[General] Highlighted Features of SAP C_ACDET_2506 Exam Practice Questions
101
【General】 Highlighted Features of SAP C_ACDET_2506 Exam Practice Questions
Posted at 1/24/2026 11:48:46      View:142 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest Fast2test C_ACDET_2506 PDF Dumps and C_ACDET_2506 Exam Engine Free Share: https://drive.google.com/open?id=1CSOZeZP-QolN8t_0GqQ5ZLN0EK3x_aK9
Fast2test offers SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite (C_ACDET_2506) practice exams (desktop & web-based) which are customizable. It means candidates can set time and SAP C_ACDET_2506 questions of the SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite (C_ACDET_2506) practice exam according to their learning needs. The Real C_ACDET_2506 Exam environment of practice test help test takers to get awareness about the test pressure so that they become capable to counter this pressure during the final exam.
Believe it or not, our C_ACDET_2506 preparation questions will relieve you from poverty. It is important to make large amounts of money in modern society. Our C_ACDET_2506 practice engine has assisted many people to improve themselves. You also can become the lucky guys as long as you are willing to learn. And with our C_ACDET_2506 Exam Materials, you will find that to learn something is also a happy and enjoyable experience, and you can be rewarded by the certification as well.
2026 Valid C_ACDET_2506 Exam Fee Pass Certify | Pass-Sure C_ACDET_2506 Pdf Demo Download: SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing SuiteThe test software used in our products is a perfect match for Windows' C_ACDET_2506 learning material, which enables you to enjoy the best learning style on your computer. Our C_ACDET_2506 certification guide also use the latest science and technology to meet the new requirements of authoritative research material network learning. Unlike the traditional way of learning, the great benefit of our C_ACDET_2506 learning material is that users can flexibly adjust their learning plans. We hope that our new design of C_ACDET_2506 test questions will make the user's learning more interesting and colorful.
SAP Certified Associate - Configuring SAP Ariba Strategic Sourcing Suite Sample Questions (Q45-Q50):NEW QUESTION # 45
When you create a custom field, how do you define where the field is added?
  • A. Each field can be linked to multiple screens, identified via UI GroupClass ID
  • B. The field is added to a class, identified by a class name
  • C. The field is added to a project header, identified by the templateClass ID
  • D. The field is added to a class, identified by the record ID
In SAP Ariba,custom fields are associated with a specific class identified by its class name, such as ContractWorkspace or ProcureLineItem. This class-level association determines where the field is available within the application. When added to a parent class, the field inherits to all its subclasses, affecting all relevant data objects. The field is not linked via UI group IDs, project templates, or record IDs, which relate to different configuration aspects. This class-based design supports consistent data models and inheritance in SAP Ariba's architecture.
NEW QUESTION # 46
Which of the following can be used to define relation types and establish a custom relationship? (Select 2 correct answers)
  • A. A custom Flex Master Data Template such as vrealm_1936.fmd_58984.Hospital
  • B. A standard class such as ariba.basic.core.CommodityCode
  • C. A custom Enumeration such as Contracts_Contract_Type
  • D. A custom Form Template such as vrealm_1936.formDoc_18697.LessonsLearned
In SAP Ariba,relation typescan be defined usingcustom Flex Master Data (FMD) templatesandstandard classessuch as ariba.basic.core.CommodityCode. These define valid relationships between fields, allowing dependent picklists or filtering logic in forms. Custom enumerations are static lists and are not used to establish dynamic relations, and custom form templates are for form layouts and do not define data relationships.
NEW QUESTION # 47
You have defined a custom field to have a default value based on another field. You have verified that the defaulting happens correctly the first time. However, when the dependent field change value, your custom field does not change.
What scenarios could cause this? Note: There are 3 correct answers to this question.
  • A. The custom field has the property Lock Inital value enabled, which prohibits a field to be changed once it's set
  • B. The parameter Application.Base.RecomputeValueOnFieldChange is not enabled
  • C. The defaulting Expression sets a value that violates the custom field Validity Condition
  • D. Your dependent field does not have the property Refresh screen on value change enabled
  • E. Your custom field has the property Respect User Value enabled, and the user has manually entered another value into the field
Answer: A,D,E
NEW QUESTION # 48
A Migration is performed for a Greenfield deployment to production, and the status of the Template configuration type indicates that it Failed. What actions do you take to make the failed template(s) available in production?
  • A. Import the missing data in production and then import the template in production
  • B. Request SAP intervention
  • C. Import the template in production
  • D. The template must always be rebuilt in production
NEW QUESTION # 49
Which document outlines the roles and responsibilities for the SAP Deployment Lead assigned to your project?
  • A. Inline Help
  • B. Deployment Description
  • C. Onboard Resource Center
  • D. Partner Statement of Work
NEW QUESTION # 50
If you are new to our website, you can ask any questions about our C_ACDET_2506 study materials. Our workers are very familiar with our C_ACDET_2506 learning braindumps. So you will receive satisfactory answers. What is more, our after sales service is free of charge. So our C_ACDET_2506 Preparation exam really deserves your choice. Welcome to come to consult us. We are looking forward to your coming at any time.
C_ACDET_2506 Pdf Demo Download: https://www.fast2test.com/C_ACDET_2506-premium-file.html
SAP Valid C_ACDET_2506 Exam Fee The software must have the following features, easy accessibility, and comprehensive content as well as good user experience, SAP Valid C_ACDET_2506 Exam Fee We pay much to research and development department every year, SAP Valid C_ACDET_2506 Exam Fee With the development of international technology and global integration certifications will be more and more valued, We promise to help you succeed to pass your C_ACDET_2506 exam test at first time.
The notion of knowing your enemy is essential in security as it is in New C_ACDET_2506 Exam Papers warfare) and top ten lists can help get software people started thinking about attacks, attackers, and the vulnerabilities they go after.
Valid C_ACDET_2506 Exam Fee Exam Pass Once Try | C_ACDET_2506 Pdf Demo DownloadUnderstand Ansible architecture, The software must have the following features, C_ACDET_2506 Online Training easy accessibility, and comprehensive content as well as good user experience, We pay much to research and development department every year.
With the development of international technology and global integration certifications will be more and more valued, We promise to help you succeed to pass your C_ACDET_2506 Exam Test at first time.
We are pass guarantee and money back guarantee C_ACDET_2506 if you fail to pass the exam, and the refund will be returned to your payment account.
Posted at 2/17/2026 06:53:50        Only Author  2#
By reading this article, I’ve developed a new understanding of both my work and life. Free Latest test L5M10 cram review resources—your key to career advancement and salary growth!
Posted at 2/19/2026 04:39:40        Only Author  3#
Through this article, my work thinking has significantly improved. The Reliable PMI-PMOCP test guide material is very good, and it’s free to access.
