Exam 312-97 Study Guide - 312-97 Latest Exam Guide
96
Posted at 1/24/2026 04:32:05      View88 | Replies0        Print      Only Author   [Copy Link] 1#
There is a high demand for EC-Council Certified DevSecOps Engineer (ECDE) certification, therefore there is an increase in the number of ECCouncil 312-97 exam candidates. Many resources are available on the internet to prepare for the EC-Council Certified DevSecOps Engineer (ECDE) exam. PDF4Test is one of the best certification exam preparation material providers where you can find newly released ECCouncil 312-97 Dumps for your exam preparation.
Our 312-97 study prep has a pass rate of 98% to 100% because of the high test hit rate. So our 312-97 study materials are not only effective but also useful. As we all know, time is very important to everyone. Some candidates are very busy with their own work and families. It is very difficult to take time out to review the 312-97 Exam. But if you use 312-97 exam materials, you will learn very little time and have a high pass rate. Our 312-97 study materials are worthy of your trust.
312-97 Latest Exam Guide & New 312-97 Exam BootcampImmediately after you have made a purchase for our 312-97 practice dumps, you can download our 312-97 study materials to make preparations. It is universally acknowledged that time is a key factor in terms of the success. The more time you spend in the preparation for 312-97 Training Materials, the higher possibility you will pass the exam. And with our 312-97 study torrent, you can get preparations and get success as early as possible.
ECCouncil EC-Council Certified DevSecOps Engineer (ECDE) Sample Questions (Q31-Q36):NEW QUESTION # 31
(Erica Mena has been working as a DevSecOps engineer in an IT company that provides customize software solutions to various clients across United States. To protect serverless and container applications with RASP, she would like to create an Azure container instance using Azure CLI in Microsoft PowerShell. She created the Azure container instance and loaded the container image to it. She then reviewed the deployment of the container instance. Which of the following commands should Erica run to get the logging information from the Azure container instance? (Assume the resource group name as ACI and container name as aci-test- closh.))
  • A. az get container logs -resource-group ACI --name aci-test-closh.
  • B. az get container logs --resource-group ACI --name aci-test-closh.
  • C. az container logs --resource-group ACI --name aci-test-closh.
  • D. az container logs -resource-group ACI -name aci-test-closh.
Azure Container Instances provide built-in logging capabilities that can be accessed using the Azure CLI. To retrieve logs from a deployed container instance, the correct command isaz container logsfollowed by the resource group and container name. The proper syntax requires double-dash parameters:--resource-groupand
--name. In Erica's case, the correct command is az container logs --resource-group ACI --name aci-test-closh.
Options that use "az get container logs" are invalid because "get" is not a supported verb in this context.
Option C uses incorrect single-dash flags, which do not match Azure CLI standards. Accessing container logs during the Code stage helps engineers validate application behavior, identify runtime errors, and ensure that security instrumentation such as RASP agents are functioning correctly before progressing further in the pipeline.
NEW QUESTION # 32
(Allen Smith has been working as a senior DevSecOps engineer for the past 4 years in an IT company that develops software products and applications for retail companies. To detect common security issues in the source code, he would like to integrate Bandit SAST tool with Jenkins. Allen installed Bandit and created a Jenkins job. In the Source Code Management section, he provided repository URL, credentials, and the branch that he wants to analyze. As Bandit is installed on Jenkins' server, he selected Execute shell for the Build step and configure Bandit script. After successfully integrating Bandit SAST tool with Jenkins, in which of the following can Allen detect security issues?.)
  • A. Python code.
  • B. C++ code.
  • C. Java code.
  • D. Ruby code.
Bandit is a Static Application Security Testing (SAST) tool developed specifically for analyzingPython source code. It scans Python scripts and applications to identify common security issues such as use of weak cryptography, hardcoded passwords, unsafe use of functions like eval, and insecure imports. Bandit works by parsing Python Abstract Syntax Trees (ASTs) and applying a set of security-focused rules. It does not support Java, Ruby, or C++ code, which require different static analysis tools tailored to their respective languages.
By integrating Bandit with Jenkins during the Build and Test stage, Allen enables automated detection of Python-specific security flaws as soon as code changes are introduced. This shift-left approach reduces remediation costs, prevents vulnerable code from progressing further in the pipeline, and improves overall application security posture.
NEW QUESTION # 33
(Curtis Morgan has been working as a software developer in an MNC company. His team has developed a NodeJS application. While doing peer review of the NodeJS application, he observed that there are insecure libraries in the application. Therefore, he approached, Teresa Lisbon, who is working as a DevSecOps engineer, to detect the insecure libraries in the NodeJS application. Teresa used a SCA tool to find known vulnerabilities in JavaScript libraries for Node.JS applications and detected all the insecure libraries in the application. Which of the following tools did Teresa use for detecting insecure libraries in the NodeJS application?)
  • A. Retire.js.
  • B. Bundler-Audit.
  • C. Bandit.
  • D. Tenable.io.
Retire.js is a Software Composition Analysis (SCA) tool designed specifically to identify known vulnerabilities in JavaScript libraries used in web and NodeJS applications. It scans dependencies and compares detected versions against a vulnerability database to identify insecure libraries. Bandit is a static analysis tool for Python, Bundler-Audit is used for Ruby dependencies, and Tenable.io focuses on infrastructure and vulnerability management rather than JavaScript libraries. Using Retire.js during the Code stage allows DevSecOps teams to identify insecure third-party dependencies early, reducing the likelihood of vulnerable libraries being deployed into production. This supports shift-left security and strengthens the application's overall security posture.
NEW QUESTION # 34
(Gabriel Jarret has been working as a senior DevSecOps engineer in an IT company located in Houston, Texas. He is using Vault to manage secrets and protect sensitive data. On February 1, 2022, Gabriel wrote the secret using vault kv put secret/wejskt command. On February 10, 2022, his team detected a brute-force attack using Splunk monitoring tool. Gabriel would like to delete the secrets in the vault that he wrote on February 1, 2022. Which of the following commands should Gabriel use to delete a secret in Vault secret management tool?)
  • A. vault kv -del secret/wejskt.
  • B. vault kv delete secret/wejskt.
  • C. vault kv del secret/wejskt.
  • D. vault kv -delete secret/wejskt.
HashiCorp Vault provides a key-value (KV) secrets engine for securely storing sensitive data. To remove a secret from the KV store, the correct command is vault kv del <path>. This command deletes the secret data at the specified path. Options using -delete or -del are syntactically incorrect, and vault kv delete is not a valid Vault CLI command. Proper secret deletion is an essential part of secret lifecycle management, especially when credentials may have been compromised. Performing this action during the Operate and Monitor stage helps contain security incidents, reduce exposure, and ensure that compromised secrets are no longer accessible. Timely deletion of secrets supports effective incident response and strengthens overall security posture.
NEW QUESTION # 35
(Andrew Gerrard has recently joined an IT company located in Fairmont, California, as a DevSecOps engineer. Due to robust security and cost-effective service provided by AWS, his organization has migrated all the workloads from on-prem to AWS cloud in January of 2020. Andrew's team leader has asked him to integrate AWS Secret Manager with Jenkins. To do so, Andrew installed the "AWS Secret Manager Credentials provider" plugin in Jenkins and configured an IAM policy in AWS that allows Jenkins to take secrets from AWS Secret manager. Which of the following file should Andrew edit to add access id and secret key parameters along with the region copied from AWS?.)
  • A. /etc/sysconfig/Jenkins.
  • B. /etc/filebeat/filebeat.yml.
  • C. /etc/sysconfig file/Jenkins.
  • D. /etc/file/Jenkins.
On Linux systems, Jenkins environment variables such as AWS access key ID, secret access key, and default region are commonly configured in the /etc/sysconfig/Jenkins file. This file allows administrators to define environment variables that are loaded when the Jenkins service starts. By placing AWS credentials and region information in this file, Jenkins jobs and plugins-such as the AWS Secrets Manager Credentials Provider- can securely access AWS resources. The other options reference invalid paths or unrelated configuration files (such as Filebeat). Editing /etc/sysconfig/Jenkins ensures consistent credential availability across Jenkins jobs while supporting secure integration with AWS services during the Code stage.
NEW QUESTION # 36
312-97 test questions have so many advantages that basically meet all the requirements of the user. If you have good comments or suggestions during the trial period, you can also give us feedback in a timely manner. Our study materials will give you a benefit as Thanks, we do it all for the benefits of the user. 312-97 Study Materials look forward to your joining in.
312-97 Latest Exam Guide: https://www.pdf4test.com/312-97-dump-torrent.html
ECCouncil Exam 312-97 Study Guide And there are three versions for you choose, One year free update is the welfare for the candidates who have bought our 312-97 Latest Exam Guide - EC-Council Certified DevSecOps Engineer (ECDE) prep material, We are glad to receive all your questions on our 312-97 exam dumps, We ensure you one year free update after purchase, so you can obtain the latest information about 312-97 study material without costing extra money, Free demo of our 312-97 dumps pdf can be downloaded before purchase and 24/7 customer assisting support can be access.
Another option is to select multiple functoids/links by holding down Ctrl while clicking them, After you bought 312-97 Real Braindumps from our website, you will enjoy one-year free update.
312-97 valid training questions & 312-97 updated practice vce & 312-97 exam cram testAnd there are three versions for you choose, One year free update is the welfare for the candidates who have bought our EC-Council Certified DevSecOps Engineer (ECDE) prep material, We are glad to receive all your questions on our 312-97 exam dumps.
