[General] CCDAK Exam Learning & New CCDAK Braindumps Sheet
106
【General】 CCDAK Exam Learning & New CCDAK Braindumps Sheet
Posted at 1/24/2026 19:10:48      View:136 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Confluent CCDAK dumps are available on Google Drive shared by DumpsTests: https://drive.google.com/open?id=1s0pOnwEPGd3nyq0ydFX9TEyOTsVx7HL-
You will go through Confluent CCDAK Exams and will see for yourself the difference in your preparation. The Confluent CCDAK practice test software is very user-friendly and simple to use. It is accessible on all browsers. It will save your progress and give a report of your mistakes which will surely be beneficial for your overall exam preparation.
Confluent CCDAK Certification Exam is an industry-recognized certification that helps developers advance their careers and demonstrate their expertise in Apache Kafka. Confluent Certified Developer for Apache Kafka Certification Examination certification is offered by Confluent, a leading company in the Apache Kafka ecosystem. Confluent Certified Developer for Apache Kafka Certification Examination certification is a valuable asset for developers who want to work with Kafka-based applications and solutions, and it is highly regarded by organizations that use Kafka for their data processing needs. Confluent Certified Developer for Apache Kafka Certification Examination certification demonstrates a developer's proficiency in Kafka and helps them stand out in a competitive job market.
New CCDAK Braindumps Sheet, Valid Braindumps CCDAK SheetTo assimilate those useful knowledge better, many customers eager to have some kinds of CCDAK learning materials worth practicing. All content is clear and easily understood in our CCDAK exam guide. They are accessible with reasonable prices and various versions for your option. All content are in compliance with regulations of the CCDAK Exam. As long as you are determined to succeed, our CCDAK study quiz will be your best reliance.
Confluent Certified Developer for Apache Kafka Certification Examination Sample Questions (Q225-Q230):NEW QUESTION # 225
Which actions will trigger partition rebalance for a consumer group? (select three)
  • A. Remove a broker from the cluster
  • B. A consumer in a consumer group shuts down
  • C. Add a new consumer to consumer group
  • D. Increase partitions of a topic
Answer: B,C,D
Add a broker to the cluster
Rebalance occurs when a new consumer is added, removed or consumer dies or paritions increased.
NEW QUESTION # 226
You are building a system for a retail store selling products to customers.
Which three datasets should you model as a GlobalKTable?
(Select three.)
  • A. Customer profile information
  • B. Log of payment transactions
  • C. Inventory of products at a warehouse
  • D. All purchases at a retail store occurring in real time
  • E. Catalog of products
Answer: A,C,E
AGlobalKTableis a replicated, read-only table available in full on all instances. It's best forreference or lookup datasetssuch as:
* Product catalog
* Customer profiles
* Warehouse inventory
FromKafka Streams Developer Guide:
"Use GlobalKTable when you need to perform joins using non-partition-aligned reference data that's small enough to replicate."
* Purchases and transactions are high-throughput, time-sensitive streams, not static reference data.
Reference:Kafka Streams Concepts > GlobalKTable
NEW QUESTION # 227
What is the risk of increasing max.in.flight.requests.per.connection while also enabling retries in a producer?
  • A. Less resilient
  • B. At least once delivery is not guaranteed
  • C. Reduce throughput
  • D. Message order not preserved
Some messages may require multiple retries. If there are more than 1 requests in flight, it may result in messages received out of order. Note an exception to this rule is if you enable the producer settingenable.
idempotence=true which takes care of the out of ordering case on its own. Seehttps://issues.apache.org/jira
/browse/KAFKA-5494
NEW QUESTION # 228
You have a topic t1 with six partitions. You use Kafka Connect to send data from topic t1 in your Kafka cluster to Amazon S3. Kafka Connect is configured for two tasks.
How many partitions will each task process?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
When using Kafka Connect with sink connectors (like S3 Sink),each task is assigned one or more topic partitions. Thetotal number of partitions (6)isevenly distributedacross the available tasks (2). Thus, each task will handle3 partitions.
FromKafka Connect Documentation:
"Kafka Connect divides the topic partitions among available tasks. For example, a topic with six partitions and two tasks results in each task handling three partitions." Reference:Kafka Connect Concepts > Tasks and Partitions
NEW QUESTION # 229
The exactly once guarantee in the Kafka Streams is for which flow of data?
  • A. Kafka => External
  • B. External => Kafka
  • C. Kafka => Kafka
Kafka Streams can only guarantee exactly once processing if you have a Kafka to Kafka topology.
NEW QUESTION # 230
Immediately after you have made a purchase for our CCDAK practice dumps, you can download our exam study materials to make preparations for the exams. It is universally acknowledged that time is a key factor in terms of the success of exams. The more time you spend in the preparation for CCDAK Training Materials, the higher possibility you will pass the exam. As you can see, we have invested big amount of money to give the most convinience for you to get our CCDAK exam braindumps.
New CCDAK Braindumps Sheet: https://www.dumpstests.com/CCDAK-latest-test-dumps.html
BTW, DOWNLOAD part of DumpsTests CCDAK dumps from Cloud Storage: https://drive.google.com/open?id=1s0pOnwEPGd3nyq0ydFX9TEyOTsVx7HL-
Posted at 2/5/2026 22:04:03        Only Author  2#
Your article was very refreshing, thank you for this amazing perspective. Here’s the free C_BCBDC_2505 free practice material for everyone. Good luck!
Posted at 2/18/2026 23:28:24        Only Author  3#
The article is easy to understand, and I have benefited a lot from it. Best wishes! Here are the free NSE7_OTS-7.2 reliable exam questions explanations resources for you.
