[General] CIS-Discovery Practice Engine | Exam CIS-Discovery Simulator Online
96
General CIS-Discovery Practice Engine | Exam CIS-Discovery Simulator Online
Posted at 1/24/2026 04:12:54      View158 | Replies2        Print      Only Author   [Copy Link] 1#
What's more, part of that ActualtestPDF CIS-Discovery dumps now are free: https://drive.google.com/open?id=10s3bAOmACj1ONfVRnnXT3WZuDbh0pJE6
There are many other advantages of our CIS-Discovery exam questions. To gain a full understanding of our CIS-Discovery learning guide. please firstly look at the introduction of the features and the functions of our CIS-Discovery exam torrent. The page of our product provide the demo to let the you understand part of our titles before their purchase and see what form the software is after the you open it. The client can visit the page of our product on the website. So the client can understand our CIS-Discovery Quiz torrent well and decide whether to buy our CIS-Discovery exam questions or not at their wishes.
ServiceNow Discovery application is an essential tool for organizations to manage their IT infrastructure. The application helps in identifying all the hardware and software assets in the IT environment, including servers, databases, applications, and network devices. The application also provides visibility into the relationships between these assets, enabling organizations to manage their IT infrastructure more efficiently. The ServiceNow CIS-Discovery Certification validates an individual's ability to implement and configure the Discovery application, making them valuable assets to any organization.
2026 High-quality CIS-Discovery Practice Engine Help You Pass CIS-Discovery EasilySometime, most candidates have to attend an exam, they may feel nervious and don't know what to do. If you happen to be one of them, our CIS-Discovery learning materials will greatly reduce your burden and improve your possibility of passing the exam. Our advantages of time-saving and efficient can make you no longer be afraid of the CIS-Discovery Exam, and you will find more about the benefits of our CIS-Discovery exam questions later on.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q73-Q78):NEW QUESTION # 73
Which choice best describes a Functionality Definition?
  • A. Defines what protocols to detect from within a Behavior.
  • B. Defines the IP addresses to discover.
  • C. Defines what CI identifiers to use.
  • D. Defines what Behavior to use from a Discovery Schedule.
A Functionality Definition is a configuration record that defines what protocols to detect from within a Behavior. A Behavior is a set of Functionality Definitions that Discovery uses to identify and explore a device or application. A Functionality Definition specifies the order, type, and parameters of the probes that Discovery launches to gather information about a device or application12.
* Functionality Definition
* Behavior
NEW QUESTION # 74
The deletion strategy is set to 'Mark as absent' for related Disk Cls discovered via the Linux Server pattern. If a related Disk Cl is discovered during the Linux Server discovery and then the same related Disk CI is not found the next time the Linux Server is discovered, the following will happen:
  • A. The Linux Server CI Operational Status (operational_status) is set to Non-Operational.
  • B. The Disk Status CI (install_status) is set to Absent.
  • C. The Linux Server CI Status (install_status) is set to Absent.
  • D. The Disk CI Operational Status (operational_status) is set to Non-Operational.
The deletion strategy 'Mark as absent' means that when a related CI that was previously discovered by a pattern is no longer found, the install_status attribute of that CI is set to Absent. This indicates that the CI is missing or removed from the network. The main CI (in this case, the Linux Server CI) is not affected by the deletion strategy of the related CI (in this case, the Disk CI)12.
References1: Set a deletion strategy - Product Documentation: San Diego - ServiceNow2: Network adapter status setting to "Absent" in EMC ... - ServiceNow ...
NEW QUESTION # 75
Which of the following best describes what may also be required when increasing the max number of threads for a MID Server?
  • A. increase the MID Server max payload size
  • B. updating the acl rules for the CMDB tables in ServiceNow
  • C. increase the amount of disk space on the MID Server host
  • D. increasing the memory allocated to the MID Server app.
When increasing the maximum number of threads for a MID Server in ServiceNow Discovery, it's often necessary to also increase the memory allocated to the MID Server application. This is because more threads can result in higher memory usage as each thread may consume resources while performing discovery tasks.
Increasing disk space, updating ACL rules for CMDB tables, or increasing the MID Server max payload size are not directly related to the number of threads used by a MID Server. References = ServiceNow Discovery documentation, especially sections discussing MID Server configuration and performance tuning.
NEW QUESTION # 76
Which of the following must be configured to allow a MID Server to access servers using WinRM? (Choose two.)
  • A. JEA Properties set to True
  • B. MID Servers need to be added to the WinRM Group policy on the Servers
  • C. MID Server Parameters Add WinRM
  • D. MID Servers must be configured as a trusted source with DNS
To allow a MID Server to access servers using WinRM, the following configurations are required:
* MID Servers need to be added to the WinRM Group policy on the Servers: This enables the servers to accept WinRM connections from the MID Servers and grant them the necessary permissions to execute commands and scripts1.
* MID Server Parameters Add WinRM: This enables the MID Server to use WinRM as a protocol for Discovery and Orchestration and specify the WinRM port, authentication method, and encryption settings2.
* Configure Windows servers for WinRM
NEW QUESTION # 77
Which service needs to be running on a host to detect a Windows device?
* WMI
* SSH
  • A. WinRM
  • B. CIM
For ServiceNow Discovery to detect a Windows device, the Windows Management Instrumentation (WMI) service needs to be running on the host. WMI is a Windows feature that provides a standardized way to access management information about operating system components and services. Discovery uses WMI to query Windows hosts for information about their hardware, software, and system configuration. SSH is used for Unix-like systems, WinRM is an alternative Windows management protocol, and CIM (Common Information Model) is a cross-platform standard; however, WMI is the primary service used for Windows device discovery.
NEW QUESTION # 78
With all CIS-Discovery practice materials being brisk in the international market, our CIS-Discovery practice materials are quite catches with top-ranking quality. But we do not stop the pace of making advancement by following the questions closely according to exam. So our experts make new update as supplementary updates. During your transitional phrase to the ultimate aim, our CIS-Discovery practice materials as well as these updates are referential. Those materials can secede you from tremendous materials with least time and quickest pace based on your own drive and practice to win. Those updates will be sent to you accordingly for one year freely.
Exam CIS-Discovery Simulator Online: https://www.actualtestpdf.com/ServiceNow/CIS-Discovery-practice-exam-dumps.html
P.S. Free 2026 ServiceNow CIS-Discovery dumps are available on Google Drive shared by ActualtestPDF: https://drive.google.com/open?id=10s3bAOmACj1ONfVRnnXT3WZuDbh0pJE6
Posted at 1/30/2026 12:38:53        Only Author  2#
Reading this article has helped me gain a deeper understanding of the related field. Upgrade your IT knowledge with free MS-102 valid test book. Best wishes for success!
Posted at 2/18/2026 08:29:21        Only Author  3#
ITIǤθޤޤʤ뤦ˡʤɤΤ褦^ޤCertiProfCEHPCԇY˺ϸ񤹤Τh֤äƤޤҡǤΤϤʤˤ٤CertiProfCEHPCԇY˺ϸ񤵤ޤgΰkչҡTopexamϤäȶयYԴȽUYäƤޤƤƤ륽եȤϤʤCertiProfCEHPCԇYΏ΄ʤߤ뤳ȤǤޤ
