[Linux] CAM-8MS1M camera on iCore-3568JQ rkisp-vir0: MIPI error: packet: 0x00100000
32
Linux CAM-8MS1M camera on iCore-3568JQ rkisp-vir0: MIPI error: packet: 0x00100000
Posted at 1/23/2025 15:23:15      View5193 | Replies8        Print      Only Author   [Copy Link] 1#
Hello, the problem is rkisp-vir0: MIPI error: packet: 0x00100000
with the CAM-8MS1M (XC7160) camera on the iCore-3568JQ, I built the OS according to the instructions of Compile Linux5.10 firmware (https://wiki.t-firefly.com/en/iC ... pile_linux5.10.html), can you tell me how to solve and what is the problem?
firefly@firefly:/boot$ sudo i2cdetect -y 4
    0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
20: -- -- -- -- -- -- -- -- -- 29 -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- 44 -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
firefly@firefly:~/Downloads$ v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelfor
mat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=0,width=1920,height=1080 --stream-to
=out.yuv
VIDIOC_QUERYCAP: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture Multiplanar:
       Width/Height      : 1920/1080
       Pixel Format      : 'NV12' (Y/CbCr 4:2:0)
       Field             : None
       Number of planes  : 1
       Flags             :
       Colorspace        : Default
       Transfer Function : Default
       YCbCr/HSV Encoding: Default
       Quantization      : Full Range
       Plane 0           :
          Bytes per Line : 1920
          Size Image     : 3110400
VIDIOC_G_SELECTION: ok
VIDIOC_S_SELECTION: ok
               VIDIOC_REQBUFS returned 0 (Success)
               VIDIOC_QUERYBUF returned 0 (Success)
               VIDIOC_QBUF returned 0 (Success)
               VIDIOC_STREAMON returned 0 (Success)
firefly@firefly:~/Downloads$ ffplay -f rawvideo -video_size 1920x1080 -pix_fmt nv12 out.yuv
ffplay version 4.2.4-1ubuntu1.0firefly3 Copyright (c) 2003-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-17ubuntu1~20.04)
configuration: --prefix=/usr --extra-version=1ubuntu1.0firefly3 --toolchain=hardened --libdir=/usr/lib/aarch
64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-av
resample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-
libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libfl
ite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-l
ibjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enab
le-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --en
able-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --
enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable
-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sd
l2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx2
64 --enable-libdrm --enable-librga --enable-rkmpp --enable-version3 --disable-libopenh264 --disable-vaapi --di
sable-vdpau --disable-decoder=h264_v4l2m2m --disable-decoder=vp8_v4l2m2m --disable-decoder=mpeg2_v4l2m2m --dis
able-decoder=mpeg4_v4l2m2m --enable-shared --disable-doc
libavutil      56. 31.100 / 56. 31.100
libavcodec     58. 54.100 / 58. 54.100
libavformat    58. 29.100 / 58. 29.100
libavdevice    58.  8.100 / 58.  8.100
libavfilter     7. 57.100 /  7. 57.100
libavresample   4.  0.  0 /  4.  0.  0
libswscale      5.  5.100 /  5.  5.100
libswresample   3.  5.100 /  3.  5.100
libpostproc    55.  5.100 / 55.  5.100
Option -pix_fmt is deprecated, use -pixel_format.
Failed to initialize a hardware accelerated renderer: Couldn't find matching render driver
Input #0, rawvideo, from 'out.yuv':
Duration: N/A, bitrate: 622080 kb/s
   Stream #0:0: Video: rawvideo (NV12 / 0x3231564E), nv12, 1920x1080, 622080 kb/s, 25 tbr, 25 tbn, 25 tbc
firefly@firefly:~/Downloads$ ls -all
total 12
drwxr-xr-x 2 firefly firefly 4096 Jan 23 06:24 .
drwxr-xr-x 1 firefly firefly 4096 Jan 23 05:51 ..
-rw-rw-r-- 1 firefly firefly    0 Jan 23 06:58 out.yuv
firefly@firefly:/boot$ dmesg | grep rkisp-vir0 | tail -n 10
[ 2034.618102] rkisp-vir0: MIPI error: packet: 0x00100000
[ 2034.618132] rkisp-vir0: MIPI error: packet: 0x00100000
ls /dev/video* -la
crw-rw----+ 1 root video 81, 0 Jan 23 05:51 /dev/video0
firefly@firefly:/boot$ nano rk3568-firefly-itx-3568q.dts
        i2c@fe5d0000 {
               compatible = "rockchip,rk3399-i2c";
               reg = <0x00 0xfe5d0000 0x00 0x1000>;
               clocks = <0x23 0x14e 0x23 0x14d>;
               clock-names = "i2c\0pclk";
               interrupts = <0x00 0x32 0x04>;
               pinctrl-names = "default";
               pinctrl-0 = <0xee>;
               #address-cells = <0x01>;
               #size-cells = <0x00>;
               status = "okay";
               clock-frequency = <0x61a80>;
               gc8034@37 {
                       compatible = "galaxycore,gc8034";
                       status = "disabled";
                       reg = <0x37>;
                       clocks = <0x23 0xd6>;
                       clock-names = "xvclk";
                       pinctrl-0 = <0xef>;
                       reset-gpios = <0xeb 0x0e 0x01>;
                       pwdn-gpios = <0xf0 0x0c 0x01>;
                       rockchip,grf = <0x3b>;
                       rockchip,camera-module-index = <0x00>;
                       rockchip,camera-module-facing = "back";
                       rockchip,camera-module-name = "RK-CMK-8M-2-v1";
                       rockchip,camera-module-lens-name = "CK8401";
                       port {
                               endpoint {
                                       remote-endpoint = <0xf1>;
                                       data-lanes = <0x01 0x02 0x03 0x04>;
                                       phandle = <0x12a>;
               os04a10@36 {
                       compatible = "ovti,os04a10";
                       reg = <0x36>;
                       power-domains = <0x25 0x08>;
                       pinctrl-0 = <0xef>;
                       pwdn-gpios = <0xf0 0x0c 0x00>;
                       rockchip,camera-module-name = "CMK-OT1607-FV1";
                       rockchip,camera-module-lens-name = "M12-40IRC-4MP-F16";
                       port {
                               endpoint {
                                       remote-endpoint = <0xf2>;
                                       phandle = <0x129>;
               ov5695@36 {
                       compatible = "ovti,ov5695";
                       reg = <0x36>;
                       pinctrl-0 = <0xef>;
                       reset-gpios = <0xeb 0x0e 0x00>;
                       rockchip,camera-module-name = "TongJu";
                       rockchip,camera-module-lens-name = "CHT842-MD";
                       port {
                               endpoint {
                                       remote-endpoint = <0xf3>;
                                       data-lanes = <0x01 0x02>;
                                       phandle = <0x12b>;
               XC7160b@1b {
                       status = "okay";
                       compatible = "firefly,xc7160";
                       reg = <0x1b>;
                       pinctrl-0 = <0xef>;
                       reset-gpios = <0xbb 0x02 0x00>;
                       pwdn-gpios = <0xbb 0x04 0x00>;
                       firefly,clkout-enabled-index = <0x00>;
                       rockchip,camera-module-name = "NC";
                       rockchip,camera-module-lens-name = "NC";
                       port {
                               endpoint {
                                       remote-endpoint = <0xf4>;
                                       phandle = <0x12c>;
firefly@firefly:/boot$ cheese
(cheese:3492): GLib-CRITICAL **: 06:54:02.465: g_strsplit: assertion 'string != NULL' failed
Segmentation fault
camera_logs.tar.gz
1.01 MB, Down times: 1
Posted at 2/8/2025 15:15:27        Only Author  2#
Why is the out.yuv file size 0 bytes despite successful execution of v4l2-ctl, and how can we ensure proper build now gg video data is being captured?
Posted at 4/29/2025 15:45:56        Only Author  3#
Procedurally generated levels in Sprunki Game guarantee no two playthroughs are ever the same, offering endless replayability and ensuring players never run out of new areas to explore and conquer.
Posted at 5/5/2025 18:19:40        Only Author  4#
alicent23 Posted at 2/8/2025 15:15
Why is the out.yuv file size 0 bytes despite successful execution of v4l2-ctl, and how can we ensure ...
Yes, the out.yuv file is not generated, I explain this by the MIPI error, which I see in DMESG - "rkisp-vir0: MIPI error: packet: 0x00100000", I would like to understand the reason for these errors. When I take the assembly from the manufacturer "ITX-3568Q_Ubuntu20.04-r3108_v1.3.2g_240111.img", the situation repeats itself. Only taking the second module iCore-3568JQ - I get an image. Does it mean that MIPI does not work on the first module iCore-3568JQ ?
Posted at 1/11/2026 12:00:58        Only Author  5#
This article has helped me understand related concepts better, and Ive gained a lot. I used the New dumps NCP-MCI-6.10 free download to secure a promotion and raise. Now, Im offering it for free. Wishing you all success in your careers!
Posted at 1/12/2026 00:06:11        Only Author  6#
Your article was truly remarkable, Im sincerely grateful. I used the 312-85 reliable practice questions files to earn a promotion and salary boost. Now, its free for everyone. Best of luck on your career journey!
restricted members
Posted at 1/25/2026 13:34:55        Only Author  7#
Your article has made a lasting impression, thank you for it. Here are the free 400-007 valid dumps sheet materialsbest of luck with your exams!
Posted at 2/10/2026 06:56:38        Only Author  8#
I really appreciate your article, it was so thought-provoking. Wish me good luck on my Latest PMHN-BC learning material exam. Hope I do great!
Posted at 3/9/2026 01:56:47        Only Author  9#
H35-210_V2.5ѧɤȤƤꡢ``ϷdzˎڹǤ``ˤYṩ뤿ˡ˽ϳ˸ƤƤޤ H35-210_V2.5ԇYʂθߤƷ|Ȅʤϡ``JƤޤH35-210_V2.5ƥYϤθߤϸʤ؏դǤ H35-210_V2.5ԇYʂʹäƤޤꡢҪʤΤ_g˅Ǥޤ̕rgH35-210_V2.5ԇY˺ϸǤǤʤΤH35-210_V2.5JYȡäƽ뤯뤳ȤǤޤ
