[General] Reliable Data-Con-101 Test Topics & Sample Data-Con-101 Questions
77
General Reliable Data-Con-101 Test Topics & Sample Data-Con-101 Questions
Posted at 1/24/2026 14:39:56      View141 | Replies1        Print      Only Author   [Copy Link] 1#
Practice materials are typically seen as the tools of reviving, practicing and remembering necessary exam questions for the exam, spending much time on them you may improve the chance of winning. However, our Data-Con-101 training materials can offer better condition than traditional practice materials and can be used effectively. We treat it as our major responsibility to offer help so our Data-Con-101 Practice Guide can provide so much help, the most typical one is the efficiency of our Data-Con-101 exam questions, which can help you pass the Data-Con-101 exam only after studying for 20 to 30 hours.
Without doubt, our Data-Con-101 practice dumps keep up with the latest information and contain the most valued key points that will show up in the real Data-Con-101 exam. Meanwhile, we can give you accurate and instant suggestion for our customer services know every detail of our Data-Con-101 Exam Questions. And they are pleased to give guide for 24 hours online. You can get assistant by them as long as you made your inquire.
Sample Data-Con-101 Questions, Data-Con-101 Exam ScoreOur passing rate of Data-Con-101 exam guide is 98%-100% and our Data-Con-101 test prep can guarantee that you can pass the exam easily and successfully. Our Data-Con-101 exam materials are highly efficient and useful and can help you pass the exam in a short time and save your time and energy. It is worthy for you to buy our Data-Con-101 Quiz torrent and you can trust our product. You neednt worry about anything as long as you have our Data-Con-101 training material. We guarantee to you our Data-Con-101 exam materials can help you and you will have an extremely high possibility to pass the exam.
Salesforce Certified Data Cloud Consultant Sample Questions (Q150-Q155):NEW QUESTION # 150
Every day, Northern Trail Outfitters uploads a summary of the last 24 hours of store transactions to a new file in an Amazon S3 bucket, and files older than seven days are automatically deleted. Each file contains a timestamp in a standardized naming convention.
Which two options should a consultant configure when ingesting this data stream?
Choose 2 answers
  • A. Ensure the refresh mode is set to "Upsert".
  • B. Ensure the refresh mode is set to "Full Refresh.''
  • C. Ensure the filename contains a wildcard to a accommodate the timestamp.
  • D. Ensure that deletion of old files is enabled.
When ingesting data from an Amazon S3 bucket, the consultant should configure the following options:
The refresh mode should be set to "Upsert", which means that new and updated records will be added or updated in Data Cloud, while existing records will be preserved. This ensures that the data is always up to date and consistent with the source.
The filename should contain a wildcard to accommodate the timestamp, which means that the file name pattern should include a variable part that matches the timestamp format. For example, if the file name is store_transactions_2023-12-18.csv, the wildcard could be store_transactions_*.csv. This ensures that the ingestion process can identify and process the correct file every day.
The other options are not necessary or relevant for this scenario:
Deletion of old files is a feature of the Amazon S3 bucket, not the Data Cloud ingestion process. Data Cloud does not delete any files from the source, nor does it require the source files to be deleted after ingestion.
Full Refresh is a refresh mode that deletes all existing records in Data Cloud and replaces them with the records from the source file. This is not suitable for this scenario, as it would result in data loss and inconsistency, especially if the source file only contains the summary of the last 24 hours of transactions. References: Ingest Data from Amazon S3, Refresh Modes
NEW QUESTION # 151
A company wants to test its marketing campaigns with different target populations.
What should the consultant adjust in the Segment Canvas interface to get different populations?
  • A. Segmentation filters, direct attributions, and data sources
  • B. Direct attributes and related attributes
  • C. Direct attributes, related attributes, and population filters
  • D. Population filters and direct attributes
Segmentation in Salesforce Data Cloud:
The Segment Canvas interface is used to define and adjust target populations for marketing campaigns.
Reference: Salesforce Segment Canvas Documentation
Elements for Adjusting Target Populations:
Direct Attributes: These are specific attributes directly related to the target entity (e.g., customer age, location).
Related Attributes: These are attributes related to other entities connected to the target entity (e.g., purchase history).
Population Filters: Filters applied to define and narrow down the segment population (e.g., active customers).
Reference: Salesforce Segmentation Guide
Steps to Adjust Populations in Segment Canvas:
Direct Attributes: Select attributes that directly describe the target population.
Related Attributes: Incorporate attributes from related entities to enrich the segment criteria.
Population Filters: Apply filters to refine and target specific subsets of the population.
Example: To create a segment of "Active Customers Aged 25-35," use age as a direct attribute, purchase activity as a related attribute, and apply population filters for activity status and age range.
Reference: Salesforce Segment Canvas Tutorial
Practical Application:
Navigate to the Segment Canvas.
Adjust direct attributes and related attributes based on campaign goals.
Apply population filters to fine-tune the target audience.
Reference: Salesforce Marketing Cloud Segmentation Best Practices
NEW QUESTION # 152
Which statement about Data Cloud's Web and Mobile Application Connector is true?
  • A. The Tenant Specific Endpoint is auto-generated in Data Cloud when setting the connector.
  • B. Any data streams associated with the connector will be automatically deleted upon deleting the app from Data Cloud Setup.
  • C. The connector schema can be updated to delete an existing field.
  • D. A standard schema containing event, profile, and transaction data is created at the time the connector is configured.
The Web and Mobile Application Connector allows you to ingest data from your websites and mobile apps into Data Cloud. To use this connector, you need to set up a Tenant Specific Endpoint (TSE) in Data Cloud, which is a unique URL that identifies your Data Cloud org. The TSE is auto-generated when you create a connector app in Data Cloud Setup. You can then use the TSE to configure the SDKs for your websites and mobile apps, which will send data to Data Cloud through the TSE. References: Web and Mobile Application Connector, Connect Your Websites and Mobile Apps, Create a Web or Mobile App Data Stream
NEW QUESTION # 153
Cumulus Financial uses Service Cloud as its CRM and stores mobile phone, home phone, and work phone as three separate fields for its customers on the Contact record. The company plans to use Data Cloud and ingest the Contact object via the CRM Connector.
What is the most efficient approach that a consultant should take when ingesting this data to ensure all the different phone numbers are properly mapped and available for use in activation?
  • A. Ingest the Contact object and then create a calculated insight to normalize the phone numbers,and then map to the Contact Point Phone data map object.
  • B. Ingest the Contact object and use streaming transforms to normalize the phone numbers fromthe Contact data stream into a separate Phone data lake object (DLO) that contains three rows,and then map this new DLO to the Contact Point Phone data map object.
  • C. Ingest the Contact object and create formula fields in the Contact data stream on the phonenumbers, and then map to the Contact Point Phone data map object.
  • D. Ingest the Contact object and map the Work Phone, Mobile Phone, and Home Phone to theContact Point Phone data map object from the Contact data stream.
The most efficient approach that a consultant should take when ingesting this data to ensure all the different phone numbers are properly mapped and available for use in activation is B. Ingest the Contact object and use streaming transforms to normalize the phone numbers from the Contact data stream into a separate Phone data lake object (DLO) that contains three rows, and then map this new DLO to the Contact Point Phone data map object. This approach allows the consultant to use the streaming transforms feature of Data Cloud, which enables data manipulation and transformation at the time of ingestion, without requiring any additional processing or storage. Streaming transforms can be used to normalize the phone numbers from the Contact data stream, such as removing spaces, dashes, or parentheses, and adding country codes if needed. The normalized phone numbers can then be stored in a separate Phone DLO, which can have one row for each phone number type (work, home, mobile). The Phone DLO can then be mapped to the Contact Point Phone data map object, which is a standard object that represents a phone number associated with a contact point.
This way, the consultant can ensure that all the phone numbers are available for activation, such as sending SMS messages or making calls to the customers.
The other options are not as efficient as option B. Option A is incorrect because it does not normalize the phone numbers, which may cause issues with activation or identity resolution. Option C is incorrect because it requires creating a calculated insight, which is an additional step that consumes more resources and time than streaming transforms. Option D is incorrect because it requires creating formula fields in the Contact data stream, which may not be supported by the CRM Connector or may cause conflicts with the existing fields in the Contact object. References: Salesforce Data Cloud Consultant Exam Guide, Data Ingestion and Modeling, Streaming Transforms, Contact Point Phone
NEW QUESTION # 154
A user Is not seeing suggested values from newly-modeled data when building a segment.
What is causing this issue?
  • A. Value suggestion requires Data Aware Specialist permissions at a minimum.
  • B. Value suggestion will only return results for the first 50 values of a specific attribute,
  • C. Value suggestion can only work on direct attributes and not related attributes.
  • D. Value suggestion is still processing and takes up to 24 hours to be available.
The most likely cause of this issue is that value suggestion is still processing and takes up to 24 hours to be available. Value suggestion is a feature that enables you to see suggested values for data model object (DMO) fields when creating segment filters. However, this feature needs to be enabled for each DMO field, and it can take up to 24 hours for the suggested values to appear after enabling the feature1. Therefore, if a user is not seeing suggested values from newly-modeled data, it could be that the data has not been processed yet by the value suggestion feature. References:
Use Value Suggestions in Segmentation
NEW QUESTION # 155
We have free demos of our Data-Con-101 study materials for your reference, as in the following, you can download which Data-Con-101 exam materials demo you like and make a choice. We have three versions of our Data-Con-101 exam guide, so we have according three versions of free demos. Therefore, if you really have some interests in our Data-Con-101 Study Materials, then trust our professionalism, we promise a full refund if you fail exam.
Sample Data-Con-101 Questions: https://www.actual4labs.com/Salesforce/Data-Con-101-actual-exam-dumps.html
This Salesforce Certified Data Cloud Consultant (Data-Con-101) certification exam has been inspiring beginners and experienced professionals since its beginning, Salesforce Reliable Data-Con-101 Test Topics As the proverb goes, "No garden is without weeds", Salesforce Reliable Data-Con-101 Test Topics Besides, we are proud to boast a 24/7 efficient customer support system via email, And here, fortunately, you have found the Data-Con-101 exam braindumps, a learning platform that can bring you unexpected experiences.
Use Seaborn and Matplotlib to visualize and Reliable Data-Con-101 Exam Questions explore data, Why are more and more consumers using their photos to snap digital photos, This Salesforce Certified Data Cloud Consultant (Data-Con-101) certification exam has been inspiring beginners and experienced professionals since its beginning.
Reliable Data-Con-101 exam dumps provide you wonderful study guide - Actual4LabsAs the proverb goes, "No garden is without weeds", Data-Con-101 Besides, we are proud to boast a 24/7 efficient customer support system via email, And here, fortunately, you have found the Data-Con-101 exam braindumps, a learning platform that can bring you unexpected experiences.
In the Salesforce Data Cloud exam, there are also questions with a little Math.
Posted at 2/23/2026 14:31:38        Only Author  2#
The article gave me so much to think about. Hope the 100-160 valid test sample exam goes well! Please wish me luck!
