[Hardware] Esri EAEP2201 Web-Based Practice Exam Questions Software
93
Hardware Esri EAEP2201 Web-Based Practice Exam Questions Software
Posted at 1/25/2026 00:57:14      View299 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest Actual4Dumps EAEP2201 PDF Dumps and EAEP2201 Exam Engine Free Share: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
There are a lot of excellent experts and professors in our company. The high quality of the EAEP2201 reference guide from our company resulted from their constant practice, hard work and their strong team spirit. After a long period of research and development, our EAEP2201 test questions have been the leader study materials in the field. We have taken our customers suggestions of the EAEP2201 Exam Prep seriously, and according to these useful suggestions, we have tried our best to perfect the EAEP2201 reference guide from our company just in order to meet the need of these customers well. So stop hesitation and buy our study materials.
Rather than pretentious help for customers, our after-seals services on our EAEP2201 exam questions are authentic and faithful. Many clients cannot stop praising us in this aspect and become regular customer for good on our EAEP2201 Study Guide. We have strict criterion to help you with the standard of our EAEP2201 training materials. Our company has also being Customer First. So we consider the facts of your interest firstly.
Latest updated Download EAEP2201 Free Dumps C The Best Interactive Practice Exam for EAEP2201 - Newest Valid EAEP2201 Exam Materialsyou may like our EAEP2201 exam materials since they contain so many different versions. You can use it anytime, anywhere. Of course, you don't have to worry about the difference in content. The contents of all versions of EAEP2201 learning engine are the same. You only need to consider which version of the EAEP2201 study questions is more suitable for you, and then buy it. Of course, we don't mind if you buy more than one version, as long as you think it is suitable.
Esri Enterprise Administration Professional 2201 Sample Questions (Q29-Q34):NEW QUESTION # 29
Multiple users report that a map service is experiencing negative performance. Upon review of ArcGIS Monitor data, the GIS analyst finds the following:
* The minimum number of instances is 2 and the maximum is 8 for that service.
* The data is in a publication Enterprise Geodatabase with no system usage in excess of 50%.
* At the p75 level of requests, the map service time is 10 times longer than the service time at the p25 level.
* The number of instances in use at the p50 level is 8.
* The maximum % of physical memory in use is 40%, and the maximum % of virtual memory in use is
44% on the ArcGIS Server.
* The maximum % CPU utilization observed is 53%.
What is causing the issue?
  • A. The client is an Android device, and the ArcGIS Server is a Linux virtual machine.
  • B. The network connection between the database server and ArcGIS Server is saturated.
  • C. The maximum instance setting is too low for the demand on the underperforming map service.
The ArcGIS Monitor data indicates that the map service is reaching its maximum configured instances (8) at the median usage level (p50), suggesting that the service cannot scale to meet higher demand. The significant increase in service time at the p75 level further supports that the service is under-provisioned. Since system resources like CPU and memory are not fully utilized, the bottleneck is likely due to the instance configuration. Increasing the maximum number of instances would allow the service to handle more concurrent requests, improving performance.
There is no evidence of network saturation or client-specific issues affecting performance in this scenario.
Reference Source:ArcGIS Monitor documentation on service instance management and performance tuning
NEW QUESTION # 30
A GIS administrator receives reports of slow-performing services and notices that disk space is filling up after recent troubleshooting sessions.
In those sessions, the following tasks were performed:
* Services added to the shared instance pool
* Log retention settings reduced
* Log level set toDebug
* ArcGIS Server machine restarted
* An additional ArcGIS Server site federated
What is causing this slow performance?
  • A. Adjusting the log level to Debug
  • B. Additional services in the shared instance pool
  • C. Federating the additional ArcGIS Server site
  • D. Restarting ArcGIS Server
Setting thelog level to Debugcan significantly impact performance and disk space. Debug-level logging writes detailed information about every process and service request to log files, which can rapidly fill up disk space and consume server resources, leading toperformance degradation.
From ArcGIS Server documentation:
"The debug log level is used only for troubleshooting specific problems and should not be used in a production environment as it can negatively affect performance and result in excessive disk space usage."
* OptionAis partially valid, but shared instance pooling is designed for efficient resource use and generallyimprovesperformance when used properly.
* OptionCis unrelated to performance directly unless misconfigured.
* OptionD(restart) is typically neutral or helpful.
Reference:ArcGIS Server -Logging Levels and Performance Considerations
NEW QUESTION # 31
A GIS administrator must share an imagery service with another ArcGIS Enterprise. The administrator sets up a distributed collaboration with the other ArcGIS Enterprise and shares the service as a reference. The users in the other organization keep being prompted for credentials.
Which action should the administrator perform?
  • A. Share the image service as a copy
  • B. Set the collaboration workspace to send and receive
  • C. Configure the service with anonymous access
  • D. Save viewer credentials in the collaboration
NEW QUESTION # 32
A GIS analyst is working withreferenced dataand needs to offload alarge dataset of millions of oil rig locationsfrom the geodatabase. The data must bequickly accessible for spatial visualizationandqueryable within ArcGIS Enterprise.
Which ArcGIS Data Store type should be configured?
  • A. External big data file share
  • B. Tile cache
  • C. Spatiotemporal
  • D. Relational
TheSpatiotemporal big data storeis designed formassive datasetsand optimized for high-speed visualization, time-enabled querying, and big data analytics. It is ideal for storingmillions of point features such as sensors or oil rig locations, especially when performance and scalability are critical.
From ArcGIS documentation:
"The spatiotemporal big data store is designed for writing and querying large volumes of spatial and temporal data. It's optimized for visualizing high-density datasets in web maps."
* OptionB(Relational) works for moderate data volumes but may not scale well.
* OptionCsupports cached tiles, not dynamic feature access.
Reference:ArcGIS Enterprise -Choosing the Right Data Store Type for Large Datasets
NEW QUESTION # 33
A client requires an ArcGIS Server site that provides the following capabilities
* Serve several cached image services Each service is published from a single raster and updated once a year with new imagery from which a new cache is generated offline before publishing
* Serve a dynamic feature class of 1.000 points coming from a PostgreSQL enterprise geodatabase Which licensing role does the client need for this ArcGIS Server site?
  • A. Image Server
  • B. GIS Server
  • C. Mission Server
NEW QUESTION # 34
As the content of the EAEP2201 exam is changing from time to time, you may feel anxious that it seems too hard to know the changes. Now, all complicate tasks have been done by our experts. They have rich experience in predicating the EAEP2201 exam. Then you are advised to purchase the study materials on our websites. Also, you can begin to prepare the EAEP2201 Exam. You are advised to finish all exercises of our EAEP2201 preparation questions and pass the exam by the first attempt very easily.
Interactive EAEP2201 Practice Exam: https://www.actual4dumps.com/EAEP2201-study-material.html
Therefore, once you follow our Actual4Dumps EAEP2201 exam preparation material, you will pass the exams easily, Esri Download EAEP2201 Free Dumps A certification is not only an affirmation to your ability but also can help you enter a better company and improve your salary, In order to let you choose to buy our products more peace of mind, you can try to free download part of the exam practice questions and answers about Esri certification EAEP2201 exam online, Esri Download EAEP2201 Free Dumps You can also join instructor-led training where the instructor will help you clear your doubts effectively.
One cool thing you can do with it is change Dumps EAEP2201 PDF the type of dozens, hundreds, or even thousands of files at once, Solaris and OpenSolaris, Therefore, once you follow our Actual4Dumps EAEP2201 Exam Preparation material, you will pass the exams easily.
HOT Download EAEP2201 Free Dumps 100% Pass | High Pass-Rate Interactive Enterprise Administration Professional 2201 Practice Exam Pass for sureA certification is not only an affirmation to your ability EAEP2201 but also can help you enter a better company and improve your salary, In order to let you choose to buyour products more peace of mind, you can try to free download part of the exam practice questions and answers about Esri certification EAEP2201 exam online.
You can also join instructor-led training where the instructor will help you clear your doubts effectively, The contents in our free demo are part of the real materials in our EAEP2201 learning dumps.
P.S. Free 2026 Esri EAEP2201 dumps are available on Google Drive shared by Actual4Dumps: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
Posted at 2/9/2026 03:47:55        Only Author  2#
Thank you for your article, it really captured my attention. Im sharing C_S4CFI_2504 latest real exam answers resources for free. Wishing you all the best!
Posted at 3/5/2026 22:27:47        Only Author  3#
Your article is absolutely wonderful, I really appreciate it! Free Valid Plat-Admn-202 exam bootcamp resources for exam success. Wishing you the best!
