[General] 2026 Test FCP_FGT_AD-7.6 Simulator Fee | Efficient 100% Free FCP_FGT_AD-7.6 Vali
88
General 2026 Test FCP_FGT_AD-7.6 Simulator Fee | Efficient 100% Free FCP_FGT_AD-7.6 Vali
Posted at 1/24/2026 10:09:56      View153 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Prep4SureReview FCP_FGT_AD-7.6 dumps for free: https://drive.google.com/open?id=1ZmC46HxawNHHYH7-gbWWQuA0TXhVRH7v
Prep4SureReview Fortinet FCP_FGT_AD-7.6 exam information are cheap and fine. We use simulation questions and answers dedication to our candidates with ultra-low price and high quality. We sincerely hope that you can pass the exam. We provide you with a convenient online service to resolve any questions about Fortinet FCP_FGT_AD-7.6 Exam Questions for you.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
Topic 5
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
FCP_FGT_AD-7.6 Valid Braindumps Questions & Valid FCP_FGT_AD-7.6 Exam TestUnder the guidance of our FCP_FGT_AD-7.6 preparation materials, you are able to be more productive and efficient, because we can provide tailor-made exam focus for different students, simplify the long and boring reference books by adding examples and diagrams and our IT experts will update FCP_FGT_AD-7.6 guide torrent on a daily basis to avoid the unchangeable matters. And you are able to study FCP_FGT_AD-7.6 study torrent on how to set a timetable or a to-so list for yourself in your daily life, thus finding the pleasure during the learning process of our FCP_FGT_AD-7.6 study materials.
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q91-Q96):NEW QUESTION # 91
Refer to the exhibits.
The exhibits show a diagram of a FortiGate device connected to the network, as well as the firewall policy and IP pool configuration on the FortiGate device Two PCs PC1 and PC2, are connected behind FortiGate and can access the internet successfully However, when the administrator adds a third PC to the network (PC3), the PC cannot connect to the internet Based on the information shown in the exhibit, which two configuration options can the administrator use to fa the connectivity issue for PC3? (Choose two.)
  • A. In the IP pool configuration, set type to overload.
  • B. In the system settings sot Multiple Interface Policies to enable
  • C. In the firewall policy, set match-vip to enable using CLI.
  • D. ln the IP pool configuration, set endip to 100.65.0.112.
NEW QUESTION # 92
Refer to the exhibit to view the firewall policy.
Why would the firewall policy not block a well-known virus, for example eicar?
  • A. Web filter is not enabled on the firewall policy to complement the antivirus profile.
  • B. The action on the firewall policy is not set to deny.
  • C. The firewall policy does not apply deep content inspection.
  • D. The firewall policy is not configured in proxy-based inspection mode.
The firewall policy uses certificate-inspection under SSL inspection and flow-based inspection mode. Certificate inspection does not decrypt HTTPS traffic; it only checks the certificate fields.
Because of this, FortiGate cannot perform deep content inspection, which is required for antivirus to detect and block threats such as the EICAR test virus within encrypted HTTPS sessions.
NEW QUESTION # 93
An administrator notices that some users are unable to establish SSL VPN connections, while others can connect without any issues.
What should the administrator check first?
  • A. Ensure that user traffic is hitting the firewall policy.
  • B. Ensure that the affected users are using the correct port number.
  • C. Ensure that the HTTPS service is enabled on SSL VPN tunnel interface
  • D. Ensure that forced tunneling is enabled to reroute all traffic through the SSL VPN
If user traffic is not matching the appropriate firewall policy that permits SSL VPN, users will be unable to establish connections, making this the first aspect to verify.
NEW QUESTION # 94
What would be the impact of these settings on the Server certificate SNI check configuration on FortiGate?
  • A. FortiGate will close the connection if the SNI does not match the CN or SAN fields.
  • B. FortiGate will accept the connection with a warning if the SNI does not match the CN or SAN fields.
  • C. FortiGate will accept and use the CN in the server certificate for URL filtering if the SNI does not match the CN or SAN fields.
  • D. FortiGate will close the connection if the SNI does not match the CN and SAN fields
With the Server certificate SNI check set to Strict, FortiGate enforces that the SNI must match either the Common Name (CN) or Subject Alternative Name (SAN) in the server certificate; otherwise, it closes the connection.
NEW QUESTION # 95
A network administrator is configuring an IPsec VPN tunnel for a sales employee travelling abroad.
Which IPsec Wizard template must the administrator apply?
  • A. Remote Access
  • B. Site to Site
  • C. Hub-and-Spoke
  • D. Dial up User
The Remote Access IPsec Wizard template is used for individual users connecting from remote locations, such as traveling employees. This template configures FortiGate to act as an IPsec VPN server, allowing remote clients (like FortiClient) to securely connect and access internal network resources while abroad.
NEW QUESTION # 96
If you buy our Software version of the FCP_FGT_AD-7.6 study questions, you can enjoy the similar real exam environment for that this version has the advantage of simulating the real exam. In addition, the software version of our FCP_FGT_AD-7.6 learning guide is not limited to the number of the computer. As long as you use it on the Windows system, then you can enjoy the convenience of this version brings. So do not hesitate and buy our Software version of FCP_FGT_AD-7.6 Preparation exam, you will benefit a lot from it.
FCP_FGT_AD-7.6 Valid Braindumps Questions: https://www.prep4surereview.com/FCP_FGT_AD-7.6-latest-braindumps.html
BTW, DOWNLOAD part of Prep4SureReview FCP_FGT_AD-7.6 dumps from Cloud Storage: https://drive.google.com/open?id=1ZmC46HxawNHHYH7-gbWWQuA0TXhVRH7v
