[General] CCAAK Verified Answers | CCAAK Latest Test Answers
100
【General】 CCAAK Verified Answers | CCAAK Latest Test Answers
Posted at 1/25/2026 00:13:39      View:116 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4Test CCAAK PDF Dumps and CCAAK Exam Engine Free Share: https://drive.google.com/open?id=1yF2B10KGMIj0txLkFpkmay3zqBCpKrOR
We have created a number of reports and learning functions for evaluating your proficiency for the Confluent Certified Administrator for Apache Kafka (CCAAK) exam dumps. In preparation, you can optimize Confluent Certified Administrator for Apache Kafka (CCAAK) practice exam time and question type by utilizing our Confluent CCAAK Practice Test software. Pass4Test makes it easy to download Confluent CCAAK exam questions immediately after purchase. You will receive a registration code and download instructions via email.
If you still desperately cram knowledge and spend a lot of precious time and energy to prepare for passing Confluent certification CCAAK exam, and at the same time do not know how to choose a more effective shortcut to pass Confluent Certification CCAAK Exam. Now Pass4Test provide you a effective method to pass Confluent certification CCAAK exam. It will play a multiplier effect to help you pass the exam.
Free PDF Quiz 2026 High Pass-Rate Confluent CCAAK Verified AnswersWith decades years in IT industry, Pass4Test has gain millions of successful customers as for its high quality exam dumps. Now, Confluent CCAAK study practice cram will give you new directions and help you to get your CCAAK certification in the easiest and fastest way. All the questions are selected from the CCAAK Original Questions pool, and then compiled and verified by our IT professionals for several times checkout. We promise you 100% pass rate.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q26-Q31):NEW QUESTION # 26
If the Controller detects the failure of a broker that was the leader for some partitions, which actions will be taken? (Choose two.)
  • A. The Controller sends the new leader and ISR list changes to all brokers.
  • B. The Controller waits for a new leader to be nominated by ZooKeeper.
  • C. The Controller persists the new leader and ISR list to ZooKeeper.
  • D. The Controller sends the new leader and ISR list changes to all producers and consumers.
The Controller updates ZooKeeper with the new leader and in-sync replica (ISR) information to maintain metadata consistency.
Brokers need this information to correctly route client requests and continue replication.
NEW QUESTION # 27
You have a Kafka cluster with topics t1 and t2. In the output below, topic t2 shows Partition 1 with a leader "-1".
What is the most likely reason for this?
$ kafka-topics --zookeeper localhost:2181 --describe --topic t1
Topic:t1 PartitionCount 1 ReplicationFactor 1 Configs:
Topic: t1 Partition: 0 Leader: 0 Replicas: 0 Isr: 0
$ kafka-topics --zookeeper localhost:2181 --describe --topic t2
Topic:t2 PartitionCount 2 ReplicationFactor 1 Configs:
Topic: t2 Partition: 0 Leader: 0 Replicas: 0 Isr: 0
Topic: t2 Partition: 1 Leader: -1 Replicas: 1 Isr:
  • A. Compression has been enabled on Broker 1.
  • B. Broker 1 failed.
  • C. Leader shows "-1" while the log cleaner thread runs on Broker 1.
  • D. Broker 1 has another partition clashing with the same name.
A Leader of -1 indicates that no broker is currently the leader for that partition. This usually happens when the only replica for that partition is unavailable, often due to the associated broker (in this case, Broker 1) failing or being offline. Kafka cannot elect a leader if no replica is in the in-sync replica (ISR) list, which leads to leader = -1.
NEW QUESTION # 28
You are managing a Kafka cluster with five brokers (broker id '0', '1','2','3','4') and three ZooKeepers. There are 100 topics, five partitions for each topic, and replication factor three on the cluster. Broker id '0' is currently the Controller, and this broker suddenly fails.
Which statements are correct? (Choose three.)
  • A. The Controller is responsible for electing Leaders among the partitions and replicas.
  • B. The number of Controllers should always be equal to the number of brokers alive in the cluster.
  • C. The Controller uses the epoch number to prevent a split brain scenario.
  • D. Kafka uses ZooKeeper's ephemeral node feature to elect a controller.
  • E. The Controller is responsible for reassigning partitions to the consumers in a Consumer Group.
  • F. The broker id is used as the epoch number to prevent a split brain scenario.
Answer: A,C,D
Kafka relies on ZooKeeper's ephemeral nodes to detect if a broker (controller) goes down and to elect a new controller.
The controller manages partition leadership assignments and handles leader election when a broker fails.
The epoch number ensures coordination and avoids outdated controllers acting on stale data.
NEW QUESTION # 29
Your organization has a mission-critical Kafka cluster that must be highly available. A Disaster Recovery (DR) cluster has been set up using Replicator, and data is continuously being replicated from source cluster to the DR cluster. However, you notice that the message on offset 1002 on source cluster does not seem to match with offset 1002 on the destination DR cluster.
Which statement is correct?
  • A. The message on DR cluster got over-written accidently by another application.
  • B. The offsets for the messages on the source, destination cluster may not match.
  • C. The DR cluster is lagging behind updates; once the DR cluster catches up, the messages will match.
  • D. The message was updated on source cluster, but the update did not flow into destination DR cluster and errored.
When using Confluent Replicator (or MirrorMaker), offsets are not preserved between the source and destination Kafka clusters. Messages are replicated based on content, but they are assigned new offsets in the DR (destination) cluster. Therefore, offset 1002 on the source and offset 1002 on the DR cluster likely refer to different messages, which is expected behavior.
NEW QUESTION # 30
A Kafka cluster with three brokers has a topic with 10 partitions and a replication factor set to three. Each partition stores 25 GB data per day and data retention is set to 24 hours.
How much storage will be consumed by the topic on each broker?
  • A. 300 GB
  • B. 75 GB
  • C. 250 GB
  • D. 750 GB
10 partitions × 25 GB/day = 250 GB total per day for the topic (primary data).
With a replication factor of 3, there are 3 full copies of the data: 250 GB × 3 = 750 GB total across the entire cluster.
The cluster has 3 brokers, and Kafka tries to distribute replicas evenly among them: 750 GB ÷ 3 brokers = 250 GB per broker on average.
However, due to replication, some partitions have leaders and followers, so there's some overlap and not-perfect distribution. Each broker stores approximately 2/3 of the total topic data (since each broker holds replicas for around 2/3 of the partitions).
2/3 × 750 GB = 500 GB, but this is shared, so each broker ends up storing ~300 GB of replicated data, including its share of leaders and followers.
NEW QUESTION # 31
The clients only need 20-30 hours to learn the CCAAK exam questions and prepare for the test. Many people may complain that we have to prepare for the CCAAK test but on the other side they have to spend most of their time on their most important things such as their jobs, learning and families. But if you buy our CCAAK Study Guide you can both do your most important thing well and pass the test easily because the preparation for the test costs you little time and energy.
CCAAK Latest Test Answers: https://www.pass4test.com/CCAAK.html
Comprehensive questions and answers about Confluent CCAAK exam, Confluent CCAAK Verified Answers A growing number of people know that if they have the chance to pass the exam, they will change their present situation and get a more decent job in the near future, Confluent CCAAK Verified Answers Besides, all products have special offers at times, Confluent CCAAK Verified Answers If you complete your purchase online using an approved credit card or PayPal account, you should receive your receipt, download link(s), and activation key(s) within minutes.
New Venture Board, Which of the following are important factors when purchasing a replacement laptop AC adapter, Comprehensive questions and answers about Confluent CCAAK Exam.
A growing number of people know that if they have the chance CCAAK to pass the exam, they will change their present situation and get a more decent job in the near future.
Pass4Test Confluent CCAAK Web-Based Practice TestBesides, all products have special offers at times, If you complete your purchase Pdf CCAAK Files online using an approved credit card or PayPal account, you should receive your receipt, download link(s), and activation key(s) within minutes.
Confluent Certified Administrator for Apache Kafka exam practice questions play a crucial role in CCAAK Confluent Certified Administrator for Apache Kafka exam preparation and give you insights Confluent Certified Administrator for Apache Kafka exam view.
P.S. Free 2026 Confluent CCAAK dumps are available on Google Drive shared by Pass4Test: https://drive.google.com/open?id=1yF2B10KGMIj0txLkFpkmay3zqBCpKrOR
