[General] B2B-Solution-Architect Latest Exam Pattern & B2B-Solution-Architect Top Dump
76
General B2B-Solution-Architect Latest Exam Pattern & B2B-Solution-Architect Top Dump
Posted at 1/24/2026 13:04:52      View166 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New B2B-Solution-Architect dumps are available on Google Drive shared by TopExamCollection: https://drive.google.com/open?id=1z5V_L5F9y4IsH062pYlETYDzQvYZbhfk
We have three versions packages of the B2B-Solution-Architect exam questions to help you comprehensively. Also, all contents are carefully prepared by our researchers. So you neednt to read and memorize the boring reference books of the B2B-Solution-Architect Exam. Most people have successfully passed the exam under the assistance of our study materials. So try to trust us. Our B2B-Solution-Architect study materials will help you generate a wonderful life.
Salesforce B2B-Solution-Architect (Salesforce Certified B2B Solution Architect) Certification Exam is a highly sought-after certification in the technology industry. It is designed for professionals who want to demonstrate their expertise in designing and implementing solutions for business-to-business (B2B) commerce using Salesforce technologies. Salesforce Certified B2B Solution Architect Exam certification is ideal for architects, consultants, and developers who work with Salesforce to deliver B2B solutions.
Earning the Salesforce Certified B2B Solution Architect certification can be a valuable asset for individuals who are looking to advance their careers in the field of B2B Commerce. Salesforce Certified B2B Solution Architect Exam certification demonstrates that an individual has the skills and expertise needed to design and implement effective B2B Commerce solutions using the Salesforce platform. Additionally, the certification can help individuals stand out in the job market and can lead to new career opportunities and higher salaries. Overall, the Salesforce Certified B2B Solution Architect certification is an excellent way for individuals to validate their skills and expertise in the field of B2B Commerce.
Quiz B2B-Solution-Architect - Accurate Salesforce Certified B2B Solution Architect Exam Latest Exam PatternWe stand behind all of our customers, so we provide you with the best valid and useful Salesforce B2B-Solution-Architect exam training. Regular and frequent updates for B2B-Solution-Architect dumps are necessary, so you can get hold of the B2B-Solution-Architect updated exam material every time. Besides, we offer the exact questions with correct answers, which can ensure you 100% pass in your Salesforce B2B-Solution-Architect Actual Test. We have 100% money back guarantee, in case of failure, we will give you full refund.
Salesforce Certified B2B Solution Architect Exam Sample Questions (Q32-Q37):NEW QUESTION # 32
Universal Containers (UC) is about to undergo its first release of its digital transformation initiative across clouds like Sales Cloud, B2B Commerce, Marketing Cloud Account Engagement, Experience Cloud, and MuleSoft. UC recently developed its Center of Excellence (CoE) model and is working on how to make sure its developers and administrators can go through a continuous release cycle. The product owner would like to make sure no work is overridden in sandboxes or production.
What is the first thing a Solution Architect should recommend within UC's DevOps setup?
  • A. Make sure the developers all have access to the CLI so that they can package and push their changes to the next environment.
  • B. Appoint a release manager who will keep track of all changes made and which changes have been deployed to the QA, SIT, and UAT environments as part of the sprint.
  • C. Set up a source control based development process that's understood and followed by administrators and developers.
  • D. Appoint a release manager who will set up the required environments and automated deployments in tandem with a source control based development process.
Salesforce DevOps is a set of practices designed to help teams build, test, and release software faster and more reliably. It stems from the need to combine the responsibilities of both software development teams ('Dev') and operations teams ('Ops').
Salesforce DevOps Center is a new feature that enables admins and developers to manage releases and collaborate on a single set of configuration and code using an elegant point-and-click interface. It also integrates with version control, automates workflows, and releases with confidence using CI tools and the Metadata API.
Therefore, a Solution Architect should recommend setting up a source control based development process that's understood and followed by administrators and developers. This way, UC can ensure that no work is overridden in sandboxes or production, as well as improve team collaboration, code quality, and deployment speed.
https://www.salesforceben.com/salesforce-devops/
NEW QUESTION # 33
Universal Containers serves customers globally across two businesses. Each business has its own org for managing its sales and support operations. Each line of business also maintains its own reporting systems using both CRM Analytics and Salesforce reports, but the CEO is asking for a unique dashboard that includes the global opportunity pipeline with data from both orgs.
What should a Solution Architect propose?
  • A. Use CRM Analytics in the primary org and create a Salesforce External Connection. Then, create a dataflow to combine data from both orgs.
  • B. Use one org as primary and create external objects for the accounts and opportunities of the other one. Then, use standard reports.
  • C. Use one org as primary and an ETL tool to synchronize the accounts and opportunities of the other org. Then, use standard reports.
  • D. Use CRM Analytics in the primary org and then, in the dashboards, use Salesforce Connect to query the data from the other org.
it allows you to connect to your secondary org using a Salesforce External Connection12, which is a connector that enables you to access data from another Salesforce org without writing any code or using any middleware. You can then use a dataflow to combine data from both orgs and create datasets that can be used for CRM Analytics dashboards3
https://help.salesforce.com/s/ar ... ge=en_US&type=5
NEW QUESTION # 34
Universal Containers uses the Salesforce Platform to track customer payments and any late payments. This is accomplished with an architecture that includes Marketing Cloud, Service Cloud, and an integration to the back-office billing system via MuleSoft. Invoices and payments are mastered in the billing system and exposed to Salesforce via MuleSoft. Notifications about customer payments are orchestrated out of Salesforce and emails are sent via Marketing Cloud. The late payment invoice data is required for service representatives to be able to reference within Salesforce.
What should the Solution Architect recommend when determining the role of each system for a use case of sending payment reminders?
  • A. Create cases within Salesforce from the billing system based on payment statues with MuleSoft event orchestration and send payment notifications via Marketing Cloud.
  • B. Recommend a trigger from the billing system into Marketing Cloud, which sends customer formatted emails.
  • C. Integrate the billing system directly with Marketing Cloud via MuleSoft to trigger based on events from the billing system.
  • D. Load the payment and invoicing data within Salesforce from the billing system with MuleSoft, and drive payment notifications via Marketing Cloud.
Creating cases in Salesforce for late payments allows service representatives to have all the necessary information within their primary work environment. Orchestrating these events with MuleSoft and then using Marketing Cloud for communication ensures a seamless flow of information and allows for the leveraging of each system's strengths: Salesforce for case management and Marketing Cloud for customer communication. This strategy aligns with the recommended practices for system integration and event-driven architectures in Salesforce ecosystems.
NEW QUESTION # 35
Universal Containers (UC) is using Sales Cloud and Service Cloud. UC wants a solution that can tend scheduled emails on a dairy, weekly, or monthly basis to existing customers and prospects. UC also wants to track if customers have opened the emails. There can be as little as 1,000 emails in a week or as many as 100,000 emails in a month, depending on the season.
Based on that criteria, which solution should the Solution Architect recommend to UC?
  • A. Set up scheduled flows to handle email sending and tracking.
  • B. Develop a custom solution using scheduled Apex to send emails.
  • C. Recommend Marketing Cloud Personalization.
  • D. Recommend Marketing Cloud Account Engagement.
NEW QUESTION # 36
AW Computing (AWC) has just completed a multi-cloud implementation for Salesforce and is facing major user adoption challenges. Users are complaining that the system is complicated and hard to navigate.
What can the Center of Excellence (CoE) for Salesforce do to help increase user adoption?
  • A. Record hour-long pieces of training for each job role so users can review on their own time.
  • B. Break down training materials into quick reference guides for job-specific functions.
  • C. Ensure each team has a Salesforce champion that can provide one-on-one training.
  • D. Place all training materials on the home page so users can find them easily.
NEW QUESTION # 37
With our excellent B2B-Solution-Architect exam questions, you can get the best chance to obtain the B2B-Solution-Architect certification to improve yourself, for better you and the better future. With our B2B-Solution-Architect training guide, you are acknowledged in your profession. The B2B-Solution-Architect exam braindumps can prove your ability to let more big company to attention you. Then you have more choice to get a better job and going to suitable workplace. Why not have a try on our B2B-Solution-Architect Exam Questions, you will be pleasantly surprised our B2B-Solution-Architect exam questions are the best praparation material.
B2B-Solution-Architect Top Dumps: https://www.topexamcollection.com/B2B-Solution-Architect-vce-collection.html
BONUS!!! Download part of TopExamCollection B2B-Solution-Architect dumps for free: https://drive.google.com/open?id=1z5V_L5F9y4IsH062pYlETYDzQvYZbhfk
Posted at 2/17/2026 02:31:25        Only Author  2#
I really appreciate your article, it has made a big impression on me. This Latest test Introduction-to-Cryptography camp materials helped me get promoted and receive a raise. Now Im offering it for free. Wishing you all success in your career paths!
Posted at 3/8/2026 06:26:48        Only Author  3#
This article is incredibly thought-provoking, I appreciate you sharing it! I used the C11 test lab questions to secure a promotion and raise. Now, Im offering it for free. Wishing you all success in your careers!
