.
No Immediate Upgrades Needed: The current array can likely handle the additional workload without requiring hardware changes.
Workload Consolidation: Using a single platform for multiple workloads simplifies infrastructure and reduces costs.
Reference: Pure Storage FlashArray Documentation: "FA File Services Overview" Pure Storage Whitepaper: "Consolidating Workloads on FlashArray" Pure Storage Knowledge Base: "Supporting Multiple Workloads with FlashArray"
NEW QUESTION # 55
A customer is looking for a new storage system with the following requirements:
* 20 TB of file shares
* Support 800 TB of Wols
* Low cost per GB
* CloudSnap utilization in the future
Which Pure Storage platform should be recommended?
  • A. FlashArray//X
  • B. FlashArray//C
  • C. FlashBlade//S
  • D. Cloud Block Store
The customer is looking for a storage system that supports 20 TB of file shares, 800 TB of workloads, has a low cost per GB, and can utilize CloudSnap in the future. The best recommendation is FlashArray//C.
Why This Matters:
FlashArray//C:
FlashArray//C is designed for capacity-optimized workloads, making it ideal for use cases requiring large amounts of storage at a lower cost per GB compared to higher-performance arrays like FlashArray//X.
It supports QLC flash technology, which provides high density and cost efficiency for less performance-intensive workloads.
CloudSnap is fully supported on FlashArray//C, enabling snapshots to be offloaded to public cloud storage for disaster recovery or archival purposes.
A). FlashArray//X:
FlashArray//X is optimized for high-performance workloads, such as databases and mission-critical applications. While it supports CloudSnap, it is more expensive and not the most cost-effective solution for large-scale capacity needs.
C). Cloud Block Store:
Cloud Block Store is a cloud-native block storage solution that runs in public clouds (e.g., AWS, Azure). It does not meet the requirement for on-premises storage with file shares and CloudSnap utilization.
D). FlashBlade//S:
FlashBlade//S is designed for file and object storage but is typically used for high-performance, unstructured data workloads. It is more expensive than FlashArray//C and not necessary for this use case.
Key Points:
FlashArray//C: Provides high-density storage at a low cost per GB, ideal for large-scale workloads.
CloudSnap Support: Enables offloading snapshots to the cloud for disaster recovery or archival purposes.
Cost Efficiency: Balances performance and cost, making it suitable for file shares and large datasets.
Reference: Pure Storage FlashArray//C Documentation: "Use Cases for FlashArray//C" Pure Storage Whitepaper: "Optimizing Storage Costs with FlashArray//C" Pure Storage Knowledge Base: "Choosing the Right FlashArray Model for Your Workload"
NEW QUESTION # 56
After meeting with a potential customer, an SE confirmed the following details:
* The customer's current workload is 50 TB
* The workload has an expected DRR of 4:1
* The customer's data has predictable growth rate of 25% per year
* A 20% headroom for any unexpected workloads that may occur in the future When sizing this solution, the SE needs to make sure that the customer will have enough capacity to last 3 years.
Which raw capacity will meet these requirements?
  • A. 56 TB
  • B. 225 TB
  • C. 300 TB
  • D. 30 TB
To determine the raw capacity required to meet the customer's needs for 3 years, we need to account for the current workload, data reduction ratio (DRR), growth rate, and headroom.
Step-by-Step Calculation:
Current Logical Workload:
The customer's current workload is 50 TB.
Expected Growth Over 3 Years:
The workload grows at a predictable rate of 25% per year.
After 3 years, the logical workload will be:
icedoc.Paragraphsfaaa_005v8.02-1741
NEW QUESTION # 57
Our company according to the situation reform on conception, question types, designers training and so on. Our latest FAAA_005 exam torrent was designed by many experts and professors. You will have the chance to learn about the demo for if you decide to use our FAAA_005 quiz prep. We can sure that it is very significant for you to be aware of the different text types and how best to approach them by demo. At the same time, our FAAA_005 Quiz torrent has summarized some features and rules of the cloze test to help customers successfully pass their exams. More importantly, you have the opportunity to get the demo of our latest FAAA_005 exam torrent for free, yes, you read that right, and our demo is free. So why still hesitate?
FAAA_005 Real Dumps: https://www.examtorrent.com/FAAA_005-valid-vce-dumps.html
In such a way, you can confirm that you get the convenience and fast from our FAAA_005 study guide, Just as an old saying goes, "It's never too old to learn", so preparing for a FAAA_005 certification is becoming a common occurrence, Over this long time period, countless FAAA_005 exam candidates have passed their Pure Storage exam with good scores, Its unique and amazing features makes one well prepared to pass the Pure Storage FlashArray Architect Associate FAAA_005 Exam with fabulous scores in the first attempt.
Designing an infrastructure that will properly FAAA_005 support Windows Active Directory requires a large amount of pre-planning, Devicesesktop and laptop computers, In such a way, you can confirm that you get the convenience and fast from our FAAA_005 Study Guide.
Providing You Reliable FAAA_005 Exam Labs with 100% Passing GuaranteeJust as an old saying goes, "It's never too old to learn", so preparing for a FAAA_005 certification is becoming a common occurrence, Over this long time period, countless FAAA_005 exam candidates have passed their Pure Storage exam with good scores.
Its unique and amazing features makes one well prepared to pass the Pure Storage FlashArray Architect Associate FAAA_005 Exam with fabulous scores in the first attempt, Let's try to make the best use of our resources and take the best way to clear exams with FAAA_005 study guide files.
P.S. Free 2026 Pure Storage FAAA_005 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1R32efvJHFEFJ86mCC3ZrN0MSjdLi1rNa
Posted at 2/1/2026 03:53:23        Only Author  2#
Es ist nicht leicht fr ITer, die PMI CPMAI IT-Zertifizierungen zu besitzen. Aber Diese Weise ist am besten fr sie, ihre Fähigkeit zu entwickeln und ihren Wert zu beweisen. Deshalb mssen viele Leute die PMI CPMAI Prfungen anmelden. So, gibt es eine einfache Methode, dass sie diese IT-Zertifizierungsprfungen sehr leicht bestehen. Selbstverständig! Die ZertPruefung Dumps ist die beste Wahl. Alle Prfungsunterlagen sind an ZertPruefung vorhanden. Und es kann Ihre Forderungen erfllen. Sie können sich mehr ber die Prfungsunterlagen an ZertPruefung informieren.
