Actual 1z0-1047-25 Test Answers & Reliable 1z0-1047-25 Braindumps
Posted at 1/24/2026 22:41:31
View212
Replies3
P.S. Free 2026 Oracle 1z0-1047-25 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=1T3n-rSnhnY-vkPf5mgDwxPjQLKv41xlu
This 1z0-1047-25 certification assists you to put your career on the right track and helps you to achieve your career goals in a short time period. There are several personal and professional benefits that you can gain after passing the Oracle Absence Management Cloud 2025 Implementation Professional (1z0-1047-25) certification exam. The prominent 1z0-1047-25 certification benefits include validation of skills and knowledge, more career opportunities, instant rise in salary, quick promotion, etc.
Our 1z0-1047-25 exam questions just focus on what is important and help you achieve your goal. When the reviewing process gets some tense, our 1z0-1047-25 practice materials will solve your problems with efficiency. With high-quality 1z0-1047-25 Guide materials and flexible choices of learning mode, they would bring about the convenience and easiness for you. Every page is carefully arranged by our experts with clear layout and helpful knowledge to remember.
Free PDF Quiz 1z0-1047-25 - Oracle Absence Management Cloud 2025 Implementation Professional CHigh-quality Actual Test AnswersYou can also trust on PrepAwayPDF Oracle 1z0-1047-25 exam dumps and start 1z0-1047-25 exam preparation with confidence. The PrepAwayPDF Oracle Absence Management Cloud 2025 Implementation Professional (1z0-1047-25) practice questions are designed and verified by experienced and qualified Oracle exam trainers. They utilize their expertise, experience, and knowledge and ensure the top standard of PrepAwayPDF 1z0-1047-25 Exam Dumps. So you can trust PrepAwayPDF Oracle 1z0-1047-25 exam questions with complete peace of mind and satisfaction.
Oracle Absence Management Cloud 2025 Implementation Professional Sample Questions (Q14-Q19):NEW QUESTION # 14
A full-time employee, having a plan balance of 200 hours, is associated with an accrual plan that has a ceiling limit of 250 hours. The employment status of the employee is changed to part-time, which has a reduced accrual plan ceiling limit of 150 hours.
What happens when the Calculate Accruals process in run?
- A. The original balance of 200 hours will remain valid, but will be moved to a different "overflow-plan to be spent as required. The new plan will accrue balances as normal up to the new 150 hours threshold.
- B. The application will generate a zero-accrual record with the new reduced ceiling limit. The balance of
200 hours that the employee had when the employment status was full-time will remain even after the change in employment status because the balance can exceed the new reduced accrual plan celling limit. However, a new accrual amount will only be generated once the balance falls below the new accrual ceiling limit. - C. The application will automatically reduce the employee's balance to 150 hours to meet the new ceiling limit and new accruals will be generated once the balance falls below this threshold.
- D. The original balance of 200 hours will be automatically disbursed through their payroll, and accruals will start generating from that point onward with a ceiling of 150 hours.
NEW QUESTION # 15
An employee is enrolled in the following accrual plans, both of which are linked to the same absence type:
Floating Holiday - Priority 100 - (Balance = 2 days), no negative balance allowed. Vacation - Priority 200 - (Balance = 3 days), negative balance allowed with a limit of 2 days.
How is a 7-day absence processed using this absence plan setup?
- A. Floating Holiday balance is decreased by 2 days and Vacation balance by 5 days.
- B. Floating Holiday balance is decreased by 2 days and Vacation balance by 3 days.
- C. Vacation balance is decreased by 5 days and Floating Holiday balance by 2 days.
- D. Floating Holiday balance is decreased by 2 days and Vacation balance by 2 days,
- E. Vacation balance is decreased by 3 days and Floating Holiday balance by 2 days.
NEW QUESTION # 16
You created a shared parental leave agreement for an employee with multiple assignments. You can view the assignments associated with the leave agreement in the Entitlement Agreements page accessible from the Manage Absences and Entitlements page.
What happens when you click the Evaluate Assignments button?
- A. The application generates a single summary tow, combining all the entitlement bands in the target plan and assignments.
- B. The application generates entitlement rows for each entitlement band in the target plan, but rolls all the assignments into one.
- C. The application generates entitlement rows for each entitlement band in the target plan, but only for the primary assignment.
- D. The application generates entitlement rows for each entitlement band in the target plan for each assignment.
NEW QUESTION # 17
Which three adjustment types can be applied through the Enrollments and Adjustments task within Manage Absence Records task?
- A. Discretionary disbursement
- B. Periodic accruals
- C. Run accruals for all plans
- D. Carryover
- E. Update balance details
- F. Transfer balance
Answer: A,E,F
NEW QUESTION # 18
You configure a Holiday absence type with the "Insufficient Balance Enforcement" rule set to Not Enabled for administrative transactions and you associate it with an absence plan that has "Allow Negative Balance?" set to No.
What is the outcome if an administrator submits a holiday with an absence type duration of 15 days for an employee who has only 10 days of balance left?
- A. The absence errors out with error message "ANC- 3405096: The selected plan does not have sufficient balance to complete the transaction."
- B. The absence errors out with error message "ANC-3405052: The absence plan and absence type must have compatible balance enforcement rules."
- C. The absence submits successfully and 10 days are deducted from the absence plan balance.
- D. The absence errors out with the error message "ANC-3405002: You cannot record this absence because your balance will fall below the configured minimum for this type of absence."
NEW QUESTION # 19
Our 1z0-1047-25 study materials are designed carefully. We have taken all your worries into consideration. Also, we adopt the useful suggestions about our 1z0-1047-25 study materials from our customers. Now, our study materials are out of supply. Thousands of people will crowd into our website to choose the 1z0-1047-25 study materials. So people are different from the past. Learning has become popular among different age groups. Our 1z0-1047-25 Study Materials truly offer you the most useful knowledge. You can totally trust us. We are trying our best to meet your demands. Why not give our Oracle study materials a chance? Our products will live up to your expectations.
Reliable 1z0-1047-25 Braindumps: https://www.prepawaypdf.com/Oracle/1z0-1047-25-practice-exam-dumps.html
The top vendors we are working with today include Cisco, Microsoft, Adobe, IBM, Brocade, Apple, CompTIA, Oracle, Oracle Reliable 1z0-1047-25 Braindumps, EMC, and several more, Oracle Actual 1z0-1047-25 Test Answers Do you still have no time to go on vocation, Oracle Actual 1z0-1047-25 Test Answers We provide real exam dumps discounts for old customers and long-term cooperation companies, Whenever they have discovered any renewal of our 1z0-1047-25 study guide materials, they will send it to you in the first time so that you can get the hang of the renewed points as soon as possible.
You may not think that the lights in your house look yellow, but the camera doesn't lie, The Oracle Absence Management Cloud 2025 Implementation Professional (1z0-1047-25) exam questions are real, valid, and verified by Oracle 1z0-1047-25 Certification Exam trainers.
Free PDF 2026 1z0-1047-25: Oracle Absence Management Cloud 2025 Implementation Professional High Hit-Rate Actual Test AnswersThe top vendors we are working with today include Cisco, Microsoft, 1z0-1047-25 Adobe, IBM, Brocade, Apple, CompTIA, Oracle, Oracle, EMC, and several more, Do you still have no time to go on vocation?
We provide real exam dumps discounts for old customers 1z0-1047-25 Official Practice Test and long-term cooperation companies, Whenever they have discovered any renewal of our 1z0-1047-25 study guide materials, they will send it Reliable 1z0-1047-25 Braindumps to you in the first time so that you can get the hang of the renewed points as soon as possible.
All 1z0-1047-25 study materials you should know are written in them with three versions to choose from: the PDF, Software and APP online versions.
- With [url]www.practicevce.com Oracle 1z0-1047-25 Real Questions Nothing Can Stop You from Getting Success 💝 Enter { www.practicevce.com } and search for 1z0-1047-25 to download for free 🥵Braindumps 1z0-1047-25 Torrent[/url]
- Get 1z0-1047-25 Exam Questions To Achieve A High Score 🤘 Search for 1z0-1047-25 and download it for free immediately on ➤ [url]www.pdfvce.com ⮘ 🚜Reliable 1z0-1047-25 Test Testking[/url]
- Free PDF 2026 Oracle Fantastic Actual 1z0-1047-25 Test Answers 🛴 Go to website ✔ [url]www.verifieddumps.com ️✔️ open and search for ⏩ 1z0-1047-25 ⏪ to download for free 👱1z0-1047-25 Real Testing Environment[/url]
- With Pdfvce Oracle 1z0-1047-25 Real Questions Nothing Can Stop You from Getting Success 🔷 ➤ [url]www.pdfvce.com ⮘ is best website to obtain 1z0-1047-25 for free download 🌑1z0-1047-25 Real Testing Environment[/url]
- 1z0-1047-25 Valid Test Blueprint ⚔ 1z0-1047-25 Valid Test Blueprint ✔ Latest 1z0-1047-25 Exam Practice 📯 Search for 1z0-1047-25 and download exam materials for free through { [url]www.vce4dumps.com } 🥭Braindumps 1z0-1047-25 Torrent[/url]
- 1z0-1047-25 - High Pass-Rate Actual Oracle Absence Management Cloud 2025 Implementation Professional Test Answers 🔆 Immediately open ➥ [url]www.pdfvce.com 🡄 and search for 1z0-1047-25 to obtain a free download ☕1z0-1047-25 Top Dumps[/url]
- Get 1z0-1047-25 Exam Questions To Achieve A High Score 📰 Go to website ▶ [url]www.prepawaypdf.com ◀ open and search for 1z0-1047-25 to download for free 🏪1z0-1047-25 Real Testing Environment[/url]
- 2026 Actual 1z0-1047-25 Test Answers: Unparalleled Oracle Absence Management Cloud 2025 Implementation Professional 100% Pass Quiz 🚤 Download ☀ 1z0-1047-25 ️☀️ for free by simply entering ▷ [url]www.pdfvce.com ◁ website 🖼1z0-1047-25 Reliable Exam Materials[/url]
- Quiz 2026 Oracle Pass-Sure Actual 1z0-1047-25 Test Answers 🥮 Search for 1z0-1047-25 and download exam materials for free through ⏩ [url]www.examcollectionpass.com ⏪ 👞1z0-1047-25 Real Testing Environment[/url]
- Quiz 2026 Oracle Pass-Sure Actual 1z0-1047-25 Test Answers 📠 Search for 1z0-1047-25 and obtain a free download on [url]www.pdfvce.com 🌼1z0-1047-25 Latest Test Experience[/url]
- 1z0-1047-25 Reliable Exam Materials 🆓 Online 1z0-1047-25 Tests 🔺 1z0-1047-25 Reliable Exam Materials 👖 Search for ⏩ 1z0-1047-25 ⏪ on ➤ [url]www.vce4dumps.com ⮘ immediately to obtain a free download 🛳Online 1z0-1047-25 Tests[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.connectantigua.com, Disposable vapes
2026 Latest PrepAwayPDF 1z0-1047-25 PDF Dumps and 1z0-1047-25 Exam Engine Free Share: https://drive.google.com/open?id=1T3n-rSnhnY-vkPf5mgDwxPjQLKv41xlu
