[General] Plat-Dev-210 Valid Exam Pdf | New Plat-Dev-210 Test Testking
105
General Plat-Dev-210 Valid Exam Pdf | New Plat-Dev-210 Test Testking
Posted at 1/24/2026 07:42:34      View112 | Replies0        Print      Only Author   [Copy Link] 1#
If you fail Plat-Dev-210 exam unluckily, dont worry about it, because we provide full refund for everyone who failed the exam. You can ask for a full refund once you show us your unqualified transcript to our staff. The whole process is time-saving and brief, which would help you pass the next Plat-Dev-210 Exam successfully. Please contact us through email when you need us. Our purchasing process is designed by the most professional experts, thats the reason why we can secure your privacy while purchasing our Plat-Dev-210 test guide.
Salesforce Plat-Dev-210 Exam Syllabus Topics:
  • Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
  • Integration Procedures: This section measures the skills of an Integration Architect and involves designing and configuring Integration Procedures to automate processes and integrate systems. It requires comparing and contrasting different elements and configurations within Integration Procedures to meet specific use cases. Candidates are also tested on selecting the correct elements and properties to satisfy functional requirements, ensuring seamless data flow and process automation.
  • Flexcards: This section of the exam measures the skills of a Solution Architect and covers the ability to design and configure FlexCards based on specific business requirements. It evaluates the candidate's knowledge in selecting appropriate card styles, defining data sources and fields, and implementing user actions across different card states. Additionally, this domain tests the understanding of constructing the underlying JSON data structure that powers the FlexCards framework, ensuring that the configured cards meet both functional and technical specifications.
  • Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
Salesforce Plat-Dev-210 Exam | Plat-Dev-210 Valid Exam Pdf - Instant Download of New Plat-Dev-210 Test TestkingYou may urgently need to attend Plat-Dev-210 certificate exam and get the certificate to prove you are qualified for the job in some area. But why Plat-Dev-210 certificate is valuable and useful and can help you a lot? Because passing the test certification can help you prove that you are competent in some area and if you buy our Plat-Dev-210 Study Materials you will pass the test almost without any problems. We are professional in these career for more than ten years and can give you promised success.
Salesforce Certified Omnistudio Developer Sample Questions (Q104-Q109):NEW QUESTION # 104
Which two fields in an Integration Procedure can use a function like CONCAT or DATEDIFF?
Choose 2 answers
  • A. In a Remote Action, in a Remote Options value field.
  • B. In Procedure Configuration, in a Tracking Custom Data value field.
  • C. In a Remote Action, in an Additional Output value field.
  • D. In a Response Action, in an Additional input value field.
According to the Integration Procedure Actions page, a Remote Action can use a function in an Additional Output value field or in a Remote Options value field. According to the Response Actions page, a Response Action can use a function in an Additional Input value field.
NEW QUESTION # 105
A developer creates an OmniScript to update billing information. After analyzing the different types of customer interactions that occur at the company, the developer determines updating billing information should be included in the majority of customer interactions.
What should the developer use to configure the action that invokes the OmniScript?
  • A. Custom Action
  • B. OmniScript Action
  • C. Lightning Action
From OmniStudio Best Practices for Modular Script Design, OmniScript Actions are the preferred mechanism to invoke another OmniScript within a parent OmniScript. This approach enables reusability and modularization, especially when a function (like updating billing information) is common across many interactions.
* A. OmniScript Action - This is the correct and standard method for embedding or launching one OmniScript from another. It allows developers to reuse common scripts without duplicating logic.
Incorrect Options:
* B. Custom Action requires custom Apex or LWC development, which is unnecessary for this use case.
* C. Lightning Action is typically used to invoke OmniScripts from Lightning pages, not within OmniScripts themselves.
OmniStudio Developer Guide # OmniScript Actions
NEW QUESTION # 106
What should a developer's first step be when troubleshooting whether a DataRaptor Extract is retrieving data?
  • A. Add a key/value pair in the DataRaptor to test it.
  • B. Go to the PREVIEW tab In OmniScript to test.
  • C. Go to the Lightning Console and reload the page to test.
  • D. Deactivate the card and layout, and go to the PREVIEW tab for the card to test.
The PREVIEW tab in OmniScript allows the developer to test the DataRaptor Extract by providing a record ID and viewing the output data. This is a quick and easy way to troubleshoot whether the DataRaptor Extract is retrieving data correctly.
NEW QUESTION # 107
The card layout uses an integration Procedure as a data source. The cards use the layout data source.
Which JSON data structure supports this card layout and follows best practices?
  • A.
  • B.
  • C.
The JSON data structure in option C supports the card layout and follows best practices. It has a list of objects, each representing a product, with the properties "roductCode", "roductName",
"roductDescription", and "roductPrice". These properties match the fields in the card layout. The JSON data structure also follows the naming convention of using camel case for property names. The JSON data structures in options A and B do not match the fields in the card layout and do not follow the naming convention.
NEW QUESTION # 108
Refer to the exhibit below. A developer has configured an Integration Procedure element with SEND
/RESPONSE TRANSFORMATIONS as shown.
Alternatively, how could the developer configure Additional Input tosend exactly the same data? Assume that the developer checked Send Only Additional Input.
  • A.
  • B.
  • C.
  • D.
The Additional Input property allows the developer to specify additional input parameters to be sent to the Integration Procedure element. The input parameters can be specified as a JSON object or as a list of key- value pairs. If the developer checked Send Only Additional Input, then only the input parameters specified in Additional Input are sent, and the SEND/RESPONSE TRANSFORMATIONS are ignored. Therefore, the developer needs to specify the same input parameters as in the SEND/RESPONSE TRANSFORMATIONS in Additional Input. Option C shows how to do this using a JSON object with two properties: "DBExtractAction:
Account" and "DBExtractAction:SecondaryAccount". The values of these properties are the same as in the SEND/RESPONSE TRANSFORMATIONS.
NEW QUESTION # 109
If you are having the same challenging problem, don't worry; Salesforce is here to help. Our direct and dependable Salesforce Treasury with Salesforce Certified Omnistudio Developer Exam Questions in three formats will surely help you pass the Salesforce Treasury with Plat-Dev-210 certification exam. Because this is a defining moment in your career, do not undervalue the importance of our Treasury with Salesforce Certified Omnistudio Developer (Plat-Dev-210) exam dumps. Profit from the opportunity to get these top-notch exam questions for the Plat-Dev-210 certification test.
New Plat-Dev-210 Test Testking: https://www.freedumps.top/Plat-Dev-210-real-exam.html
