[Hardware] Free PDF Esri - EAEP2201 Authoritative Exam Objectives Pdf
【Hardware】 Free PDF Esri - EAEP2201 Authoritative Exam Objectives Pdf
Posted at 1/24/2026 19:48:47      View:109 | Replies:3        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Dumpcollection EAEP2201 dumps for free: https://drive.google.com/open?id=1rtmxvbk3tfGrTVE3FTuh2mAhFwH5Omc6
Because of not having appropriate review methods and review materials, or not grasping the rule of the questions, so many candidates eventually failed to pass the EAEP2201 exam even if they have devoted much effort. At this moment, we sincerely recommend our EAEP2201 Exam Materials to you, which will be your best companion on the way to preparing for the exam. And with high pass rate as 98% to 100%, you will be bound to pass the exam as long as you choose our EAEP2201 praparation questions.
Upon successful completion of the Esri EAEP2201 Exam, candidates will receive an Enterprise Administration Professional certificate that showcases their competencies as ArcGIS Enterprise Administrators. The certificate provides a valuable credential to showcase one’s skills and knowledge to peers, employers, and potential clients. Enterprise Administration Professional 2201 certification program also helps professionals to stay up-to-date with the latest advancements in the ArcGIS platform and maintain the expertise required to tackle the challenges of Enterprise solutions. Overall, the Esri EAEP2201 Exam is an excellent way for ArcGIS Enterprise Administration Professionals to validate their expertise and take their career to the next level.
The Enterprise Administration Professional 2201 certification exam covers a range of topics including system architecture, security, database management, web services, and performance tuning. It is designed to test the knowledge and skills of professionals who work with Esri's enterprise GIS software on a daily basis. EAEP2201 exam consists of 80 multiple-choice questions and has a time limit of two hours.
Latest EAEP2201 Exam Cost - Test EAEP2201 Topics PdfAs candidates, the quality must be your first consideration when buying EAEP2201 learning materials. We have a professional team to collect the first-hand information for the exam. Our company have reliable channel for collecting EAEP2201 learning materials. We can ensure you that EAEP2201 exam materials you receiveare the latest version. We have strict requirements for the EAEP2201 Questions and answers, and the correctness of the answers can be guaranteed. In order to serve our customers better, we offer free update for you, so that you can get the latest version timely.
Esri Enterprise Administration Professional 2201 Sample Questions (Q30-Q35):NEW QUESTION # 30
Multiple users report that a map service is experiencing negative performance. Upon review of ArcGIS Monitor data, the GIS analyst finds the following:
* The minimum number of instances is 2 and the maximum is 8 for that service.
* The data is in a publication Enterprise Geodatabase with no system usage in excess of 50%.
* At the p75 level of requests, the map service time is 10 times longer than the service time at the p25 level.
* The number of instances in use at the p50 level is 8.
* The maximum % of physical memory in use is 40%, and the maximum % of virtual memory in use is
44% on the ArcGIS Server.
* The maximum % CPU utilization observed is 53%.
What is causing the issue?
  • A. The maximum instance setting is too low for the demand on the underperforming map service.
  • B. The client is an Android device, and the ArcGIS Server is a Linux virtual machine.
  • C. The network connection between the database server and ArcGIS Server is saturated.
The ArcGIS Monitor data indicates that the map service is reaching its maximum configured instances (8) at the median usage level (p50), suggesting that the service cannot scale to meet higher demand. The significant increase in service time at the p75 level further supports that the service is under-provisioned. Since system resources like CPU and memory are not fully utilized, the bottleneck is likely due to the instance configuration. Increasing the maximum number of instances would allow the service to handle more concurrent requests, improving performance.
There is no evidence of network saturation or client-specific issues affecting performance in this scenario.
Reference Source:ArcGIS Monitor documentation on service instance management and performance tuning
NEW QUESTION # 31
A client wants to performincremental webgisdr backupsdaily and full backups weekly. They store all data in therelational ArcGIS Data Store, withno tile or map caches.
Which action is required to enable incremental backups?
  • A. Decrease the max connections during backups
  • B. Increase the heap size of ArcGIS Data Store
  • C. Enable point-in-time recovery on ArcGIS Data Store
To performincremental backupsusing thewebgisdr tool,point-in-time recoverymust be enabled on the relational data store. This creates transaction logs needed for differential backups and aligns with best practices for enterprise-level backup strategies.
From Esri documentation:
"Incremental backups can only be used with a relational data store when point-in-time recovery is enabled.
This enables transaction log capture needed for delta backups."
* OptionAis unrelated to backup functionality.
* OptionCis not required unless performance tuning is needed.
Reference:ArcGIS Enterprise -Enabling Point-in-Time Recovery in ArcGIS Data Store for Incremental Backups
NEW QUESTION # 32
After upgrading, a GIS administrator tries to log in to Portal for ArcGIS using admin credentials. The portal site doesn't display correctly and an error is shown. Login fails.
What should the administrator do?
  • A. Roll back the upgrade
  • B. Reinstall the ArcGIS Web Adaptor
  • C. Clear the browser's cache
  • D. Run portalscan.py
After an upgrade, Portal for ArcGIS often changes web elements, scripts, and cached content. If the browser is usingold cached files, the portal page may not render correctly, and authentication may fail.Clearing the browser cacheensures that new files are loaded.
"After upgrading ArcGIS Enterprise, clear the browser's cache to ensure that all updated components and scripts are loaded properly."
* OptionAis a diagnostic tool, not a fix.
* OptionBmay be excessive if the issue is simply browser cache.
* OptionDis not a standard troubleshooting step.
Reference:ArcGIS Enterprise -Post-Upgrade Troubleshooting and Web Adaptor Behavior
NEW QUESTION # 33
A small organization has an ArcGIS Enterprise deployment where all components are installed on one virtual server hosted on Microsoft Azure. Each deployment component was initially installed manually. The organization wants to upgrade its deployment to the most recent version in the most efficient way.
Which action should the organization perform?
  • A. Upgrade the entire deployment with ArcGIS Enterprise Builder
  • B. Manually upgrade each ArcGIS Enterprise component
  • C. Run the ArcGIS Enterprise Cloud Builder for Microsoft Azure tool
For ArcGIS Enterprise deployments on Microsoft Azure that were initially installed manually, the recommended approach for upgrading is to manually upgrade each component. This involves downloading the latest installers for each component (Portal for ArcGIS, ArcGIS Server, ArcGIS Data Store, etc.) and following the standard upgrade procedures for each. This method ensures that each component is properly updated and configured according to the organization's specific setup.
Using ArcGIS Enterprise Builder (Option B) is intended for new installations and is not suitable for upgrading existing deployments. ArcGIS Enterprise Cloud Builder for Microsoft Azure (Option C) is designed for deployments that were originally created using Cloud Builder; it cannot be used to upgrade deployments that were installed manually.
Reference Source:ArcGIS Enterprise documentation on upgrading manually installed deployments
NEW QUESTION # 34
An organization has a requirement to geocode crime incidents from a CSV uploaded to the ArcGIS Enterprise portal. How should the organization configure their ArcGIS Server site to meet this requirement?
  • A. As the hosting server
  • B. With a registered geodatabase
  • C. As an ArcGIS GeoEvent Server
To enable geocoding of addresses from CSV files uploaded to the ArcGIS Enterprise portal, the organization must designate a federated ArcGIS Server site as thehosting server. This hosting server must have a relational data store configured. Once set up,the portal can utilize a geocode utility service to process the addresses. This configuration allows users to map addresses from CSV files added to the portal.
Reference Source:ArcGIS Enterprise documentation on configuring the portal to geocode addresses
NEW QUESTION # 35
This professionally designed desktop practice exam software is customizable, which helps you to adjust timings and questions of the mock tests. This feature of Windows-based Enterprise Administration Professional 2201 software helps you improve time-management abilities and weak areas of the test preparation. We regularly upgrade this Esri EAEP2201 Practice Exam software after receiving valuable feedback from experts worldwide.
Latest EAEP2201 Exam Cost: https://www.dumpcollection.com/EAEP2201_braindumps.html
2026 Latest Dumpcollection EAEP2201 PDF Dumps and EAEP2201 Exam Engine Free Share: https://drive.google.com/open?id=1rtmxvbk3tfGrTVE3FTuh2mAhFwH5Omc6
Posted at 1/28/2026 22:27:27        Only Author  2#
あなたは自分の職場の生涯にユニークな挑戦に直面していると思いましたら、MicrosoftのAZ-305の認定試験に合格することが必要になります。CertShikenはMicrosoftのAZ-305の認定試験を真実に、全面的に研究したサイトです。CertShiken のユニークなMicrosoftのAZ-305の認定試験の問題と解答を利用したら、試験に合格することがたやすくなります。CertShikenは認証試験の専門的なリーダーで、最全面的な認証基準のトレーニング方法を追求して、100パーセントの成功率を保証します。CertShikenのMicrosoftのAZ-305の試験問題と解答は当面の市場で最も徹底的かつ正確かつ最新な模擬テストです。それを利用したら、初めに試験を受けても、合格する自信を持つようになります。
Posted at 2/9/2026 07:31:34        Only Author  3#
Wenn Sie die EXIN ITIL-German nicht bestehen, nachdem Sie unsere Unterlagen gekauft hat, bieten wir eine volle Rückerstattung. Diese Versprechung bedeutet nicht, dass wir nicht unserer EXIN ITIL-German Software nicht zutrauen, sondern unsere herzliche und verantwortungsvolle Einstellung, weil wir die Kunden sorgenfrei lassen wollen. Mit professionelle EXIN ITIL-German Prüfungssoftware und der nach wie vor freundliche Kundendienst hoffen wir, dass Sie sich keine Sorge machen.
Posted at 2/20/2026 08:57:36        Only Author  4#
The content of the article is detailed, and I’ve learned many useful things. The ISO-45001-Lead-Auditor exam dumps demo content is excellent, and you can get it without any cost.
