100% Pass 2026 JN0-664: Service Provider, Professional (JNCIP-SP)¨CReliable New D
106
Posted at 1/24/2026 16:34:50      View£º154 | Replies£º1        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamDumpsVCE JN0-664 dumps now are free: https://drive.google.com/open?id=1TvmriukweSO8TvOnhZ4jk1V7BgWG4TI4
Whatever your professional, working towards a Service Provider, Professional (JNCIP-SP) JN0-664 certification or designation takes a significant amount of effort and time. Once you have put all your effort, and investment and prepared well then you will be in a position to pass the Service Provider, Professional (JNCIP-SP) JN0-664 Certification Exam. But once you get success in the Service Provider, Professional (JNCIP-SP) JN0-664 test you¡¯ll be eligible to avail all the personal and professional benefits associated with Service Provider, Professional (JNCIP-SP) JN0-664 certification.
Our JN0-664 real materials support your preferences of different practice materials, so three versions are available. PDF version - legible to read and remember, support customers¡¯ printing request. Software version of JN0-664 real materials - supporting simulation test system, and support Windows system users only. App online version of JN0-664 Guide question - suitable to all kinds of equipment or digital devices, supportive to offline exercises on the condition that you practice it without mobile data. You can take a look of these JN0-664 exam dumps and take your time to decide.
New Juniper JN0-664 Exam Cram, JN0-664 Certification Exam DumpsWe have brought in an experienced team of experts to develop our JN0-664 study materials, which are close to the exam syllabus. With the help of our JN0-664 practice guide, you don't have to search all kinds of data, because our products are enough to meet your needs. And our JN0-664 leanring guide can help you get all of the keypoints and information that you need to make sure that you will pass the exam.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q55-Q60):NEW QUESTION # 55
In IS-IS. which two statements are correct about the designated intermediate system (DIS) on a multi-access network segment? (Choose two.)
  • A. On the multi-access network, each router forms an adjacency to every other router on the segment.
  • B. A router with a priority of 1 wins the DIS election over a router with a priority of 10.
  • C. On the multi-access network, each router only forms an adjacency to the DIS.
  • D. A router with a priority of 10 wins the DIS election over a router with a priority of 1.
NEW QUESTION # 56
Exhibit
Referring to the exhibit, PIM-SM is configured on all routers, and Anycast-RP with Anycast-PIM is used for the discovery mechanism on RP1 and RP2. The interface metric values are shown for the OSPF area.
In this scenario, which two statements are correct about which RP is used? (Choose two.)
  • A. Source2 will use RP2 and Receiver2 will use RP2 for group 224.2.2.2.
  • B. Source1 will use RP1 and Receiver1 will use RP1 for group 224.1.1.1.
  • C. Source2 will use RP1 and Receiver2 will use RP1 for group 224.2.2.2.
  • D. Source1 will use RP1 and Receiver1 will use RP2 for group 224.1 1 1
A sham link is a logical link between two PE routers that belong to the same OSPF area but are connected through an L3VPN. A sham link makes the PE routers appear as if they are directly connected, and prevents OSPF from preferring an intra-area back door link over the VPN backbone. A sham link creates an OSPF multihop neighborship between the PE routers using TCP port 646. The PEs exchange Type 1 OSPF LSAs instead of Type 3 OSPF LSAs for the L3VPN routes, which allows OSPF to use the correct metric for route selection1.
NEW QUESTION # 57
You are asked to protect your company's customers from amplification attacks. In this scenario, what is Juniper's recommended protection method?
  • A. ASN prepending
  • B. unicast Reverse Path Forwarding
  • C. BGP FlowSpec
  • D. destination-based Remote Triggered Black Hole
amplification attacks are a type of distributed denial-of-service (DDoS) attack that exploit the characteristics of certain protocols to amplify the traffic sent to a victim. For example, an attacker can send a small DNS query with a spoofed source IP address to a DNS server, which will reply with a much larger response to the victim. This way, the attacker can generate a large amount of traffic with minimal resources.
One of the methods to protect against amplification attacks is destination-based Remote Triggered Black Hole (RTBH) filtering. This technique allows a network operator to drop traffic destined to a specific IP address or prefix at the edge of the network, thus preventing it from reaching the victim and consuming bandwidth and resources. RTBH filtering can be implemented using BGP to propagate a special route with a next hop of
192.0.2.1 (a reserved address) to the edge routers. Any traffic matching this route will be discarded by the edge routers.
NEW QUESTION # 58
Exhibit
Referring to the exhibit, PE-1 and PE-2 are getting route updates for VPN-B when neither of them service that VPN Which two actions would optimize this process? (Choose two.)
  • A. Configure the family route-target statement on the RR.
  • B. Configure the resolution rib bgp.l3vpn.0 resolution-ribs inet.0 statement on the PEs.
  • C. Configure the resolution rib bgp.l3vpn.0 resolution-ribs inet.0 statement on the RR.
  • D. Configure the family route-target statement on the PEs.
BGP route target filtering can be configured on PE devices or on route reflectors (RRs). Configuring BGP route target filtering on RRs is more efficient and scalable, as it reduces the number of BGP sessions and updates between PE devices. To configure BGP route target filtering on RRs, the following steps are required:
Configure the family route-target statement under the BGP group or neighbor configuration on the RRs. This enables the exchange of the route-target address family between the RRs and their clients (PE devices). Configure the resolution rib bgp.l3vpn.0 resolution-ribs inet.0 statement under the routing-options configuration on the RRs. This enables the RRs to resolve next hops for VPN routes using the inet.0 routing table.
NEW QUESTION # 59
You have an L2VPN connecting two CEs across a provider network. The CEs and provider network are configured with the default MTU setting. You use the ping command from one CE to the other CE with a size of 1500 bytes.
In this scenario, which statement is correct when using the ping command?
  • A. You expect a silent discard.
  • B. You expect the ping results to be fragmented.
  • C. You expect an echo reply.
  • D. You expect an ICMP message too long error.
Layer 2 VPNs don't support fragmentation in the provider network. It is critical that the provider network supports the largest frame that the CE devices can generate after the MPLS and virtual routing and forwarding (VRF) labels are added by the PE devices. This example leaves the CE devices at the default 1500-byte maximum transmission unit (MTU) while configuring the provider core to support a 4000 byte MTU. This configuration avoids discards by ensuring the CE devices cannot exceed the MTU in the provider's network.
NEW QUESTION # 60
These are expertly designed Juniper JN0-664 mock tests, under the supervision of thousands of professionals. A 24/7 customer service is available for assistance in case of any sort of pinch. It shows results at the end of every JN0-664 mock test attempt so you don't repeat mistakes in the next try. To confirm the license of the product, you need an active internet connection. ExamDumpsVCE desktop Service Provider, Professional (JNCIP-SP) (JN0-664) practice test is compatible with every Windows-based computer. You can use this software without an active internet connection.
New JN0-664 Exam Cram: https://www.examdumpsvce.com/JN0-664-valid-exam-dumps.html
It¡¯s important for the safety of the website while buying the JN0-664 exam bootcamp online, Juniper JN0-664 New Dumps Ppt Labs Virtual boot camp on your PC Test your knowledge Build your troubleshooting skills Learn about the hardware and software you'll face every day Available Online in seconds See Samples of Simulation Labs Our Complete Simulation Labs will to solidify your existing knowledge, and take you step-by-step through everything you need to know, So they can easily pass JN0-664 exam tests and it is much more cost-effective for them than those who spend lots of time and energy to prepare for JN0-664 exam questions.
Deitel has delivered hundreds of professional JN0-664 seminars to major corporations, academic institutions, government organizations and the military, Regardless of the type of JN0-664 New Dumps Ppt perspective grid you choose, all grids share these basic components: a horizon line.
100% Pass Quiz Juniper - JN0-664 - Valid Service Provider, Professional (JNCIP-SP) New Dumps PptIt¡¯s important for the safety of the website while buying the JN0-664 Exam Bootcamp online, Labs Virtual boot camp on your PC Test your knowledge Build your troubleshooting skills Learn about the hardware and software you'll face every day Available Online in seconds See Samples of Simulation Practice JN0-664 Exams Labs Our Complete Simulation Labs will to solidify your existing knowledge, and take you step-by-step through everything you need to know.
We also provide other benefits such as discount on occasion, Software version of JN0-664 exam questions and answers: it is software that can be downloaded and installed on personal computers, you can study on computers.
P.S. Free & New JN0-664 dumps are available on Google Drive shared by ExamDumpsVCE: https://drive.google.com/open?id=1TvmriukweSO8TvOnhZ4jk1V7BgWG4TI4
Posted at 2/4/2026 09:31:00        Only Author  2#
Liking it because this content is awesome. The Exam C_BCSSS_2502 test questions helped me achieve my career goals, and I¡¯m offering them to you for free today!
