[General] Exam AD0-E137 Dumps, AD0-E137 Hot Spot Questions
98
【General】 Exam AD0-E137 Dumps, AD0-E137 Hot Spot Questions
Posted at 1/24/2026 05:43:22      View:191 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest TestPassKing AD0-E137 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1A7tRS-HuSaDliZ_aBf3l00q1SRilR47G
TestPassKing provides numerous extra features to help you succeed on the AD0-E137 exam, in addition to the Adobe AD0-E137 exam questions in PDF format and online practice test engine. These include 100% real questions and accurate answers, 1 year of free updates, a free demo of the Adobe AD0-E137 Exam Questions, a money-back guarantee in the event of failure, and a 20% discount. TestPassKing is the ideal alternative for your Adobe Experience Manager Sites Developer Expert (AD0-E137) test preparation because it combines all of these elements.
Regarding the process of globalization, every fighter who seeks a better life needs to keep pace with its tendency to meet challenges. AD0-E137 certification is a stepping stone for you to stand out from the crowd. Nowadays, having knowledge of the AD0-E137 study braindumps become widespread, if you grasp solid technological knowledge, you are sure to get a well-paid job and be promoted in a short time. According to our survey, those who have passed the exam with our AD0-E137 Test Guide convincingly demonstrate their abilities of high quality, raise their professional profile, expand their network and impress prospective employers.
AD0-E137 Hot Spot Questions | Exam AD0-E137 DemoOur system is high effective and competent. After the clients pay successfully for the AD0-E137 certification material the system will send the products to the clients by the mails. The clients click on the links in the mails and then they can use the AD0-E137 prep guide materials immediately. It takes only a few minutes for you to make the successful payment for our AD0-E137 learning file. Our system will automatically send the updates of the AD0-E137 learning file to the clients as soon as the updates are available. So our system is wonderful.
Adobe AD0-E137 Exam Syllabus Topics:
  • Environment Maintenance: This section of the exam measures the skills of Implementation Specialists and covers managing AEM environment configurations, release management, synchronizing content and configurations across environments via package manager, and applying maintenance tools to support environments.
  • Build and Deployment: This section of the exam measures the skills of AEM Developers and covers front-end and back-end dependency management, creating a project via Maven archetype, crafting custom run modes, configuring workflows, and creating and managing custom Oak indexes.
  • Configurations: This section of the exam measures skills of AEM Developers and covers how to select and configure dispatcher rules based on scenario, set up multi-tenant environments, integrate SAML and LDAP for authentication, configure replication agents, and manage editable templates or content fragment models.
  • AEM Development: This section of the exam measures the skills of Technical Consultants and covers implementing a single-page application (SPA) structure, building components using HTL, sling models, and services, writing unit tests and mapping mock data, integrating third-party APIs, developing OSGi services or servlets, and choosing appropriate JCR queries in context.
Adobe Experience Manager Sites Developer Expert Sample Questions (Q31-Q36):NEW QUESTION # 31
An Adobe Experience Manager architect is asked to configure run mode for their UAT environment.
Which configuration will work for the environment?
  • A. /apps/<Project Name>/osgiconfig/config.author.author/<Persistent Identity>.json in ui.apps project
  • B. /apps/<Project Name>/osgiconfig/config.uat.author/<Persistent Identity>.cfg.json in ui.apps project
  • C. /apps/<Project Name>/osgiconfig/config.publish.uat/<Persistent Identity>.cfg.json in ui.config project
NEW QUESTION # 32
A developer is writing a unit test for a service that depends on a query of nodes inside the JCR.
What is the correct approach to unit testing the service?
  • A. Use SlingContext with ResourceResolverType of JCR_OAK.
  • B. Use an @Mock annotation on the Query object with when and then methods.
  • C. Add the currentResource method call to include the nodes to be queried.
NEW QUESTION # 33
A developer decides to use a text pre-extraction for re/indexing Lucene indexes.
When is this recommended?
  • A. When dealing with binary-heavy repositories with a small volume of files
  • B. When the repository contains a large volume of images
  • C. When reindexing an existing Lucene index with binary extraction enabled
NEW QUESTION # 34
A customer noticed slower Adobe Experience Manager performance in the last couple of days. The segment store size is almost double the size from the previous week.
To reduce the segment store size and maintain overall Adobe Experience Manager health, which two Adobe Experience Manager maintenance tasks should be executed Weekly? (Choose two.)
  • A. Datastore Garbage Collection
  • B. Online Revision Cleanup
  • C. Version Purge
  • D. Clientlib Dumps
NEW QUESTION # 35
A developer is tasked with designing a solution to accommodate multiple client projects within a single Adobe Experience Manager (AEM) instance, each requiring its own set of unique resources, code, and content.
Given the need for true multi-tenancy, where each tenant operates independently with zero knowledge of other tenants and no shared code, content, or common authors, which approach should the developer recommend?
  • A. Encourage the use of component groups and allowedPaths properties to logically separate tenant-specific components and templates within the same AEM instance.
  • B. Utilize AEM's out-of-the-box multi-tenancy capabilities to segregate tenants within the same author and publish instances, relying on access control lists (ACLs) and content path organization to ensure separation.
  • C. Implement separate author and publish instances for each tenant, ensuring complete isolation of resources, code, and content, thereby achieving true multi-tenancy.
NEW QUESTION # 36
It is well known that even the best people fail sometimes, not to mention the ordinary people. In face of the AD0-E137 exam, everyone stands on the same starting line, and those who are not excellent enough must do more. Every year there are a large number of people who can't pass the AD0-E137 Exam smoothly. But we are professional in this career for over ten years. And our AD0-E137 study materials will help you pass the exam easily.
AD0-E137 Hot Spot Questions: https://www.testpassking.com/AD0-E137-exam-testking-pass.html
BTW, DOWNLOAD part of TestPassKing AD0-E137 dumps from Cloud Storage: https://drive.google.com/open?id=1A7tRS-HuSaDliZ_aBf3l00q1SRilR47G
Posted at 2/15/2026 10:40:30        Only Author  2#
Such an insightful article, I’m thankful for your sharing. Explore C-BCHCM-2502 valid study guide free download, which is packed with valuable content, freely available to help you.
Posted at 2/18/2026 18:29:28        Only Author  3#
I appreciate you sharing this brilliant article, it’s really fantastic! Best of luck! Here are the PostgreSQL-Essentials test dumps.zip materials, free for all!
Posted at 2/19/2026 07:37:43        Only Author  4#
Absolutely worthy of a like, no hesitation. The Valid study guide Plat-Dev-201 book resources are free and very helpful.
