Get High-quality Plat-Dev-301 Exam Preparation and High Pass-Rate Plat-Dev-301 S
Posted at 1/23/2026 22:35:45
View168
Replies0
there are free trial services provided by our Plat-Dev-301 preparation braindumps-the free demos. On the one hand, by the free trial services you can get close contact with our products, learn about our Plat-Dev-301 study guide, and know how to choose the most suitable version. On the other hand, using free trial downloading before purchasing, I can promise that you will have a good command of the function of our Plat-Dev-301 training prep.
We provide 24-hour online service for all customers who have purchased Plat-Dev-301 test guide. You can send us an email to ask questions at anytime, anywhere. For any questions you may have during the use of Plat-Dev-301 exam questions, our customer service staff will be patient to help you to solve them. At the same time, if you have problems with downloading and installing, Plat-Dev-301 Torrent prep also has dedicated staff that can provide you with remote online guidance. In order to allow you to use our products with confidence, Plat-Dev-301 test guide provide you with a 100% pass rate guarantee. Once you unfortunately fail the exam, we will give you a full refund, and our refund process is very simple.
Salesforce Plat-Dev-301 Exam | Plat-Dev-301 Exam Preparation - 365 Days Free Updates of Plat-Dev-301 Sample ExamWe often ask, what is the purpose of learning? Why should we study? Why did you study for Plat-Dev-301exam so long? As many people think that, even if one day we forget the formula for the area of a triangle, we can still live very well, but if it were not for the knowledge of learning Plat-Dev-301 Exam and try to obtain certification, how can we have the opportunity to good to future life? So, the examination is necessary, only to get the test Plat-Dev-301 certification, get a certificate, to prove better us, to pave the way for our future life.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q41-Q46):NEW QUESTION # 41
A corporation has many different Salesforce orgs, with some different objects and some common objects, and wants to build a single Java application that can create, retrieve, and update common object records in all of the different orgs.
Which method of integration should the application use?
- A. Apex REST Web Service
- B. Metadata APT
- C. SOAP API with the Enterprise WSDL
- D. SOAP API with the Partner WSDL
The SOAP API with the Partner WSDL is ideal for building integrations that work across multiple Salesforce orgs, especially when they have varying schemas. The Partner WSDL is designed to be flexible and dynamic, catering to different metadata.
NEW QUESTION # 42
Consider the following code snippet:
As part of the deployment cycle, a developer creates the following test class:
When the test class runs, the assertion fails. Which change should the developer implement in the Apex test method to ensure the test method executes successfully? A)
B)
C)
D)
- A. Option D
- B. Option A
- C. Option C
- D. Option B
To ensure that test methods execute successfully and are able to verify the behavior of the code, it is important to set up the proper context and to make sure that the test covers the expected outcomes accurately.
Option B is correct because enclosing the method call within Test.startTest() and Test.stopTest() ensures that any asynchronous operations are completed before the assertions are made. This is crucial when the code being tested is expected to perform operations that may run after the initial transaction, such as future methods, queueable jobs, or batch operations.
Options A, C, and D are incorrect because they do not address the issue of ensuring that all operations are completed before the assertion is made. Option A incorrectly suggests modifying the test setup code, while Options C and D suggest changes that are not related to the test execution flow.
Salesforce Developer Documentation on Testing Best Practices: Apex Testing Best Practices
NEW QUESTION # 43
A developer wrote a test class that successfully asserts a trigger on Account, It fires and updates data correctly In a sandbox environment.
A Salesforce admin with a custom profile attempts to deploy this trigger via a change set into the production environment, but the test class falls with an Insufficient privileges error.
What should a developer do to fix the problem?
- A. Add seeallData=true to the test class to work within the sharing model for the productionenvironment.
- B. Verify that Test. startTest() Is not Inside a For loop in the test class,
- C. Add System.runAs() to the test class to execute the trigger as a user with the correct objectpermissions.
- D. Configure the production environment to enable"Run All Tests as Admin User."
When a test class fails with an "Insufficient privileges" error during deployment, it indicates that the user profile under which the tests are being executed doesn't have the necessary permissions to perform the actions required by the test. In a sandbox, the test might have been running with a different set of permissions compared to the production environment.
By using System.runAs(), you can specify a user context in which the test should run, which allows you to simulate the appropriate permissions. For this to work, you need to create a User instance in your test class with the profile that has the necessary permissions and then enclose the logic of your test within a System.runAs() block with this user.
This is a preferred solution over seeAllData=true, which would give the test access to all data in the production environment, potentially leading to tests that are not isolated and thus less reliable. It's also preferred over changing organization-wide settings or relying on specific setup in test classes, such as making sure Test.startTest() is not inside a loop.
Salesforce Documentation on Using the runAs Method: Testing with the runAs Method Salesforce Help Article on System Permissions: Profiles and Permissions
NEW QUESTION # 44
Refer to the code snippet below:
A custom object called Credit_Memo__c exists in a Salesforce environment. As part of a new feature development that retrieves and manipulates this type of record, the developer needs to ensure race conditions are prevented when a set of records are modified within an Apex transaction. In the preceding Apex code, how can the developer alter the query statement to use SOQL features to prevent race conditions within a transaction? A)
B)
C)
D)
- A. Option D
- B. Option B
- C. Option C
- D. Option A
To prevent race conditions during an Apex transaction, the SOQL query can be modified to include the "FOR UPDATE" keyword. This keyword locks the records that are returned by the query, preventing other transactions from modifying them until the current transaction is complete. This ensures that the retrieved records cannot be changed by another process before the current transaction is completed, thus preventing race conditions. The correct option to use in the code snippet provided is:
[SELECT Id, Name, Amount__c FROM Credit_Memo__c WHERE Customer_Id__c = :customerId LIMIT 50 FOR UPDATE] This will lock up to 50 records of Credit_Memo__c with the specified Customer_Id__c for the duration of the transaction.
FOR UPDATE
Preventing Record Update Conflicts
NEW QUESTION # 45
A company manages information about their product offerings in custom objects named Catalog and Catalog Item. Catalog Item has a master-detail field to Catalog, and each Catalog may have as many as 100,000 Catalog Items.
Both custom objects have a CurrencylsoCode text field that contains the currency code they should use. If a Catalog's CurrencylsoCode changes, all of its Catalog Items' CurrencylsoCodes should be changed as well.
What should a developer use to update the CurrencylsoCodes on the Catalog Items when the Catalog's CurrencylsoCode changes?
- A. An after insert trigger on Catalog Item that updates the Catalog Items if the Catalog's CurrencylsoCode is different
- B. An after insert trigger on Catalog that updates the Catalog Items if the Catalogs CurrencylsoCode is different
- C. A Database. schedulable and Dazabase.Bazchacle class that queries the Catalog object and updates the Catalog Items if the Catalog CurrencylSoCode is different
- D. A Database.Schedulable and Database.Batchacle class that queries the Catalog Item object and updates the Catalog Items if the Catalog CurrencylSoCode is different
Use Database.Batchable for handling large data sets. It can efficiently process 100,000 Catalog Items asynchronously and update CurrencylsoCodes.
NEW QUESTION # 46
Because of the different habits and personal devices, requirements for the version of our Plat-Dev-301 exam questions vary from person to person. To address this issue, our Plat-Dev-301 actual exam offers three different versions for users to choose from. The PC version is the closest to the real test environment, which is an excellent choice for windows - equipped computers. And this version also helps establish the confidence of the candidates when they attend the Plat-Dev-301 Exam after practicing.
Plat-Dev-301 Sample Exam: https://www.prepawayexam.com/Salesforce/braindumps.Plat-Dev-301.ete.file.html
therefore no need to install it, and you can start practicing for the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam by creating the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice test, And the pass rate of the Plat-Dev-301 exam is 98%, In normal times, you may take months or even a year to review a professional exam, but with Plat-Dev-301 exam guide you only need to spend 20-30 hours to review before the exam, Salesforce Plat-Dev-301 Exam Preparation More than 99.5% of our customers pass the exams at their first tries.
And, of course, social media keeps growing, These Plat-Dev-301 extra hours might be over a period of days and occasionally over weeks, therefore no need to install it, and you can start practicing for the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) exam by creating the Salesforce Certified Platform Developer II - Multiple Choice (Plat-Dev-301) practice test.
Salesforce Plat-Dev-301 the latest certification exam training materialsAnd the pass rate of the Plat-Dev-301 exam is 98%, In normal times, you may take months or even a year to review a professional exam, but with Plat-Dev-301 exam guide you only need to spend 20-30 hours to review before the exam.
More than 99.5% of our customers pass the exams at their first tries, Our company solemnly declares that if you buy our Plat-Dev-301 training pdf dumps, you will pass the Plat-Dev-301 exam at a time.
- 2026 Useful Plat-Dev-301 Exam Preparation | 100% Free Salesforce Certified Platform Developer II - Multiple Choice Sample Exam ⏹ Download ▶ Plat-Dev-301 ◀ for free by simply searching on ➤ [url]www.testkingpass.com ⮘ 🤬Updated Plat-Dev-301 Demo[/url]
- Pass Guaranteed Quiz Updated Salesforce - Plat-Dev-301 Exam Preparation 🔥 Search for ➽ Plat-Dev-301 🢪 on ▛ [url]www.pdfvce.com ▟ immediately to obtain a free download 🥺Valid Plat-Dev-301 Vce Dumps[/url]
- Books Plat-Dev-301 PDF 😣 Plat-Dev-301 Latest Test Practice 🥵 Plat-Dev-301 Valid Test Syllabus 💳 Go to website [ [url]www.vce4dumps.com ] open and search for { Plat-Dev-301 } to download for free ⛅
lat-Dev-301 New Braindumps Files[/url] - Plat-Dev-301 Test Labs 📄 Valid Plat-Dev-301 Vce Dumps ⭐ New Plat-Dev-301 Test Cram 🚺 Open { [url]www.pdfvce.com } enter ➽ Plat-Dev-301 🢪 and obtain a free download 🐆Latest Plat-Dev-301 Test Blueprint[/url]
- Valid Plat-Dev-301 Vce Dumps 🚆 Plat-Dev-301 New Braindumps Files 💔 Plat-Dev-301 Valid Dumps Pdf 😯 The page for free download of [ Plat-Dev-301 ] on ➡ [url]www.examdiscuss.com ️⬅️ will open immediately IPlat-Dev-301 Free Sample[/url]
- Maximize Your Success with Pdfvce Customizable Plat-Dev-301 Salesforce Certified Platform Developer II - Multiple Choice Practice Test 💿 Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for Plat-Dev-301 to download for free 😦
lat-Dev-301 New Cram Materials[/url] - Plat-Dev-301 New Cram Materials ➿ Valid Plat-Dev-301 Vce Dumps 👝 Plat-Dev-301 Latest Test Practice 🤿 Copy URL [url]www.pass4test.com open and search for Plat-Dev-301 to download for free 🪕
lat-Dev-301 New Cram Materials[/url] - Books Plat-Dev-301 PDF 🎈 Plat-Dev-301 Valid Dumps Pdf 🥭 Plat-Dev-301 Free Sample 🙌 Download Plat-Dev-301 for free by simply searching on ➤ [url]www.pdfvce.com ⮘ 🤏New Plat-Dev-301 Test Cram[/url]
- Test Plat-Dev-301 Vce Free 🛶 Plat-Dev-301 Latest Study Plan 💸 Plat-Dev-301 Valid Test Syllabus 🎡 Open [url]www.prepawayete.com and search for ▷ Plat-Dev-301 ◁ to download exam materials for free 💛Test Plat-Dev-301 Vce Free[/url]
- Salesforce Plat-Dev-301 1 year of Free Updates 🤧 Search for ☀ Plat-Dev-301 ️☀️ and download it for free on ▶ [url]www.pdfvce.com ◀ website 🧵
lat-Dev-301 Valid Test Syllabus[/url] - Test Plat-Dev-301 Vce Free 📼 Test Plat-Dev-301 Vce Free 📆 New Plat-Dev-301 Test Cram 🚛 Copy URL [url]www.pass4test.com open and search for ▶ Plat-Dev-301 ◀ to download for free 🧉New Plat-Dev-301 Test Cram[/url]
- wanderlog.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.slideshare.net, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
