Hardware
DP-420 Latest Braindumps Ppt - Latest DP-420 Dumps
Posted at 1/24/2026 13:51:36
View144
Replies2
P.S. Free & New DP-420 dumps are available on Google Drive shared by TroytecDumps: https://drive.google.com/open?id=1onLsaeRvsUGL2_eusZVobPZ-K9TFVLCe
TroytecDumps offers authentic and up-to-date DP-420 study material that every candidate can rely on for good preparation. Our top priority is to help you pass the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam on the first try. The cost of registering for a certification Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) exam is quite expensive, ranging between $100 and $1000. After paying such an amount, the candidate is sure to be on a tight budget. TroytecDumps provides Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) preparation material at very low prices compared to other platforms. We also assure you that the amount will not be wasted and you will not have to pay for the Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB (DP-420) certification test for a second time.
Here is the easiest way to get prepared for the Microsoft DP-420 Certification ExamYou can get ready for taking the Microsoft DP-420 Certification Exam by following the steps mentioned here. You should always make a study plan for the Microsoft DP-420 Certification Exam. You should know the exam objectives and syllabus. The candidate should also know the previous question and answer of the DP-420 Certification Exam. You should prepare the questions and answers of the DP-420 Certification Exam by referring to the study materials. After that, you should always make a mock test for the Microsoft DP-420 Certification Exam. You should take a mock test before the actual exam.
You can also use DP-420 Dumps. It will help you to get a clear idea about your preparation. You should also take a mock test periodically. You should also compare your performance with other candidates. It will help you to get a clear idea about your preparation. In the end, you should practice the DP-420 Certification Exam by using the practice test software. It will help you to get a clear idea about your preparation. You should also practice the questions and answers of the DP-420 Certification Exam. You should try to solve the questions as soon as you finish reading the question.
Latest DP-420 Dumps - Exam DP-420 AssessmentWe has been developing faster and faster and gain good reputation in the world owing to our high-quality DP-420 exam materials and high passing rate. Since we can always get latest information resource, we have unique advantages on DP-420 study guide. Our high passing rate is the leading position in this field. We are the best choice for candidates who are eager to pass DP-420 Exams and acquire the certifications. Our DP-420 practice engine will be your best choice to success.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q68-Q73):NEW QUESTION # 68
You have a container named container1 in an Azure Cosmos DB for NoSQL account named account1.
You configure container1 to use Always Encrypted by using an encryption policy as shown in the C# and the Java exhibits. (Click the C# tab to view the encryption policy in C#. Click the Java tab to see the encryption policy in Java.)
According to the Azure Cosmos DB documentation1, Always Encrypted is a feature designed to protect sensitive data, such as credit card numbers or national identification numbers, stored in Azure Cosmos DB.
Always Encrypted allows clients to encrypt sensitive data inside client applications and never reveal the encryption keys to the database.
To use Always Encrypted, you need to define an encryption policy for each container that specifies which properties should be encrypted and which data encryption keys (DEK) should be used. The DEKs are stored in Azure Cosmos DB and are wrapped by customer-managed keys (CMK) that are stored in Azure Key Vault.
Based on the encryption policy shown in the exhibits, the creditcard property is encrypted with a DEK named dek1, and the SSN property is encrypted with a DEK named dek2. Both DEKs are wrapped by a CMK named cmk1.
To answer your statements:
* You can perform a query that filters on the creditcard property = No. This is because the creditcard property is encrypted and cannot be used for filtering or sorting operations1.
* You can perform a query that filters on the SSN property = No. This is also because the SSN property is encrypted andcannot be used for filtering or sorting operations1.
* An application can be allowed to read the creditcard property while being restricted from reading the SSN property = Yes. This is possible by using different CMKs to wrap different DEKs and applying access policies on the CMKs in Azure Key Vault. For example, if you use cmk2 to wrap dek2 instead of cmk1, you can grant an application access to cmk1 but not cmk2, which means it can read the creditcard property but not the SSN property2.
NEW QUESTION # 69
You have an Azure Cosmos DB for NoSQL account that frequently receives the same three queries.
You need to configure indexing to minimize RUs consumed by the queries.
Which type of index should you use for each query? To answer, select the appropriate options in the answer area.
Box 1 = Range Azure Cosmos DB supports three types of indexes: range, spatial and composite. For the query you provided, which is an equality query on a single property, the best type of index to use is range. Range index is based on an ordered tree-like structure and it is used for equality queries, range queries and checking for the presence of a property1. Range index also supports any string or number2.
Box 2 = Composite
Azure Cosmos DB supports three types of indexes: range, spatial and composite. For the query you provided, which is an order by query on two properties, the best type of index to use is composite. Composite index is used for optimizing order by queries on multiple properties1. Composite index allows you to specify a list of property paths and sort orders that are used for ordering items2.
Box 3 = spatial
Azure Cosmos DB supports three types of indexes: range, spatial and composite. For the query you provided, which is a spatial query on a point property, the best type of index to use is spatial. Spatial index is used for querying items based on their location or proximity to a given point1. Spatial index supports point, polygon and linestring data types2.
NEW QUESTION # 70
You need to provide a solution for the Azure Functions notifications following updates to con-product. The solution must meet the business requirements and the product catalog requirements.
Which two actions should you perform? Each correct answer presents part of the solution.
- A. Configure the trigger for each function to use a different leaseCollectionPrefix
- B. Configure the trigger for each function to use the same leaseCollectionPrefix
- C. Configure the trigger for each function to use the same leaseCollectionNair.e
- D. Configure the trigger for each function to use a different leaseCollectionName
leaseCollectionPrefix: when set, the value is added as a prefix to the leases created in the Lease collection for this Function. Using a prefix allows two separate Azure Functions to share the same Lease collection by using different prefixes.
Scenario: Use Azure Functions to send notifications about product updates to different recipients.
Trigger the execution of two Azure functions following every update to any document in the con-product container.
https://docs.microsoft.com/en-us ... cosmosdb-v2-trigger
NEW QUESTION # 71
You have a multi-region Azure Cosmos DB account named account1 that has a default consistency level of strong.
You have an app named App1 that is configured to request a consistency level of session.
How will the read and write operations of App1 be handled? To answer, select the appropriate options in the answer area.
Box 1 = Write and replicate data to every region synchronously
This is because the write concern is mapped to the default consistency level configured on your Azure Cosmos DB account2, which is strong in this case. Strong consistency ensures that every write operation is synchronously committed to every region associated with your Azure Cosmos DB account1. The request level consistency level of session only applies to the read operations of App11.
Box 2: That has the lowest estimated latency to the client
This is because the read operations of App1 will use the session consistency level that is specified in the request options. Session consistency is a client-centric consistency model that guarantees monotonic reads, monotonic writes, and read-your-own-writes within a session. A session is scoped to a client connection or a stored procedure execution. Session consistency allows clients to read from any region that has the lowest latency to the client.
NEW QUESTION # 72
You have a container named container1 in an Azure Cosmos DB Core (SQL) API account. Upserts of items in container1 occur every three seconds.
You have an Azure Functions app named function1 that is supposed to run whenever items are inserted or replaced in container1.
You discover that function1 runs, but not on every upsert.
You need to ensure that function1 processes each upsert within one second of the upsert.
Which property should you change in the Function.json file of function1?
- A. feedPollDelay
- B. leaseCollectionsThroughput
- C. maxItemsPerInvocation
- D. checkpointInterval
With an upsert operation we can either insert or update an existing record at the same time.
FeedPollDelay: The time (in milliseconds) for the delay between polling a partition for new changes on the feed, after all current changes are drained. Default is 5,000 milliseconds, or 5 seconds.
Reference: https://docs.microsoft.com/en-us ... cosmosdb-v2-trigger
NEW QUESTION # 73
It is important to check the exercises and find the problems. Once you use our DP-420 study prep to aid your preparation of the exam, all of your exercises of the study materials will be carefully recorded on the system of the DP-420 exam braindump. Also, you can know your current learning condition clearly. The results will display your final scores on the screen. Also, you will know the numbers of correct and false questions of your exercise. Our DP-420 test question grading system is designed to assist your study, which is able to calculate quickly. So you dont need to wait for a long time. The calculating speed of our DP-420 study prep is undergoing the test of practice. The highest record is up to five seconds. There has no delay time of the grading process. Slow system response doesnt exist. In addition, the calculation system of the DP-420 test question is very powerful and stable. We promise that the results of your exercises are accurate.
Latest DP-420 Dumps: https://www.troytecdumps.com/DP-420-troytec-exam-dumps.html
- Top DP-420 Questions 🐯 Latest DP-420 Exam Duration 🗣 Exam DP-420 Forum 🗓 Simply search for ▛ DP-420 ▟ for free download on ⮆ [url]www.troytecdumps.com ⮄ 🍹DP-420 Valid Exam Tips[/url]
- Download the Actual Microsoft DP-420 Exam Questions with Free Updates 😱 Search for ⮆ DP-420 ⮄ and download exam materials for free through [url]www.pdfvce.com ⬅️Study DP-420 Materials[/url]
- New DP-420 Exam Sample 🧳 Test DP-420 Collection Pdf 😠 DP-420 Trusted Exam Resource 💝 Search for ▶ DP-420 ◀ and download exam materials for free through ▛ [url]www.troytecdumps.com ▟ 🍵New DP-420 Exam Pdf[/url]
- New DP-420 Exam Sample 📃 Braindump DP-420 Free 🐢 DP-420 Simulated Test 🕶 Search for DP-420 and download it for free on [url]www.pdfvce.com website 🧃Top DP-420 Questions[/url]
- Download the Actual Microsoft DP-420 Exam Questions with Free Updates 🍓 Search for DP-420 and download it for free immediately on ✔ [url]www.pdfdumps.com ️✔️ 👔Braindump DP-420 Free[/url]
- How To Pass Microsoft DP-420 Exam On First Attempt 🏄 Open website ➥ [url]www.pdfvce.com 🡄 and search for DP-420 for free download 😪DP-420 Vce Test Simulator[/url]
- DP-420 Trusted Exam Resource 👧 Exam DP-420 Dumps 🎡 Latest DP-420 Exam Forum 🐉 Download ⏩ DP-420 ⏪ for free by simply searching on [url]www.examcollectionpass.com 🐤New DP-420 Exam Pdf[/url]
- Braindump DP-420 Free 👑 DP-420 Simulated Test 😳 DP-420 Latest Cram Materials 🚑 Easily obtain free download of ⏩ DP-420 ⏪ by searching on ⇛ [url]www.pdfvce.com ⇚ 🗨DP-420 Latest Cram Materials[/url]
- Braindump DP-420 Free 🙇 DP-420 Valid Exam Tips 🥀 New DP-420 Test Review 🐪 Copy URL [url]www.prepawaypdf.com open and search for ▷ DP-420 ◁ to download for free 💓New DP-420 Test Review[/url]
- Pass Guaranteed Quiz 2026 Microsoft DP-420: Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Unparalleled Latest Braindumps Ppt 💢 Search for ▛ DP-420 ▟ and obtain a free download on [url]www.pdfvce.com 💭DP-420 Exam Dumps[/url]
- How To Pass Microsoft DP-420 Exam On First Attempt 🐫 Search on ▛ [url]www.practicevce.com ▟ for ➤ DP-420 ⮘ to obtain exam materials for free download 🗜New DP-420 Exam Sample[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
