[General] Free 1z1-076 Download Pdf - Realistic 2026 Oracle Reliable Oracle Database 19c:
68
General Free 1z1-076 Download Pdf - Realistic 2026 Oracle Reliable Oracle Database 19c:
Posted at 1/24/2026 07:32:44      View269 | Replies3        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamDumpsVCE 1z1-076 dumps now are free: https://drive.google.com/open?id=1g64OMCJS2L8LZ7fRzEWEFLQ7IOmW7zF0
By keeping minimizing weak points and maiming strong points, our Oracle 1z1-076 exam materials are nearly perfect for you to choose. As a brand now, many companies strive to get our Oracle Database 19c: Data Guard Administration 1z1-076 practice materials to help their staffs achieve more certifications for our quality and accuracy.
Oracle Database 19c: Data Guard Administration (1z1-076) PDF dumps are the third and most convenient format of the Oracle Database 19c: Data Guard Administration (1z1-076) PDF questions prep material. This format is perfect for busy test takers who prefer to study for the Oracle Database 19c: Data Guard Administration (1z1-076) exam on the go. Questions bank in the ExamDumpsVCE Oracle 1z1-076 Pdf Dumps is accessible via all smart devices. We also update Oracle Database 19c: Data Guard Administration (1z1-076) PDF questions regularly to ensure they match with the new content of the 1z1-076 exam.
Reliable 1z1-076 Dumps Free, PDF 1z1-076 Cram ExamIf you use the ExamDumpsVCE Oracle 1z1-076 Study Materials, you can reduce the time and economic costs of the exam. It can help you to pass the exam successfully. Before you decide to buy our Oracle 1z1-076 exam materials, you can download our free test questions, including the PDF version and the software version. If you need software versions please do not hesitate to obtain a copy from our customer service staff.
Oracle 1z1-076 Exam Syllabus Topics:
  • Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
  • Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
Topic 5
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
Topic 6
  • Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
Topic 7
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
Topic 8
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Topic 10
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
Topic 11
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Topic 12
  • Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
Topic 13
  • Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
Oracle Database 19c: Data Guard Administration Sample Questions (Q67-Q72):NEW QUESTION # 67
Which two statements are true regarding asynchronous redo transport in a Data Guard
  • A. Real-time query performance on a physical standby database improves for current read requests when using this transport mode.
  • B. This transport mode satisfies the minimum requirements for Maximum Availability data protection mode.
  • C. The performance of SQL apply on a logical standby database always improves when using this transport mode.
  • D. This transport mode satisfies the minimum requirements for Maximum Performance data protection mode.
  • E. A transaction can commit without waiting for redo to be sent to any standby database in the data guard configuration.
Answer: D,E
Asynchronous redo transport is a method where the primary database does not wait for an acknowledgment from the standby database before committing transactions, which helps in minimizing the impact on the primary database's performance (B). This transport mode is associated with the Maximum Performance data protection mode, which prioritizes performance over synchronicity of data between the primary and standby databases (C). While it provides a level of data protection, there could be some data loss in the event of a primary database failure because redo data may not have been transmitted to the standby database at the time of the failure.
Oracle Data Guard Concepts and Administration documentation provides detailed explanations of different redo transport modes and their implications on data protection and performance. Asynchronous transport mode's behavior and association with Maximum Performance mode are outlined explicitly.
NEW QUESTION # 68
Which four requirements can be met by deploying a logical standby database?
  • A. Support for workloads requiring additional indexes.
  • B. It can be used to create additional schemas.
  • C. It must provide a disaster-recovery solution that protects all data with capability of performing switchovers and failovers.
  • D. Support for workloads requiring additional materialized views.
  • E. It can be used for Real Application Testing without affecting the disaster recovery capabilities.
  • F. It can be used to create additional tables.
  • G. It must have the same physical structure as the primary database.
Answer: A,D,E,F
A logical standby database is part of Oracle Data Guard and allows the standby database to be open for read-write operations, providing additional flexibility. The requirements met by a logical standby database include:
* Support for workloads requiring additional materialized views (A): Logical standby databases can support materialized views, allowing for complex data summarization and reporting workloads.
* It can be used to create additional tables (C): Unlike physical standby databases, logical standby databases allow for the creation of additional tables that do not exist in the primary database, enabling custom workloads and reporting.
* It can be used for Real Application Testing without affecting the disaster recovery capabilities (E):
Logical standby databases can be used to test application changes, patches, and upgrades while still maintaining their role as part of the disaster recovery strategy.
* Support for workloads requiring additional indexes (F): Logical standby databases allow for the creation of additional indexes to optimize query performance for reporting and analytical workloads.
* Oracle Data Guard Concepts and Administration
* Oracle Database High Availability Overview
NEW QUESTION # 69
The Oracle database 19c Observer is currently running on host1 and you wish to have it running on host2.
Examine this list of possible steps:
1) Stop the observer on host1
2) Disable Fast-Start Failover
3) Update the broker configuration with the new observer hostname
4) Enable Fast-Start Failover
5) Start the Observer on host2
Which contains the minimum required steps to move the observer to host2?
  • A. Execute tasks 1, 2, 3, 4, and 5
  • B. Execute only task 5
  • C. Execute tasks 1, 3, and 5
  • D. Execute tasks 1 and 5
* Stop the Observer on host1 to ensure that there are no conflicts between the instances of the Observer running on different hosts.
* Update the Data Guard Broker configuration with the new hostname for the Observer. This step is crucial to redirect the Data Guard Broker to communicate with the Observer on the new host.
* Start the Observer on host2 to resume its operations in the new environment.
Disabling and re-enabling Fast-Start Failover (steps 2 and 4) are not strictly necessary for moving the Observer to a new host. These steps would be more relevant if changes to the configuration of Fast-Start Failover itself were required, which is not the case when simply relocating the Observer.
NEW QUESTION # 70
Which three are true about using Flashback database through role transitions in a Data Guard environment?
  • A. Physical standby databases retain their current role when you flash back to a point in time before a reinstate occurred which caused this database to become a physical standby.
  • B. Logical standby database roles are reverted to their original role when you flash back to a point in time before the switchover occurred which caused this database to become a logical standby.
  • C. Flashback database may not be used to undo a physical standby database activation.
  • D. Physical standby databases retain their current role when you flash back to a point in time before the switchover occurred which caused this database to become a physical standby.
  • E. Logical standby databases retain their current role when you flash back through to a point in time before the switchover occurred which caused this database to become a logical standby.
Answer: A,C,D
NEW QUESTION # 71
A Data Guard environment has this configuration and these attributes:
A primary database
A physical standby database named sbdb
The configuration is in maximum availability protection mode.
Then sbdb is converted to a snapshot standby database.
Which two statements are true?
  • A. sbdb can still receive redo.
  • B. The recovery point objective increases.
  • C. The recovery time objective increases.
  • D. sbdb can still apply redo.
  • E. The protection mode is lowered to maximum performance.
NEW QUESTION # 72
Review the products offered by us by downloading their free demos and compare them with the 1z1-076 study material offered in online course free and vendors' files. You will find our products the better than our competitors such as exam collection and others. The excellent quality of our 1z1-076 content, their relevance with the actual exam needs and their interactive and simple format will prove them superior and quite pertinent to your needs and requirements.
Reliable 1z1-076 Dumps Free: https://www.examdumpsvce.com/1z1-076-valid-exam-dumps.html
P.S. Free 2026 Oracle 1z1-076 dumps are available on Google Drive shared by ExamDumpsVCE: https://drive.google.com/open?id=1g64OMCJS2L8LZ7fRzEWEFLQ7IOmW7zF0
Posted at 2/4/2026 03:19:29        Only Author  2#
Fantastic content, Im giving it a like without thinking twice. Reliable PL-200 exam practice provides excellent material, and it's entirely free of charge.
Posted at 2/21/2026 23:42:19        Only Author  3#
Experience-Cloud-Consultant-JPNԇYϤʤΥꥢΥޥ륹ȩ`ǡΕrǡޤϤҪˤʤޤʤһؤǚݘSExperience-Cloud-Consultant-JPNԇY˺ϸ񤹤뤳Ȥ^ޤ¤󥹤äơ¤Sˤ餻ޤJapancert΂Τꤽ줬줹ϤϤ뤫˴󤭤ǤҡϱƷȤʤŬͨƤʤExperience-Cloud-Consultant-JPNԇY˺ϸ񤹤뤳ȤǤŤƤޤ
Posted at 3/9/2026 09:40:12        Only Author  4#
Thank you for your article; it truly shocked me! Dumps BAPv5 PDF test questions are the key to career successavailable for free!
