[General] Pass Guaranteed Juniper - Authoritative Free JN0-481 Study Material
95
【General】 Pass Guaranteed Juniper - Authoritative Free JN0-481 Study Material
Posted at 1/24/2026 03:16:16      View:195 | Replies:4        Print      Only Author   [Copy Link] 1#
2026 Latest PrepAwayETE JN0-481 PDF Dumps and JN0-481 Exam Engine Free Share: https://drive.google.com/open?id=1gsq2e5jIDxUBqEyfLWYf2fWjEP3ZOaOJ
Iif you still spend a lot of time studying and waiting for JN0-481 qualification examination, then you need our JN0-481 test prep, which can help solve all of the above problems. I can guarantee that our study materials will be your best choice. Our JN0-481 valid practice questions have three different versions, including the PDF version, the software version and the online version, to meet the different needs, our JN0-481 Study Materials have many advantages, and you can free download the demo of our JN0-481 exam questios to have a check.
Nowadays the requirements for jobs are higher than any time in the past. The job-hunters face huge pressure because most jobs require both working abilities and profound major knowledge. Passing JN0-481 exam can help you find the ideal job. If you buy our JN0-481 test prep you will pass the JN0-481 Exam easily and successfully, and you will realize you dream to find an ideal job and earn a high income. Our JN0-481 training braindump is of high quality and the passing rate and the hit rate are both high as more than 98%.
Valid Test JN0-481 Testking | Valid JN0-481 Exam DurationConfronting a tie-up during your review of the exam? Feeling anxious and confused to choose the perfect JN0-481 latest dumps to pass it smoothly? We understand your situation of susceptibility about the exam, and our JN0-481 test guide can offer timely help on your issues right here right now. Without tawdry points of knowledge to remember, our experts systematize all knowledge for your reference. You can download our free demos and get to know synoptic outline before buying. We offer free demos as your experimental tryout before downloading our Real JN0-481 Exam Questions. For more textual content about practicing exam questions, you can download our products with reasonable prices and get your practice begin within 5 minutes.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q72-Q77):NEW QUESTION # 72
Referring to the exhibit, how many rack types are used in the staged blueprint?
  • A. three
  • B. six
  • C. two
  • D. seven
Referring to the exhibit, the image shows the Racks table under the Staged menu in the Juniper Apstra UI. The Racks table displays the details of the racks that are used in the blueprint, such as the name, rack type, and date. The rack type is a resource that defines the type and number of leaf devices, access switches, and/or generic systems that are used in rack builds. The image shows seven racks in the table, but only two rack types: BorderLeaf and ServerRack.
NEW QUESTION # 73
You are installing a Juniper Apstra server in your data center. You have multiple users that will be expected to configure, manage, and carry out operational tasks in your data center. You have decided to implement remote user authentication for the role-based access control of your Apstra server. In this scenario, which three methods are supported? (Choose three.)
  • A. TACACS+
  • B. SAML
  • C. LDAP
  • D. Auth0
  • E. RADIUS
Answer: A,C,E
To implement remote user authentication for the role-based access control of your Apstra server, you can use one of the following methods: TACACS+, LDAP, or RADIUS. These are the protocols that Juniper Apstra supports to authenticate and authorize users based on roles assigned to individual users within an enterprise. You can configure the Apstra server to use one or more of these protocols as the authentication sources and specify the order of preference. You can also configure the Apstra server to use local user accounts as a fallback option if the remote authentication fails.
NEW QUESTION # 74
In Juniper Apstra. which three modes are available for devices? (Choose three.)
  • A. Ready
  • B. Drain
  • C. Active
  • D. Stopped
  • E. Deploy
Answer: A,B,E
Juniper Apstra supports three deploy modes for devices: Deploy, Drain, and Ready. These modes determine the configuration and state of the devices in the data center fabric.
Deploy: This mode applies the full Apstra-rendered configuration to the device, according to the Apstra Reference Design. The device state becomes IS-ACTIVE and the device is ready to carry traffic in the fabric.
Drain: This mode adds a "drain" configuration to the device, which prevents any new traffic from entering the device. The device state becomes IS-READY and the device is prepared for maintenance or decommissioning.
Ready: This mode removes the Apstra-rendered configuration from the device, leaving only the basic configuration such as device hostname, interface descriptions, and port speed/breakout.
The device state becomes IS-READY and the device is not part of the fabric.
NEW QUESTION # 75
Which two actions are required during Juniper Apstra's deploy phase? (Choose two.)
  • A. Assign device profiles to the blueprint.
  • B. Assign resources to the blueprint.
  • C. Assign user roles to the blueprint.
  • D. Assign interlace maps to the blueprint.
The deploy phase is the final step in the Juniper Apstra data center fabric design and deployment process. In this phase, you apply the Apstra-rendered configuration to the devices and verify the intent of the blueprint. Based on the web search results, we can infer the following actions are required during the deploy phase:
Assign device profiles to the blueprint. This action associates a specific vendor model to each logical device in the blueprint. Device profiles contain extensive hardware model details, such as form factor, ASIC, CPU, RAM, ECMP limit, and supported features. Device profiles also define how configuration is generated, how telemetry commands are rendered, and how configuration is deployed on a device. Device profiles enable the Apstra system to render and deploy the configuration according to the Apstra Reference Design. Assign resources to the blueprint. This action allocates the physical devices, IP addresses, VLANs, and ASNs to the logical devices, networks, and routing zones in the blueprint. Resources can be assigned manually or automatically by the Apstra system. Assigning resources ensures that the blueprint has all the necessary elements to generate the configuration and deploy the fabric5 . Assign user roles to the blueprint. This action is not required during the deploy phase. User roles are defined at the system level, not at the blueprint level. User roles determine the permissions and access levels of different users in the Apstra system. User roles can be system-defined or custom-defined .
Assign interface maps to the blueprint. This action is not required during the deploy phase.
Interface maps are defined at the design phase, not at the deploy phase. Interface maps are objects that map the logical interfaces of a logical device to the physical interfaces of a device profile. Interface maps enable the Apstra system to generate the correct interface configuration for each device in the fabric.
NEW QUESTION # 76
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Lead and Leat6 using the same virtual network identifier (VNI). Which two statements are correct in this scenario? (Choose two.)
  • A. The underlay must use IRB interfaces.
  • B. Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices.
  • C. The underlay EBGP peering's must be established between leaf and spine devices.
  • D. The underlay must be provisioned with PIMv2.
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Leaf1 and Leaf6 using the same virtual network identifier (VNI). This means that the servers belong to the same Layer 2 domain and can communicate with each other using VXLAN tunnels across the fabric. The underlay network provides the IP connectivity between the leaf and spine devices, and it uses EBGP as the routing protocol. Therefore, the following two statements are correct in this scenario:
Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices. This is because the loopback addresses are used as the source and destination IP addresses for the VXLAN tunnels, and they must be reachable by all the devices in the fabric.
The loopback addresses are also used as the router IDs and the BGP peer addresses for the EBGP sessions.
The underlay EBGP peering's must be established between leaf and spine devices. This is because the EBGP sessions are used to exchange the underlay routing information and the EVPN routes for the overlay network. The EBGP sessions are established using the loopback addresses of the devices, and they follow a spine-and-leaf topology, where each leaf device peers with all the spine devices, and each spine device peers with all the leaf devices.
NEW QUESTION # 77
We keep a close watch at the most advanced social views about the knowledge of the test Juniper certification. Our experts will renovate the test bank with the latest JN0-481 study materials and compile the latest knowledge and information into the questions and answers. In the answers, our experts will provide the authorized verification and detailed demonstration so as to let the learners master the latest information timely and follow the trend of the times. All we do is to integrate the most advanced views into our JN0-481 Study Materials.
Valid Test JN0-481 Testking: https://www.prepawayete.com/Juniper/JN0-481-practice-exam-dumps.html
However, preparing for the Juniper JN0-481 exam can be a difficult and time-consuming process, They can change the settings of the time and questions as per need while giving the Juniper JN0-481 tests, So that if you practice with our JN0-481 exam questions, then you will pass for sure, Juniper Free JN0-481 Study Material Most of our customers pass exam at first shot.
Truth About Confident Presenting, TheTruth About Confident Presenting, JN0-481 The, Lists all the environments prepped for use in testing, including environments that have been deployed.
However, preparing for the Juniper JN0-481 Exam can be a difficult and time-consuming process, They can change the settings of the time and questions as per need while giving the Juniper JN0-481 tests.
PrepAwayETE Juniper JN0-481 Exam Questions are Real and Verified by ExpertsSo that if you practice with our JN0-481 exam questions, then you will pass for sure, Most of our customers pass exam at first shot, Generally, when you buy some goods, and ifyou find some flaw, the vendor often admit to replace the goods Valid Test JN0-481 Testking with you, even though the vendor reply to refund, the process is cumbersome and the money back to you is too slow.
DOWNLOAD the newest PrepAwayETE JN0-481 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1gsq2e5jIDxUBqEyfLWYf2fWjEP3ZOaOJ
Posted at 1/26/2026 18:56:29        Only Author  2#
This article is full of inspiration, thank you for posting it! Good luck to me as I prepare for the Latest study guide Analytics-Admn-201 ebook exam!
Posted at 1/26/2026 19:33:22        Only Author  3#
This is a truly exceptional piece of writing, thank you for sharing. I’m sharing the FCP_GCS_AD-7.6 reliable braindumps free test that helped me get promoted and receive a salary increase. It’s free for you today—wishing you success in your career!
Posted at 2/6/2026 13:11:28        Only Author  4#
Your article is absolutely stunning, I’m so grateful for your share! I owe my career success to the Workday-Pro-Compensation useful dumps test, and now I’m sharing it with you free of charge!
Posted at 2/23/2026 11:42:34        Only Author  5#
This is one of the most inspiring articles I’ve read, thank you! We offer free access to 100-160 relevant exam dumps, filled with material meant to help you succeed.
