[Hardware] Latest Real NCM-MCI-6.10 Exam | NCM-MCI-6.10 Test Vce
61
Hardware Latest Real NCM-MCI-6.10 Exam | NCM-MCI-6.10 Test Vce
Posted at 1/24/2026 16:26:04      View184 | Replies2        Print      Only Author   [Copy Link] 1#
There are various individuals who have never shown up for the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) certification test as of now. They know close to nothing about the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) exam model and how to attempt the requests. Nutanix NCM-MCI-6.10 Dumps give an unequivocal thought of the last preliminary of the year model and how a promising rookie ought to attempt the solicitation paper to score well.
Under the help of our NCM-MCI-6.10 training materials, the pass rate among our customers has reached as high as 98% to 100%. Our NCM-MCI-6.10 training materials have been honored as the panacea for the candidates for the exam since all of the contents in the NCM-MCI-6.10 guide materials are the essences of the exam. Consequently, with the help of our NCM-MCI-6.10 Study Materials, you can be confident that you will pass the NCM-MCI-6.10 exam and get the related certification as easy as rolling off a log. So what are you waiting for? Just take immediate actions!
Pass Guaranteed Quiz 2026 Nutanix Reliable NCM-MCI-6.10: Latest Real Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) ExamIn order to give the best NCM-MCI-6.10 study braindumps to our worthy customers, we also focus on the customer's user experience. Our staff provides you with the smoothest system. If you have encountered some problems while using NCM-MCI-6.10 Practice Guide, you can also get our timely help as our service are working 24/7 online. Of course, our NCM-MCI-6.10 exam questions are advancing with the times and you will get the latest information.
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q18-Q23):NEW QUESTION # 18
Task 14
An administrator has been asked to configure a storage for a distributed application which uses large data sets across multiple worker VMs.
The worker VMs must run on every node. Data resilience is provided at the application level and low cost per GB is a Key Requirement.
Configure the storage on the cluster to meet these requirements. Any new object created should include the phrase Distributed_App in the name.
See the Explanation for step by step solution.
To configure the storage on the cluster for the distributed application, you can follow these steps:
Log in to Prism Element of cluster A using the credentials provided.
Go to Storage > Storage Pools and click on Create Storage Pool.
Enter a name for the new storage pool, such as Distributed_App_Storage_Pool, and select the disks to include in the pool. You can choose any combination of SSDs and HDDs, but for low cost per GB, you may prefer to use more HDDs than SSDs.
Click Save to create the storage pool.
Go to Storage > Containers and click on Create Container.
Enter a name for the new container, such as Distributed_App_Container, and select the storage pool that you just created, Distributed_App_Storage_Pool, as the source.
Under Advanced Settings, enable Erasure Coding and Compression to reduce the storage footprint of the data.
You can also disable Replication Factor since data resilience is provided at the application level. These settings will help you achieve low cost per GB for the container.
Click Save to create the container.
Go to Storage > Datastores and click on Create Datastore.
Enter a name for the new datastore, such as Distributed_App_Datastore, and select NFS as the datastore type.
Select the container that you just created, Distributed_App_Container, as the source.
Click Save to create the datastore.
The datastore will be automatically mounted on all nodes in the cluster. You can verify this by going to Storage > Datastores and clicking on Distributed_App_Datastore. You should see all nodes listed under Hosts.
You can now create or migrate your worker VMs to this datastore and run them on any node in the cluster.
The datastore will provide low cost per GB and high performance for your distributed application.
NEW QUESTION # 19
The DB team is requesting an SQL database instance and has requested it be configured for best performance.
This VM has been migrated from a 3 tier solution into Nutanix.
The database VM hosts 4 databases, each set to a 20 GB limit. Logs are expected to not grow beyond 20 GB and should be limited to within 25% to avoid runaway processes. Do not configure more storage than is needed.
The VM that has been migrated is identified as sql3532. Once the VM has been properly reconfigured, the DBA team will reconfigure the OS and database.
The VM should be configured as per KB-3532.
While this VM is being tested, make sure it is the first VM to power up in the event the node it is on goes down.
To maximize performance, ensure as much of the VM as possible will be kept on SSD drives.
Note: The VM does not need to be powered on. The VM should remain on the default container and should not be configured with a volume group. No network is required at this time.
See the Explanation below for detailed answer.
Here is the step-by-step solution to reconfigure the sql3532 virtual machine.
This task is performed from the Prism Element interface for the cluster the VM is on (e.g., Cluster 1).
1. Locate and Update the VM
* From the Prism Element main dashboard, navigate to the VM view.
* Find the VM named sql3532 in the VM table.
* Select the checkbox next to sql3532 and click the Update button.
2. Configure HA Priority and Flash Mode
In the "Update VM" dialog, configure the HA and SSD performance settings:
* HA Priority:
* Find the VM High Availability section.
* Select the High Priority radio button. This ensures it is one of the first VMs to power on during an HA event.
* Flash Mode (SSD Performance):
* Scroll down to the Flash Mode section.
* Check the box to Enable Flash Mode. This pins the VM's vDisks to the SSD tier, satisfying the requirement to keep as much of the VM as possible on SSDs, especially since it's on the default (hybrid) container.
3. Reconfigure Disks (per KB-3532)
While still in the "Update VM" dialog, scroll to the Disks section to add the new data and log disks. The key to "best performance" (KB-3532) is to place Data and Logs on separate vSCSI controllers.
* (The VM already has an OS disk, which we will assume is on scsi.0.)
* Add Data Disk:
* Click the + Add New Disk button.
* Storage Container: default (as required).
* Size: 80 GB (for the 4 x 20 GB databases).
* Bus Type: SCSI.
* Device Index: 1. (This creates a new vSCSI controller, scsi.1, for the data disk).
* Click Add.
* Add Log Disk:
* Size: 20 GB.
* Bus Type: SCSI.
* Device Index: 2. (This creates a third vSCSI controller, scsi.2, for the log disk).
* Click Add.
4. Save Configuration
* After adding the disks and setting HA/Flash Mode, click the main Save button at the bottom of the
"Update VM" dialog.
The VM is now configured with high availability, its storage is pinned to SSD, and its disk layout follows performance best practices by separating the OS, Data, and Log I/O paths onto three different controllers.
NEW QUESTION # 20
Use Prism Element for this question.
The Application team has a 3 tier application (App Server, Web Server, and Database Server) that is mission critical and requires as close to 0 RPO and RTO as possible with their current license level.
The organization has 2 clusters, with one cluster (Cluster 1) being production and the other cluster (Cluster 2) being remote/DR. Cluster 2 should be able to fail back to Cluster 1.
The connectivity between the two sites is >5ms and replication traffic should not use more than 10Mbps of bandwidth. The Application team requests a plan that includes the ability to go back 2 days locally, and 2 days remotely.
The team also requests that all 3 VMs be treated as a single group and backed up collectively in a snapshot.
The three VMs are:
* Web-Prod
* App-Prod
* DB-Prod
Use Task3 as part of the name for any objects created for this task.
Note: VMs do NOT need to be powered on. You will need to use the 172.30.0.x IP addresses when configuring DR.
Here is the step-by-step solution to configure Disaster Recovery from the Cluster 1 Prism Element interface.
1. Add Cluster 2 as a Remote Site
First, you must register Cluster 2 as a DR target for Cluster 1.
* From the Cluster 1 Prism Element dashboard, navigate to Data Protection from the main dropdown menu.
* Click the Remote Site tab.
* Click the + Remote Site button and select Physical Cluster.
* In the "Name" field, enter Cluster2_DR_Task3.
* In the "Address" field, enter the 172.30.0.x Virtual IP address of Cluster 2.
* Click Save. The clusters will exchange credentials and connect.
2. Throttle Replication Bandwidth
Next, apply the 10 Mbps bandwidth limit for traffic going to Cluster 2.
* On the same Remote Site tab, select the newly created Cluster2_DR_Task3.
* Click the Update button.
* In the dialog, set the Bandwidth Limit to 10 Mbps.
* Click Save.
3. Create the Protection Domain
A Protection Domain (PD) is the top-level object that will manage the VMs and replication schedules.
* In the Data Protection dashboard, click the Table tab.
* Click the + Protection Domain button and select Async DR.
* For the Name, enter App_PD_Task3.
* Click Create.
4. Protect VMs in a Consistency Group
Now you will add the three application VMs to the new Protection Domain as a single Consistency Group (CG).
* You will be taken to the dashboard for the new App_PD_Task3. In the Entities panel, click the Protect Entities button.
* In the "rotect Entities" dialog, search for and select the three VMs:
* Web-Prod
* App-Prod
* DB-Prod
* Click Next.
* Select Create new consistency group and name it App_CG_Task3.
* Click Protect.
5. Create the Replication Schedule
Finally, configure the schedule to meet the RPO and retention requirements.
* In the App_PD_Task3 dashboard, click the Schedules tab.
* Click the + New Schedule button.
* Remote Site: Select Cluster2_DR_Task3.
* RPO (Repeat every): Select NearSync. Set the RPO to 1 minute.
* Note: This is the lowest possible RPO for an Async (>5ms latency) connection, fulfilling the "as close to 0" requirement.
* Local Retention: Set to 2 Days.
* Remote Retention: Set to 2 Days.
* Ensure the "Store snapshots for 2-way replication" checkbox is enabled to allow failback from Cluster 2.
* Click Create Schedule.
NEW QUESTION # 21
An administrator regularly sees a WARN for backup_schedule_check and also receives alerts for Pulse not being enabled on Cluster 1.
Detailed information for backup_schedule_check:
Node xx.xx.xx.xx:
WARN: Backup schedule(s) exist for protection domain NoVMs; however, there are no entities in the protection domain.
Refer
to KB 1910 (http://portal.nutanix.com/kb/1910) for details on backup_schedule_check or Recheck with: ncc health_checks data_protection_checks protection_domain_checks backup_schedule_check.
This shows up in NCC, however, it is something set up by the company and they do not want the NCC check to be run.
Configure Cluster 1 to no longer have messages in NCC about the backup_schedule_check.
Turn off the alert for Pulse not being enabled, and resolve the alert. They would like messages about Pulse to be recorded, but do not want an alert.
Note: You may need to run the "ulse is not enabled" check in order to have one to resolve.
Here is the step-by-step solution to configure Cluster 1 from its Prism Element interface.
1. Disable the backup_schedule_check NCC Check
This will prevent the WARN message for the NoVMs protection domain.
* Log in to the Cluster 1 Prism Element (PE) interface.
* Navigate to the Health dashboard (click the "heart" icon in the top-left).
* In the left-hand menu, select NCC.
* In the search bar for the checks, type backup_schedule_check to find the specific check.
* Select the checkbox next to the backup_schedule_check in the list.
* Click the Disable button that appears above the table. This will stop this check from running during NCC health reports.
2. Configure and Resolve Pulse Alerts
This process involves two parts: disabling the alerting policy, and then enabling Pulse itself to resolve the underlying condition.
A. Disable the Alert Policy
This stops the system from generating a new alert if Pulse is ever disabled, satisfying the "do not want an alert" requirement.
* Click the gear icon (Settings) in the top-right corner.
* From the left-hand menu, select Alert Policies.
* In the search bar, type Pulse to find the policy.
* Select the checkbox for the alert policy named Pulse is not enabled (or pulse_disabled_alert).
* Uncheck the Enable box for the policy.
* Click Save.
B. Enable Pulse (to Resolve the Condition)
This enables the Pulse service to record messages (as requested) and fixes the root cause of the alert, allowing it to be resolved.
* From the left-hand menu, select Pulse.
* Click the Enable Pulse button (or "Update" if it's already partially configured).
* Check the box for Enable Pulse.
* (Note: Any "Enable alerts for Pulse" boxes would remain unchecked or be ignored, as the main Alert Policy itself is now disabled.)
* Click Save.
C. Resolve the Active Alert
* Navigate to the Alerts dashboard (click the "bell" icon in the top-left).
* Find the active alert: Pulse is not enabled.
* (Note: If the alert is not present, you would first go to the Health dashboard, run the check_pulse NCC check to generate it, and then return to the Alerts dashboard.)
* Select the checkbox next to the "ulse is not enabled" alert.
* Click the Resolve button that appears at the top of the list. Since the underlying condition (Pulse being disabled) is now fixed, the alert will be successfully resolved.
NEW QUESTION # 22
Task 7
An administrator has been informed that a new workload requires a logically segmented network to meet security requirements.
Network configuration:
VLAN: 667
Network: 192.168.0.0
Subnet Mask: 255.255.255.0
DNS server: 34.82.231.220
Default Gateway: 192.168.0.1
Domain: cyberdyne.net
IP Pool: 192.168.9.100-200
DHCP Server IP: 192.168.0.2
Configure the cluster to meet the requirements for the new workload if new objects are required, start the name with 667.
To configure the cluster to meet the requirements for the new workload, you need to do the following steps:
Create a new VLAN with ID 667 on the cluster. You can do this by logging in to Prism Element and going to Network Configuration > VLANs > Create VLAN. Enter 667 as the VLAN ID and a name for the VLAN, such as 667_VLAN.
Create a new network segment with the network details provided. You can do this by logging in to Prism Central and going to Network > Network Segments > Create Network Segment. Enter a name for the network segment, such as 667_Network_Segment, and select 667_VLAN as the VLAN. Enter 192.168.0.0 as the Network Address and 255.255.255.0 as the Subnet Mask. Enter 192.168.0.1 as the Default Gateway and
34.82.231.220 as the DNS Server. Enter cyberdyne.net as the Domain Name.
Create a new IP pool with the IP range provided. You can do this by logging in to Prism Central and going to Network > IP Pools > Create IP Pool. Enter a name for the IP pool, such as 667_IP_Pool, and select
667_Network_Segment as the Network Segment. Enter 192.168.9.100 as the Starting IP Address and
192.168.9.200 as the Ending IP Address.
Configure the DHCP server with the IP address provided. You can do this by logging in to Prism Central and going to Network > DHCP Servers > Create DHCP Server. Enter a name for the DHCP server, such as
667_DHCP_Server, and select 667_Network_Segment as the Network Segment. Enter 192.168.0.2 as the IP Address and select 667_IP_Pool as the IP Pool.
NEW QUESTION # 23
The Nutanix Practice Test engine included with NCM-MCI-6.10 exam questions simulates the actual NCM-MCI-6.10 examinations. This is excellent for familiarizing yourself with the Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) and learning what to expect on test day. You may also use the Nutanix NCM-MCI-6.10 online practice test engine to track your progress and examine your answers to determine where you need to improve on the NCM-MCI-6.10 exam.
NCM-MCI-6.10 Test Vce: https://www.dumps4pdf.com/NCM-MCI-6.10-valid-braindumps.html
Every year more than 31927 candidates from all over the world choose our NCM-MCI-6.10 cram PDF to help them sail through examinations, Nutanix Latest Real NCM-MCI-6.10 Exam If you make the best use of your time and obtain a useful certification you may get a senior position ahead of others, Nutanix Latest Real NCM-MCI-6.10 Exam Then the unfamiliar questions will never occur in the examination, Nutanix Latest Real NCM-MCI-6.10 Exam The support team is always available to help applicants use the product.
And because I like to start my programming books NCM-MCI-6.10 Test Vce with a bit of programming, let's get right to it, This `Id` can be read but only set by internal class code, Every year more than 31927 candidates from all over the world choose our NCM-MCI-6.10 cram PDF to help them sail through examinations.
100% Pass 2026 Nutanix Reliable NCM-MCI-6.10: Latest Real Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) ExamIf you make the best use of your time and obtain a useful certification New NCM-MCI-6.10 Exam Question you may get a senior position ahead of others, Then the unfamiliar questions will never occur in the examination.
The support team is always available to help applicants use the product, NCM-MCI-6.10 You can now prepare for your Master Level exams without leaving your home and simply download everything you need from Dumps4PDF website.
Posted at 1/30/2026 07:46:38        Only Author  2#
Im truly amazed by your article, thank you for your generosity! Improve your IT expertise with free Latest test Plat-Admn-201 passing score access. Best of luck in your exams!
Posted at 2/4/2026 15:25:03        Only Author  3#
Clicking the like button immediatelythis is brilliant. C_P2W22_2504 relevant answers test questions are the key to career successavailable for free!
