[General] 312-50v13 exam practice & 312-50v13 latest dumps & 312-50v13 training to
87
General 312-50v13 exam practice & 312-50v13 latest dumps & 312-50v13 training to
Posted at 1/25/2026 00:35:07      View185 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest Exam4Free 312-50v13 PDF Dumps and 312-50v13 Exam Engine Free Share: https://drive.google.com/open?id=1kNcJ7WHlUVBBKMVnZrfedq3mtPB4I_9w
Provided you get the certificate this time with our 312-50v13 practice materials, you may have striving and excellent friends and promising colleagues just like you. It is also as obvious magnifications of your major ability of profession, so 312-50v13 practice materials may bring underlying influences with positive effects. The promotion or acceptance will be easy. So it is quite rewarding investment.
Those who are ambitious to obtain 312-50v13 certification mainly include office workers; they expect to reach a higher position and get handsome salary, moreover, a prosperous future. All of these requirements our 312-50v13 exam materials can meet. Our 312-50v13 study materials can help you pass the exam successful. Before you decide to buy our 312-50v13 Exam Torrent, you can free download the demo of our 312-50v13 exam questions, which contains a few of questions and answers of our 312-50v13 training guide.
2026 312-50v13 Accurate Prep Material - High Pass-Rate ECCouncil Certified Ethical Hacker Exam (CEHv13) - 312-50v13 Valid Test RegistrationYou many face many choices of attending the certificate exams and there are a variety of certificates for you to get. You want to get the most practical and useful certificate which can reflect your ability in some area. If you choose to attend the test 312-50v13 certification buying our 312-50v13 exam guide can help you pass the test and get the valuable certificate. Our company has invested a lot of personnel, technology and capitals on our products and is always committed to provide the top-ranking 312-50v13 Study Material to the clients and serve for the client wholeheartedly.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q482-Q487):NEW QUESTION # 482
What is the purpose of a DNS AAAA record?
  • A. Address database record
  • B. Address prefix record
  • C. Authorization, Authentication and Auditing record
  • D. IPv6 address resolution record
The AAAA (Quad A) record is the DNS record type used to map a domain name to an IPv6 address. It is the IPv6 equivalent of an A (Address) record, which maps to an IPv4 address.
From CEH v13 Courseware:
Module 4: Enumeration # DNS Record Types
Reference:IETF RFC 3596 - DNS Extensions for IPv6
NEW QUESTION # 483
There have been concerns in your network that the wireless network component is not sufficiently secure.
You perform a vulnerability scan of the wireless network and find that it is using an old encryption protocol that was designed to mimic wired encryption, what encryption protocol is being used?
  • A. RADIUS
  • B. WPA
  • C. WEP
  • D. WPA3
Wired Equivalent Privacy (WEP) may be a security protocol, laid out in the IEEE wireless local area network (Wi-Fi) standard, 802.11b, that's designed to supply a wireless local area network (WLAN) with A level of security and privacy like what's usually expected of a wired LAN. A wired local area network (LAN) is usually protected by physical security mechanisms (controlled access to a building, for example) that are effective for a controlled physical environment, but could also be ineffective for WLANs because radio waves aren't necessarily bound by the walls containing the network. WEP seeks to determine similar protection thereto offered by the wired network's physical security measures by encrypting data transmitted over the WLAN. encoding protects the vulnerable wireless link between clients and access points; once this measure has been taken, other typical LAN security mechanisms like password protection, end-to-end encryption, virtual private networks (VPNs), and authentication are often put in situ to make sure privacy.
A research group from the University of California at Berkeley recently published a report citing "major security flaws" in WEP that left WLANs using the protocol susceptible to attacks (called wireless equivalent privacy attacks). within the course of the group's examination of the technology, they were ready to intercept and modify transmissions and gain access to restricted networks. The Wireless Ethernet Compatibility Alliance (WECA) claims that WEP - which is included in many networking products - was never intended to be the only security mechanism for a WLAN, and that, in conjunction with traditional security practices, it's very effective.
NEW QUESTION # 484
A cyber attacker has initiated a series of activities against a high-profile organization following the Cyber Kill Chain Methodology. The attacker is presently in the "Delivery" stage. As an Ethical Hacker, you are trying to anticipate the adversary's next move. What is the most probable subsequent action from the attacker based on the Cyber Kill Chain Methodology?
  • A. The attacker will exploit the malicious payload delivered to the target organization and establish a foothold.
  • B. The attacker will start reconnaissance to gather as much information as possible about the target.
  • C. The attacker will attempt to escalate privileges to gain complete control of the compromised system.
  • D. The attacker will initiate an active connection to the target system to gather more data.
The most probable subsequent action from the attacker based on the Cyber Kill Chain Methodology is to exploit the malicious payload delivered to the target organization and establish a foothold. This option works as follows:
The Cyber Kill Chain Methodology is a framework that describes the stages of a cyberattack from the perspective of the attacker. It helps defenders to understand the attacker's objectives, tactics, and techniques, and to design effective countermeasures. The Cyber Kill Chain Methodology consists of seven stages:
reconnaissance, weaponization, delivery, exploitation, installation, command and control, and actions on objectives12.
The delivery stage is the third stage in the Cyber Kill Chain Methodology, and it involves sending or transmitting the weaponized payload to the target system. The delivery stage can use various methods, such as email attachments, web links, removable media, or network protocols. The delivery stage aims to reach the target system and bypass any security controls, such as firewalls, antivirus, or email filters12.
The exploitation stage is the fourth stage in the Cyber Kill Chain Methodology, and it involves executing the malicious payload on the target system. The exploitation stage can use various techniques, such as buffer overflows, code injection, or privilege escalation. The exploitation stage aims to exploit a vulnerability or a weakness in the target system and gain access to its resources, such as files, processes, or memory12.
The installation stage is the fifth stage in the Cyber Kill Chain Methodology, and it involves installing a backdoor or a malware on the target system. The installation stage can use various tools, such as rootkits, trojans, or ransomware. The installation stage aims to establish a foothold on the target system and maintain persistence, which means to survive reboots, updates, or scans12.
Therefore, the most probable subsequent action from the attacker based on the Cyber Kill Chain Methodology is to exploit the malicious payload delivered to the target organization and establish a foothold, because:
This action follows the logical sequence of the Cyber Kill Chain Methodology, as it is the next stage after the delivery stage.
This action is consistent with the attacker's goal, as it allows the attacker to gain access and control over the target system and prepare for further actions.
This action is feasible, as the attacker has already delivered the malicious payload to the target system and may have bypassed some security controls.
The other options are not as probable as option B for the following reasons:
A). The attacker will attempt to escalate privileges to gain complete control of the compromised system: This option is possible, but not the most probable, because it is not the next stage in the Cyber Kill Chain Methodology, but rather a technique that can be used in the exploitation stage or the installation stage.
Privilege escalation is a method of increasing the level of access or permissions on a system, such as from a normal user to an administrator. Privilege escalation can help the attacker to gain complete control of the compromised system, but it is not a mandatory step, as the attacker may already have sufficient privileges or may use other techniques to achieve the same goal12.
C). The attacker will initiate an active connection to the target system to gather more data: This option is possible, but not the most probable, because it is not the next stage in the Cyber Kill Chain Methodology, but rather a technique that can be used in the command and control stage or the actions on objectives stage. An active connection is a communication channel that allows the attacker to send commands or receive data from the target system, such as a remote shell or a botnet. An active connection can help the attacker to gather more data from the target system, but it is not a necessary step, as the attacker may already have enough data or may use other techniques to obtain more data12.
D). The attacker will start reconnaissance to gather as much information as possible about the target: This option is not probable, because it is not the next stage in the Cyber Kill Chain Methodology, but rather the first stage. Reconnaissance is the process of collecting information about the target, such as its IP address, domain name, network structure, services, vulnerabilities, or employees. Reconnaissance is usually done before the delivery stage, as it helps the attacker to identify the target and plan the attack. Reconnaissance can be done again after the delivery stage, but it is not the most likely action, as the attacker may already have enough information or may focus on other actions12.
1: The Cyber Kill Chain: The Seven Steps of a Cyberattack - EC-Council
2: Cyber Kill Chain | Lockheed Martin
NEW QUESTION # 485
Password cracking programs reverse the hashing process to recover passwords. (True/False.)
  • A. True
  • B. False
NEW QUESTION # 486
You are tasked to configure the DHCP server to lease the last 100 usable IP addresses in subnet to. 1.4.0/23.
Which of the following IP addresses could be teased as a result of the new configuration?
  • A. 10.1.5.200
  • B. 210.1.55.200
  • C. 10.1.4.254
  • D. 10.1.4.156
https://en.wikipedia.org/wiki/Subnetwork
As we can see, we have an IP address of 10.1.4.0 with a subnet mask of /23. According to the question, we need to determine which IP address will be included in the range of the last 100 IP addresses.
The available addresses for hosts start with 10.1.4.1 and end with 10.1.5.254. Now you can clearly see that the last 100 addresses include the address 10.1.5.200.
NEW QUESTION # 487
To help you get to know the exam questions and knowledge of the 312-50v13 practice exam successfully and smoothly, our experts just pick up the necessary and essential content in to our 312-50v13 test guide with unequivocal content rather than trivia knowledge that exam do not test at all. To make you understand the content more efficient, our experts add charts, diagrams and examples in to 312-50v13 Exam Questions to speed up you pace of gaining success. So these 312-50v13 latest dumps will be a turning point in your life. And on your way to success, they can offer titanic help to make your review more relaxing and effective. Moreover, the passing certificate and all benefits coming along are not surreal dreams anymore.
312-50v13 Valid Test Registration: https://www.exam4free.com/312-50v13-valid-dumps.html
ECCouncil 312-50v13 Accurate Prep Material Reliable Customers Service, After further practice with 312-50v13 original questions, you will acquire the main knowledge which may be tested in the 312-50v13 actual test, I believe it is a wise option to choose 312-50v13 test cram materials as your helpful materials while preparing for your real test, ECCouncil 312-50v13 Accurate Prep Material It's fast and effective.
One day you will understand, It is a simple process to photograph 312-50v13 objects to use to create your own frames and then put them together to illustrate your art, Reliable Customers Service.
After further practice with 312-50v13 Original Questions, you will acquire the main knowledge which may be tested in the 312-50v13 actual test, I believe it is a wise option to choose 312-50v13 test cram materials as your helpful materials while preparing for your real test.
Updated 312-50v13 Accurate Prep Material | 100% Free 312-50v13 Valid Test RegistrationIt's fast and effective, Are you worried about how to pass the 312-50v13 exam test and get the certification?
DOWNLOAD the newest Exam4Free 312-50v13 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1kNcJ7WHlUVBBKMVnZrfedq3mtPB4I_9w
Posted at 1/26/2026 02:24:56        Only Author  2#
ECCouncil312-50v13ԇY˺ϸ񤹤ΤyǤϸǤΤϤʤ^ǤǤʤHĤJɤäޤECCouncil312-50v13ԇYΜʂҪǤҡShikenPASSоECCouncil312-50v13ΏYϤϿѧĤʷǤʤΈRp٤ޤ
Posted at 3/8/2026 12:16:08        Only Author  3#
Im all about this contentdefinitely liking it. Wish me the best of luck for my New 200-901 test voucher exam!
