[Hardware] 2V0-16.25 Valid Test Book - Training 2V0-16.25 Tools
59
Hardware 2V0-16.25 Valid Test Book - Training 2V0-16.25 Tools
Posted at 1/24/2026 02:17:52      View180 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Itbraindumps 2V0-16.25 dumps from Cloud Storage: https://drive.google.com/open?id=1PQdgwfRvguuR8smD5gFevnfgFPc0r68Q
In our study, we found that many people have the strongest ability to use knowledge for a period of time at the beginning of their knowledge. As time goes on, memory fades. Our 2V0-16.25 study materials are designed to help users consolidate what they have learned, will add to the instant of many training, the user can test their learning effect in time after finished the part of the learning content, have a special set of wrong topics in our 2V0-16.25 Study Materials, enable users to find their weak spot of knowledge in this function, iterate through constant practice, finally reach a high success rate.
VMware 2V0-16.25 Exam Syllabus Topics:
  • Deploy, Configure, and Operate VMware vSphere Foundation (VVF): This section of the exam measures the expertise of Data Center Administrators and emphasizes hands-on skills in deploying and configuring VMware vSphere Foundation environments. Candidates must understand the components of a VVF deployment, configure Supervisors within clusters, and manage identity, access control, licensing, and certificate management. The objectives also extend to lifecycle management within the vSphere Foundation. Furthermore, it explores operational tasks including monitoring and analyzing logs, configuring alerting, managing dashboards, and integrating with VMware Cloud Foundation (VCF) Operations. Candidates will also be tested on cost and pricing configuration, compliance monitoring, and security hardening practices. Finally, automation skills are validated through deploying services with Supervisors, running Kubernetes workloads, using VM services, and integrating VCF Operations Orchestrator to support enterprise automation.
  • Plan and Design the VMware by Broadcom Solution: This section of the exam measures the ability of VMware Solution Architects to plan and design solutions. While there are no specific testable objectives included, the focus is on preparing professionals to design VMware-based solutions that align with organizational goals and best practices.
  • VMware vSphere Foundation Fundamentals: This section of the exam measures the skills of Virtualization Engineers and focuses on the essentials of virtualization technology. It introduces the principles of virtualization, explores use cases, and highlights the value it brings to businesses. Candidates are expected to demonstrate knowledge of VMware compute components such as vCenter and ESX, cluster configuration, and lifecycle management of virtual machines. It also covers secure workload operations, encryption, and managing resources with content libraries. In addition, storage fundamentals are examined through configuring vSphere storage, deploying VMware vSAN clusters, defining storage policies, and ensuring data availability. Networking fundamentals are also introduced, requiring the ability to differentiate between VMware vSphere networking components.
  • IT Architectures, Technologies, Standards: This section of the exam measures the understanding of IT Infrastructure Architects and covers foundational concepts of architectures, emerging technologies, and industry standards. Although no testable objectives are listed here, it establishes the baseline knowledge needed to interpret and design VMware-related environments effectively.
Topic 5
  • Troubleshoot and Optimize the VMware Solution: This section of the exam measures the ability of Systems Engineers to troubleshoot and optimize VMware-based environments. While no explicit testable objectives are listed, candidates are expected to apply their problem-solving skills to diagnose, resolve, and enhance VMware solutions for improved reliability and performance.
Training 2V0-16.25 Tools - 2V0-16.25 New Real TestThese days the Itbraindumps is providing you online VMware 2V0-16.25 exam questions to crack the VMware 2V0-16.25 certification exam which means you don't need to be physically present anywhere except the chair at your home. You need a laptop and an active internet connection to access the Itbraindumps VMware 2V0-16.25 Exam Questions and practice exam.
VMware vSphere Foundation 9.0 Administrator Sample Questions (Q21-Q26):NEW QUESTION # 21
An administrator must configure identity access for VMware vSphere Foundation (VVF) to allow admin accounts from the enterprise Active Directory domain corp.local to log in using domain credentials. Security requires authentication to use the default Active Directory protocol, without federation.
Which configuration step is required to enable Active Directory users to authenticate to vCenter?
  • A. Add Active Directory over LDAP as an identity source.
  • B. Configure a trusted identity provider using OpenID Connect (OIDC).
  • C. Configure Identity Federation using SAML with corp.local.
  • D. Add the domain controller certificate to the Trusted Root store in vCenter.
To allowActive Directory domain users(corp.local) to authenticate in vCenter with domain credentials:
* The correct method is configuringActive Directory over LDAP as an identity source. (D)
* This uses thedefault AD protocol (LDAP/Kerberos)without requiring SAML or OIDC federation.
Other options:
* A. Adding domain controller certificate# Needed for LDAPS but not the main step.
* B. Identity Federation with SAML# Requires federation, not allowed per requirements.
* C. OpenID Connect (OIDC)# Used for external IdPs, not traditional AD auth.
VMware vSphere 9.0 -Configuring Active Directory Identity Sources
VMware Docs: Add AD over LDAP as Identity Source
NEW QUESTION # 22
Which rule in a virtual machine (VM) storage policy is configured to ensure data redundancy in a VMware vSAN environment?
  • A. Stripe Width
  • B. Disk Stripes Per Object
  • C. Failures to Tolerate
  • D. Flash Read Cache Reservation
TheVM Storage Policy rulethat controlsdata redundancy in vSANisFailures to Tolerate (FTT).
* Defines the number of hardware failures (host, disk, network) that vSAN can tolerate while maintaining data availability.
* Configurations includeRAID-1 (mirroring),RAID-5/6 (erasure coding).
Other options:
* B. Disk Stripes Per Object# Defines performance striping, not redundancy.
* C. Stripe Width# Same as above, not redundancy.
* D. Flash Read Cache Reservation# Relates to caching performance, not redundancy.
VMware vSphere 9.0 -Storage Policy Rules in vSAN
VMware Docs: vSAN Failures to Tolerate
NEW QUESTION # 23
An administrator has noticed occasional performance degradation during peak usage times and needs to address this issue proactively by creating a mechanism that doesn't give data or outputs too often to overload the team.
Which of the following steps is required to create the mechanism in VMware Cloud Foundation (VCF) Operations?
  • A. Create a custom dashboard to visualize all alerts.
  • B. Implement an alert specifying the metric, threshold, and duration.
  • C. Implement an alert that notifies the IT team during off-peak hours.
  • D. Implement an alert with the default alert settings.
The administrator wants toproactively manage performance degradationduring peak times without overwhelming the IT team.
* The correct method is tocreate a custom alert with specific metric, threshold, and duration(A).
* This ensures alerts are triggered only when sustained performance issues occur, reducing noise.
* B. Default alert settings# Too generic, may cause alert storms.
* C. Custom dashboard# Useful for visualization but not proactive alerting.
* D. Notify during off-peak hours# Defers the issue, not proactive.
VMware Cloud Foundation 9.0.3 -Creating Alerts and Policies
VMware Docs: [Configuring Alerts in vRealize Operations]
NEW QUESTION # 24
An administrator has been tasked with creating a custom alert for an object in VMware Cloud Foundation (VCF) Operations.
When creating the alert, the administrator completes the following:
* A new symptom definition.
* A new alert definition.
* Select the Object type.
What additional step must the administrator take to complete the stated objective and ensure the alert is triggered?
  • A. Create and enable a super metric for read latency in the Active Policy.
  • B. Create a new Payload Template.
  • C. Create an instance of the Rest Notification Plugin.
  • D. Enable the alert in an Active Policy.
When creating acustom alert in VCF Operations, the final required step is:
* Enable the alert in an Active Policy, so it applies to the target objects.
Without policy activation, the alert exists but will never trigger.
Other options:
* A. Super metric# Only required if monitoring a custom metric, not for standard alerts.
* B. REST Notification Plugin# Used for outbound integration, not triggering alerts.
* C. Payload Template# Used in notifications, not in core alert configuration.
VMware Cloud Foundation 9.0 -Custom Alerts and Policies
VMware Docs: Alert Definitions in vRealize Operations
NEW QUESTION # 25
During a recent audit, it was determined that a group of users may have been compromised. These users should not have access to any VMware vCenter resources while an investigation is underway. All the affected users have been placed into a SUSPECT_USERS group.
Which step is required to ensure that the suspect users will never have access to resources in vCenter?
  • A. Assign the SUSPECT_USERS group the Administrator role to the vCenter Object and uncheck propagate.
  • B. Assign the SUSPECT_USERS group the No access role to the vCenter Object and check propagate.
  • C. Assign the SUSPECT_USERS group the Read-only role to the vCenter Object and check propagate.
  • D. Disconnect the vCenter from Active Directory.
To ensurecompromised users cannot access vCenter resources:
* Assign theNo Accessrole at the vCenter level.
* Enable propagationso this restriction applies to all child objects.
* This guaranteeszero permissionsfor SUSPECT_USERS.
Other options:
* B. Administrator with uncheck propagate# Still gives dangerous access at root level.
* C. Disconnect Active Directory# Disrupts all AD users, not just suspect ones.
* D. Read-only role# Still grants access, not acceptable during investigation.
VMware vSphere 9.0 -Roles and Permissions Best Practices
VMware KB 1025569 -Assigning the No Access Role in vCenter
NEW QUESTION # 26
Our 2V0-16.25 test prep attaches great importance to a skilled, trained and motivated workforce as well as the companys overall performance. Adhere to new and highly qualified 2V0-16.25 quiz guide to meet the needs of customer, we are also committed to providing the first -class after-sale service. There will be our customer service agents available 24/7 for your supports; any request for further assistance or information about 2V0-16.25 Exam Torrent will receive our immediate attention.
Training 2V0-16.25 Tools: https://www.itbraindumps.com/2V0-16.25_exam.html
Posted at 2/12/2026 10:43:26        Only Author  2#
SD-WAN-EngineerJYȡäJYȡäȡιä_k̶țQޤ뤿ᡢSD-WAN-EngineerԇYɤϸΤ돾ITˤʤ뤿˾ƤޤҤˑäƤ↖}ޤ󡣌gHSD-WAN-EngineerԇY˺ϸ񤹤뤿ηϽҕǤSD-WAN-EngineerΥƥȜʂ򿼤ƤˤϤ_ɤǤǤʤयΥƥĤͬrҙ뤳ȤǤޤ
